[GRASS-SVN] r45187 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Jan 26 05:02:46 EST 2011
Author: martinl
Date: 2011-01-26 02:02:44 -0800 (Wed, 26 Jan 2011)
New Revision: 45187
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
wxGUI: handle error when zooming
(merge r45186 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-01-26 09:57:48 UTC (rev 45186)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-01-26 10:02:44 UTC (rev 45187)
@@ -541,9 +541,45 @@
         """!Abort running process, used by main thread to signal an abort"""
         self._want_abort = True
+def _formatMsg(text):
+    """!Format error messages for dialogs
+    message = ''
+    for line in text.splitlines():
+        if len(line) == 0:
+            continue
+        elif 'GRASS_INFO_MESSAGE' in line:
+            message += line.split(':', 1)[1].strip() + '\n'
+        elif 'GRASS_INFO_WARNING' in line:
+        elif 'GRASS_INFO_ERROR' in line:
+        elif 'GRASS_INFO_END' in line:
+            return message
+        else:
+            message += line.strip() + '\n'
+    return message
 def RunCommand(prog, flags = "", overwrite = False, quiet = False, verbose = False,
                parent = None, read = False, stdin = None, getErrorMsg = False, **kwargs):
-    """!Run GRASS command"""
+    """!Run GRASS command
+    @param prog program to run
+    @param flags flags given as a string
+    @param overwrite, quiet, verbose flags
+    @param parent parent window for error messages
+    @param read fetch stdout
+    @param stdin stdin or None
+    @param getErrorMsg get error messages on failure
+    @param kwargs program parameters
+    @return returncode (read == False and getErrorMsg == False)
+    @return returncode, messages (read == False and getErrorMsg == True)
+    @return stdout (read == True and getErrorMsg == False)
+    @return returncode, stdout, messages (read == True and getErrorMsg == True)
+    @return stdout, stderr
     Debug.msg(1, "gcmd.RunCommand(): %s" % ' '.join(grass.make_command(prog, flags, overwrite,
        quiet, verbose, **kwargs)))
@@ -574,12 +610,12 @@
         if not getErrorMsg:
             return ret
         else:
-            return ret, stderr
+            return ret, _formatMsg(stderr)
     if not getErrorMsg:
         return stdout
     if read and getErrorMsg:
-        return ret, stdout, stderr
+        return ret, stdout, _formatMsg(stderr)
-    return stdout, stderr
+    return stdout, _formatMsg(stderr)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py	2011-01-26 09:57:48 UTC (rev 45186)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmanager.py	2011-01-26 10:02:44 UTC (rev 45187)
@@ -1396,48 +1396,46 @@
                 msg = err = ''
                 ret, out, err = gcmd.RunCommand('v.transform',
-                           flags = '-o',
-                           input=vect,
-                           output=self.outname,
-                           pointsfile=self.file['points'],
-                           getErrorMsg=True, read=True)
+                                                flags = 'o',
+                                                input = vect,
+                                                output = self.outname,
+                                                pointsfile = self.file['points'],
+                                                getErrorMsg = True, read = True)
                 if ret == 0:
                     self.VectGRList.append(self.outname)
-                    print err
                     # note: WriteLog doesn't handle GRASS_INFO_PERCENT well, so using a print here
-#                    self.parent.goutput.WriteLog(text = _(err), switchPage = True)
-                    self.parent.goutput.WriteLog(text = _(out), switchPage = True)
+                    # self.parent.goutput.WriteLog(text = _(err), switchPage = True)
+                    self.parent.goutput.WriteLog(text = out, switchPage = True)
                 else:
                     self.parent.goutput.WriteError(_('Georectification of vector map <%s> failed') %
-                                                           self.outname)
-                    self.parent.goutput.WriteError(_(err))
+                                                   self.outname)
+                    self.parent.goutput.WriteError(err)
                 # FIXME
                 # Copying database information not working.
                 # Does not copy from xy location to current location
                 # TODO: replace $GISDBASE etc with real paths
-#                xyLayer = []
-#                for layer in grass.vector_db(map = vect).itervalues():
-#                    xyLayer.append((layer['driver'],
-#                                    layer['database'],
-#                                    layer['table']))
+                #                xyLayer = []
+                #                for layer in grass.vector_db(map = vect).itervalues():
+                #                    xyLayer.append((layer['driver'],
+                #                                    layer['database'],
+                #                                    layer['table']))
+                    #                dbConnect = grass.db_connection()
+                    #                print 'db connection =', dbConnect
+                    #                for layer in xyLayer:
+                    #                    self.parent.goutput.RunCmd(['db.copy',
+                    #                                                '--q',
+                    #                                                '--o',
+                    #                                                'from_driver=%s' % layer[0],
+                    #                                                'from_database=%s' % layer[1],
+                    #                                                'from_table=%s' % layer[2],
+                    #                                                'to_driver=%s' % dbConnect['driver'],
+                    #                                                'to_database=%s' % dbConnect['database'],
+                    #                                                'to_table=%s' % layer[2] + '_' + self.extension])
-#                dbConnect = grass.db_connection()
-#                print 'db connection =', dbConnect
-#                for layer in xyLayer:
-#                    self.parent.goutput.RunCmd(['db.copy',
-#                                                '--q',
-#                                                '--o',
-#                                                'from_driver=%s' % layer[0],
-#                                                'from_database=%s' % layer[1],
-#                                                'from_table=%s' % layer[2],
-#                                                'to_driver=%s' % dbConnect['driver'],
-#                                                'to_database=%s' % dbConnect['database'],
-#                                                'to_table=%s' % layer[2] + '_' + self.extension])
             # copy all georectified vectors from source location to current location
             for name in self.VectGRList:
                 xyvpath = os.path.join(self.grassdatabase,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2011-01-26 09:57:48 UTC (rev 45186)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2011-01-26 10:02:44 UTC (rev 45187)
@@ -642,14 +642,16 @@
         if vect:
             cmd['vect'] = ','.join(vect)
-        ret = gcmd.RunCommand('g.region',
-                              read = True,
-                              **cmd)
-        if not ret:
+        ret, reg, msg = gcmd.RunCommand('g.region',
+                                        read = True,
+                                        **cmd)
+        if ret != 0:
             if rast:
-                message = _("Unable to zoom to raster map <%s>.") % rast[0]
+                message = _("Unable to zoom to raster map <%s>.\n\nDetails: %s") % (rast[0], msg)
             elif vect:
-                message = _("Unable to zoom to vector map <%s>.") % vect[0]
+                message = _("Unable to zoom to vector map <%s>.\n\nDetails: %s") % (vect[0], msg)
             else:
                 message = _("Unable to get current geographic extent. "
                             "Force quiting wxGUI. Please run manually g.region to "
@@ -657,8 +659,8 @@
             gcmd.GError(message)
             return self.region
-        for reg in ret.splitlines():
-            key, val = reg.split("=", 1)
+        for r in reg.splitlines():
+            key, val = r.split("=", 1)
             try:
                 region[key] = float(val)
             except ValueError:
