[GRASS-SVN] r46939 - grass/trunk/lib/vector/rtree
Sun Jul 3 13:56:34 EDT 2011
Author: mmetz
Date: 2011-07-03 10:56:34 -0700 (Sun, 03 Jul 2011)
New Revision: 46939
   grass/trunk/lib/vector/rtree/index.c
   grass/trunk/lib/vector/rtree/index.h
   grass/trunk/lib/vector/rtree/indexf.c
   grass/trunk/lib/vector/rtree/indexm.c
   grass/trunk/lib/vector/rtree/io.c
   grass/trunk/lib/vector/rtree/node.c
   grass/trunk/lib/vector/rtree/rect.c
   grass/trunk/lib/vector/rtree/split.c
   grass/trunk/lib/vector/rtree/split.h
change struct names to avoid conflicts
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/index.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -34,7 +34,7 @@
 struct RTree *RTreeNewIndex(int fd, off_t rootpos, int ndims)
     struct RTree *new_rtree;
-    struct Node *n;
+    struct RTree_Node *n;
     int i;
     new_rtree = (struct RTree *)malloc(sizeof(struct RTree));
@@ -44,15 +44,15 @@
     new_rtree->ndims = ndims;
     new_rtree->nsides = 2 * ndims;
-    new_rtree->rectsize = sizeof(struct Rect);
+    new_rtree->rectsize = sizeof(struct RTree_Rect);
     /* init free nodes */
     new_rtree->free_nodes.avail = 0;
     new_rtree->free_nodes.alloc = 0;
     new_rtree->free_nodes.pos = NULL;
-    new_rtree->nodesize = sizeof(struct Node);
-    new_rtree->branchsize = sizeof(struct Branch);
+    new_rtree->nodesize = sizeof(struct RTree_Node);
+    new_rtree->branchsize = sizeof(struct RTree_Branch);
     /* create empty root node */
     n = RTreeNewNode(new_rtree, 0);
@@ -141,7 +141,7 @@
  * overlap the argument rectangle.
  * Return the number of qualifying data rects.
-int RTreeSearch(struct RTree *t, struct Rect *r, SearchHitCallback *shcb,
+int RTreeSearch(struct RTree *t, struct RTree_Rect *r, SearchHitCallback *shcb,
 		void *cbarg)
     assert(r && t);
@@ -155,9 +155,9 @@
  * tid data id stored with rectangle, must be > 0
  * t RTree where rectangle should be inserted
-int RTreeInsertRect(struct Rect *r, int tid, struct RTree *t)
+int RTreeInsertRect(struct RTree_Rect *r, int tid, struct RTree *t)
-    union Child newchild;
+    union RTree_Child newchild;
     assert(r && t && tid > 0);
@@ -179,9 +179,9 @@
  * compile warnings to rtree lib
  * this way it's easier to fix if necessary?
-int RTreeDeleteRect(struct Rect *r, int tid, struct RTree *t)
+int RTreeDeleteRect(struct RTree_Rect *r, int tid, struct RTree *t)
-    union Child child;
+    union RTree_Child child;
@@ -194,12 +194,12 @@
  * Allocate space for a node in the list used in DeleteRect to
  * store Nodes that are too empty.
-struct ListNode *RTreeNewListNode(void)
+struct RTree_ListNode *RTreeNewListNode(void)
-    return (struct ListNode *)malloc(sizeof(struct ListNode));
+    return (struct RTree_ListNode *)malloc(sizeof(struct RTree_ListNode));
-void RTreeFreeListNode(struct ListNode *p)
+void RTreeFreeListNode(struct RTree_ListNode *p)
     free(p);
@@ -208,9 +208,9 @@
  * Add a node to the reinsertion list.  All its branches will later
  * be reinserted into the index structure.
-void RTreeReInsertNode(struct Node *n, struct ListNode **ee)
+void RTreeReInsertNode(struct RTree_Node *n, struct RTree_ListNode **ee)
-    struct ListNode *l = RTreeNewListNode();
+    struct RTree_ListNode *l = RTreeNewListNode();
     l->node = n;
     l->next = *ee;
@@ -220,7 +220,7 @@
  * Free ListBranch
-void RTreeFreeListBranch(struct ListBranch *p)
+void RTreeFreeListBranch(struct RTree_ListBranch *p)
     free(p);
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/index.h	2011-07-03 17:56:34 UTC (rev 46939)
@@ -56,31 +56,31 @@
 #define NODETYPE(l, fd) ((l) == 0 ? 0 : ((fd) < 0 ? 1 : 2))
-struct Rect
+struct RTree_Rect
     RectReal boundary[NUMSIDES];	/* xmin,ymin,...,xmax,ymax,... */
-struct Node;               /* node for spatial index */
+struct RTree_Node;               /* node for spatial index */
-union Child
+union RTree_Child
     int id;              /* child id */
-    struct Node *ptr;    /* pointer to child node */
+    struct RTree_Node *ptr;    /* pointer to child node */
     off_t pos;           /* position of child node in file */
-struct Branch              /* branch for spatial index */
+struct RTree_Branch              /* branch for spatial index */
-    struct Rect rect;
+    struct RTree_Rect rect;
-struct Node             /* node for spatial index */
+struct RTree_Node             /* node for spatial index */
     int count;          /* number of branches */
     int level;		/* 0 is leaf, others positive */
-    struct Branch branch[MAXCARD];
+    struct RTree_Branch branch[MAXCARD];
@@ -90,15 +90,15 @@
  * It can terminate the search early by returning 0 in which case
  * the search will return the number of hits found up to that point.
-typedef int SearchHitCallback(int id, struct Rect rect, void *arg);
+typedef int SearchHitCallback(int id, struct RTree_Rect rect, void *arg);
 struct RTree;
-typedef int rt_search_fn(struct RTree *, struct Rect *,
+typedef int rt_search_fn(struct RTree *, struct RTree_Rect *,
                          SearchHitCallback *, void *);
-typedef int rt_insert_fn(struct Rect *, union Child, int, struct RTree *);
-typedef int rt_delete_fn(struct Rect *, union Child, struct RTree *);
-typedef int rt_valid_child_fn(union Child *);
+typedef int rt_insert_fn(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+typedef int rt_delete_fn(struct RTree_Rect *, union RTree_Child, struct RTree *);
+typedef int rt_valid_child_fn(union RTree_Child *);
 struct RTree
@@ -134,7 +134,7 @@
      * more than three nodes per level would require too complex cache management */
     struct NodeBuffer
-	struct Node n;	    /* buffered node */
+	struct RTree_Node n;	    /* buffered node */
 	off_t pos;	    /* file position of buffered node */
 	char dirty;         /* node in buffer was modified */
     } nb[MAXLEVEL][3];
@@ -150,90 +150,90 @@
     rt_search_fn *search_rect;
     rt_valid_child_fn *valid_child;
-    struct Node *root;     /* pointer to root node */
+    struct RTree_Node *root;     /* pointer to root node */
     off_t rootpos;         /* root node position in file */
-struct ListNode
-    struct ListNode *next;
-    struct Node *node;
+    struct RTree_ListNode *next;
+    struct RTree_Node *node;
-struct ListFNode
+struct RTree_ListFNode
-    struct ListFNode *next;
+    struct RTree_ListFNode *next;
     off_t node_pos;
-struct ListBranch
+struct RTree_ListBranch
-    struct ListBranch *next;
-    struct Branch b;
+    struct RTree_ListBranch *next;
+    struct RTree_Branch b;
     int level;
 /* index.c */
-extern int RTreeSearch(struct RTree *, struct Rect *, SearchHitCallback *,
+extern int RTreeSearch(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
 		       void *);
-extern int RTreeInsertRect(struct Rect *, int, struct RTree *);
-extern int RTreeDeleteRect(struct Rect *, int, struct RTree *);
+extern int RTreeInsertRect(struct RTree_Rect *, int, struct RTree *);
+extern int RTreeDeleteRect(struct RTree_Rect *, int, struct RTree *);
 extern struct RTree *RTreeNewIndex(int, off_t, int);
 extern void RTreeFreeIndex(struct RTree *);
-extern struct ListNode *RTreeNewListNode(void);
-extern void RTreeFreeListNode(struct ListNode *);
-extern void RTreeReInsertNode(struct Node *, struct ListNode **);
-extern void RTreeFreeListBranch(struct ListBranch *);
+extern struct RTree_ListNode *RTreeNewListNode(void);
+extern void RTreeFreeListNode(struct RTree_ListNode *);
+extern void RTreeReInsertNode(struct RTree_Node *, struct RTree_ListNode **);
+extern void RTreeFreeListBranch(struct RTree_ListBranch *);
 /* indexm.c */
-extern int RTreeSearchM(struct RTree *, struct Rect *, SearchHitCallback *,
+extern int RTreeSearchM(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
 		       void *);
-extern int RTreeInsertRectM(struct Rect *, union Child, int, struct RTree *);
-extern int RTreeDeleteRectM(struct Rect *, union Child, struct RTree *);
-extern int RTreeValidChildM(union Child *child);
+extern int RTreeInsertRectM(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+extern int RTreeDeleteRectM(struct RTree_Rect *, union RTree_Child, struct RTree *);
+extern int RTreeValidChildM(union RTree_Child *child);
 /* indexf.c */
-extern int RTreeSearchF(struct RTree *, struct Rect *, SearchHitCallback *,
+extern int RTreeSearchF(struct RTree *, struct RTree_Rect *, SearchHitCallback *,
 		       void *);
-extern int RTreeInsertRectF(struct Rect *, union Child, int, struct RTree *);
-extern int RTreeDeleteRectF(struct Rect *, union Child, struct RTree *);
-extern int RTreeValidChildF(union Child *child);
+extern int RTreeInsertRectF(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
+extern int RTreeDeleteRectF(struct RTree_Rect *, union RTree_Child, struct RTree *);
+extern int RTreeValidChildF(union RTree_Child *child);
 /* node.c */
-extern struct Node *RTreeNewNode(struct RTree *, int);
-extern void RTreeInitNode(struct Node *, int);
-extern void RTreeFreeNode(struct Node *);
-extern void RTreeDestroyNode(struct Node *, int);
-extern struct Rect RTreeNodeCover(struct Node *, struct RTree *);
-extern int RTreeAddBranch(struct Branch *, struct Node *, struct Node **,
-            struct ListBranch **, struct Rect *, int *, struct RTree *);
-extern int RTreePickBranch(struct Rect *, struct Node *, struct RTree *);
