[GRASS-SVN] r46906 - grass/trunk/vector/v.support
Fri Jul 1 04:57:18 EDT 2011
Author: mmetz
Date: 2011-07-01 01:57:18 -0700 (Fri, 01 Jul 2011)
New Revision: 46906
   grass/trunk/vector/v.support/main.c
line_3 -> comment
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c	2011-07-01 08:56:30 UTC (rev 46905)
+++ grass/trunk/vector/v.support/main.c	2011-07-01 08:57:18 UTC (rev 46906)
@@ -160,11 +160,11 @@
     if (comment->answer) {	/* apparently only one line comments allowed, so we use space to delimit */
 	char *temp;
-	if (r_flag->answer || strlen(Map.head.line_3) == 0) {	/* check if new/replacing or adding */
+	if (r_flag->answer || strlen(Vect_get_comment(&Map)) == 0) {	/* check if new/replacing or adding */
 	    G_asprintf(&temp, "%s", comment->answer);
 	else {
-	    G_asprintf(&temp, "%s %s", Map.head.line_3, comment->answer);
+	    G_asprintf(&temp, "%s %s", Vect_get_comment(&Map), comment->answer);
 	Vect_set_comment(&Map, temp);
