[GRASS-SVN] r47067 - grass/trunk/gui/wxpython/gui_modules
Sat Jul 9 02:06:41 EDT 2011
Author: cmbarton
Date: 2011-07-08 23:06:41 -0700 (Fri, 08 Jul 2011)
New Revision: 47067
   grass/trunk/gui/wxpython/gui_modules/preferences.py
Use native font dialog for command output font
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-07-08 16:29:19 UTC (rev 47066)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py	2011-07-09 06:06:41 UTC (rev 47067)
@@ -2081,42 +2081,33 @@
     def OnSetOutputFont(self, event):
         """'Set output font' button pressed
-        dlg = DefaultFontDialog(parent = self,
-                                title = _('Select output font'),
-                                style = wx.DEFAULT_DIALOG_STYLE,
-                                type = 'outputfont')
-        if dlg.ShowModal() == wx.ID_OK:
-            # set output font and font size variables
-            if dlg.font:
-                self.settings.Set(group = 'appearance', value = dlg.font,
-                                  key = 'outputfont', subkey = 'type')
-                self.settings.Set(group = 'appearance', value = dlg.fontsize,
-                                  key = 'outputfont', subkey = 'size')
-# Standard font dialog broken for Mac in OS X 10.6
-#        type = self.settings.Get(group = 'display', key = 'outputfont', subkey = 'type')
+        type = self.settings.Get(group = 'appearance', key = 'outputfont', subkey = 'type')
-#        size = self.settings.Get(group = 'display', key = 'outputfont', subkey = 'size')
-#        if size == None or size == 0: size = 10
-#        size = float(size)
+        size = self.settings.Get(group = 'appearance', key = 'outputfont', subkey = 'size')
+        if size == None or size == 0: size = 11
+        size = float(size)
+        if type == None or type == '': type = 'Courier'
-#        data = wx.FontData()
-#        data.EnableEffects(True)
-#        data.SetInitialFont(wx.Font(pointSize = size, family = wx.FONTFAMILY_MODERN, faceName = type, style = wx.NORMAL, weight = 0))
+        outfont = wx.Font(size, wx.FONTFAMILY_MODERN, wx.NORMAL, 0, faceName = type)
+        fontdata = wx.FontData()
+        fontdata.EnableEffects(True)
+        fontdata.SetColour('black')
+        fontdata.SetInitialFont(outfont)
+        dlg = wx.FontDialog(self, fontdata)
+        'FIXME: native font dialog does not initialize with current font'
-#        dlg = wx.FontDialog(self, data)
+        if dlg.ShowModal() == wx.ID_OK:
+            outdata = dlg.GetFontData()
+            font = outdata.GetChosenFont()
-#        if dlg.ShowModal() == wx.ID_OK:
-#            data = dlg.GetFontData()
-#            font = data.GetChosenFont()
-#            self.settings.Set(group = 'display', value = font.GetFaceName(),
-#                                  key = 'outputfont', subkey = 'type')
-#            self.settings.Set(group = 'display', value = font.GetPointSize(),
-#                                  key = 'outputfont', subkey = 'size')
+            self.settings.Set(group = 'appearance', value = font.GetFaceName(),
+                                  key = 'outputfont', subkey = 'type')
+            self.settings.Set(group = 'appearance', value = font.GetPointSize(),
+                                  key = 'outputfont', subkey = 'size')
         dlg.Destroy()
         event.Skip()
