[GRASS-SVN] r45135 - grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify
Fri Jan 21 07:10:38 EST 2011
Author: mmetz
Date: 2011-01-21 04:10:38 -0800 (Fri, 21 Jan 2011)
New Revision: 45135
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/report.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/target.c
sync messages to i.rectify
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c	2011-01-21 11:53:03 UTC (rev 45134)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/exec.c	2011-01-21 12:10:38 UTC (rev 45135)
@@ -18,7 +18,7 @@
     char *name;
     char *mapset;
     char *result;
-    char *type;
+    char *type = "raster";
     int n;
     struct Colors colr;
     struct Categories cats;
@@ -51,6 +51,8 @@
     /* this is used only if target cells have no elevation */
     get_aver_elev(&group.control_points, &aver_z);
+    G_message("-----------------------------------------------");
     /* rectify each file */
     for (n = 0; n < group.group_ref.nfiles; n++) {
 	if (!ref_list[n])
@@ -69,9 +71,6 @@
 	G_debug(2, "RESULT %s", result);
 	G_debug(2, "select_current_env...");
-	G_message(_("Rectified input raster map <%s> will be saved as <%s>"),
-		  name, result);
 	select_current_env();
 	cats_ok = G_read_cats(name, mapset, &cats) >= 0;
@@ -98,7 +97,6 @@
 		G_write_history(result, &hist);
 	    /* Initialze History */
-	    type = "raster";
 	    G_short_history(name, type, &hist);
 	    G_command_history(&hist);
@@ -120,7 +118,5 @@
 	camera_angle(angle_map);
-    G_done_msg(" ");
     return 0;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c	2011-01-21 11:53:03 UTC (rev 45134)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/main.c	2011-01-21 12:10:38 UTC (rev 45135)
@@ -110,7 +110,7 @@
     mem->type = TYPE_DOUBLE;
     mem->key_desc = "memory in MB";
     mem->required = NO;
-    mem->answer = "100";
+    mem->answer = "300";
     mem->description = _("Amount of memory to use in MB");
     ipolname = make_ipol_list();
@@ -370,6 +370,8 @@
     /* go do it */
     exec_rectify(extension, interpol->answer, angle->answer);
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/report.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/report.c	2011-01-21 11:53:03 UTC (rev 45134)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/report.c	2011-01-21 12:10:38 UTC (rev 45135)
@@ -1,14 +1,13 @@
+#include <grass/glocale.h>
 #include "global.h"
-int
-report(long rectify, int ok)
+int report(long rectify, int ok)
     int minutes, hours;
     long seconds;
     long ncells;
-    fprintf(stderr, "%s\n", ok ? _("complete") : _("failed"));
-    fprintf(stderr, "-----------------------------------------------\n");
+    G_message("%s", ok ? _("complete") : _("failed"));
     if (!ok)
 	return 1;
@@ -18,17 +17,17 @@
     hours = minutes / 60;
     minutes -= hours * 60;
     ncells = target_window.rows * target_window.cols;
-    fprintf(stderr, _(" %d rows, %d cols (%ld cells) completed in "),
-	    target_window.rows, target_window.cols, ncells);
+    G_verbose_message(_("%d rows, %d cols (%ld cells) completed in"),
+			target_window.rows, target_window.cols, ncells);
     if (hours)
-	fprintf(stderr, "%d:%02d:%02ld hours\n", hours, minutes, seconds % 60);
+	G_verbose_message(_("%d:%02d:%02ld hours"), hours, minutes, seconds % 60);
     else
-	fprintf(stderr, "%d:%02ld minutes\n", minutes, seconds % 60);
+	G_verbose_message(_("%d:%02ld minutes"), minutes, seconds % 60);
     if (seconds)
-	fprintf(stderr, _(" %.1f cells per minute\n"),
-		(60.0 * ncells) / ((double)seconds));
+	G_verbose_message(_("%.1f cells per minute"),
+			  (60.0 * ncells) / ((double)seconds));
     return 1;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/target.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/target.c	2011-01-21 11:53:03 UTC (rev 45134)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/i.photo.rectify/target.c	2011-01-21 12:10:38 UTC (rev 45135)
@@ -2,21 +2,21 @@
 #include <string.h>
 #include "global.h"
-int get_target(char *name)
+int get_target(char *group)
-    char location[40];
-    char mapset[40];
+    char location[GMAPSET_MAX];
+    char mapset[GMAPSET_MAX];
     char buf[1024];
     int stat;
-    if (!I_get_target(name, location, mapset)) {
-	sprintf(buf, _("Target information for group <%s> missing.\n"), name);
+    if (!I_get_target(group, location, mapset)) {
+	sprintf(buf, _("Target information for group <%s> missing"), group);
 	goto error;
     sprintf(buf, "%s/%s", G_gisdbase(), location);
     if (access(buf, 0) != 0) {
-	sprintf(buf, _("Target location <%s> not found\n"), location);
+	sprintf(buf, _("Target location <%s> not found"), location);
 	goto error;
     select_target_env();
@@ -29,7 +29,7 @@
 	return 1;
     sprintf(buf, _("Mapset <%s> in target location <%s> - "), mapset, location);
-    strcat(buf, stat == 0 ? _("permission denied\n") : _("not found\n"));
+    strcat(buf, stat == 0 ? _("permission denied") : _("not found"));
   error:
     G_fatal_error(buf);
