[GRASS-SVN] r46978 - grass/trunk/lib/driver
Tue Jul 5 06:09:39 EDT 2011
Author: martinl
Date: 2011-07-05 03:09:39 -0700 (Tue, 05 Jul 2011)
New Revision: 46978
   grass/trunk/lib/driver/driver.h
   grass/trunk/lib/driver/init.c
   grass/trunk/lib/driver/parse_ftcap.c
libdriver: doxygen documentation updated
	   variable `name` added to `driver` data structure
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h	2011-07-05 10:07:39 UTC (rev 46977)
+++ grass/trunk/lib/driver/driver.h	2011-07-05 10:09:39 UTC (rev 46978)
@@ -21,6 +21,8 @@
 struct driver
+    char *name;
     void (*Box)(double, double, double, double);
     void (*Erase)(void);
     int (*Graph_set)(void);
Modified: grass/trunk/lib/driver/init.c
--- grass/trunk/lib/driver/init.c	2011-07-05 10:07:39 UTC (rev 46977)
+++ grass/trunk/lib/driver/init.c	2011-07-05 10:09:39 UTC (rev 46978)
@@ -1,17 +1,17 @@
+  \file lib/driver/init.c
- * MODULE:       driver
- * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor)
- *               Huidae Cho <grass4u gmail.com>
- * PURPOSE:
- * COPYRIGHT:    (C) 2006-2006 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
+  \brief Display Driver - initialization
+  (C) 2006-2011 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Glynn Clements <glynn gclements.plus.com> (original contributor)
+  \author Huidae Cho <grass4u gmail.com>
 #include <grass/config.h>
 #include <stdio.h>
@@ -39,6 +39,11 @@
 double text_cosrot;
 int matrix_valid;
+  \brief Initialize display driver
+  \param pointer to driver structure
 void LIB_init(const struct driver *drv)
     const char *p;
@@ -47,7 +52,6 @@
     ftcap = parse_fontcap();
     /* initialize graphics */
     p = getenv("GRASS_WIDTH");
     screen_width = (p && atoi(p)) ? atoi(p) : DEF_WIDTH;
Modified: grass/trunk/lib/driver/parse_ftcap.c
--- grass/trunk/lib/driver/parse_ftcap.c	2011-07-05 10:07:39 UTC (rev 46977)
+++ grass/trunk/lib/driver/parse_ftcap.c	2011-07-05 10:09:39 UTC (rev 46978)
@@ -1,3 +1,17 @@
+  \file lib/driver/parse_ftcap.c
+  \brief Display Driver - fontcaps
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
@@ -7,11 +21,23 @@
 #include <grass/fontcap.h>
 #include "driverlib.h"
+  \brief Check if font exists
 int font_exists(const char *name)
     return access(name, R_OK) >= 0;
+  \brief Parse fontcap entry
+  \param e pointer to GFONT_CAP struct
+  \param str ?
+  \return 1 on success
+  \return 0 on failure
 int parse_fontcap_entry(struct GFONT_CAP *e, const char *str)
     char name[GNAME_MAX], longname[GNAME_MAX], path[GPATH_MAX], encoding[128];
@@ -39,6 +65,11 @@
     return 1;
+  \brief Parse fontcaps
+  \return pointer to GFONT_CAP structure
 struct GFONT_CAP *parse_fontcap(void)
     char *capfile, file[GPATH_MAX];
@@ -85,6 +116,11 @@
     return fonts;
+  \brief Free allocated GFONT_CAP structure
+  \param fpcap pointer to GFONT_CAP to be freed
 void free_fontcap(struct GFONT_CAP *ftcap)
     int i;
@@ -101,4 +137,3 @@
     G_free(ftcap);
