[GRASS-SVN] r47083 - grass/trunk/display/d.mon
Sat Jul 9 15:41:05 EDT 2011
Author: martinl
Date: 2011-07-09 12:41:05 -0700 (Sat, 09 Jul 2011)
New Revision: 47083
   grass/trunk/display/d.mon/main.c
   grass/trunk/display/d.mon/proto.h
   grass/trunk/display/d.mon/start.c
d.mon: true color output by default
       add flag to disable true colors
Modified: grass/trunk/display/d.mon/main.c
--- grass/trunk/display/d.mon/main.c	2011-07-09 19:39:40 UTC (rev 47082)
+++ grass/trunk/display/d.mon/main.c	2011-07-09 19:41:05 UTC (rev 47083)
@@ -26,7 +26,7 @@
     struct Option *start_opt, *select_opt, *stop_opt, *output_opt,
       *width_opt, *height_opt, *bgcolor_opt;
     struct Flag *list_flag, *selected_flag, *select_flag, *release_flag,
-	*cmd_flag;
+	*cmd_flag, *truecolor_flag;
     int nopts, ret;
     const char *mon;
@@ -109,6 +109,11 @@
     release_flag->description = _("Release currently selected monitor and exit");
     release_flag->guisection = _("Manage");
+    truecolor_flag = G_define_flag();
+    truecolor_flag->key = 't';
+    truecolor_flag->description = _("Disable true colors");
+    truecolor_flag->guisection = _("Manage");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -159,7 +164,8 @@
     if (start_opt->answer)
 	ret = start_mon(start_opt->answer, output_opt->answer, !select_flag->answer,
-			width_opt->answer, height_opt->answer, bgcolor_opt->answer);
+			width_opt->answer, height_opt->answer, bgcolor_opt->answer,
+			!truecolor_flag->answer);
     if (stop_opt->answer)
 	ret = stop_mon(stop_opt->answer);
Modified: grass/trunk/display/d.mon/proto.h
--- grass/trunk/display/d.mon/proto.h	2011-07-09 19:39:40 UTC (rev 47082)
+++ grass/trunk/display/d.mon/proto.h	2011-07-09 19:41:05 UTC (rev 47083)
@@ -1,5 +1,6 @@
 /* start */
-int start_mon(const char *, const char *, int, const char *, const char *, const char *);
+int start_mon(const char *, const char *, int, const char *,
+	      const char *, const char *, int);
 /* select.c */
 int select_mon(const char *);
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2011-07-09 19:39:40 UTC (rev 47082)
+++ grass/trunk/display/d.mon/start.c	2011-07-09 19:41:05 UTC (rev 47083)
@@ -45,7 +45,8 @@
 int start_mon(const char *name, const char *output, int select,
-	      const char *width, const char *height, const char *bgcolor)
+	      const char *width, const char *height, const char *bgcolor,
+	      int truecolor)
     const char *curr_mon;
     char *env_name, *env_value, *cmd_value;
@@ -80,6 +81,10 @@
 	    sprintf(buf, "GRASS_BACKGROUNDCOLOR=%s\n", bgcolor);
 	write(env_fd, buf, strlen(buf));
+    if (truecolor) {
+	sprintf(buf, "GRASS_TRUECOLOR=TRUE\n");
+	write(env_fd, buf, strlen(buf));
     close(env_fd);
     cmd_value = NULL;
