[GRASS-SVN] r46998 - in grass/trunk/gui/wxpython: . gui_modules
    svn_grass at osgeo.org
    Tue Jul  5 09:09:21 EDT 2011
Author: martinl
Date: 2011-07-05 06:09:21 -0700 (Tue, 05 Jul 2011)
New Revision: 46998
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/gui_modules/utils.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: major update for d.mon
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -1,20 +1,19 @@
 @package mapdisp.py
- at brief GIS map display canvas, with toolbar for various display
-management functions, and additional toolbars (vector digitizer, 3d
-view).
+ at brief Map display with toolbar for various display management
+functions, and additional toolbars (vector digitizer, 3d view).
-Can be used either from Layer Manager or as p.mon backend.
+Can be used either from Layer Manager or as d.mon backend.
 Classes:
 - MapFrame
 - MapApp
 Usage:
-python mapdisp.py monitor-identifier /path/to/command/file
+python mapdisp.py monitor-identifier /path/to/map/file /path/to/command/file /path/to/env/file
-(C) 2006-2010 by the GRASS Development Team
+(C) 2006-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
@@ -35,19 +34,9 @@
 import wx
 import wx.aui
-try:
-    import subprocess
-except:
-    CompatPath = os.path.join(globalvar.ETCWXDIR)
-    sys.path.append(CompatPath)
-    from compat import subprocess
+sys.path.append(os.path.join(globalvar.ETCWXDIR, "icons"))
+sys.path.append(os.path.join(globalvar.ETCDIR,   "python"))
-gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
-sys.path.append(gmpath)
-grassPath = os.path.join(globalvar.ETCDIR, "python")
-sys.path.append(grassPath)
 import render
 import toolbars
 import menuform
@@ -61,16 +50,21 @@
 import globalvar
 import utils
 import gdialogs
-from grass.script import core as grass
-from debug import Debug
-from icon  import Icons
+from debug       import Debug
+from icon        import Icons
 from preferences import globalSettings as UserSettings
 from mapdisp_command import Command
-from mapdisp_window import BufferedWindow
+from mapdisp_window  import BufferedWindow
+from grass.script import core as grass
 # for standalone app
-cmdfilename = None
+monFile = { 'cmd' : None,
+            'map' : None,
+            'env' : None,
+monName = None
 haveCtypes = False
@@ -83,8 +77,8 @@
                  tree = None, notebook = None, lmgr = None, page = None,
                  Map = None, auimgr = None, **kwargs):
         """!Main map display window with toolbars, statusbar and
-        DrawWindow
+        BufferedWindow (map canvas)
         @param toolbars array of activated toolbars, e.g. ['map', 'digit']
         @param tree reference to layer tree
         @param notebook control book ID in Layer Manager
@@ -427,7 +421,7 @@
         self.SetStatusText("", 0)
         Debug.msg(5, "MapFrame._addToolbarNviz(): end")
     def AddToolbar(self, name):
         """!Add defined toolbar to the window
@@ -533,7 +527,7 @@
         self.Map.ChangeMapSize(self.GetClientSize())
         self.Map.region = self.Map.GetRegion() # g.region -upgc
         # self.Map.SetRegion() # adjust region to match display window
     def OnUpdateProgress(self, event):
         """!Update progress bar info
@@ -627,8 +621,7 @@
             self.MapWindow.SetCursor(self.cursors["default"])
     def OnZoomIn(self, event):
-        Zoom in the map.
+        """!Zoom in the map.
         Set mouse cursor, zoombox attributes, and zoom direction
         if self.toolbars['map']:
@@ -644,8 +637,7 @@
         self.MapWindow.SetCursor(self.cursors["cross"])
     def OnZoomOut(self, event):
-        Zoom out the map.
+        """!Zoom out the map.
@@ -661,15 +653,13 @@
     def OnZoomBack(self, event):
+        """!Zoom last (previously stored position)
-        Zoom last (previously stored position)
         self.MapWindow.ZoomBack()
     def OnPan(self, event):
+        """!Panning, set mouse to drag
-        Panning, set mouse to drag
             self.toolbars['map'].OnTool(event)
             self.toolbars['map'].action['desc'] = ''
@@ -682,24 +672,21 @@
         self.MapWindow.SetCursor(self.cursors["hand"])
     def OnErase(self, event):
+        """!Erase the canvas
-        Erase the canvas
         self.MapWindow.EraseMap()
     def OnZoomRegion(self, event):
+        """!Zoom to region
-        Zoom to region
         self.Map.getRegion()
         self.Map.getResolution()
         self.UpdateMap()
         # event.Skip()
     def OnAlignRegion(self, event):
+        """!Align region
-        Align region
         if not self.Map.alignRegion:
             self.Map.alignRegion = True
         else:
@@ -2025,73 +2012,90 @@
         return self._layerManager
-# end of class MapFrame
 class MapApp(wx.App):
     def OnInit(self):
         wx.InitAllImageHandlers()
         if __name__ == "__main__":
-            Map = render.Map() # instance of Map class to render GRASS display output to PPM file
+            self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
+            Map = render.Map(cmdfile = monFile['cmd'], mapfile = monFile['map'],
+                             envfile = monFile['env'], monitor = monName)
         else:
             Map = None
         self.mapFrm = MapFrame(parent = None, id = wx.ID_ANY, Map = Map,
                                size = globalvar.MAP_WINDOW_SIZE)
-        #self.SetTopWindow(Map)
+        # self.SetTopWindow(Map)
         self.mapFrm.Show()
-            # redraw map, if new command appears
-            self.redraw = False
-            status = Command(self, Map, cmdfilename)
-            status.start()
+            #status = Command(self, Map, cmdfile)
+            # status.start()
             self.timer = wx.PyTimer(self.watcher)
-            # check each 0.1s
-            self.timer.Start(100)
-        return 1
+            #check each 0.5s
+            global mtime
+            mtime = 500
+            self.timer.Start(mtime)
+        return True
     def OnExit(self):
             # stop the timer
+            # self.timer.Stop()
+            # terminate thread
+            for f in monFile.itervalues():
+                grass.try_remove(f)
+    def watcher(self):
+        """!Redraw, if new layer appears (check's timestamp of
+        cmdfile)
+        # todo: events
+        if os.path.getmtime(monFile['cmd']) > self.cmdTimeStamp:
             self.timer.Stop()
-            # terminate thread (a bit ugly)
-            os.system("""!echo "quit" >> %s""" % (cmdfilename))
-    def watcher(self):
-        """!Redraw, if new layer appears"""
-        if self.redraw:
             self.mapFrm.OnDraw(None)
-        return
-# end of class MapApp
-    ###### SET command variable
-    if len(sys.argv) != 3:
+    # set command variable
+    if len(sys.argv) != 5:
         print __doc__
-        sys.exit()
-    title = sys.argv[1]
-    cmdfilename = sys.argv[2]
+        sys.exit(1)
+    monName = sys.argv[1]
+    monFile = { 'map' : sys.argv[2],
+                'cmd' : sys.argv[3],
+                'env' : sys.argv[4],
     import gettext
     gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    grass.verbose(_("Starting map display <%s>...") % (monName))
-    print >> sys.stderr, "\nStarting monitor <%s>...\n" % (title)
+    gcmd.RunCommand('g.gisenv',
+                    set = 'MONITOR_%s_PID=%d' % (monName, os.getpid()))
     gm_map = MapApp(0)
     # set title
     gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " +
-                             title +
+                             monName +
                              " - Location: " + grass.gisenv()["LOCATION_NAME"]))
     gm_map.MainLoop()
-    os.remove(cmdfilename)
-    os.system("""!g.gisenv set="GRASS_PYCMDFILE" """)
+    grass.verbose(_("Stopping map display <%s>...") % (monName))
-    print >> sys.stderr, "\nStopping monitor <%s>...\n" % (title)
+    # clean up GRASS env variables
+    env = grass.gisenv()
+    env_name = 'MONITOR_%s' % monName
+    for key in env.keys():
+        if key.find(env_name) == 0:
+                              set = '%s=' % key)
+        if key == 'MONITOR' and env[key] == monName:
     sys.exit(0)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -444,7 +444,6 @@
         If self.redrawAll is False on self.pdcTmp content is re-drawn
         Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
         dc = wx.BufferedPaintDC(self, self.buffer)
         dc.Clear()
@@ -632,7 +631,7 @@
         self.resize = False
-        if self.img is None:
+        if not self.Map.cmdfile and self.img is None:
             render = True
@@ -663,10 +662,12 @@
                     windres = True
                 else:
                     windres = False
                 self.mapfile = self.Map.Render(force = True, mapWindow = self.parent,
                                                windres = windres)
             else:
                 self.mapfile = self.Map.Render(force = False, mapWindow = self.parent)
         except gcmd.GException, e:
             gcmd.GError(message = e.value)
             self.mapfile = None
@@ -772,6 +773,7 @@
         else:
             self.parent.statusbarWin['mask'].SetLabel('')
         Debug.msg (1, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
                    (render, renderVector, (stop-start)))
@@ -1211,6 +1213,7 @@
             self.DrawLines(pdc = self.pdcTmp)
         elif self.mouse["use"] == "pointer" and \
+                not self.parent.IsStandalone() and \
                 self.parent.GetLayerManager().gcpmanagement:
             # -> GCP manager
             if self.parent.toolbars['gcpdisp']:
@@ -1224,6 +1227,7 @@
                 self.UpdateMap(render = False, renderVector = False)
                 self.parent.GetLayerManager().georectifying:
             # -> georectifying
             coord = self.Pixel2Cell(self.mouse['end'])
@@ -1340,7 +1344,8 @@
     def OnMouseEnter(self, event):
         """!Mouse entered window and no mouse buttons were pressed
-        if self.parent.GetLayerManager().gcpmanagement:
+        if not self.parent.IsStandalone() and \
+                self.parent.GetLayerManager().gcpmanagement:
                 if not self.parent.MapWindow == self:
                     self.parent.MapWindow = self
@@ -1432,8 +1437,7 @@
         return (x, y)
     def Zoom(self, begin, end, zoomtype):
-        Calculates new region while (un)zoom/pan-ing
+        """!Calculates new region while (un)zoom/pan-ing
         x1, y1 = begin
         x2, y2 = end
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -24,13 +24,6 @@
 import glob
 import math
 import copy
-try:
-    import subprocess
-except:
-    compatPath = os.path.join(globalvar.ETCWXDIR, "compat")
-    sys.path.append(compatPath)
-    import subprocess
 import tempfile
 import wx
@@ -46,22 +39,19 @@
 wxUpdateProgressBar, EVT_UPDATE_PRGBAR = NewEvent()
-# use g.pnmcomp for creating image composition or
-# wxPython functionality
 USE_GPNMCOMP = True
 class Layer(object):
     """!Virtual class which stores information about layers (map layers and
     overlays) of the map composition.
-    For map layer use MapLayer class.
-    For overlays use Overlay class.
+    - For map layer use MapLayer class.
+    - For overlays use Overlay class.
     def __init__(self, type, cmd, name = None,
                  active = True, hidden = False, opacity = 1.0):
+        """!Create new instance
         @todo pass cmd as tuple instead of list
         @param type layer type ('raster', 'vector', 'overlay', 'command', etc.)
@@ -94,22 +84,26 @@
                         self.opacity, self.hidden))
         # generated file for each layer
-        self.gtemp = tempfile.mkstemp()[1]
-        self.maskfile = self.gtemp + ".pgm"
-        if self.type == 'overlay':
-            self.mapfile  = self.gtemp + ".png"
+        if USE_GPNMCOMP or self.type == 'overlay':
+            tmpfile = tempfile.mkstemp()[1]
+            self.maskfile = tmpfile + '.pgm'
+            if self.type == 'overlay':
+                self.mapfile  = tmpfile + '.png'
+            else:
+                self.mapfile  = tmpfile + '.ppm'
+            grass.try_remove(tmpfile)
         else:
-            self.mapfile  = self.gtemp + ".ppm"
+            self.mapfile = self.maskfile = None
     def __del__(self):
         Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
                    (self.name, self.GetCmd(string = True)))
     def Render(self):
         """!Render layer to image
         @return rendered image filename
-        @return None on error
+        @return None on error or if cmdfile is defined
         if not self.cmd:
             return None
@@ -135,7 +129,7 @@
         # start monitor
 	if self.mapfile:
 	    os.environ["GRASS_PNGFILE"] = self.mapfile
         # execute command
         try:
             if self.type == 'command':
@@ -154,37 +148,24 @@
             else:
                 ret, msg = gcmd.RunCommand(self.cmd[0],
                                            getErrorMsg = True,
-                                           quiet = True,
+                                           # quiet = True,
+                                           verbose = True,
                                            **self.cmd[1])
-            # if len(msg):
-            # sys.stderr.write(_("Running") + " '" + utils.GetCmdString(self.cmd) + "'")
-            # sys.stderr.write(msg)
             if ret != 0:
-                # clean up after problem
-                try:
-                    os.remove(self.mapfile)
-                    os.remove(self.maskfile)
-                    os.remove(self.gtemp)
-                except (OSError, TypeError):
-                    pass
-                self.mapfile = None
-                self.maskfile = None
+                raise gcmd.GException(value = _("%s failed") % self.cmd[0])
             # sys.stderr.write(e.value)
             # clean up after problems
-            try:
-                pass
+            for f in [self.mapfile, self.maskfile]:
+                if not f:
+                    continue
+                f = None
         # stop monitor
-        if "GRASS_PNGFILE" in os.environ:
+        if self.mapfile and "GRASS_PNGFILE" in os.environ:
             del os.environ["GRASS_PNGFILE"]
         self.force_render = False
@@ -350,9 +331,15 @@
         self.id = id
 class Map(object):
-    """!Map composition (stack of map layers and overlays)
-    def __init__(self, gisrc = None):
+    def __init__(self, gisrc = None, cmdfile = None, mapfile = None, envfile = None, monitor = None):
+        """!Map composition (stack of map layers and overlays)
+        @param gisrc alternative gisrc (used eg. by georectifier)
+        @param cmdline full path to the cmd file (defined by d.mon)
+        @param mapfile full path to the map file (defined by d.mon)
+        @param envfile full path to the env file (defined by d.mon)
+        @param monitor name of monitor (defined by d.mon)
         # region/extent settigns
         self.wind      = dict() # WIND settings (wind file)
         self.region    = dict() # region settings (g.region)
@@ -366,21 +353,38 @@
         self.ovlookup  = dict()  # lookup dictionary for overlay items and overlays
         # environment settings
-        # environment variables, like MAPSET, LOCATION_NAME, etc.
         self.env   = dict()
         # path to external gisrc
         self.gisrc = gisrc
-        # generated file for g.pnmcomp output for rendering the map
-        self.mapfile = tempfile.mkstemp(suffix = '.ppm')[1]
+        self.cmdfile = cmdfile
+        self.envfile = envfile
+        self.monitor = monitor
+        if mapfile:
+            self.mapfile = mapfile
+        else:
+            # generated file for g.pnmcomp output for rendering the map
+            self.mapfile = grass.tempfile(create = False) + '.ppm'
         # setting some initial env. variables
         self._initGisEnv() # g.gisenv
         self.GetWindow()
         # GRASS environment variable (for rendering)
-        os.environ["GRASS_TRANSPARENT"] = "TRUE"
-        os.environ["GRASS_BACKGROUNDCOLOR"] = "ffffff"
+        env = {"GRASS_TRANSPARENT"     : "TRUE",
+               "GRASS_BACKGROUNDCOLOR" : "FFFFFF",
+               # "GRASS_PNG_AUTO_WRITE"  : "TRUE",
+               "GRASS_COMPRESSION"     : "0",
+               "GRASS_TRUECOLOR"       : "TRUE" }
+        if self.cmdfile:
+            env["GRASS_PNG_READ"] = "TRUE"
+        else:
+            env["GRASS_PNG_READ"] = "FALSE"
+        self._writeEnvFile(env)
+        for k, v in env.iteritems():
+            os.environ[k] = v
         # projection info
         self.projinfo = self._projInfo()
@@ -540,24 +544,47 @@
             if self.region['s'] < -90.0:
                 self.region['s'] = -90.0
+    def _writeEnvFile(self, data):
+        """!Write display-related variable to the file (used for
+        standalone app)
+        if not self.envfile:
+            return
+        try:
+            fd = open(self.envfile, "r")
+            for line in fd.readlines():
+                key, value = line.split('=')
+                if key not in data.keys():
+                    data[key] = value
+            fd.close()
+            fd = open(self.envfile, "w")
+            for k, v in data.iteritems():
+                fd.write('%s=%s\n' % (k.strip(), str(v).strip()))
+        except IOError, e:
+            grass.warning(_("Unable to open file '%s' for writting. Details: %s") % \
+                              (self.envfile, e))
+            return
+        fd.close()
     def ChangeMapSize(self, (width, height)):
         """!Change size of rendered map.
         @param width,height map size
-        @return True on success
-        @return False on failure
         try:
             self.width  = int(width)
             self.height = int(height)
-            Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
-                          (self.width, self.height))
-            return True
         except:
             self.width  = 640
             self.height = 480
-            return False
+        Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
+                      (self.width, self.height))
+        self._writeEnvFile({'GRASS_WIDTH' : self.width,
+                            'GRASS_HEIGHT' : self.height})
     def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
                   n = None, s = None, e = None, w = None, default = False,
@@ -800,15 +827,12 @@
         # render map layers
         ilayer = 1
         for layer in self.layers + self.overlays:
-            # skip dead or disabled map layers
-            if layer == None or layer.active == False:
+            # skip non-active map layers
+            if not layer or not layer.active:
                 continue
-            # render if there is no mapfile
-            if force or \
-               layer.force_render or \
-               layer.mapfile == None or \
-               (not os.path.isfile(layer.mapfile) or not os.path.getsize(layer.mapfile)):
+            # render
+            if force or layer.force_render:
                 if not layer.Render():
                     continue
@@ -823,10 +847,49 @@
                 maps.append(layer.mapfile)
                 masks.append(layer.maskfile)
                 opacities.append(str(layer.opacity))
-            Debug.msg (3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
+            Debug.msg(3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
             ilayer += 1
+    def _parseCmdFile(self):
+        """!Parse cmd file for standalone application
+        try:
+            fd = open(self.cmdfile, 'r')
+            grass.try_remove(self.mapfile)
+            for cmd in fd.readlines():
+                cmdStr = cmd.strip().split(' ')
+                cmd = utils.CmdToTuple(cmdStr)
+                gcmd.RunCommand(cmd[0], **cmd[1])
+            grass.warning(_("Unable to read cmdfile '%s'. Details: %s") % \
+                              (self.cmdfile, e))
+            return
+        Debug.msg(1, "Map.__parseCmdFile(): cmdfile=%s" % self.cmdfile)
+        Debug.msg(1, "                      nlayers=%d" % len(self.layers))
+        fd.close()
+    def _renderCmdFile(self, force, windres):
+        if not force:
+            return self.mapfile
+        os.environ["GRASS_REGION"] = self.SetRegion(windres)
+        currMon = grass.gisenv()['MONITOR']
+        if currMon != self.monitor:
+                            set = 'MONITOR=%s' % self.monitor)
+        self._parseCmdFile()
+                            set = 'MONITOR=%s' % currMon)
     def Render(self, force = False, mapWindow = None, windres = False):
         """!Creates final image composite
@@ -839,10 +902,13 @@
         @return name of file with rendered image or None
-        maps = []
-        masks = []
-        opacities = []
+        if self.cmdfile:
+            return self._renderCmdFile(force, windres)
+        maps      = list()
+        masks     = list()
+        opacities = list()
         # use external gisrc if defined
         gisrc_orig = os.getenv("GISRC")
         if self.gisrc:
@@ -852,9 +918,6 @@
         os.environ["GRASS_WIDTH"]  = str(self.width)
         os.environ["GRASS_HEIGHT"] = str(self.height)
-	os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
-	os.environ["GRASS_COMPRESSION"] = "0"
-	os.environ["GRASS_TRUECOLOR"] = "TRUE"
         driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
         if driver == 'cairo':
             os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
@@ -863,12 +926,10 @@
         else:
             os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
-        os.environ["GRASS_PNG_READ"] = "FALSE"
         self._renderLayers(force, mapWindow, maps, masks, opacities)
         # ugly hack for MSYS
-        if not subprocess.mswindows:
+        if sys.platform != 'win32':
             mapstr = ",".join(maps)
             maskstr = ",".join(masks)
             mapoutstr = self.mapfile
@@ -882,33 +943,18 @@
                 maskstr += item.replace('\\', '/')
             maskstr = maskstr.rstrip(',')
             mapoutstr = self.mapfile.replace('\\', '/')
-        # compose command
+        # run g.pngcomp to get composite image
         bgcolor = ':'.join(map(str, UserSettings.Get(group = 'display', key = 'bgcolor',
                                                      subkey = 'color')))
-        complist = ["g.pnmcomp",
-                    "in=%s" % ",".join(maps),
-                    "mask=%s" % ",".join(masks),
-                    "opacity=%s" % ",".join(opacities),
-                    "background=%s" % bgcolor,
-                    "width=%s" % str(self.width),
-                    "height=%s" % str(self.height),
-                    "output=%s" % self.mapfile]
-        # render overlays
-        if tmp_region:
-            os.environ["GRASS_REGION"] = tmp_region
-        else:
-            del os.environ["GRASS_REGION"]
         if maps:
-            # run g.pngcomp to get composite image
             ret = gcmd.RunCommand('g.pnmcomp',
+                                  overwrite = True,
                                   input = '%s' % ",".join(maps),
                                   mask = '%s' % ",".join(masks),
                                   opacity = '%s' % ",".join(opacities),
-                                  background = bgcolor,
+                                  bgcolor = bgcolor,
                                   width = self.width,
                                   height = self.height,
                                   output = self.mapfile)
@@ -916,9 +962,15 @@
             if ret != 0:
                 print >> sys.stderr, _("ERROR: Rendering failed")
                 return None
-            Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        Debug.msg (3, "Map.Render() force=%s file=%s" % (force, self.mapfile))
+        # back to original region
+        if tmp_region:
+            os.environ["GRASS_REGION"] = tmp_region
+        else:
+            del os.environ["GRASS_REGION"]
         # back to original gisrc
         if self.gisrc:
             os.environ["GISRC"] = gisrc_orig
@@ -1228,43 +1280,23 @@
         return self.DeleteLayer(overlay, overlay = True)
+    def _clean(self, llist):
+        for layer in llist:
+            if layer.maskfile:
+                grass.try_remove(layer.maskfile)
+            if layer.mapfile:
+                grass.try_remove(layer.mapfile)
+            llist.remove(layer)
     def Clean(self):
         """!Clean layer stack - go trough all layers and remove them
         from layer list.
-        Removes also l_mapfile and l_maskfile
+        Removes also mapfile and maskfile.
-        try:
-            dir = os.path.dirname(self.mapfile)
-            base = os.path.basename(self.mapfile).split('.')[0]
-            removepath = os.path.join(dir,base)+r'*'
-            for f in glob.glob(removepath):
-                os.remove(f)
-            for layer in self.layers:
-                if layer.mapfile:
-                    dir = os.path.dirname(layer.mapfile)
-                    base = os.path.basename(layer.mapfile).split('.')[0]
-                        os.remove(f)
-                self.layers.remove(layer)
-            for overlay in self.overlays:
-                if overlay.mapfile:
-                    dir = os.path.dirname(overlay.mapfile)
-                    base = os.path.basename(overlay.mapfile).split('.')[0]
-                        os.remove(f)
-                self.overlays.remove(overlay)
-        except:
-            return False
+        self._clean(self.layers)
+        self._clean(self.overlays)
-        return True
     def ReverseListOfLayers(self):
         """!Reverse list of layers"""
         return self.layers.reverse()
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -208,7 +208,8 @@
             log = self.parent.GetLayerManager().GetLogWindow()
         if haveNviz:
-            if not self.parent.GetLayerManager().existNviz:
+            if self.parent.GetLayerManager() and \
+                    not self.parent.GetLayerManager().existNviz:
                 choices.append(_('3D view'))
                 self.toolId['3d'] = 1
             else:
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -480,7 +480,7 @@
     for item in cmd[1:]:
         if '=' in item: # params
             key, value = item.split('=', 1)
-            dcmd[str(key)] = str(value)
+            dcmd[str(key)] = str(value).replace('"', '')
         elif item[:2] == '--': # long flags
             flag = item[2:]
             if flag in ('verbose', 'quiet', 'overwrite'):
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-07-05 12:50:12 UTC (rev 46997)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-07-05 13:09:21 UTC (rev 46998)
@@ -1687,14 +1687,12 @@
     workspaceFile = process_opt(opts, args)[0]
     # run application
     app = GMApp(workspaceFile)
     # suppress wxPython logs
     q = wx.LogNull()
     app.MainLoop()
     sys.exit(main())
