[GRASS-SVN] r47020 - grass/trunk/general/g.proj
Wed Jul 6 08:29:41 EDT 2011
Author: martinl
Date: 2011-07-06 05:29:40 -0700 (Wed, 06 Jul 2011)
New Revision: 47020
Added:
   grass/trunk/general/g.proj/create.c
   grass/trunk/general/g.proj/input.c
   grass/trunk/general/g.proj/local_proto.h
   grass/trunk/general/g.proj/main.c
   grass/trunk/general/g.proj/output.c
g.proj: don't require `-c` when `location` is defined
	code reorganization
	message cosmetics
Added: grass/trunk/general/g.proj/create.c
--- grass/trunk/general/g.proj/create.c	                        (rev 0)
+++ grass/trunk/general/g.proj/create.c	2011-07-06 12:29:40 UTC (rev 47020)
@@ -0,0 +1,67 @@
+#include <errno.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+void create_location(char *location)
+    int ret;
+    ret = G__make_location(location, &cellhd, projinfo, projunits, NULL);
+    if (ret == 0)
+	G_message(_("Location <%s> created"), location);
+    else if (ret == -1)
+	G_fatal_error(_("Unable to create location <%s>: %s"),
+		    location, strerror(errno));
+    else if (ret == -2)
+	G_fatal_error(_("Unable to create projection files: %s"),
+		    strerror(errno));
+    else
+	/* Shouldn't happen */
+	G_fatal_error(_("Unspecified error while creating new location"));
+    G_message(_("You can switch to the new location by `%s=%s`"),
+	      "g.gisenv set=LOCATION_NAME", location);
+void modify_projinfo()
+    const char *mapset = G_mapset();
+    struct Cell_head old_cellhd;
+    if (strcmp(mapset, "PERMANENT") != 0)
+	G_fatal_error(_("You must select the PERMANENT mapset before updating the "
+			"current location's projection (current mapset is <%s>)."),
+		      mapset);
+    /* Read projection information from current location first */
+    G_get_default_window(&old_cellhd);
+    char path[GPATH_MAX];
+    /* Write out the PROJ_INFO, and PROJ_UNITS if available. */
+    if (projinfo != NULL) {
+	G_file_name(path, "", "PROJ_INFO", "PERMANENT");
+	G_write_key_value_file(path, projinfo);
+    if (projunits != NULL) {
+	G_file_name(path, "", "PROJ_UNITS", "PERMANENT");
+	G_write_key_value_file(path, projunits);
+    if ((old_cellhd.zone != cellhd.zone) ||
+	(old_cellhd.proj != cellhd.proj)) {
+	/* Recreate the default, and current window files if projection
+	 * number or zone have changed */
+	G__put_window(&cellhd, "", "DEFAULT_WIND");
+	G__put_window(&cellhd, "", "WIND");
+	G_message(_("Default region was updated to the new projection, but if you have "
+		    "multiple mapsets `g.region -d` should be run in each to update the "
+		    "region from the default"));
+    G_important_message(_("Projection information updated"));
Property changes on: grass/trunk/general/g.proj/create.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Modified: grass/trunk/general/g.proj/input.c
--- grass/trunk/general/g.proj/input.c	2011-07-06 12:21:41 UTC (rev 47019)
+++ grass/trunk/general/g.proj/input.c	2011-07-06 12:29:40 UTC (rev 47020)
@@ -95,7 +95,7 @@
 	G_squeeze(buff);
     else
-	G_fatal_error(_("Unable to open file [%s] for reading"), wktfile);
+	G_fatal_error(_("Unable to open file '%s' for reading"), wktfile);
     ret = GPJ_wkt_to_grass(&cellhd, &projinfo, &projunits, buff, 0);
     set_default_region();
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h	2011-07-06 12:21:41 UTC (rev 47019)
+++ grass/trunk/general/g.proj/local_proto.h	2011-07-06 12:29:40 UTC (rev 47020)
@@ -19,7 +19,10 @@
 #ifdef HAVE_OGR
 void print_wkt(int, int);
 #endif
-void create_location(char *);
 /* datumtrans.c */
 int set_datumtrans(int, int);
+/* create.c */
+void create_location(char *);
+void modify_projinfo();
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c	2011-07-06 12:21:41 UTC (rev 47019)
+++ grass/trunk/general/g.proj/main.c	2011-07-06 12:29:40 UTC (rev 47020)
@@ -61,12 +61,13 @@
     module = G_define_module();
     G_add_keyword(_("general"));
     G_add_keyword(_("projection"));
+    G_add_keyword(_("create location"));
 #ifdef HAVE_OGR
     module->label =
-	_("Converts co-ordinate system descriptions (i.e. projection "
-	  "information) between various formats (including GRASS format).");
+	_("Prints and manipulates GRASS projection information files "
+	  "(in various co-ordinate system descriptions).");
     module->description =
-	_("Can also be used to create GRASS locations.");
+	_("Can also be used to create new GRASS locations.");
 #else
 	_("Prints and manipulates GRASS projection information files.");
@@ -123,8 +124,8 @@
     ingeo->type = TYPE_STRING;
     ingeo->key_desc = "file";
     ingeo->required = NO;
-    ingeo->guisection = _("Input");
-    ingeo->description = _("Georeferenced data file to read projection "
+    ingeo->guisection = _("Specification");
+    ingeo->description = _("Name of georeferenced data file to read projection "
