[GRASS-SVN] r47062 - grass/trunk/visualization/nviz2/cmd
Fri Jul 8 09:34:04 EDT 2011
Author: annakrat
Date: 2011-07-08 06:34:04 -0700 (Fri, 08 Jul 2011)
New Revision: 47062
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/volume.c
nviz_cmd: volumes: add transparency, shininess, color, shading, position, resolution settings
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2011-07-08 09:44:31 UTC (rev 47061)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2011-07-08 13:34:04 UTC (rev 47062)
@@ -600,7 +600,61 @@
     params->isosurf_level->multiple = YES;
     params->isosurf_level->description = _("Isosurface level");
     params->isosurf_level->guisection = _("Volumes");
+    /* isosurface color map */
+    params->isosurf_color_map = G_define_standard_option(G_OPT_R3_MAPS);
+    params->isosurf_color_map->key = "isosurf_color_map";
+    params->isosurf_color_map->required = NO;
+    params->isosurf_color_map->multiple = YES;
+    params->isosurf_color_map->description = _("Name of volume for isosurface color");
+    params->isosurf_color_map->guisection = _("Volumes");
+    /* isosurface color value */
+    params->isosurf_color_const = G_define_standard_option(G_OPT_C_FG);
+    params->isosurf_color_const->key = "isosurf_color_value";
+    params->isosurf_color_const->required = NO;
+    params->isosurf_color_const->multiple = YES;
+    params->isosurf_color_const->label = _("Isosurface color");
+    params->isosurf_color_const->guisection = _("Volumes");
+    params->isosurf_color_const->answer = NULL;
+    /* isosurface transparency */
+    params->isosurf_transp_map = G_define_standard_option(G_OPT_R3_MAP);
+    params->isosurf_transp_map->multiple = YES;
+    params->isosurf_transp_map->required = NO;
+    params->isosurf_transp_map->description =
+	_("Name of 3D raster map(s) for transparency");
+    params->isosurf_transp_map->guisection = _("Volumes");
+    params->isosurf_transp_map->key = "isosurf_transparency_map";
+    params->isosurf_transp_const = G_define_option();
+    params->isosurf_transp_const->key = "isosurf_transparency_value";
+    params->isosurf_transp_const->key_desc = "value";
+    params->isosurf_transp_const->type = TYPE_INTEGER;
+    params->isosurf_transp_const->required = NO;
+    params->isosurf_transp_const->multiple = YES;
+    params->isosurf_transp_const->description = _("Transparency value(s)for isosurfaces");
+    params->isosurf_transp_const->guisection = _("Volumes");
+    params->isosurf_transp_const->options = "0-255";
+    /* isosurface shininess */
+    params->isosurf_shine_map = G_define_standard_option(G_OPT_R3_MAP);
+    params->isosurf_shine_map->multiple = YES;
+    params->isosurf_shine_map->required = NO;
+    params->isosurf_shine_map->description = _("Name of 3D raster map(s) for shininess");
+    params->isosurf_shine_map->guisection = _("Volumes");
+    params->isosurf_shine_map->key = "isosurf_shininess_map";
+    params->isosurf_shine_const = G_define_option();
+    params->isosurf_shine_const->key = "isosurf_shininess_value";
+    params->isosurf_shine_const->key_desc = "value";
+    params->isosurf_shine_const->type = TYPE_INTEGER;
+    params->isosurf_shine_const->required = NO;
+    params->isosurf_shine_const->multiple = YES;
+    params->isosurf_shine_const->description = _("Shininess value(s) for isosurfaces");
+    params->isosurf_shine_const->guisection = _("Volumes");
+    params->isosurf_shine_const->options = "0-255";
     return;
@@ -671,7 +725,6 @@
     params->cplane_rot->type = TYPE_DOUBLE;
     params->cplane_rot->multiple = YES;
     params->cplane_rot->required = NO;
-    params->cplane_rot->label = _("Cutting plane rotation along the vertical axis");
     params->cplane_rot->guisection = _("Cutting planes");
     params->cplane_rot->description = _("Cutting plane rotation along the vertical axis");
     params->cplane_rot->answer = "0";
@@ -683,7 +736,6 @@
     params->cplane_tilt->type = TYPE_DOUBLE;
     params->cplane_tilt->multiple = YES;
     params->cplane_tilt->required = NO;
-    params->cplane_tilt->label = _("Cutting plane tilt");
     params->cplane_tilt->guisection = _("Cutting planes");
     params->cplane_tilt->description = _("Cutting plane tilt");
     params->cplane_tilt->answer = "0";
@@ -695,7 +747,6 @@
     params->cplane_shading->type = TYPE_STRING;
     params->cplane_shading->multiple = NO;
     params->cplane_shading->required = NO;
-    params->cplane_shading->label = _("Cutting plane color (between two surfaces)");
     params->cplane_shading->guisection = _("Cutting planes");
     params->cplane_shading->description = _("Cutting plane color (between two surfaces)");
     params->cplane_shading->answer = "clear";
@@ -767,6 +818,8 @@
     int nvlines;
     int nvpoints;
+    int nvolumes, nisosurf;
     /* topography */
     nelev_map = opt_get_num_answers(params->elev_map);
@@ -911,14 +964,38 @@
 		      params->vlines->key, nvlines, params->vline_pos->key,
 		      nconsts);
-    return;
      * vector points
     nvpoints = opt_get_num_answers(params->vpoints);
     /* TODO */
+     * volumes
+    nvolumes = opt_get_num_answers(params->volume);
+    nisosurf = opt_get_num_answers(params->isosurf_level);
+    /* transparency */
+    nmaps = opt_get_num_answers(params->isosurf_transp_map);
+    nconsts = opt_get_num_answers(params->isosurf_transp_const);
+    if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"),
+		      params->isosurf_level->key, nisosurf, params->isosurf_transp_map->key, nmaps,
+		      params->isosurf_transp_const->key, nconsts);
+    /* shininess */
+    nmaps = opt_get_num_answers(params->isosurf_shine_map);
+    nconsts = opt_get_num_answers(params->isosurf_shine_const);
+		    params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
+		    params->isosurf_shine_const->key, nconsts);
+    return;
 void print_error(int nmaps, int nconsts, int nelevs,
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-07-08 09:44:31 UTC (rev 47061)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-07-08 13:34:04 UTC (rev 47062)
@@ -22,6 +22,8 @@
 	*vpoint_layer, *vpoint_size_column, *vpoint_marker_column, *vpoint_color_column, *vpoint_width_column,
     /* volumes */
 	*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
+	*isosurf_color_map, *isosurf_color_const, *isosurf_transp_map, *isosurf_transp_const,
+	*isosurf_shine_map, *isosurf_shine_const,
     /* misc */
 	*exag, *bgcolor,
     /* cutting planes */
Modified: grass/trunk/visualization/nviz2/cmd/volume.c
--- grass/trunk/visualization/nviz2/cmd/volume.c	2011-07-08 09:44:31 UTC (rev 47061)
+++ grass/trunk/visualization/nviz2/cmd/volume.c	2011-07-08 13:34:04 UTC (rev 47062)
@@ -29,7 +29,8 @@
 int load_rasters3d(const struct GParams *params, nv_data *data)
-  int i, nvol, id;
+    int i, nvol, id;
+    float x, y, z;
     char *mapset;
     nvol = opt_get_num_answers(params->volume);
@@ -45,6 +46,20 @@
 			      G_fully_qualified_name(params->volume->answers[i],
 						     mapset),
 			      0.0, data);
+	/* set position */
+	if (opt_get_num_answers(params->volume_pos) != 3 * nvol) {
+	    x = atof(params->volume_pos->answers[0]);
+	    y = atof(params->volume_pos->answers[1]);
+	    z = atof(params->volume_pos->answers[2]);
+	else {
+	    x = atof(params->volume_pos->answers[i*3+0]);
+	    y = atof(params->volume_pos->answers[i*3+1]);
+	    z = atof(params->volume_pos->answers[i*3+2]);
+	GVL_set_trans(id, x, y, z);
     return 1;
@@ -62,7 +77,10 @@
     int i;
     int num, level, nvols, *vol_list, id, nisosurfs;
+    int ncolor_map, ncolor_const, ntransp_map, ntransp_const, nshine_map, nshine_const;
+    int res, draw_mode;
     char **tokens;
+    const char *mapset, *style;
     vol_list = GVL_get_vol_list(&nvols);
@@ -94,12 +112,98 @@
 			  nisosurfs-1, ATT_TOPO, id);
+	/* set resolution */
+	if (opt_get_num_answers(params->volume_res) != nvols)
+	    res = atof(params->volume_res->answers[0]);
+	else
+	    res = atof(params->volume_res->answers[i]);
+	GVL_isosurf_set_drawres(id, res, res, res);
+	/* set shading */
+	if (opt_get_num_answers(params->volume_shade) != nvols)
+	    style = params->volume_shade->answers[0];
+	else
+	    style = params->volume_shade->answers[i];
+	draw_mode = 0;
+	if (strcmp(style, "flat") == 0) {
+	    draw_mode |= DM_FLAT;
+	else {
+	    draw_mode |= DM_GOURAUD;
+	GVL_isosurf_set_drawmode(id, draw_mode);
 	/* color */
-	if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[0]) < 0) {
-	    G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
-			  nisosurfs-1, ATT_COLOR, id);
+	ncolor_map = opt_get_num_answers(params->isosurf_color_map);
+	ncolor_const = opt_get_num_answers(params->isosurf_color_const);
+	if (i < ncolor_map && strcmp(params->isosurf_color_map->answers[i], "")) {
+	    mapset = G_find_grid3(params->isosurf_color_map->answers[i], "");
+	    if (mapset == NULL) {
+		G_fatal_error(_("3d raster map <%s> not found"),
+			      params->isosurf_color_map->answers[i]);
+	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR,
+					params->isosurf_color_map->answers[i]) < 0)
+		G_fatal_error(_("Unable to set isosurface (%d) attribute (%d) of volume %d"),
+				nisosurfs-1, ATT_COLOR, id);
+	else if (i-ncolor_map < ncolor_const &&
+		 strcmp(params->isosurf_color_const->answers[i-ncolor_map], "")) {
+	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_COLOR,
+			    Nviz_color_from_str(params->isosurf_color_const->answers[i-ncolor_map])) < 0)
+	else {			/* use by default 3d raster map for coloring */
+	    GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_COLOR, params->volume->answers[num-1]);
+	    G_verbose_message(_("Color attribute not defined, using default <%s>"),
+				params->volume->answers[num-1]);
+	ntransp_map = opt_get_num_answers(params->isosurf_transp_map);
+	ntransp_const = opt_get_num_answers(params->isosurf_transp_const);
+	if (i < ntransp_map && strcmp(params->isosurf_transp_map->answers[i], "")) {
+	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_TRANSP,
+					params->isosurf_transp_map->answers[i]) < 0)
+				nisosurfs-1, ATT_TRANSP, id);
+	else if (i-ntransp_map < ntransp_const &&
+		 strcmp(params->isosurf_transp_const->answers[i-ntransp_map], "")) {
+	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_TRANSP,
+					  atof(params->isosurf_transp_const->answers[i-ntransp_map])) < 0)
+	/* shine */
+	nshine_map = opt_get_num_answers(params->isosurf_shine_map);
+	nshine_const = opt_get_num_answers(params->isosurf_shine_const);
+	if (i < nshine_map && strcmp(params->isosurf_shine_map->answers[i], "")) {
+	    if (GVL_isosurf_set_att_map(id, nisosurfs-1, ATT_SHINE,
+					params->isosurf_shine_map->answers[i]) < 0)
+				nisosurfs-1, ATT_SHINE, id);
+	else if (i-nshine_map < nshine_const &&
+		 strcmp(params->isosurf_shine_const->answers[i-nshine_map], "")) {
+	    if (GVL_isosurf_set_att_const(id, nisosurfs-1, ATT_SHINE,
+					  atof(params->isosurf_shine_const->answers[i-nshine_map])) < 0)
     return 1;
