[GRASS-SVN] r46955 - grass/trunk/lib/vector/diglib
Mon Jul 4 06:46:44 EDT 2011
Author: mmetz
Date: 2011-07-04 03:46:44 -0700 (Mon, 04 Jul 2011)
New Revision: 46955
   grass/trunk/lib/vector/diglib/list.c
   grass/trunk/lib/vector/diglib/spindex.c
remove redundant code in vector lib: update diglib
Modified: grass/trunk/lib/vector/diglib/list.c
--- grass/trunk/lib/vector/diglib/list.c	2011-07-04 10:11:58 UTC (rev 46954)
+++ grass/trunk/lib/vector/diglib/list.c	2011-07-04 10:46:44 UTC (rev 46955)
@@ -29,10 +29,11 @@
 /* Init box list */
-int dig_init_boxlist(struct boxlist *list)
+int dig_init_boxlist(struct boxlist *list, int have_boxes)
     list->id = NULL;
     list->box = NULL;
+    list->have_boxes = have_boxes != 0;
     list->n_values = 0;
     list->alloc_values = 0;
@@ -69,18 +70,21 @@
 	    return 0;
 	list->id = (int *)p;
-	size = (list->n_values + 1000) * sizeof(struct bound_box);
-	p = G_realloc((void *)list->box, size);
+	if (list->have_boxes) {
+	    size = (list->n_values + 1000) * sizeof(struct bound_box);
+	    p = G_realloc((void *)list->box, size);
-	if (p == NULL)
-	    return 0;
-	list->box = (int *)p;
+	    if (p == NULL)
+		return 0;
+	    list->box = (int *)p;
 	list->alloc_values = list->n_values + 1000;
     list->id[list->n_values] = id;
-    list->box[list->n_values] = box;
+	list->box[list->n_values] = box;
     list->n_values++;
     return 1;
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c	2011-07-04 10:11:58 UTC (rev 46954)
+++ grass/trunk/lib/vector/diglib/spindex.c	2011-07-04 10:46:44 UTC (rev 46955)
@@ -626,40 +626,6 @@
-   \brief Select lines by box
-   \param Plus pointer to Plus_head structure
-   \param box bounding box
-   \param list list of selected lines
-   \return number of selected lines
-int
-dig_select_lines(struct Plus_head *Plus, const struct bound_box * box,
-		 struct ilist *list)
-    struct RTree_Rect rect;
-    G_debug(3, "dig_select_lines()");
-    list->n_values = 0;
-    rect.boundary[0] = box->W;
-    rect.boundary[1] = box->S;
-    rect.boundary[2] = box->B;
-    rect.boundary[3] = box->E;
-    rect.boundary[4] = box->N;
-    rect.boundary[5] = box->T;
-    if (Plus->Spidx_new)
-	RTreeSearch(Plus->Line_spidx, &rect, (void *)_add_item, list);
-    else
-	rtree_search(Plus->Line_spidx, &rect, (void *)_add_item, list, Plus);
-    return (list->n_values);
    \brief Select lines with boxes by box
@@ -669,7 +635,7 @@
    \return 0 not found
-int dig_select_lines_with_box(struct Plus_head *Plus, const struct bound_box *box,
+int dig_select_lines(struct Plus_head *Plus, const struct bound_box *box,
@@ -728,40 +694,6 @@
-   \brief Select areas by box
-   \return number of selected areas
-int
-dig_select_areas(struct Plus_head *Plus, const struct bound_box * box,
-    G_debug(3, "dig_select_areas()");
-	RTreeSearch(Plus->Area_spidx, &rect, (void *)_add_item, list);
-    else
-	rtree_search(Plus->Area_spidx, &rect, (void *)_add_item, list, Plus);
    \brief Select areas with boxes by box
@@ -771,7 +703,7 @@
 int
-dig_select_areas_with_box(struct Plus_head *Plus, const struct bound_box * box,
+dig_select_areas(struct Plus_head *Plus, const struct bound_box * box,
@@ -829,40 +761,6 @@
     return (ret);
-   \brief Select isles by box
-   \return number of selected isles
-int
-dig_select_isles(struct Plus_head *Plus, const struct bound_box * box,
-    G_debug(3, "dig_select_isles()");
-	RTreeSearch(Plus->Isle_spidx, &rect, (void *)_add_item, list);
-    else
-	rtree_search(Plus->Isle_spidx, &rect, (void *)_add_item, list, Plus);
    \brief Select isles with boxes by box
@@ -873,7 +771,7 @@
 int
-dig_select_isles_with_box(struct Plus_head *Plus, const struct bound_box * box,
+dig_select_isles(struct Plus_head *Plus, const struct bound_box * box,
