[GRASS-SVN] r47050 - grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
Thu Jul 7 15:10:26 EDT 2011
Author: madi
Date: 2011-07-07 12:10:26 -0700 (Thu, 07 Jul 2011)
New Revision: 47050
   grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
working copy gsoc 2011
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py	2011-07-07 17:17:55 UTC (rev 47049)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py	2011-07-07 19:10:26 UTC (rev 47050)
@@ -20,10 +20,124 @@
 sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython', 'gui_modules'))
+import wx
+import wx.aui
+from debug import Debug as Debug
+from preferences import globalSettings as UserSettings
+import grass.script as grass
+import gselect
+import gcmd
+import dbm
 import globalvar
+import utils
+import menuform
-import wx
+## #-------------Panels-------------
+# First panel # Network extraction
+class TabPanelOne(wx.Panel):
+    def __init__(self, parent):
+        wx.Panel.__init__(self, parent, id = wx.ID_ANY)
+        self.parent = parent
+        # define the panel for select maps
+	self.panel = wx.Panel(self)
+        # define gselect
+        self.mapselect = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
+                                    type = 'rast', multiple = False)
+        # binder of gselect
+        self.mapselect.Bind(wx.EVT_TEXT, self.OnSelect)
+	# create the layout
+        self._layout()
+    def _layout(self):
+	# create the grid for gselect
+        select = wx.GridBagSizer(8, 5)
+        # Ask user for digital elevation model
+        text1 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "Elevation") #FIXME text does not appear
+        select.Add(item = text1, flag = wx.LEFT, pos = (1,0),span = (1,2))
+        select.Add(item = self.mapselect, pos = (2,0),
+                     span = (1,2))
+        self.SetSizer(select)
+        btnPanel = wx.Panel(self)
+        #-------------Buttons-------------
+        self.createButtonBar(btnPanel)
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        sizer.Add(self.panel, 1, wx.EXPAND)
+        sizer.Add(btnPanel, 0, wx.EXPAND)
+        self.SetSizer(sizer)
+    def OnSelect(self, event):
+            """!Gets raster map or function selection and send it to
+            insertion method
+            item = event.GetString()
+            self._addSomething(item)
+    def buttonData(self):
+        return (("Update Preview", self.OnPreview),
+                ("Run Analysis", self.OnRun))
+    def createButtonBar(self, panel, yPos = 0):
+        xPos = 0
+        for eachLabel, eachHandler in self.buttonData():
+            pos = (xPos, yPos)
+            button = self.buildOneButton(panel, eachLabel, eachHandler, pos)
+            xPos += button.GetSize().width
+    def buildOneButton(self, parent, label, handler, pos = (0,0)):
+        button = wx.Button(parent, wx.ID_ANY, label, pos)
+        self.Bind(wx.EVT_BUTTON, handler, button)
+        return button
+    def OnPreview(self, event):
+        pass
+    def OnRun(self, event):
+        pass
+# Child panel class before customization
+class TabPanel(wx.Panel):
+        wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
+        txtOne = wx.TextCtrl(self, wx.ID_ANY, "")
+        txtTwo = wx.TextCtrl(self, wx.ID_ANY, "")
+        sizer.Add(txtOne, 0, wx.ALL, 5)
+        sizer.Add(txtTwo, 0, wx.ALL, 5)
+## #-------------Main Frame-------------
 class RStreamFrame(wx.Frame):
     def __init__(self, parent = None, id = wx.ID_ANY,
                  title = _("GRASS GIS Hydrological Modelling Utility"), **kwargs):
@@ -38,7 +152,40 @@
         wx.Frame.__init__(self, parent = parent, id = id, title = title, name = "RStream", **kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
+        #panel = ParentPanel(self)
+        # create the AuiNotebook instance
+        nb = wx.aui.AuiNotebook(self)
+        # add some pages to the notebook
+        pages = [(TabPanelOne(nb), "Network extraction"),
+                 (TabPanel(nb), "Tab 2"),
+                 (TabPanel(nb), "Tab 3")]
+        for page, label in pages:
+            nb.AddPage(page, label)
+        sizer.Add(nb, 1, wx.EXPAND)
+        # button for close and other
+        button = wx.BoxSizer(wx.HORIZONTAL)
+        self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+        button.Add(item=self.btn_close,flag = wx.ALL, border = 5)
+        sizer.Add(button)
+    def OnClose(self, event):
+        self.Destroy()
+        self.Show()
 def main():
     app = wx.PySimpleApp()
     wx.InitAllImageHandlers()
@@ -50,3 +197,4 @@
 if __name__ == "__main__":
     main()
