[GRASS-SVN] r47100 - grass-addons/grass7/gui/wxpython/wx.wms
Tue Jul 12 14:54:28 EDT 2011
Author: sudeepsingh
Date: 2011-07-12 11:54:28 -0700 (Tue, 12 Jul 2011)
New Revision: 47100
Removed:
   grass-addons/grass7/gui/wxpython/wx.wms/toolbars.py
   grass-addons/grass7/gui/wxpython/wx.wms/wxgui.py
core.diff contains the changes, removing core files
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.wms/toolbars.py	2011-07-12 18:50:35 UTC (rev 47099)
+++ grass-addons/grass7/gui/wxpython/wx.wms/toolbars.py	2011-07-12 18:54:28 UTC (rev 47100)
@@ -1,1641 +0,0 @@
- at package toolbar
- at brief wxGUI toolbar widgets
-Classes:
- - AbstractToolbar
- - MapToolbar
- - GCPMapToolbar
- - GCPDisplayToolbar
- - VDigitToolbar
- - ProfileToolbar
- - NvizToolbar
- - ModelToolbar
- - HistogramToolbar
- - LMWorkspaceToolbar
- - LMDataToolbar
- - LMToolsToolbar
- - LMMiscToolbar
- - PsMapToolbar
-(C) 2007-2011 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Michael Barton
- at author Jachym Cepicky
- at author Martin Landa <landa.martin gmail.com>
- at author Anna Kratochvilova <anna.kratochvilova fsv.cvut.cz>
-import os
-import sys
-import platform
-from grass.script import core as grass
-import wx
-import globalvar
-import gcmd
-import gdialogs
-from vdigit import VDigitSettingsDialog, haveVDigit, VDigit
-from debug import Debug
-from preferences import globalSettings as UserSettings
-from nviz import haveNviz
-from nviz_preferences import NvizPreferencesDialog
-sys.path.append(os.path.join(globalvar.ETCWXDIR, "icons"))
-from icon import Icons
-class AbstractToolbar(wx.ToolBar):
-    """!Abstract toolbar class"""
-    def __init__(self, parent):
-        self.parent = parent
-        wx.ToolBar.__init__(self, parent = self.parent, id = wx.ID_ANY)
-        self.action = dict()
-        self.Bind(wx.EVT_TOOL, self.OnTool)
-        self.SetToolBitmapSize(globalvar.toolbarSize)
-    def InitToolbar(self, toolData):
-        """!Initialize toolbar, add tools to the toolbar
-        for tool in toolData:
-            self.CreateTool(*tool)
-        self._data = toolData
-    def _toolbarData(self):
-        """!Toolbar data (virtual)"""
-        return None
-    def CreateTool(self, label, bitmap, kind,
-                   shortHelp, longHelp, handler):
-        """!Add tool to the toolbar
-        @return id of tool
-        bmpDisabled = wx.NullBitmap
-        tool = -1
-        if label:
-            tool = vars(self)[label] = wx.NewId()
-            Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
-                          (tool, label, bitmap))
-            toolWin = self.AddLabelTool(tool, label, bitmap,
-                                        bmpDisabled, kind,
-                                        shortHelp, longHelp)
-            self.Bind(wx.EVT_TOOL, handler, toolWin)
-        else: # separator
-            self.AddSeparator()
-        return tool
-    def EnableLongHelp(self, enable = True):
-        """!Enable/disable long help
-        @param enable True for enable otherwise disable
-        for tool in self._data:
-            if tool[0] == '': # separator
-                continue
-            if enable:
-                self.SetToolLongHelp(vars(self)[tool[0]], tool[4])
-            else:
-                self.SetToolLongHelp(vars(self)[tool[0]], "")
-    def OnTool(self, event):
-        """!Tool selected
-        if self.parent.GetName() == "GCPFrame":
-            return
-        if hasattr(self.parent, 'toolbars'):
-            if self.parent.toolbars['vdigit']:
-                # update vdigit toolbar (unselect currently selected tool)
-                id = self.parent.toolbars['vdigit'].GetAction(type = 'id')
-                self.parent.toolbars['vdigit'].ToggleTool(id, False)
-        if event:
-            # deselect previously selected tool
-            id = self.action.get('id', -1)
-            if id != event.GetId():
-                self.ToggleTool(self.action['id'], False)
-            else:
-                self.ToggleTool(self.action['id'], True)
-            self.action['id'] = event.GetId()
-            event.Skip()
-        else:
-            # initialize toolbar
-    def GetAction(self, type = 'desc'):
-        """!Get current action info"""
-        return self.action.get(type, '')
-    def SelectDefault(self, event):
