[GRASS-SVN] r47041 - grass/trunk/display/d.mon
Thu Jul 7 05:04:54 EDT 2011
Author: martinl
Date: 2011-07-07 02:04:54 -0700 (Thu, 07 Jul 2011)
New Revision: 47041
   grass/trunk/display/d.mon/main.c
   grass/trunk/display/d.mon/proto.h
   grass/trunk/display/d.mon/start.c
d.mon: add new options: 'width', 'height' and 'bgcolor'
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c	2011-07-07 08:56:17 UTC (rev 47040)
+++ grass/trunk/display/d.mon/main.c	2011-07-07 09:04:54 UTC (rev 47041)
@@ -23,7 +23,8 @@
 int main(int argc, char *argv[])
     struct GModule *module;
-    struct Option *start_opt, *select_opt, *stop_opt, *output_opt;
+    struct Option *start_opt, *select_opt, *stop_opt, *output_opt,
+      *width_opt, *height_opt, *bgcolor_opt;
     struct Flag *list_flag, *selected_flag, *select_flag, *release_flag;
     int nopts, ret;
@@ -35,7 +36,8 @@
     G_add_keyword(_("display"));
     G_add_keyword(_("graphics"));
     G_add_keyword(_("monitors"));
-    module->description = _("Controls graphics monitors.");
+    G_add_keyword(_("CLI"));
+    module->description = _("Controls graphics display monitors which can be controlled from the command line.");
     start_opt = G_define_option();
     start_opt->key = "start";
@@ -58,11 +60,29 @@
     select_opt->options = "wx0,wx1,wx2,wx3,wx4,wx5,wx6,wx7,png,ps,html,cairo";
     select_opt->guisection = _("Manage");
+    width_opt = G_define_option();
+    width_opt->key = "width";
+    width_opt->description = _("Width for display monitor if not set by GRASS_WIDTH");
+    width_opt->type = TYPE_INTEGER;
+    width_opt->key_desc = "value";
+    width_opt->guisection = _("Settings");
+    height_opt = G_define_option();
+    height_opt->key = "height";
+    height_opt->description = _("Height for display monitor if not set by GRASS_HEIGHT");
+    height_opt->type = TYPE_INTEGER;
+    height_opt->key_desc = "value";
+    height_opt->guisection = _("Settings");
+    bgcolor_opt = G_define_standard_option(G_OPT_C_BG);
+    bgcolor_opt->guisection = _("Settings");
     output_opt = G_define_standard_option(G_OPT_F_OUTPUT);
     output_opt->required = NO;
     output_opt->label = _("Name for output file (when starting new monitor)");
     output_opt->description = _("Ignored for 'wx' monitors");
+    output_opt->guisection = _("Settings");
     list_flag = G_define_flag();
     list_flag->key = 'l';
     list_flag->description = _("List running monitors and exit");
@@ -91,11 +111,14 @@
 	    G_warning(_("Flag -%c ignored"), list_flag->key);
 	mon = G__getenv("MONITOR");
 	if (selected_flag->answer) {
-	    if (mon)
+	    if (mon) {
+		G_message(_("Currently selected monitor:"));
 		fprintf(stdout, "%s\n", mon);
-	else {
+	else if (mon) {
 	    G_unsetenv("MONITOR");
+	    G_verbose_message(_("Monitor <%s> released"), mon);
 	if (!mon)
 	    G_important_message(_("No monitor selected"));
@@ -125,7 +148,8 @@
 	G_warning(_("Option <%s> ignored"), output_opt->key);
     if (start_opt->answer)
-	ret = start_mon(start_opt->answer, output_opt->answer, !select_flag->answer);
+	ret = start_mon(start_opt->answer, output_opt->answer, !select_flag->answer,
+			width_opt->answer, height_opt->answer, bgcolor_opt->answer);
     if (stop_opt->answer)
 	ret = stop_mon(stop_opt->answer);
Modified: grass/trunk/display/d.mon/proto.h
--- grass/trunk/display/d.mon/proto.h	2011-07-07 08:56:17 UTC (rev 47040)
+++ grass/trunk/display/d.mon/proto.h	2011-07-07 09:04:54 UTC (rev 47041)
@@ -1,5 +1,5 @@
 /* start */
-int start_mon(const char *, const char *, int);
+int start_mon(const char *, const char *, int, const char *, const char *, const char *);
 /* select.c */
 int select_mon(const char *);