-extern void RTreeDisconnectBranch(struct Node *, int, struct RTree *);
-extern void RTreePrintNode(struct Node *, int, struct RTree *);
+extern struct RTree_Node *RTreeNewNode(struct RTree *, int);
+extern void RTreeInitNode(struct RTree_Node *, int);
+extern void RTreeFreeNode(struct RTree_Node *);
+extern void RTreeDestroyNode(struct RTree_Node *, int);
+extern struct RTree_Rect RTreeNodeCover(struct RTree_Node *, struct RTree *);
+extern int RTreeAddBranch(struct RTree_Branch *, struct RTree_Node *, struct RTree_Node **,
+            struct RTree_ListBranch **, struct RTree_Rect *, int *, struct RTree *);
+extern int RTreePickBranch(struct RTree_Rect *, struct RTree_Node *, struct RTree *);
+extern void RTreeDisconnectBranch(struct RTree_Node *, int, struct RTree *);
+extern void RTreePrintNode(struct RTree_Node *, int, struct RTree *);
 extern void RTreeTabIn(int);
 /* rect.c */
-extern void RTreeInitRect(struct Rect *);
-extern struct Rect RTreeNullRect(void);
-extern RectReal RTreeRectArea(struct Rect *, struct RTree *);
-extern RectReal RTreeRectSphericalVolume(struct Rect *, struct RTree *);
-extern RectReal RTreeRectVolume(struct Rect *, struct RTree *);
-extern RectReal RTreeRectMargin(struct Rect *, struct RTree *);
-extern struct Rect RTreeCombineRect(struct Rect *, struct Rect *, struct RTree *);
-extern int RTreeCompareRect(struct Rect *, struct Rect *, struct RTree *);
-extern int RTreeOverlap(struct Rect *, struct Rect *, struct RTree *);
-extern void RTreePrintRect(struct Rect *, int);
+extern void RTreeInitRect(struct RTree_Rect *);
+extern struct RTree_Rect RTreeNullRect(void);
+extern RectReal RTreeRectArea(struct RTree_Rect *, struct RTree *);
+extern RectReal RTreeRectSphericalVolume(struct RTree_Rect *, struct RTree *);
+extern RectReal RTreeRectVolume(struct RTree_Rect *, struct RTree *);
+extern RectReal RTreeRectMargin(struct RTree_Rect *, struct RTree *);
+extern struct RTree_Rect RTreeCombineRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+extern int RTreeCompareRect(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+extern int RTreeOverlap(struct RTree_Rect *, struct RTree_Rect *, struct RTree *);
+extern void RTreePrintRect(struct RTree_Rect *, int);
 /* split.c */
-extern void RTreeSplitNode(struct Node *, struct Branch *, struct Node *, struct RTree *);
+extern void RTreeSplitNode(struct RTree_Node *, struct RTree_Branch *, struct RTree_Node *, struct RTree *);
 /* card.c */
 extern int RTreeSetNodeMax(int, struct RTree *);
 extern int RTreeSetLeafMax(int, struct RTree *);
 extern int RTreeGetNodeMax(struct RTree *);
 extern int RTreeGetLeafMax(struct RTree *);
 /* fileio.c */
-extern void RTreeGetNode(struct Node *, off_t, int, struct RTree *);
-extern size_t RTreeReadNode(struct Node *, off_t, struct RTree *);
-extern void RTreePutNode(struct Node *, off_t, struct RTree *);
-extern size_t RTreeWriteNode(struct Node *, struct RTree *);
-extern size_t RTreeRewriteNode(struct Node *, off_t, struct RTree *);
-extern void RTreeUpdateRect(struct Rect *, struct Node *, off_t, int, struct RTree *);
+extern void RTreeGetNode(struct RTree_Node *, off_t, int, struct RTree *);
+extern size_t RTreeReadNode(struct RTree_Node *, off_t, struct RTree *);
+extern void RTreePutNode(struct RTree_Node *, off_t, struct RTree *);
+extern size_t RTreeWriteNode(struct RTree_Node *, struct RTree *);
+extern size_t RTreeRewriteNode(struct RTree_Node *, off_t, struct RTree *);
+extern void RTreeUpdateRect(struct RTree_Rect *, struct RTree_Node *, off_t, int, struct RTree *);
 extern void RTreeAddNodePos(off_t, int, struct RTree *);
 extern off_t RTreeGetNodePos(struct RTree *);
 extern void RTreeFlushBuffer(struct RTree *);
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/indexf.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -29,12 +29,12 @@
 /* stack used for non-recursive insertion/deletion */
 struct fstack
-    struct Node sn;	/* stack node */
+    struct RTree_Node sn;	/* stack node */
     int branch_id;	/* branch no to follow down */
     off_t pos;		/* file position of stack node */
-int RTreeValidChildF(union Child *child)
+int RTreeValidChildF(union RTree_Child *child)
     return (child->pos > -1);
@@ -44,10 +44,10 @@
-int RTreeSearchF(struct RTree *t, struct Rect *r,
+int RTreeSearchF(struct RTree *t, struct RTree_Rect *r,
 		 SearchHitCallback *shcb, void *cbarg)
-    struct Node *n;
     int hitCount = 0, found, currlevel;
     int i;
     struct fstack s[MAXLEVEL];
@@ -115,15 +115,15 @@
  * The level argument specifies the number of steps up from the leaf
  * level to insert; e.g. a data rectangle goes in at level = 0.
-static int RTreeInsertRect2F(struct Rect *r, union Child child, int level,
-			     struct Node *newnode, off_t *newnode_pos,
+static int RTreeInsertRect2F(struct RTree_Rect *r, union RTree_Child child, int level,
+			     struct RTree_Node *newnode, off_t *newnode_pos,
 			     struct RTree *t,
-			     struct ListBranch **ee, int *overflow)
+			     struct RTree_ListBranch **ee, int *overflow)
     int i, currlevel;
-    struct Branch b;
-    struct Rect nr, *cover;
-    struct Node *n, *n2, nn;
+    struct RTree_Rect nr, *cover;
+    struct RTree_Node *n, *n2, nn;
     int top = 0, down = 0;
     int result;
@@ -230,12 +230,12 @@
  * RTreeInsertRect2 does the actual insertion.
-int RTreeInsertRectF(struct Rect *r, union Child child, int level,
+int RTreeInsertRectF(struct RTree_Rect *r, union RTree_Child child, int level,
                      struct RTree *t)
-    struct Node oldroot, newroot, newnode;
-    struct Branch b;
-    struct ListBranch *e, *reInsertList = NULL;
+    struct RTree_Node oldroot, newroot, newnode;
+    struct RTree_ListBranch *e, *reInsertList = NULL;
     int result;
     int i, overflow[MAXLEVEL];
     off_t newnode_pos = -1;
@@ -312,12 +312,12 @@
  * Returns 1 if record not found, 0 if success.
 static int
-RTreeDeleteRect2F(struct Rect *r, union Child child, struct RTree *t,
-		 struct ListNode **ee)
+RTreeDeleteRect2F(struct RTree_Rect *r, union RTree_Child child, struct RTree *t,
+		 struct RTree_ListNode **ee)
     int i, notfound = 1, currlevel;
-    struct Node *n;
-    struct Rect nr;
+    struct RTree_Rect nr;
     int minfill;
@@ -414,11 +414,11 @@
  * RTreeDeleteRect1 provides for eliminating the root.
-int RTreeDeleteRectF(struct Rect *r, union Child child, struct RTree *t)
+int RTreeDeleteRectF(struct RTree_Rect *r, union RTree_Child child, struct RTree *t)
     int i;
-    struct Node *n, rn;
-    struct ListNode *e, *reInsertList = NULL;
+    struct RTree_Node *n, rn;
+    struct RTree_ListNode *e, *reInsertList = NULL;
     if (!RTreeDeleteRect2F(r, child, t, &reInsertList)) {
 	/* found and deleted a data item */
Modified: grass/trunk/lib/vector/rtree/indexm.c
--- grass/trunk/lib/vector/rtree/indexm.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/indexm.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -25,11 +25,11 @@
 struct stack
-    struct Node *sn;	/* stack node */
+    struct RTree_Node *sn;	/* stack node */
-int RTreeValidChildM(union Child *child)
+int RTreeValidChildM(union RTree_Child *child)
     return (child->ptr != NULL);
@@ -39,10 +39,10 @@
-int RTreeSearchM(struct RTree *t, struct Rect *r,
+int RTreeSearchM(struct RTree *t, struct RTree_Rect *r,
-    struct Node *n;
     int hitCount = 0, found;
     int i;
     struct stack s[MAXLEVEL];
@@ -107,15 +107,15 @@
-static int RTreeInsertRect2M(struct Rect *r, union Child child, int level,
-			     struct Node **newnode,
+static int RTreeInsertRect2M(struct RTree_Rect *r, union RTree_Child child, int level,
+			     struct RTree_Node **newnode,
 			     struct RTree *t,
     int i;
-    struct Branch b;
-    struct Node *n, *n2;
-    struct Rect *cover;
+    struct RTree_Node *n, *n2;
+    struct RTree_Rect *cover;
     int result;
@@ -201,14 +201,13 @@
-int RTreeInsertRectM(struct Rect *r, union Child child, int level,
+int RTreeInsertRectM(struct RTree_Rect *r, union RTree_Child child, int level,
 		     struct RTree *t)
-    struct Node *newnode;
-    struct Node *newroot;
-    struct Branch b;
-    struct ListBranch *reInsertList = NULL;
-    struct ListBranch *e;
+    struct RTree_Node *newnode, *newroot;
+    struct RTree_ListBranch *reInsertList = NULL;
+    struct RTree_ListBranch *e;
     int result;
@@ -280,11 +279,11 @@
 static int
-RTreeDeleteRect2M(struct Rect *r, union Child child, struct RTree *t,
+RTreeDeleteRect2M(struct RTree_Rect *r, union RTree_Child child, struct RTree *t,
     int i, notfound = 1;
-    struct Node *n;
     int minfill;
@@ -369,12 +368,12 @@
-int RTreeDeleteRectM(struct Rect *r, union Child child, struct RTree *t)
+int RTreeDeleteRectM(struct RTree_Rect *r, union RTree_Child child, struct RTree *t)
     int i;
-    struct Node *n;
-    struct ListNode *reInsertList = NULL;
-    struct ListNode *e;
+    struct RTree_ListNode *reInsertList = NULL;
+    struct RTree_ListNode *e;
     if (!RTreeDeleteRect2M(r, child, t, &reInsertList)) {
Modified: grass/trunk/lib/vector/rtree/io.c
--- grass/trunk/lib/vector/rtree/io.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/io.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -68,14 +68,14 @@
 /* read node from file */
-size_t RTreeReadNode(struct Node *n, off_t nodepos, struct RTree *t)
+size_t RTreeReadNode(struct RTree_Node *n, off_t nodepos, struct RTree *t)
     lseek(t->fd, nodepos, SEEK_SET);
     return read(t->fd, n, t->nodesize);
 /* get node from buffer or file */
-void RTreeGetNode(struct Node *n, off_t nodepos, int level, struct RTree *t)
+void RTreeGetNode(struct RTree_Node *n, off_t nodepos, int level, struct RTree *t)
     int which = (nodepos == t->nb[level][2].pos ? 2 : nodepos == t->nb[level][1].pos);
@@ -104,21 +104,21 @@
 /* write new node to file */
-size_t RTreeWriteNode(struct Node *n, struct RTree *t)
+size_t RTreeWriteNode(struct RTree_Node *n, struct RTree *t)
     /* file position must be set first with RTreeGetFNodePos() */
     return write(t->fd, n, t->nodesize);
 /* rewrite updated node to file */
-size_t RTreeRewriteNode(struct Node *n, off_t nodepos, struct RTree *t)
+size_t RTreeRewriteNode(struct RTree_Node *n, off_t nodepos, struct RTree *t)
 /* update node in buffer */
-void RTreePutNode(struct Node *n, off_t nodepos, struct RTree *t)
+void RTreePutNode(struct RTree_Node *n, off_t nodepos, struct RTree *t)
     int which = (nodepos == t->nb[n->level][2].pos ? 2 : nodepos == t->nb[n->level][1].pos);
@@ -138,7 +138,7 @@
 /* update rectangle */
-void RTreeUpdateRect(struct Rect *r, struct Node *n, off_t nodepos, int b, struct RTree *t)
+void RTreeUpdateRect(struct RTree_Rect *r, struct RTree_Node *n, off_t nodepos, int b, struct RTree *t)
Modified: grass/trunk/lib/vector/rtree/node.c
--- grass/trunk/lib/vector/rtree/node.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/node.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -31,21 +31,21 @@
 /* Initialize one branch cell in an internal node. */
-static void RTreeInitNodeBranchM(struct Branch *b)
+static void RTreeInitNodeBranchM(struct RTree_Branch *b)
     RTreeInitRect(&(b->rect));
     b->child.ptr = NULL;
-static void RTreeInitNodeBranchF(struct Branch *b)
+static void RTreeInitNodeBranchF(struct RTree_Branch *b)
     b->child.pos = -1;
 /* Initialize one branch cell in a leaf node. */
-static void RTreeInitLeafBranch(struct Branch *b)
+static void RTreeInitLeafBranch(struct RTree_Branch *b)
     b->child.id = 0;
@@ -57,7 +57,7 @@
 /* Initialize a Node structure. */
 /* type = 1: leaf, type = 2: internal, memory, type = 3: internal, file */
-void RTreeInitNode(struct Node *n, int type)
+void RTreeInitNode(struct RTree_Node *n, int type)
     int i;
@@ -69,17 +69,17 @@
 /* Make a new node and initialize to have all branch cells empty. */
-struct Node *RTreeNewNode(struct RTree *t, int level)
+struct RTree_Node *RTreeNewNode(struct RTree *t, int level)
-    struct Node *n;
-    n = (struct Node *)malloc((size_t) t->nodesize);
+    n = (struct RTree_Node *)malloc((size_t) t->nodesize);
     assert(n);
     RTreeInitNode(n, NODETYPE(level, t->fd));
     return n;
-void RTreeFreeNode(struct Node *n)
+void RTreeFreeNode(struct RTree_Node *n)
     assert(n);
     free(n);
@@ -89,10 +89,10 @@
  * Find the smallest rectangle that includes all rectangles in
  * branches of a node.
-struct Rect RTreeNodeCover(struct Node *n, struct RTree *t)
+struct RTree_Rect RTreeNodeCover(struct RTree_Node *n, struct RTree *t)
     int i, first_time = 1;
-    struct Rect r;
+    struct RTree_Rect r;
     RTreeInitRect(&r);
     if ((n)->level > 0) { /* internal node */
@@ -134,13 +134,13 @@
  * to get the best resolution when searching.
-static int RTreePickLeafBranch(struct Rect *r, struct Node *n, struct RTree *t)
+static int RTreePickLeafBranch(struct RTree_Rect *r, struct RTree_Node *n, struct RTree *t)
-    struct Rect *rr;
+    struct RTree_Rect *rr;
     int i, j;
     RectReal increase, bestIncr = -1, area, bestArea = 0;
     int best = 0, bestoverlap;
-    struct Rect tmp_rect;
+    struct RTree_Rect tmp_rect;
     int overlap;
     bestoverlap = t->nodecard + 1;
@@ -193,13 +193,13 @@
  * In case of a tie, pick the one which was smaller before, to get
  * the best resolution when searching.
