[GRASS-SVN] r46959 - in grass/trunk/vector: v.clean v.distance v.edit v.generalize v.kernel v.neighbors v.net.steiner v.select
Mon Jul 4 06:49:36 EDT 2011
Author: mmetz
Date: 2011-07-04 03:49:36 -0700 (Mon, 04 Jul 2011)
New Revision: 46959
   grass/trunk/vector/v.clean/prune.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.edit/select.c
   grass/trunk/vector/v.generalize/misc.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/vector/v.net.steiner/main.c
   grass/trunk/vector/v.select/main.c
remove redundant code in vector lib: update modules
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.clean/prune.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -42,14 +42,14 @@
     struct line_pnts *Points, *TPoints, *BPoints, *Points_orig;
     struct line_cats *Cats;
     struct bound_box box;
-    struct ilist *List;
+    struct boxlist *List;
     Points = Vect_new_line_struct();
     Points_orig = Vect_new_line_struct();
     TPoints = Vect_new_line_struct();
     BPoints = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    List = Vect_new_list();
+    List = Vect_new_boxlist(0);
     nlines = Vect_get_num_lines(Out);
@@ -122,7 +122,7 @@
 		struct line_pnts **AXLines, **BXLines;
 		int naxlines, nbxlines;
-		bline = List->value[i];
+		bline = List->id[i];
 		if (bline == line)
 		    continue;
@@ -131,6 +131,7 @@
 		/* Vect_line_intersection is quite slow, hopefully not so bad because only few
 		 * intersections should be found if any */
+		AXLines = BXLines = NULL;
 		Vect_line_intersection(TPoints, BPoints, &AXLines, &BXLines,
 				       &naxlines, &nbxlines, 0);
@@ -143,14 +144,16 @@
 		    for (j = 0; j < naxlines; j++) {
 			Vect_destroy_line_struct(AXLines[j]);
+		if (AXLines)
 		    G_free(AXLines);
 		if (nbxlines > 0) {
 		    for (j = 0; j < nbxlines; j++) {
 			Vect_destroy_line_struct(BXLines[j]);
+		if (BXLines)
 		    G_free(BXLines);
 		if (naxlines > 1 || nbxlines > 1) {
 		    intersect = 1;
@@ -221,7 +224,7 @@
     Vect_destroy_line_struct(TPoints);
     Vect_destroy_line_struct(BPoints);
     Vect_destroy_cats_struct(Cats);
-    Vect_destroy_list(List);
+    Vect_destroy_boxlist(List);
     return 1;
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.distance/main.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -103,7 +103,7 @@
     char buf1[2000], buf2[2000];
     int update_ok, update_err, update_exist, update_notexist, update_dupl,
 	update_notfound;
     dbCatValArray cvarr;
     dbColumn *column;
@@ -504,7 +504,7 @@
     FCats = Vect_new_cats_struct();
     TCats = Vect_new_cats_struct();
     /* Allocate space ( may be more than needed (duplicate cats and elements without cats) ) */
     nfrom = Vect_get_num_lines(&From);
@@ -595,7 +595,7 @@
 		    /* the objective is to enlarge the search box
 		     * in the first iterations just a little bit
 		     * to keep the number of hits low */
-		    Vect_reset_list(List);
+		    Vect_reset_boxlist(List);
 		    while (curr_step < n_max_steps) {
 			box_edge = max_step[curr_step];
@@ -633,7 +633,7 @@
 		dist = PORT_DOUBLE_MAX;
 		for (i = 0; i < List->n_values; i++) {
 		    tmp_tcat = -1;
-		    Vect_read_line(&To, TPoints, TCats, List->value[i]);
+		    Vect_read_line(&To, TPoints, TCats, List->id[i]);
 		    tseg =
 			Vect_line_distance(TPoints, FPoints->x[0], FPoints->y[0],
@@ -692,7 +692,7 @@
 		    else {
 			if (tline == 0 || (tmp_dist < dist)) {
-			    tline = List->value[i];
+			    tline = List->id[i];
 			    tcat = tmp_tcat;
 			    dist = tmp_dist;
 			    tx = tmp_tx;
@@ -777,7 +777,7 @@
@@ -817,7 +817,7 @@
 		    int tmp_tcat;
-		    area = List->value[i];
+		    area = List->id[i];
 		    G_debug(4, "%d: area %d", i, area);
 		    Vect_get_area_points(&To, area, TPoints);
Modified: grass/trunk/vector/v.edit/select.c
--- grass/trunk/vector/v.edit/select.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.edit/select.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -23,6 +23,7 @@