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2011-07-07 08:56:17 UTC (rev 47040)
+++ grass/trunk/display/d.mon/start.c	2011-07-07 09:04:54 UTC (rev 47041)
@@ -7,38 +7,30 @@
 #include "proto.h"
 static void start(const char *, const char *);
-static void start_wx(const char *);
+static void start_wx(const char *, const char *, const char *,
+		     const char *, const char *);
+/* start file-based monitor */
 void start(const char *name, const char *output)
-    char *tempfile;
-    char *env_name, *env_value;
+    char *env_name;
+    if (!output)
+	return;
-    tempfile = G_tempfile();
     env_name = NULL;
-    G_asprintf(&env_name, "MONITOR_%s_ENVFILE", name);
-    G_asprintf(&env_value, "%s.env", tempfile);
-    G_setenv(env_name, env_value);
-    close(creat(env_value, 0666));
     G_asprintf(&env_name, "MONITOR_%s_MAPFILE", name);
     G_setenv(env_name, output);
-void start_wx(const char *name)
+/* start wxGUI display monitor */
+void start_wx(const char *name, const char *tempfile, const char *env_value,
+	      const char *width, const char *height)
     char progname[GPATH_MAX];
-    char *tempfile;
-    char *env_name, *map_value, *cmd_value, *env_value;
+    char *env_name, *map_value, *cmd_value;
+    env_name = NULL;
     G_asprintf(&env_name, "MONITOR_%s_CMDFILE", name);
     G_asprintf(&cmd_value, "%s.cmd", tempfile);
     G_setenv(env_name, cmd_value);
@@ -49,29 +41,62 @@
     G_setenv(env_name, map_value);
     /* close(creat(map_value, 0666)); */
-    G_debug(1, "start: name=%s ", name);
-    G_debug(1, "       cmdfile = %s", cmd_value);
-    G_debug(1, "       mapfile = %s", map_value);
-    G_debug(1, "       envfile = %s", env_value);
+    G_debug(3, "       cmdfile = %s", cmd_value);
+    G_debug(3, "       mapfile = %s", map_value);
     sprintf(progname, "%s/etc/gui/wxpython/gui_modules/mapdisp.py", G_gisbase());
     G_spawn_ex(getenv("GRASS_PYTHON"), progname, progname,
-	       name, map_value, cmd_value, env_value, SF_BACKGROUND, NULL);
+	       name, map_value, cmd_value, env_value, width ? width : "", height ? height : "", SF_BACKGROUND, NULL);
-int start_mon(const char *name, const char *output, int select)
+int start_mon(const char *name, const char *output, int select,
+	      const char *width, const char *height, const char *bgcolor)
     const char *curr_mon;
+    char *env_name, *env_value;
+    char *tempfile, buf[1024];
+    int env_fd;
     curr_mon = G__getenv("MONITOR");
     if (curr_mon && strcmp(curr_mon, name) == 0 && check_mon(curr_mon))
 	G_fatal_error(_("Monitor <%s> already running"), name);
+    tempfile = G_tempfile();
+    env_name = env_value = NULL;
+    G_asprintf(&env_name, "MONITOR_%s_ENVFILE", name);
+    G_asprintf(&env_value, "%s.env", tempfile);
+    G_setenv(env_name, env_value);
+    env_fd = creat(env_value, 0666);
+    if (env_fd < 0)
+	G_fatal_error(_("Unable to create file '%s'"), env_value);
+    if (width) {
+	sprintf(buf, "GRASS_WIDTH=%s\n", width);
+	write(env_fd, buf, strlen(buf));
+    if (height) {
+	sprintf(buf, "GRASS_HEIGHT=%s\n", height);
+    if (bgcolor) {
+	if (strcmp(bgcolor, "none") == 0)
+	    sprintf(buf, "GRASS_TRANSPARENT=TRUE\n");
+	else
+	    sprintf(buf, "GRASS_BACKGROUNDCOLOR=%s\n", bgcolor);
+    close(env_fd);
+    G_verbose_message(_("Staring monitor <%s> with env file '%s'"), name, env_value);
+    G_debug(1, "start: name=%s ", name);
+    G_debug(3, "       envfile = %s", env_value);
     if (select)
 	G_setenv("MONITOR", name);
     if (strncmp(name, "wx", 2) == 0) /* use G_strncasecmp() instead */
-	start_wx(name);
+	start_wx(name, tempfile, env_value, width, height);
     else
 	start(name, output);
