[GRASS-SVN] r47057 - grass-addons/grass7/gui/wxpython/wx.wms
Fri Jul 8 00:13:12 EDT 2011
Author: sudeepsingh
Date: 2011-07-07 21:13:12 -0700 (Thu, 07 Jul 2011)
New Revision: 47057
Removed:
   grass-addons/grass7/gui/wxpython/wx.wms/core.diff
   grass-addons/grass7/gui/wxpython/wx.wms/default.png
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/core.diff
--- grass-addons/grass7/gui/wxpython/wx.wms/core.diff	2011-07-08 04:08:04 UTC (rev 47056)
+++ grass-addons/grass7/gui/wxpython/wx.wms/core.diff	2011-07-08 04:13:12 UTC (rev 47057)
@@ -1,100 +0,0 @@
-Index: gui/wxpython/wxgui.py
---- gui/wxpython/wxgui.py	(revision 46749)
-+++ gui/wxpython/wxgui.py	(working copy)
-@@ -81,6 +81,7 @@
- from gui_modules import gmodeler
- from gui_modules import vclean
- from gui_modules import nviz_tools
-+from gui_modules.wmsmenu import func as func1 #sudeep
- from gui_modules.debug    import Debug
- from gui_modules.ghelp    import MenuTreeWindow, AboutWindow, InstallExtensionWindow
- from gui_modules.toolbars import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar, LMMiscToolbar
-@@ -1176,10 +1177,64 @@
-         # show ATM window
-         dbmanager.Show()
-+    def OnNewDisplay1(self, event = None):
-+        """!Create new layer tree and map display instance"""
-+        self.NewDisplay1()
-+    def NewDisplay1(self, show = True):
-+        Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
-+    	func1()
-+        """!Create new layer tree, which will
-+        create an associated map display frame
-+        @param show show map display window if True
-+        @return reference to mapdisplay intance
-+  	'''      Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
-+        # make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
-+        self.pg_panel = wx.Panel(self.gm_cb, id = wx.ID_ANY, style = wx.EXPAND)
-+        self.gm_cb.AddPage(self.pg_panel, text = "Display "+ str(self.disp_idx + 1), select = True)
-+        self.curr_page = self.gm_cb.GetCurrentPage()
-+        # create layer tree (tree control for managing GIS layers)  and put on new notebook page
-+        self.curr_page.maptree = layertree.LayerTree(self.curr_page, id = wx.ID_ANY, pos = wx.DefaultPosition,
-+                                                     size = wx.DefaultSize, style = wx.TR_HAS_BUTTONS |
-+                                                     wx.TR_LINES_AT_ROOT| wx.TR_HIDE_ROOT |
-+                                                     wx.TR_DEFAULT_STYLE| wx.NO_BORDER | wx.FULL_REPAINT_ON_RESIZE,
-+                                                     idx = self.disp_idx, lmgr = self, notebook = self.gm_cb,
-+                                                     auimgr = self._auimgr, showMapDisplay = show)
-+        # layout for controls
-+        cb_boxsizer = wx.BoxSizer(wx.VERTICAL)
-+        cb_boxsizer.Add(self.curr_page.maptree, proportion = 1, flag = wx.EXPAND, border = 1)
-+        self.curr_page.SetSizer(cb_boxsizer)
-+        cb_boxsizer.Fit(self.curr_page.maptree)
-+        self.curr_page.Layout()
-+        self.curr_page.maptree.Layout()
-+        # use default window layout
-+        if UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled'):
-+            dim = UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'dim')
-+            idx = 4 + self.disp_idx * 4
-+            try:
-+                x, y = map(int, dim.split(',')[idx:idx + 2])
-+                w, h = map(int, dim.split(',')[idx + 2:idx + 4])
-+                self.curr_page.maptree.mapdisplay.SetPosition((x, y))
-+                self.curr_page.maptree.mapdisplay.SetSize((w, h))
-+            except:
-+                pass
-+        self.disp_idx += 1
-+        return self.curr_page.maptree.mapdisplay'''
-     def OnNewDisplay(self, event = None):
-         """!Create new layer tree and map display instance"""
-         self.NewDisplay()
-     def NewDisplay(self, show = True):
-         """!Create new layer tree, which will
-         create an associated map display frame
-Index: gui/wxpython/gui_modules/toolbars.py
---- gui/wxpython/gui_modules/toolbars.py	(revision 46749)
-+++ gui/wxpython/gui_modules/toolbars.py	(working copy)
-@@ -270,6 +270,8 @@
-         icons = Icons['displayWindow']
-         return self._getToolbarData((('displaymap', icons['display'],
-                                       self.parent.OnDraw),
-+                                      ('displaymap', icons['display'],
-+                                      self.parent.OnDraw),
-                                      ('rendermap', icons['render'],
-                                       self.parent.OnRender),
-                                      ('erase', icons['erase'],
-@@ -1472,6 +1474,8 @@
-         icons = Icons['layerManager']
-         return self._getToolbarData((('newdisplay', icons["newdisplay"],
-                                       self.parent.OnNewDisplay),
-+                                      ('newdisplay', icons["newdisplay"],
-+                                      self.parent.OnNewDisplay1),
-                                      (None, ),
-                                      ('workspaceNew', icons["workspaceNew"],
-                                       self.parent.OnWorkspaceNew),
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/default.png
(Binary files differ)
