[GRASS-SVN] r47044 - grass/trunk/display/d.mon
Thu Jul 7 05:48:54 EDT 2011
Author: martinl
Date: 2011-07-07 02:48:54 -0700 (Thu, 07 Jul 2011)
New Revision: 47044
   grass/trunk/display/d.mon/list.c
   grass/trunk/display/d.mon/main.c
   grass/trunk/display/d.mon/proto.h
   grass/trunk/display/d.mon/start.c
d.mon: new flag `-c` to list command for selected monitor
Modified: grass/trunk/display/d.mon/list.c
--- grass/trunk/display/d.mon/list.c	2011-07-07 09:09:55 UTC (rev 47043)
+++ grass/trunk/display/d.mon/list.c	2011-07-07 09:48:54 UTC (rev 47044)
@@ -66,3 +66,26 @@
     return TRUE;
+/* list related commands for given monitor */
+void list_cmd(const char *name, FILE *fd_out)
+    char buf[1024];
+    char *cmd_name;
+    const char *cmd_value;
+    FILE *fd;
+    cmd_name = NULL;
+    G_asprintf(&cmd_name, "MONITOR_%s_CMDFILE", name);
+    cmd_value = G__getenv(cmd_name);
+    if (!cmd_value)
+	G_fatal_error(_("Command file not found"));
+    fd = fopen(cmd_value, "r");
+    if (!fd)
+	G_fatal_error(_("Unable to read command file"));
+    while (G_getl2(buf, sizeof(buf) - 1, fd) != 0) {
+	fprintf(fd_out, "%s\n", buf);
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c	2011-07-07 09:09:55 UTC (rev 47043)
+++ grass/trunk/display/d.mon/main.c	2011-07-07 09:48:54 UTC (rev 47044)
@@ -3,8 +3,8 @@
  * MODULE:       d.mon
  * AUTHOR(S):    Martin Landa <landa.martin gmail.com>
- * PURPOSE:      Controls map displays
- * COPYRIGHT:    (C) 2011 by the GRASS Development Team
+ * PURPOSE:      Controls graphics monitors for CLI
+ * COPYRIGHT:    (C) 2011 by Martin Landa, and the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
@@ -25,7 +25,8 @@
     struct GModule *module;
     struct Option *start_opt, *select_opt, *stop_opt, *output_opt,
       *width_opt, *height_opt, *bgcolor_opt;
-    struct Flag *list_flag, *selected_flag, *select_flag, *release_flag;
+    struct Flag *list_flag, *selected_flag, *select_flag, *release_flag,
+	*cmd_flag;
     int nopts, ret;
     const char *mon;
@@ -93,6 +94,11 @@
     selected_flag->description = _("Print name of currently selected monitor and exit");
     selected_flag->guisection = _("Print");
+    cmd_flag = G_define_flag();
+    cmd_flag->key = 'c';
+    cmd_flag->description = _("Print commands for currently selected monitor and exit");
+    cmd_flag->guisection = _("Print");
     select_flag = G_define_flag();
     select_flag->key = 's';
     select_flag->description = _("Do not automatically select when starting");
@@ -106,21 +112,25 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    if (selected_flag->answer || release_flag->answer) {
+    if (selected_flag->answer || release_flag->answer || cmd_flag->answer) {
 	if (list_flag->answer)
 	    G_warning(_("Flag -%c ignored"), list_flag->key);
 	mon = G__getenv("MONITOR");
-	if (selected_flag->answer) {
-	    if (mon) {
+	if (mon) {
+	    if (selected_flag->answer) {
 		G_message(_("Currently selected monitor:"));
 		fprintf(stdout, "%s\n", mon);
+	    else if (cmd_flag->answer) {
+		G_message(_("List of commands for monitor <%s>:"), mon);
+		list_cmd(mon, stdout);
+	    else if (mon) { /* release */
+		G_unsetenv("MONITOR");
+		G_verbose_message(_("Monitor <%s> released"), mon);
-	else if (mon) {
-	    G_unsetenv("MONITOR");
-	    G_verbose_message(_("Monitor <%s> released"), mon);
-	if (!mon)
+	else
 	    G_important_message(_("No monitor selected"));
 	exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.mon/proto.h
--- grass/trunk/display/d.mon/proto.h	2011-07-07 09:09:55 UTC (rev 47043)
+++ grass/trunk/display/d.mon/proto.h	2011-07-07 09:48:54 UTC (rev 47044)
@@ -11,3 +11,4 @@
 void list_mon();
 void print_list(FILE *);
 int check_mon(const char *);
+void list_cmd(const char *, FILE *);
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2011-07-07 09:09:55 UTC (rev 47043)
+++ grass/trunk/display/d.mon/start.c	2011-07-07 09:48:54 UTC (rev 47044)
@@ -8,7 +8,7 @@
 static void start(const char *, const char *);
 static void start_wx(const char *, const char *, const char *,
-		     const char *, const char *);
+		     const char *, const char *, const char *);
 /* start file-based monitor */
 void start(const char *name, const char *output)
@@ -24,24 +24,19 @@
 /* start wxGUI display monitor */
-void start_wx(const char *name, const char *tempfile, const char *env_value,
+void start_wx(const char *name, const char *tempfile,
+	      const char *env_value, const char *cmd_value,
 	      const char *width, const char *height)
     char progname[GPATH_MAX];
-    char *env_name, *map_value, *cmd_value;
+    char *env_name, *map_value;
     env_name = NULL;
-    G_asprintf(&env_name, "MONITOR_%s_CMDFILE", name);
-    G_asprintf(&cmd_value, "%s.cmd", tempfile);
-    G_setenv(env_name, cmd_value);
-    close(creat(cmd_value, 0666));
     G_asprintf(&env_name, "MONITOR_%s_MAPFILE", name);
     G_asprintf(&map_value, "%s.ppm", tempfile);
     G_setenv(env_name, map_value);
     /* close(creat(map_value, 0666)); */
-    G_debug(3, "       cmdfile = %s", cmd_value);
     G_debug(3, "       mapfile = %s", map_value);
     sprintf(progname, "%s/etc/gui/wxpython/gui_modules/mapdisp.py", G_gisbase());
@@ -53,7 +48,7 @@
 	      const char *width, const char *height, const char *bgcolor)
     const char *curr_mon;
-    char *env_name, *env_value;
+    char *env_name, *env_value, *cmd_value;
     char *tempfile, buf[1024];
     int env_fd;
@@ -87,16 +82,24 @@
     close(env_fd);
+    cmd_value = NULL;
+    G_asprintf(&env_name, "MONITOR_%s_CMDFILE", name);
+    G_asprintf(&cmd_value, "%s.cmd", tempfile);
+    G_setenv(env_name, cmd_value);
+    close(creat(cmd_value, 0666));
     G_verbose_message(_("Staring monitor <%s> with env file '%s'"), name, env_value);
     G_debug(1, "start: name=%s ", name);
     G_debug(3, "       envfile = %s", env_value);
+    G_debug(3, "       cmdfile = %s", cmd_value);
     if (select)
 	G_setenv("MONITOR", name);
     if (strncmp(name, "wx", 2) == 0) /* use G_strncasecmp() instead */
-	start_wx(name, tempfile, env_value, width, height);
+	start_wx(name, tempfile, env_value, cmd_value,
+		 width, height);
     else
 	start(name, output);