 static char first_selection = 1;
 static int merge_lists(struct ilist *, struct ilist *);
+static int merge_lists2(struct ilist *, struct boxlist *);
    \brief Select vector features
@@ -342,14 +343,14 @@
     struct bound_box bbox;
-    struct ilist *List_tmp;
+    struct boxlist *List_tmp;
     if (first_selection) {
 	List_tmp = List;
 	first_selection = 0;
     else {
-	List_tmp = Vect_new_list();
+	List_tmp = Vect_new_boxlist();
     /* bounding box */
@@ -367,7 +368,7 @@
     /* merge lists (only duplicate items) */
     if (List_tmp != List) {
 	merge_lists(List, List_tmp);
-	Vect_destroy_list(List_tmp);
+	Vect_destroy_boxlist(List_tmp);
     return List->n_values;
@@ -547,7 +548,7 @@
-   \brief merge two list, i.e. store only duplicate items
+   \brief merge two lists, i.e. store only duplicate items
    \param[in] alist,blist list to be merged
@@ -574,6 +575,33 @@
+   \param[in] alist,blist list to be merged
+   \return result number of items
+static int merge_lists2(struct ilist *alist, struct boxlist *blist)
+    int i;
+    struct ilist *list_del;
+    list_del = Vect_new_list();
+    for (i = 0; i < alist->n_values; i++) {
+	if (!Vect_val_in_boxlist(blist, alist->value[i]))
+	    Vect_list_append(list_del, alist->value[i]);
+    Vect_list_delete_list(alist, list_del);
+    Vect_destroy_list(list_del);
+    return alist->n_values;
    \brief Reverse list selection
    \param[in] Map vector map
Modified: grass/trunk/vector/v.generalize/misc.c
--- grass/trunk/vector/v.generalize/misc.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.generalize/misc.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -261,12 +261,12 @@
 	left_new, right_new;
     static struct line_pnts *BPoints = NULL;
-    static struct ilist *List = NULL;
+    static struct boxlist *List = NULL;
     if (!BPoints)
     if (!List)
     /* Check intersection of the modified boundary with other boundaries */
     Vect_line_box(Points, &box);
@@ -278,7 +278,7 @@
 	if (bline == line)
 	    continue;
@@ -287,6 +287,7 @@
 	Vect_line_intersection(Points, BPoints, &AXLines, &BXLines,
@@ -299,14 +300,16 @@
+	if (AXLines)
 	    G_free(AXLines);
 	if (nbxlines > 0) {
+	if (BXLines)
 	    G_free(BXLines);
 	    intersect = 1;
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.kernel/main.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -605,11 +605,11 @@
     double dist;
     struct line_pnts *APoints, *BPoints;
     APoints = Vect_new_line_struct();
     nn = Vect_get_num_primitives(In, GV_POINTS);
     nn = nn * (nn - 1);
@@ -639,7 +639,7 @@
 	    int bline, ret;
 	    if (bline == aline)
 		continue;
@@ -701,14 +701,14 @@
     static struct line_pnts *Points = NULL;
     static struct line_pnts *FPoints = NULL;
-    static struct ilist *PointsList = NULL;
+    static struct boxlist *PointsList = NULL;
     static struct ilist *NodesList = NULL;
     if (!Points)
     if (!PointsList)
-	PointsList = Vect_new_list();
+	PointsList = Vect_new_boxlist(0);
     if (node_method == NODE_EQUAL_SPLIT) {
 	if (!NodesList)
@@ -736,7 +736,7 @@
     for (i = 0; i < PointsList->n_values; i++) {
 	int line, ret;
-	line = PointsList->value[i];
+	line = PointsList->id[i];
 	Vect_read_line(In, Points, NULL, line);
 	G_debug(3, "  SP: %f %f -> %f %f", x, y, Points->x[0], Points->y[0]);
@@ -800,14 +800,15 @@
     /* spatial index handling, borrowed from lib/vector/Vlib/find.c */
-    static struct ilist *NList = NULL;
+    static struct boxlist *NList = NULL;
     a[0] = E;
     a[1] = N;
-    if (!NList)
-	NList = Vect_new_list();
+    if (!NList) {
+	NList = Vect_new_boxlist(0);
     if (!Points)
@@ -826,7 +827,7 @@
     for (line = 0; line < nlines; line++) {
-	Vect_read_line(In, Points, NULL, NList->value[line]);
+	Vect_read_line(In, Points, NULL, NList->id[line]);
 	b[0] = Points->x[0];