-        """!Select default tool"""
-        self.ToggleTool(self.defaultAction['id'], True)
-        self.defaultAction['bind'](event)
-        self.action = { 'id' : self.defaultAction['id'],
-                        'desc' : self.defaultAction.get('desc', '') }
-    def FixSize(self, width):
-	"""!Fix toolbar width on Windows
-	@todo Determine why combobox causes problems here
-        if platform.system() == 'Windows':
-            size = self.GetBestSize()
-            self.SetSize((size[0] + width, size[1]))
-    def Enable(self, tool, enable = True):
-        """!Enable defined tool
-        @param tool name
-        @param enable True to enable otherwise disable tool
-        try:
-            id = getattr(self, tool)
-        except AttributeError:
-            return
-        self.EnableTool(id, enable)
-    def _getToolbarData(self, data):
-        """!Define tool
-        retData = list()
-        for args in data:
-            retData.append(self._defineTool(*args))
-        return retData
-    def _defineTool(self, name = None, icon = None, handler = None, item = wx.ITEM_NORMAL):
-        """!Define tool
-        if name:
-            return (name, icon.GetBitmap(),
-                    item, icon.GetLabel(), icon.GetDesc(),
-                    handler)
-        return ("", "", "", "", "", "") # separator
-class MapToolbar(AbstractToolbar):
-    """!Map Display toolbar
-    def __init__(self, parent, mapcontent):
-        """!Map Display constructor
-        @param parent reference to MapFrame
-        @param mapcontent reference to render.Map (registred by MapFrame)
-        self.mapcontent = mapcontent # render.Map
-        AbstractToolbar.__init__(self, parent = parent) # MapFrame
-        self.InitToolbar(self._toolbarData())
-        # optional tools
-        choices = [ _('2D view'), ]
-        self.toolId = { '2d' : 0 }
-        if self.parent.GetLayerManager():
-            log = self.parent.GetLayerManager().GetLogWindow()
-        if haveNviz:
-            if not self.parent.GetLayerManager().existNviz:
-                choices.append(_('3D view'))
-                self.toolId['3d'] = 1
-            else:
-                self.toolId['3d'] = -1
-        else:
-            from nviz import errorMsg
-            log.WriteCmdLog(_('3D view mode not available'))
-            log.WriteWarning(_('Reason: %s') % str(errorMsg))
-            log.WriteLog(_('Note that the wxGUI\'s 3D view mode is currently disabled '
-                           'on MS Windows (hopefully this will be fixed soon). '
-                           'Please keep an eye out for updated versions of GRASS. '
-                           'In the meantime you can use "NVIZ" from the File menu.'), wrap = 60)
-        if haveVDigit:
-            choices.append(_('Digitize'))
-            if self.toolId['3d'] > -1:
-                self.toolId['vdigit'] = 2
-            else:
-                self.toolId['vdigit'] = 1
-        else:
-            from vdigit import errorMsg
-            log.WriteCmdLog(_('Vector digitizer not available'))
-            log.WriteWarning(_('Reason: %s') % errorMsg)
-            log.WriteLog(_('Note that the wxGUI\'s vector digitizer is currently disabled '
-                           '(hopefully this will be fixed soon). '
-                           'In the meantime you can use "v.digit" from the Develop Vector menu.'), wrap = 60)
-            self.toolId['vdigit'] = -1
-        self.combo = wx.ComboBox(parent = self, id = wx.ID_ANY,
-                                 choices = choices,
-                                 style = wx.CB_READONLY, size = (90, -1))
-        self.combo.SetSelection(0)
-        self.comboid = self.AddControl(self.combo)
-        self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
-        # realize the toolbar
-        self.Realize()
-        # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
-        self.combo.Hide()
-        self.combo.Show()
-        self.action = { 'id' : self.pointer }
-        self.defaultAction = { 'id' : self.pointer,
-                               'bind' : self.parent.OnPointer }
-        self.OnTool(None)
-        self.EnableTool(self.zoomback, False)
-        self.FixSize(width = 90)
-        """!Toolbar data"""
-        icons = Icons['displayWindow']
