[GRASS-SVN] r46975 - grass/trunk/general/g.tempfile
Tue Jul 5 05:58:48 EDT 2011
Author: martinl
Date: 2011-07-05 02:58:48 -0700 (Tue, 05 Jul 2011)
New Revision: 46975
   grass/trunk/general/g.tempfile/main.c
g.tempfile: dry run mode added (don't create a file, just print it's name)
	    i18n-related fixes
Modified: grass/trunk/general/g.tempfile/main.c
--- grass/trunk/general/g.tempfile/main.c	2011-07-05 09:07:12 UTC (rev 46974)
+++ grass/trunk/general/g.tempfile/main.c	2011-07-05 09:58:48 UTC (rev 46975)
@@ -4,14 +4,16 @@
  * MODULE:       g.tempfile
  * AUTHOR(S):    Michael Shapiro CERL (original contributor)
  *               Markus Neteler <neteler itc.it>,
- *               Roberto Flor <flor itc.it>, Bernhard Reiter <bernhard intevation.de>,
- *               Jan-Oliver Wagner <jan intevation.de>
+ *               Roberto Flor <flor itc.it>,
+ *               Bernhard Reiter <bernhard intevation.de>,
+ *               Jan-Oliver Wagner <jan intevation.de>,
+ *               Martin Landa <landa.martin gmail.com>
  * PURPOSE:
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2006, 2011 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
+ *               This program is free software under the GNU General
+ *               Public License (>=v2). Read the file COPYING that
+ *               comes with GRASS for details.
 #include <stdlib.h>
@@ -26,36 +28,42 @@
     struct GModule *module;
     struct Option *pid;
+    struct Flag *dry_run;
     char *tempfile, *G__tempfile();
     int p;
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("general"));
-    G_add_keyword(_("map management"));
-    module->description =
-	"Creates a temporary file and prints the file name.";
+    G_add_keyword(_("support"));
+    module->description = _("Creates a temporary file and prints it's file name.");
     pid = G_define_option();
     pid->key = "pid";
     pid->type = TYPE_INTEGER;
     pid->required = YES;
-    pid->description = "Process id to use when naming the tempfile";
+    pid->description = _("Process id to use when naming the tempfile");
+    dry_run = G_define_flag();
+    dry_run->key = 'd';
+    dry_run->description = _("Dry run - don't create a file, just prints it's file name");
     G_disable_interactive();
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     if (sscanf(pid->answer, "%d", &p) != 1) {
 	G_usage();
 	exit(EXIT_FAILURE);
     tempfile = G__tempfile(p);
     /* create tempfile so next run of this program will create a unique name */
-    close(creat(tempfile, 0666));
+    if (!dry_run->answer)
+	close(creat(tempfile, 0666));
     fprintf(stdout, "%s\n", tempfile);
     exit(EXIT_SUCCESS);
