[GRASS-SVN] r46926 - grass/trunk/visualization/nviz2/cmd
Fri Jul 1 15:26:43 EDT 2011
Author: annakrat
Date: 2011-07-01 12:26:43 -0700 (Fri, 01 Jul 2011)
New Revision: 46926
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/vector.c
nviz_cmd: loading more vectors fixed
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2011-07-01 19:24:27 UTC (rev 46925)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2011-07-01 19:26:43 UTC (rev 46926)
@@ -903,6 +903,13 @@
 	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
 		      params->vlines->key, nvlines, params->vline_height->key,
 		      nconsts);
+    /* position */
+    nconsts = opt_get_num_answers(params->vline_pos);
+    if (nvlines > 0 && nconsts != 3 * nvlines)
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+		      params->vlines->key, nvlines, params->vline_pos->key,
+		      nconsts);
     return;
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2011-07-01 19:24:27 UTC (rev 46925)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2011-07-01 19:26:43 UTC (rev 46926)
@@ -87,9 +87,9 @@
 			      0.0, data);
 	/* set position */
-	x = atof(position->answers[i]);
-	y = atof(position->answers[i+1]);
-	z = atof(position->answers[i+2]);
+	x = atof(position->answers[i*3+0]);
+	y = atof(position->answers[i*3+1]);
+	z = atof(position->answers[i*3+2]);
 	if (map_obj_type == MAP_OBJ_VECT)
 	    GV_set_trans(id, x, y, z);
@@ -208,12 +208,12 @@
 	marker = params->vpoint_marker_column;
     for (i = 0; map->answers[i]; i++) {
-	if (1 > Vect_open_old(&Map, map->answer, ""))
-	    G_fatal_error(_("Unable to open vector map <%s>"), map->answer);
-	Fi = Vect_get_field2(&Map, layer->answer);
+	if (1 > Vect_open_old(&Map, map->answers[i], ""))
+	    G_fatal_error(_("Unable to open vector map <%s>"), map->answers[i]);
+	Fi = Vect_get_field2(&Map, layer->answers[i]);
 	if (!Fi)
 	    G_fatal_error(_("Database connection not defined for layer %s"),
-			  layer->answer);
+			  layer->answers[i]);
 	driver = db_start_driver_open_database(Fi->driver, Fi->database);
 	if (!driver)