-int RTreePickBranch(struct Rect *r, struct Node *n, struct RTree *t)
+int RTreePickBranch(struct RTree_Rect *r, struct RTree_Node *n, struct RTree *t)
-    struct Rect *rr;
     RectReal increase, bestIncr = (RectReal) -1, area, bestArea = 0;
     int best = 0;
     assert((n)->level > 0);	/* must not be called on leaf node */
@@ -228,7 +228,7 @@
 /* Disconnect a dependent node. */
-void RTreeDisconnectBranch(struct Node *n, int i, struct RTree *t)
+void RTreeDisconnectBranch(struct RTree_Node *n, int i, struct RTree *t)
 	assert(n && i >= 0 && i < t->nodecard);
@@ -249,7 +249,7 @@
 /* Destroy (free) node recursively. */
 /* NOTE: only needed for memory based index */
-void RTreeDestroyNode(struct Node *n, int nodes)
+void RTreeDestroyNode(struct RTree_Node *n, int nodes)
     int i;
@@ -398,19 +398,19 @@
  * Allocate space for a branch in the list used in InsertRect to
  * store branches of nodes that are too full.
-static struct ListBranch *RTreeNewListBranch(void)
+static struct RTree_ListBranch *RTreeNewListBranch(void)
-    return (struct ListBranch *)malloc(sizeof(struct ListBranch));
+    return (struct RTree_ListBranch *)malloc(sizeof(struct RTree_ListBranch));
  * Add a branch to the reinsertion list.  It will later
-static void RTreeReInsertBranch(struct Branch b, int level,
-				struct ListBranch **ee)
+static void RTreeReInsertBranch(struct RTree_Branch b, int level,
+				struct RTree_ListBranch **ee)
-    register struct ListBranch *l;
+    register struct RTree_ListBranch *l;
     l = RTreeNewListBranch();
     l->b = b;
@@ -424,15 +424,15 @@
  * center is farthest away from node cover center.
  * Old node updated.
-static void RTreeRemoveBranches(struct Node *n, struct Branch *b,
-				struct ListBranch **ee, struct Rect *cover,
+static void RTreeRemoveBranches(struct RTree_Node *n, struct RTree_Branch *b,
+				struct RTree_ListBranch **ee, struct RTree_Rect *cover,
 				struct RTree *t)
     int i, j, maxkids, type;
     RectReal center_n[NUMDIMS], center_r, delta;
-    struct Branch branchbuf[MAXCARD + 1];
+    struct RTree_Branch branchbuf[MAXCARD + 1];
     struct dist rdist[MAXCARD + 1];
-    struct Rect new_cover;
+    struct RTree_Rect new_cover;
     assert(cover);
@@ -497,9 +497,9 @@
  * Old node updated, becomes one of two.
  * Returns 2 if branches were removed for forced reinsertion
-int RTreeAddBranch(struct Branch *b, struct Node *n,
-		   struct Node **newnode, struct ListBranch **ee,
-		   struct Rect *cover, int *overflow, struct RTree *t)
+int RTreeAddBranch(struct RTree_Branch *b, struct RTree_Node *n,
+		   struct RTree_Node **newnode, struct RTree_ListBranch **ee,
+		   struct RTree_Rect *cover, int *overflow, struct RTree *t)
     int i, maxkids;
@@ -561,14 +561,14 @@
 	putchar('\t');
-static void RTreePrintBranch(struct Branch *b, int depth, struct RTree *t)
+static void RTreePrintBranch(struct RTree_Branch *b, int depth, struct RTree *t)
     RTreePrintRect(&(b->rect), depth);
     RTreePrintNode(b->child.ptr, depth, t);
 /* Print out the data in a node. */
-void RTreePrintNode(struct Node *n, int depth, struct RTree *t)
+void RTreePrintNode(struct RTree_Node *n, int depth, struct RTree *t)
     int i, maxkids;
Modified: grass/trunk/lib/vector/rtree/rect.c
--- grass/trunk/lib/vector/rtree/rect.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/rect.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -35,9 +35,9 @@
 | Initialize a rectangle to have all 0 coordinates.
-void RTreeInitRect(struct Rect *R)
+void RTreeInitRect(struct RTree_Rect *R)
-    register struct Rect *r = R;
+    register struct RTree_Rect *r = R;
     register int i;
     for (i = 0; i < NUMSIDES; i++)
@@ -49,9 +49,9 @@
 | Return a rect whose first low side is higher than its opposite side -
 | interpreted as an undefined rect.
-struct Rect RTreeNullRect(void)
+struct RTree_Rect RTreeNullRect(void)
-    struct Rect r;
     register int i;
     r.boundary[0] = (RectReal) 1;
@@ -68,9 +68,9 @@
 | Fills in random coordinates in a rectangle.
 | The low side is guaranteed to be less than the high side.
-void RTreeRandomRect(struct Rect *R)
+void RTreeRandomRect(struct RTree_Rect *R)
     register int i;
     register RectReal width;
@@ -95,9 +95,9 @@
 | and has size from 0 to the size of the data area in each dimension,
 | i.e. search rect can stick out beyond data area.
