[GRASS-SVN] r46909 - grass/trunk/include/vect
Fri Jul 1 05:29:59 EDT 2011
Author: neteler
Date: 2011-07-01 02:29:59 -0700 (Fri, 01 Jul 2011)
New Revision: 46909
   grass/trunk/include/vect/dig_structs.h
white space cosmetics
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2011-07-01 08:58:52 UTC (rev 46908)
+++ grass/trunk/include/vect/dig_structs.h	2011-07-01 09:29:59 UTC (rev 46909)
@@ -281,7 +281,7 @@
 struct dig_head
-      \brief Orgranization name
+      \brief Organization name
     char *organization;
@@ -393,7 +393,7 @@
   \brief Non-native format info (OGR)
   \todo Structure size should not change depending on compilation I
-think, do it better
+        think, do it better
 struct Format_info_ogr
@@ -467,7 +467,7 @@
       NULL if no feature is in cache
 #ifdef HAVE_OGR
-    OGRFeatureH feature_cache;
+    OGRFeatureH feature_cache;
 #else
     void *feature_cache;
 #endif
@@ -546,7 +546,7 @@
       \brief Number of unique cats (not updated)
-    int n_ucats;
+    int n_ucats;
       \brief Number of types in type
@@ -566,7 +566,7 @@
       \brief Offset of the beginning of this index in cidx file
-    off_t offset;
+    off_t offset;
@@ -595,7 +595,7 @@
       \brief Version codes for spatial index (major)
-    int spidx_Version_Major;
+    int spidx_Version_Major;
       \brief Version codes for spatial index (minor)
@@ -603,7 +603,7 @@
       \brief Earliest version that can use this data format (major)
-    int spidx_Back_Major;
+    int spidx_Back_Major;
        \brief Earliest version that can use this data format (minor)
@@ -612,7 +612,7 @@
       \brief Version codes for category index (major)
-    int cidx_Version_Major;
+    int cidx_Version_Major;
       \brief Version codes for category index (minor)
@@ -620,7 +620,7 @@
-    int cidx_Back_Major;
+    int cidx_Back_Major;
@@ -654,28 +654,28 @@
       \brief Topo header size
-    long head_size;
+    long head_size;
       \brief Spatial index header size
-    long spidx_head_size;
+    long spidx_head_size;
       \brief Category index header size
-    long cidx_head_size;
+    long cidx_head_size;
       \brief Release memory occupied by support structures
       (topo, spatial, category)
-    int release_support;
+    int release_support;
     /*** portability info */
       \brief Portability information
-    struct Port_info port;
+    struct Port_info port;
       \brief Portability information for spatial index
@@ -683,7 +683,7 @@
       \brief Portability information for category index
-    struct Port_info cidx_port;
+    struct Port_info cidx_port;
       \brief Access mode
@@ -691,7 +691,7 @@
       - GV_MODE_WRITE
       - GV_MODE_RW
-    int mode;
+    int mode;
       \brief Highest level of topology currently available
@@ -703,21 +703,21 @@
       - GV_BUILD_CENTROIDS
       - GV_BUILD_ALL
-    int built;
+    int built;
       \brief Bounding box of features
-    struct bound_box box;
+    struct bound_box box;
     /*** topology ***/
      \brief Array of nodes
-    struct P_node **Node;
+    struct P_node **Node;
      \brief Array of vector geometries
-    struct P_line **Line;
+    struct P_line **Line;
      \brief Array of areas
@@ -730,40 +730,37 @@
     /* add here P_FACE, P_VOLUME, P_HOLE */
-      \brief Current number of vector geometries
       \brief Current number of points
-    plus_t n_plines;
+    plus_t n_plines;
       \brief Current number of lines
-    plus_t n_llines;
+    plus_t n_llines;
       \brief Current number of boundaries
-    plus_t n_blines;
+    plus_t n_blines;
       \brief Current number of centroids
-    plus_t n_clines;
+    plus_t n_clines;
       \brief Current number of faces
-    plus_t n_flines;
+    plus_t n_flines;
       \brief Current number of kernels
-    plus_t n_klines;
+    plus_t n_klines;
       \brief Current number of volume faces
-    plus_t n_vfaces;
+    plus_t n_vfaces;
       \brief Current number of hole faces
-    plus_t n_hfaces;
+    plus_t n_hfaces;
       \brief Current number of topological features derived from vector
@@ -780,34 +777,34 @@
-    plus_t n_lines;
+    plus_t n_lines;
       \brief Current number of areas
-    plus_t n_areas;
+    plus_t n_areas;
       \brief Current number of isles
-    plus_t n_isles;
+    plus_t n_isles;
-    plus_t n_faces;
+    plus_t n_faces;
       \brief Current number of volumes
-    plus_t n_volumes;
+    plus_t n_volumes;
       \brief Current number of holes
-    plus_t n_holes;
+    plus_t n_holes;
      \brief Number of allocated nodes
      i.e. array size - 1
-    plus_t alloc_nodes;
+    plus_t alloc_nodes;
      \brief Number of allocated edges
@@ -819,25 +816,25 @@
      i.e. array size - 1
-    plus_t alloc_lines;
+    plus_t alloc_lines;
      \brief Number of allocated areas
      i.e. array size - 1
-    plus_t alloc_areas;
+    plus_t alloc_areas;
      \brief Number of allocated isles
      i.e. array size - 1
-    plus_t alloc_isles;