 	b[1] = Points->y[0];
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.neighbors/main.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -37,7 +37,7 @@
     struct Option *method_opt, *size_opt;
     struct Map_info In;
     double radius;
     struct Cell_head region;
     struct line_pnts *Points;
@@ -91,7 +91,7 @@
     result = Rast_allocate_buf(CELL_TYPE);
     /*open the new cellfile */
     out_fd = Rast_open_new(out_opt->answer, CELL_TYPE);
@@ -127,7 +127,7 @@
 	    count = 0;
-		Vect_read_line(&In, Points, Cats, List->value[i]);
+		Vect_read_line(&In, Points, Cats, List->id[i]);
 		if (field != -1 && Vect_cat_get(Cats, field, NULL) == 0)
 		    continue;
Modified: grass/trunk/vector/v.net.steiner/main.c
--- grass/trunk/vector/v.net.steiner/main.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.net.steiner/main.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -332,7 +332,7 @@
     struct ilist *TList;	/* list of terminal nodes */
     struct ilist *StArcs;	/* list of arcs on Steiner tree */
     struct ilist *StNodes;	/* list of nodes on Steiner tree */
-    struct ilist *pointlist;
+    struct boxlist *pointlist;
     double cost, tmpcost;
     struct cat_list *Clist;
@@ -633,7 +633,7 @@
 	    StNodes->n_values);
     k = 0;
-    pointlist = Vect_new_list();
+    pointlist = Vect_new_boxlist(0);
     for (i = 0; i < StNodes->n_values; i++) {
 	double x, y, z;
@@ -648,7 +648,7 @@
 	nlines = Vect_get_node_n_lines(&Map, node);
 	for (j = 0; j < pointlist->n_values; j++) {
-	    line = pointlist->value[j];
+	    line = pointlist->id[j];
 	    ltype = Vect_read_line(&Map, Points, Cats, line);
 	    if (!(ltype & GV_POINT))
 		continue;
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2011-07-04 10:48:20 UTC (rev 46958)
+++ grass/trunk/vector/v.select/main.c	2011-07-04 10:49:36 UTC (rev 46959)
@@ -40,7 +40,8 @@
     struct line_cats *ACats, *BCats;
     int *ALines;		/* List of lines: 0 do not output, 1 - write to output */
-    struct ilist *List, *TmpList, *BoundList;
+    struct ilist *BoundList, *LList;
+    struct boxlist *List, *TmpList;
     G_gisinit(argv[0]);
@@ -109,9 +110,10 @@
     ACats = Vect_new_cats_struct();
     BCats = Vect_new_cats_struct();
-    TmpList = Vect_new_list();
+    TmpList = Vect_new_boxlist(0);
     BoundList = Vect_new_list();
+    LList = Vect_new_list();
     /* Open output */
     Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0])));
@@ -184,7 +186,7 @@
 		    int bline;
 		    G_debug(3, "  bline = %d", bline);
 		    /* Check category */
@@ -227,7 +229,7 @@
 		    int barea;
-		    barea = List->value[i];
+		    barea = List->id[i];
 		    G_debug(3, "  barea = %d", barea);
 		    if (Vect_get_area_cat(&(In[1]), barea, ifield[1]) < 0) {
@@ -299,7 +301,7 @@
 		    int bline;
 		    if (!flag.cat->answer && Vect_get_line_cat(&(In[1]), bline, ifield[1]) < 0) {
 			nskipped++;
@@ -332,11 +334,11 @@
 		/* List of areas B */
 		/* Make a list of features forming area A */
+		Vect_reset_list(LList);
 		Vect_get_area_boundaries(&(In[0]), aarea, BoundList);
 		for (i = 0; i < BoundList->n_values; i++) {
-		    Vect_list_append(List, abs(BoundList->value[i]));
+		    Vect_list_append(LList, abs(BoundList->value[i]));
 		naisles = Vect_get_area_num_isles(&(In[0]), aarea);
@@ -348,21 +350,21 @@
 		    Vect_get_isle_boundaries(&(In[0]), aisle, BoundList);
 		    for (j = 0; j < BoundList->n_values; j++) {
-			Vect_list_append(List, BoundList->value[j]);
+			Vect_list_append(LList, BoundList->value[j]);
 		Vect_select_areas_by_box(&(In[1]), &abox, TmpList);
-		for (i = 0; i < List->n_values; i++) {
+		for (i = 0; i < LList->n_values; i++) {
 		    int j, aline;
-		    aline = abs(List->value[i]);
+		    aline = abs(LList->value[i]);
 		    for (j = 0; j < TmpList->n_values; j++) {
 			int barea, bcentroid;
-			barea = TmpList->value[j];
+			barea = TmpList->id[j];
