[GRASS-SVN] r45178 - grass/branches/develbranch_6/lib/vector/Vlib
Tue Jan 25 05:13:48 EST 2011
Author: mmetz
Date: 2011-01-25 02:13:48 -0800 (Tue, 25 Jan 2011)
New Revision: 45178
   grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
merge r38554 from 64
Modified: grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c
--- grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c	2011-01-25 09:53:51 UTC (rev 45177)
+++ grass/branches/develbranch_6/lib/vector/Vlib/buffer2.c	2011-01-25 10:13:48 UTC (rev 45178)
@@ -1070,7 +1070,7 @@
     struct line_pnts **isles;
-    int isles_count = 0;
+    int isles_count = 0, n_isles;
     int i, isle;
@@ -1082,8 +1082,8 @@
     /* initializations */
     tPoints = Vect_new_line_struct();
-    isles_count = Vect_get_area_num_isles(Map, area);
-    isles_allocated = isles_count;
+    n_isles = Vect_get_area_num_isles(Map, area);
+    isles_allocated = n_isles;
     isles = G_malloc(isles_allocated * sizeof(struct line_pnts *));
     /* outer contour */
@@ -1092,7 +1092,7 @@
     Vect_append_point(outer, outer->x[0], outer->y[0], outer->z[0]);
     /* inner contours */
-    for (i = 0; i < isles_count; i++) {
+    for (i = 0; i < n_isles; i++) {
 	isle = Vect_get_area_isle(Map, area, i);
 	Vect_get_isle_points(Map, isle, tPoints);
