[GRASS-SVN] r46991 - in grass/trunk/raster/r.li: r.li.cwed
r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv
r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum
r.li.pielou r.li.renyi r.li.richness r.li.setup r.li.shannon
r.li.shape r.li.simpson
svn_grass at osgeo.org
Tue Jul 5 06:33:16 EDT 2011
Author: neteler
Date: 2011-07-05 03:33:16 -0700 (Tue, 05 Jul 2011)
New Revision: 46991
grass/trunk/raster/r.li/r.li.cwed/cwed.c
grass/trunk/raster/r.li/r.li.dominance/dominance.c
grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
grass/trunk/raster/r.li/r.li.mpa/mpa.c
grass/trunk/raster/r.li/r.li.mps/mps.c
grass/trunk/raster/r.li/r.li.padcv/padcv.c
grass/trunk/raster/r.li/r.li.padrange/padrange.c
grass/trunk/raster/r.li/r.li.padsd/padsd.c
grass/trunk/raster/r.li/r.li.patchdensity/main.c
grass/trunk/raster/r.li/r.li.patchnum/main.c
grass/trunk/raster/r.li/r.li.pielou/pielou.c
grass/trunk/raster/r.li/r.li.renyi/renyi.c
grass/trunk/raster/r.li/r.li.richness/richness.c
grass/trunk/raster/r.li/r.li.setup/masked_area_selection
grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
grass/trunk/raster/r.li/r.li.shannon/shannon.c
grass/trunk/raster/r.li/r.li.shape/main.c
grass/trunk/raster/r.li/r.li.simpson/simpson.c
renamed conf parameter to config
Modified: grass/trunk/raster/r.li/r.li.cwed/cwed.c
--- grass/trunk/raster/r.li/r.li.cwed/cwed.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.cwed/cwed.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -54,7 +54,7 @@
raster = G_define_standard_option(G_OPT_R_INPUT);
conf = G_define_option();
- conf->key = "conf";
+ conf->key = "config";
conf->description = _("Configuration file");
conf->type = TYPE_STRING;
conf->required = YES;
Modified: grass/trunk/raster/r.li/r.li.dominance/dominance.c
--- grass/trunk/raster/r.li/r.li.dominance/dominance.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.dominance/dominance.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -49,7 +49,7 @@
conf->gisprompt = "old_file,file,input";
Modified: grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.edgedensity/edgedensity.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -46,7 +46,7 @@
Modified: grass/trunk/raster/r.li/r.li.mpa/mpa.c
--- grass/trunk/raster/r.li/r.li.mpa/mpa.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.mpa/mpa.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -46,7 +46,7 @@
Modified: grass/trunk/raster/r.li/r.li.mps/mps.c
--- grass/trunk/raster/r.li/r.li.mps/mps.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.mps/mps.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -47,7 +47,7 @@
Modified: grass/trunk/raster/r.li/r.li.padcv/padcv.c
--- grass/trunk/raster/r.li/r.li.padcv/padcv.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.padcv/padcv.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -44,7 +44,7 @@
Modified: grass/trunk/raster/r.li/r.li.padrange/padrange.c
--- grass/trunk/raster/r.li/r.li.padrange/padrange.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.padrange/padrange.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -46,7 +46,7 @@
Modified: grass/trunk/raster/r.li/r.li.padsd/padsd.c
--- grass/trunk/raster/r.li/r.li.padsd/padsd.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.padsd/padsd.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -44,7 +44,7 @@
Modified: grass/trunk/raster/r.li/r.li.patchdensity/main.c
--- grass/trunk/raster/r.li/r.li.patchdensity/main.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.patchdensity/main.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -41,7 +41,7 @@
Modified: grass/trunk/raster/r.li/r.li.patchnum/main.c
--- grass/trunk/raster/r.li/r.li.patchnum/main.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.patchnum/main.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -42,7 +42,7 @@
Modified: grass/trunk/raster/r.li/r.li.pielou/pielou.c
--- grass/trunk/raster/r.li/r.li.pielou/pielou.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.pielou/pielou.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -64,7 +64,7 @@
Modified: grass/trunk/raster/r.li/r.li.renyi/renyi.c
--- grass/trunk/raster/r.li/r.li.renyi/renyi.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.renyi/renyi.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -51,7 +51,7 @@
Modified: grass/trunk/raster/r.li/r.li.richness/richness.c
--- grass/trunk/raster/r.li/r.li.richness/richness.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.richness/richness.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -47,7 +47,7 @@
Modified: grass/trunk/raster/r.li/r.li.setup/masked_area_selection
--- grass/trunk/raster/r.li/r.li.setup/masked_area_selection 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.setup/masked_area_selection 2011-07-05 10:33:16 UTC (rev 46991)
@@ -1,4 +1,4 @@
-#! /bin/sh -x
+#!/bin/sh
#%Module
#%description: Select a circular or polygonal area
#%End
@@ -21,7 +21,7 @@
#% required: no
#%end
#%option
-#% key: conf
+#% key: config
#% type: string
#% description: name of configuration file where insert areas
#% required: yes
Modified: grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh 2011-07-05 10:33:16 UTC (rev 46991)
@@ -19,7 +19,7 @@
#% required: yes
#%end
#%option
-#% key: conf
+#% key: config
#% type: string
#% required: yes
Modified: grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh 2011-07-05 10:33:16 UTC (rev 46991)
@@ -27,7 +27,7 @@
#% required: no
#%end
#%option
-#% key: conf
+#% key: config
#% type: string
#% required: yes
Modified: grass/trunk/raster/r.li/r.li.shannon/shannon.c
--- grass/trunk/raster/r.li/r.li.shannon/shannon.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.shannon/shannon.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -46,7 +46,7 @@
Modified: grass/trunk/raster/r.li/r.li.shape/main.c
--- grass/trunk/raster/r.li/r.li.shape/main.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.shape/main.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -41,7 +41,7 @@
Modified: grass/trunk/raster/r.li/r.li.simpson/simpson.c
--- grass/trunk/raster/r.li/r.li.simpson/simpson.c 2011-07-05 10:28:23 UTC (rev 46990)
+++ grass/trunk/raster/r.li/r.li.simpson/simpson.c 2011-07-05 10:33:16 UTC (rev 46991)
@@ -47,7 +47,7 @@