-void RTreeSearchRect(struct Rect *Search, struct Rect *Data)
+void RTreeSearchRect(struct RTree_Rect *Search, struct RTree_Rect *Data)
-    register struct Rect *search = Search, *data = Data;
+    register struct RTree_Rect *search = Search, *data = Data;
     register int i, j;
     register RectReal size, center;
@@ -127,9 +127,9 @@
 | Print out the data for a rectangle.
-void RTreePrintRect(struct Rect *R, int depth)
+void RTreePrintRect(struct RTree_Rect *R, int depth)
     register int i;
     assert(r);
@@ -145,9 +145,9 @@
 | Calculate the n-dimensional volume of a rectangle
-RectReal RTreeRectVolume(struct Rect *R, struct RTree *t)
+RectReal RTreeRectVolume(struct RTree_Rect *R, struct RTree *t)
     register int i;
     register RectReal volume = (RectReal) 1;
@@ -229,9 +229,9 @@
  * A fast approximation to the volume of the bounding sphere for the
  * given Rect. By Paul B.
-RectReal RTreeRectSphericalVolume(struct Rect *R, struct RTree *t)
+RectReal RTreeRectSphericalVolume(struct RTree_Rect *R, struct RTree *t)
     register int i;
     RectReal maxsize = (RectReal) 0, c_size;
@@ -251,7 +251,7 @@
  * The exact volume of the bounding sphere for the given Rect.
-RectReal RTreeRectSphericalVolume(struct Rect *r, struct RTree *t)
+RectReal RTreeRectSphericalVolume(struct RTree_Rect *r, struct RTree *t)
     int i;
     double sum_of_squares = 0, radius, half_extent;
@@ -272,7 +272,7 @@
 | Calculate the n-dimensional surface area of a rectangle
-RectReal RTreeRectSurfaceArea(struct Rect *r, struct RTree *t)
+RectReal RTreeRectSurfaceArea(struct RTree_Rect *r, struct RTree *t)
     int i, j;
     RectReal j_extent, sum = (RectReal) 0;
@@ -301,7 +301,7 @@
 | Calculate the n-dimensional margin of a rectangle
 | the margin is the sum of the lengths of the edges
-RectReal RTreeRectMargin(struct Rect *r, struct RTree *t)
+RectReal RTreeRectMargin(struct RTree_Rect *r, struct RTree *t)
     int i;
     RectReal margin = 0.0;
@@ -319,10 +319,10 @@
 | Combine two rectangles, make one that includes both.
-struct Rect RTreeCombineRect(struct Rect *r, struct Rect *rr, struct RTree *t)
+struct RTree_Rect RTreeCombineRect(struct RTree_Rect *r, struct RTree_Rect *rr, struct RTree *t)
     int i, j;
-    struct Rect new_rect;
+    struct RTree_Rect new_rect;
     assert(r && rr);
@@ -352,7 +352,7 @@
 | Decide whether two rectangles are identical.
-int RTreeCompareRect(struct Rect *r, struct Rect *s, struct RTree *t)
+int RTreeCompareRect(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
     register int i, j;
@@ -372,7 +372,7 @@
 | Decide whether two rectangles overlap.
-int RTreeOverlap(struct Rect *r, struct Rect *s, struct RTree *t)
+int RTreeOverlap(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
     register int i, j;
@@ -392,7 +392,7 @@
 | Decide whether rectangle r is contained in rectangle s.
-int RTreeContained(struct Rect *r, struct Rect *s, struct RTree *t)
+int RTreeContained(struct RTree_Rect *r, struct RTree_Rect *s, struct RTree *t)
     register int i, j, result;
Modified: grass/trunk/lib/vector/rtree/split.c
--- grass/trunk/lib/vector/rtree/split.c	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/split.c	2011-07-03 17:56:34 UTC (rev 46939)
@@ -28,18 +28,18 @@
 #define DBL_MAX 1.797693E308  /* DBL_MAX approximation */
 #endif
-struct Branch BranchBuf[MAXCARD + 1];
+struct RTree_Branch BranchBuf[MAXCARD + 1];
 int BranchCount;
-struct Rect CoverSplit;
+struct RTree_Rect CoverSplit;
 RectReal CoverSplitArea;
 /* variables for finding a partition */
-struct PartitionVars Partitions[1];
+struct RTree_PartitionVars Partitions[1];
 | Load branch buffer with branches from full node plus the extra branch.
-static void RTreeGetBranches(struct Node *n, struct Branch *b,
+static void RTreeGetBranches(struct RTree_Node *n, struct RTree_Branch *b,
 			     struct RTree *t)
     int i, maxkids = 0;
@@ -79,7 +79,7 @@
 | Put a branch in one of the groups.
-static void RTreeClassify(int i, int group, struct PartitionVars *p,
+static void RTreeClassify(int i, int group, struct RTree_PartitionVars *p,
 			  struct RTree *t)
     assert(!p->taken[i]);
@@ -109,7 +109,7 @@
 | Pick the two that waste the most area if covered by a single
 | rectangle.