+    plus_t alloc_isles;
      \brief Number of allocated faces
      i.e. array size - 1
-    plus_t alloc_faces;
+    plus_t alloc_faces;
      \brief Number of allocated volumes
@@ -849,12 +846,12 @@
      i.e. array size - 1
-    plus_t alloc_holes;
+    plus_t alloc_holes;
       \brief Offset of array of nodes in topo file
-    off_t Node_offset;
+    off_t Node_offset;
       \brief Offset of array of edges in topo file
@@ -886,7 +883,7 @@
       Set to 1 if spatial index is available
-    int Spidx_built;
+    int Spidx_built;
       \brief Build new spatial index
@@ -908,7 +905,7 @@
       \brief Offset of nodes in sidx file
-    off_t Node_spidx_offset;
+    off_t Node_spidx_offset;
       \brief Offset of lines in sidx file
@@ -978,18 +975,18 @@
       \brief Allocated space for category indexes
-    int a_cidx;
+    int a_cidx;
       \brief Array of category indexes
-    struct Cat_index *cidx;
+    struct Cat_index *cidx;
       \brief Category index to be updated
       Set to 1 when cidx is created
       and reset to 0 whenever any line is changed
-    int cidx_up_to_date;
+    int cidx_up_to_date;
       \brief Size of coor file
@@ -998,13 +995,13 @@
       \brief Time of last coor modification
-    long coor_mtime;
+    long coor_mtime;
     /*** level 2 ***/
       \brief Used internaly in diglib to know if list is maintained
-    int do_uplist;
+    int do_uplist;
       \brief Array of updated lines
@@ -1022,7 +1019,7 @@
       \brief Number of updated lines (level 2)
-    int n_uplines;
+    int n_uplines;
       \brief Array of updated nodes (level 2)
@@ -1053,41 +1050,41 @@
       - GV_FORMAT_OGR
       - GV_FORMAT_DIRECT
-    int format;
+    int format;
       \brief Temporary file flag, not yet used
-    int temporary;
+    int temporary;
       \brief DB links
-    struct dblinks *dblnk;
+    struct dblinks *dblnk;
       \brief Topology info
-    struct Plus_head plus;
+    struct Plus_head plus;
     /* graph-related section */
       \brief Graph-related section - line type used to build the graph
-    int graph_line_type;
+    int graph_line_type;
       \brief Graph-related section - graph structure
-    dglGraph_s graph;
+    dglGraph_s graph;
       \brief Graph-related section - shortest path cache
-    dglSPCache_s spCache;
+    dglSPCache_s spCache;
       \brief Graph-related section - forward costs used for graph
       dglGetEdge() is not supported for _DGL_V1)
-    double *edge_fcosts;
+    double *edge_fcosts;
       \brief Graph-related section - backward costs used for graph
@@ -1095,11 +1092,11 @@
       \brief Graph-related section - node costs used for graph
-    double *node_costs;
+    double *node_costs;
       \brief Graph-related section - edge and node costs multiplicator
-    int cost_multip;
+    int cost_multip;
       \brief Open indicator
@@ -1109,7 +1106,7 @@
       anything else implies that structure has
       never been initialized
-    int open;
+    int open;
     /* Open mode
        - read (GV_MODE_READ),
        - write (GV_MODE_WRITE),
@@ -1128,7 +1125,7 @@
       Non-zero code to open only header of vector map
-    int head_only;
+    int head_only;
       \brief Support files were updated
@@ -1138,7 +1135,7 @@
       \brief Sequential read (level 1)
-    plus_t next_line;
+    plus_t next_line;
       \brief Map name (for 4.0)
@@ -1190,7 +1187,7 @@
       \brief GV file pointer (native format only)
-    struct gvfile dig_fp;
+    struct gvfile dig_fp;
       \brief Coor file header info (native format only)
@@ -1214,7 +1211,7 @@
       \todo To be removed?
-    struct site_att *site_att;
+    struct site_att *site_att;
       \brief Number of attributes in site_att array
@@ -1249,7 +1246,7 @@
     double y;
-      \brief Z coordinate (used only for 3D data
+      \brief Z coordinate (used only for 3D data)
     double z;
@@ -1423,7 +1420,7 @@
       \brief 1st generation interior islands
-    plus_t *isles;
+    plus_t *isles;
@@ -1490,19 +1487,19 @@
       \brief Array of layers (fields)
-    int *field;
+    int *field;
       \brief Array of categories
-    int *cat;
+    int *cat;
       \brief Number of categories attached to element
-    int n_cats;
+    int n_cats;
       \brief Allocated space for categories
-    int alloc_cats;
+    int alloc_cats;
 /*! \brief Category list */
@@ -1511,23 +1508,23 @@
       \brief Category layer (field)
-    int field;
+    int field;
       \brief Array of minimum values
-    int *min;
+    int *min;
       \brief Array of maximum values
-    int *max;
+    int *max;
       \brief Number of ranges
-    int n_ranges;
+    int n_ranges;
       \brief Allocated space for ranges
-    int alloc_ranges;
+    int alloc_ranges;
@@ -1540,11 +1537,11 @@
       \brief Array of values
-    int *value;
+    int *value;
       \brief Number of values in the list
-    int n_values;
+    int n_values;
       \brief Allocated space for values