 			   "information from");
     inwkt = G_define_option();
@@ -132,24 +133,26 @@
     inwkt->type = TYPE_STRING;
     inwkt->key_desc = "file";
     inwkt->required = NO;
-    inwkt->guisection = _("Input");
-    inwkt->description = _("ASCII file containing a WKT projection "
-			   "description (- for stdin)");
+    inwkt->guisection = _("Specification");
+    inwkt->label = _("Name of ASCII file containing a WKT projection "
+		     "description");
+    inwkt->description = _("'-' for standard input");
     inproj4 = G_define_option();
     inproj4->key = "proj4";
     inproj4->type = TYPE_STRING;
     inproj4->key_desc = "params";
     inproj4->required = NO;
-    inproj4->guisection = _("Input");
-    inproj4->description = _("PROJ.4 projection description (- for stdin)");
+    inproj4->guisection = _("Specification");
+    inproj4->label = _("PROJ.4 projection description");
+    inproj4->description = _("'-' for standard input");
     inepsg = G_define_option();
     inepsg->key = "epsg";
     inepsg->type = TYPE_INTEGER;
     inepsg->required = NO;
     inepsg->options = "1-1000000";
-    inepsg->guisection = _("Input");
+    inepsg->guisection = _("Specification");
     inepsg->description = _("EPSG projection code");
 #endif
@@ -172,16 +175,16 @@
     create = G_define_flag();
     create->key = 'c';
-    create->guisection = _("Create/Edit");
+    create->guisection = _("Modify");
     create->description = _("Create new projection files (modifies current "
-			    "location unless 'location' option specified)");
+			    "location)");
     location = G_define_option();
     location->key = "location";
     location->type = TYPE_STRING;
     location->key_desc = "name";
     location->required = NO;
-    location->guisection = _("Create/Edit");
+    location->guisection = _("Create");
     location->description = _("Name of new location to create");
     if (G_parser(argc, argv))
@@ -264,12 +267,16 @@
     else if (printwkt->answer)
 	print_wkt(esristyle->answer, dontprettify->answer);
 #endif
+    else if (location->answer)
+	create_location(location->answer);
     else if (create->answer)
-	create_location(location->answer);
+	modify_projinfo();
     else
-	G_warning(_("No output! Please specify an output option."));
+	G_fatal_error(_("No output format specified, define one "
+			"of flags -%c, -%c, -%c, or -%c"),
+		      printinfo->key, shellinfo->key, printproj4->key, printwkt->key);
     /* Tidy Up */
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c	2011-07-06 12:21:41 UTC (rev 47019)
+++ grass/trunk/general/g.proj/output.c	2011-07-06 12:29:40 UTC (rev 47020)
@@ -15,8 +15,6 @@
 #include <stdio.h>
-#include <string.h>
-#include <errno.h>
 #include <proj_api.h>
@@ -164,68 +162,6 @@
 #endif
-void create_location(char *location)
-    int ret;
-    if (location) {
-	ret = G__make_location(location, &cellhd, projinfo, projunits, NULL);
-	if (ret == 0)
-	    G_message(_("Location <%s> created"), location);
-	else if (ret == -1)
-	    G_fatal_error(_("Unable to create location <%s>: %s"),
-			  location, strerror(errno));
-	else if (ret == -2)
-			 G_fatal_error(_("Unable to create projection files: %s"),
-			  strerror(errno));
-	else
-	    /* Shouldn't happen */
-	    G_fatal_error(_("Unspecified error while creating new location"));
-    else {
-	/* Create flag given but no location specified; overwrite
-	 * projection files for current location */
-	const char *mapset = G_mapset();
-	struct Cell_head old_cellhd;
-	if (strcmp(mapset, "PERMANENT") != 0)
-	    G_fatal_error(_("You must select the PERMANENT mapset before updating the "
-			   "current location's projection. (Current mapset is %s)"),
-			  mapset);
-	/* Read projection information from current location first */
-	G_get_default_window(&old_cellhd);
-	char path[GPATH_MAX];
-	/* Write out the PROJ_INFO, and PROJ_UNITS if available. */
-	if (projinfo != NULL) {
-	    G_file_name(path, "", "PROJ_INFO", "PERMANENT");
-	    G_write_key_value_file(path, projinfo);
-	if (projunits != NULL) {
-	    G_file_name(path, "", "PROJ_UNITS", "PERMANENT");
-	    G_write_key_value_file(path, projunits);
-	if ((old_cellhd.zone != cellhd.zone) ||
-	    (old_cellhd.proj != cellhd.proj)) {
-	    /* Recreate the default, and current window files if projection
-	     * number or zone have changed */
-	    G__put_window(&cellhd, "", "DEFAULT_WIND");
-		G__put_window(&cellhd, "", "WIND");
-		G_message(_("N.B. The default region was updated to the new projection, but if you have "
-			    "multiple mapsets g.region -d should be run in each to update the region from "
-			    "the default."));
-	G_message(_("Projection information updated!"));
-    return;
 static int check_xy(int shell)
     if (cellhd.proj == PROJECTION_XY) {