-static void RTreePickSeeds(struct PartitionVars *p, struct RTree *t)
+static void RTreePickSeeds(struct RTree_PartitionVars *p, struct RTree *t)
     int i, j, seed0 = 0, seed1 = 0;
     RectReal worst, waste, area[MAXCARD + 1];
@@ -120,7 +120,7 @@
     worst = -CoverSplitArea - 1;
     for (i = 0; i < p->total - 1; i++) {
 	for (j = i + 1; j < p->total; j++) {
-	    struct Rect one_rect;
+	    struct RTree_Rect one_rect;
 	    one_rect = RTreeCombineRect(&BranchBuf[i].rect,
 					&BranchBuf[j].rect, t);
@@ -141,8 +141,8 @@
 | Copy branches from the buffer into two nodes according to the
 | partition.
-static void RTreeLoadNodes(struct Node *n, struct Node *q,
-			   struct PartitionVars *p, struct RTree *t)
+static void RTreeLoadNodes(struct RTree_Node *n, struct RTree_Node *q,
+			   struct RTree_PartitionVars *p, struct RTree *t)
     int i;
@@ -158,7 +158,7 @@
 | Initialize a PartitionVars structure.
-void RTreeInitPVars(struct PartitionVars *p, int maxrects, int minfill)
+void RTreeInitPVars(struct RTree_PartitionVars *p, int maxrects, int minfill)
     int i;
@@ -177,7 +177,7 @@
 | Print out data for a partition from PartitionVars struct.
 | Unused, for debugging only
-static void RTreePrintPVars(struct PartitionVars *p)
+static void RTreePrintPVars(struct RTree_PartitionVars *p)
     int i;
@@ -226,7 +226,7 @@
 | group to violate min fill requirement) then other group gets the rest.
 | These last are the ones that can go in either group most easily.
-static void RTreeMethodZero(struct PartitionVars *p, int minfill,
+static void RTreeMethodZero(struct RTree_PartitionVars *p, int minfill,
 			    struct RTree *t)
     int i;
@@ -242,7 +242,7 @@
 	biggestDiff = (RectReal) - 1.;
 	for (i = 0; i < p->total; i++) {
 	    if (!p->taken[i]) {
-		struct Rect *r, rect_0, rect_1;
+		struct RTree_Rect *r, rect_0, rect_1;
 		RectReal growth0, growth1, diff;
 		r = &BranchBuf[i].rect;
@@ -298,9 +298,9 @@
 | swap branches
-static void RTreeSwapBranches(struct Branch *a, struct Branch *b)
+static void RTreeSwapBranches(struct RTree_Branch *a, struct RTree_Branch *b)
-    struct Branch c;
+    struct RTree_Branch c;
     c = *a;
     *a = *b;
@@ -313,7 +313,7 @@
 | return 0 if a == b
 | return -1 if a < b
-static int RTreeCompareBranches(struct Branch *a, struct Branch *b, int side)
+static int RTreeCompareBranches(struct RTree_Branch *a, struct RTree_Branch *b, int side)
     if (a->rect.boundary[side] > b->rect.boundary[side])
 	return 1;
@@ -450,14 +450,14 @@
-static void RTreeMethodOne(struct PartitionVars *p, int minfill,
+static void RTreeMethodOne(struct RTree_PartitionVars *p, int minfill,
                            int maxkids, struct RTree *t)
     int i, j, k, l, s;
     int axis = 0, best_axis = 0, side = 0, best_side[NUMDIMS];
     int best_cut[NUMDIMS];
     RectReal margin, smallest_margin = 0;
-    struct Rect *r1, *r2, testrect1, testrect2, upperrect, orect;
+    struct RTree_Rect *r1, *r2, testrect1, testrect2, upperrect, orect;
     int minfill1 = minfill - 1;
     RectReal overlap, vol, smallest_overlap = -1, smallest_vol = -1;
@@ -591,10 +591,10 @@
 | Old node is one of the new ones, and one really new one is created.
 | May use quadratic split or R*-tree split.
-void RTreeSplitNode(struct Node *n, struct Branch *b, struct Node *nn,
-		    struct RTree *t)
+void RTreeSplitNode(struct RTree_Node *n, struct RTree_Branch *b,
+                    struct RTree_Node *nn, struct RTree *t)
-    struct PartitionVars *p;
+    struct RTree_PartitionVars *p;
     int level;
     /* load all the branches into a buffer, initialize old node */
Modified: grass/trunk/lib/vector/rtree/split.h
--- grass/trunk/lib/vector/rtree/split.h	2011-07-03 17:00:20 UTC (rev 46938)
+++ grass/trunk/lib/vector/rtree/split.h	2011-07-03 17:56:34 UTC (rev 46939)
@@ -24,21 +24,21 @@
 /* METHOD 1: R*-Tree split */
 #define METHOD 1
-struct PartitionVars {
+struct RTree_PartitionVars {
     int partition[MAXCARD + 1];
     int total, minfill;
     int taken[MAXCARD + 1];
     int count[2];
-    struct Rect cover[2];
+    struct RTree_Rect cover[2];
     RectReal area[2];
-extern struct Branch BranchBuf[MAXCARD + 1];
+extern struct RTree_Branch BranchBuf[MAXCARD + 1];
 extern int BranchCount;
-extern struct Rect CoverSplit;
+extern struct RTree_Rect CoverSplit;
 extern RectReal CoverSplitArea;
-extern struct PartitionVars Partitions[1];
+extern struct RTree_PartitionVars Partitions[1];
-extern void RTreeInitPVars(struct PartitionVars *, int, int);
+extern void RTreeInitPVars(struct RTree_PartitionVars *, int, int);