-        return self._getToolbarData((('displaymap', icons['display'],
-                                      self.parent.OnDraw),
-                                      ('displaymap', icons['display'],
-                                     ('rendermap', icons['render'],
-                                      self.parent.OnRender),
-                                     ('erase', icons['erase'],
-                                      self.parent.OnErase),
-                                     (None, ),
-                                     ('pointer', icons['pointer'],
-                                      self.parent.OnPointer,
-                                      wx.ITEM_CHECK),
-                                     ('query', icons['query'],
-                                      self.parent.OnQuery,
-                                      wx.ITEM_CHECK),
-                                     ('pan', icons['pan'],
-                                      self.parent.OnPan,
-                                      wx.ITEM_CHECK),
-                                     ('zoomin', icons['zoomIn'],
-                                      self.parent.OnZoomIn,
-                                      wx.ITEM_CHECK),
-                                     ('zoomout', icons['zoomOut'],
-                                      self.parent.OnZoomOut,
-                                      wx.ITEM_CHECK),
-                                     ('zoomextent', icons['zoomExtent'],
-                                      self.parent.OnZoomToMap),
-                                     ('zoomback', icons['zoomBack'],
-                                      self.parent.OnZoomBack),
-                                     ('zoommenu', icons['zoomMenu'],
-                                      self.parent.OnZoomMenu),
-                                     (None, ),
-                                     ('analyze', icons['analyze'],
-                                      self.parent.OnAnalyze),
-                                     (None, ),
-                                     ('dec', icons['overlay'],
-                                      self.parent.OnDecoration),
-                                     (None, ),
-                                     ('savefile', icons['saveFile'],
-                                      self.parent.SaveToFile),
-                                     ('printmap', icons['print'],
-                                      self.parent.PrintMenu),
-                                     (None, ))
-    def OnSelectTool(self, event):
-        """!Select / enable tool available in tools list
-        tool =  event.GetSelection()
-        if tool == self.toolId['2d']:
-            self.ExitToolbars()
-            self.Enable2D(True)
-        elif tool == self.toolId['3d'] and \
-                not self.parent.toolbars['nviz']:
-            self.parent.AddToolbar("nviz")
-        elif tool == self.toolId['vdigit'] and \
-                not self.parent.toolbars['vdigit']:
-            self.parent.AddToolbar("vdigit")
-            self.parent.MapWindow.SetFocus()
-    def ExitToolbars(self):
-            self.parent.toolbars['vdigit'].OnExit()
-        if self.parent.toolbars['nviz']:
-            self.parent.toolbars['nviz'].OnExit()
-    def Enable2D(self, enabled):
-        """!Enable/Disable 2D display mode specific tools"""
-        for tool in (self.pointer,
-                     self.pan,
-                     self.zoomin,
-                     self.zoomout,
-                     self.zoomback,
-                     self.zoommenu,
-                     self.analyze,
-                     self.dec,
-                     self.printmap):
-            self.EnableTool(tool, enabled)
-class GCPManToolbar(AbstractToolbar):
-    """!Toolbar for managing ground control points
-    @param parent reference to GCP widget
-        AbstractToolbar.__init__(self, parent)
-        self.Realize()
-        icons = Icons['georectify']
-        return self._getToolbarData((('gcpSave', icons["gcpSave"],
-                                      self.parent.SaveGCPs),
-                                     ('gcpReload', icons["gcpReload"],
-                                      self.parent.ReloadGCPs),
-                                     (None, ),
-                                     ('gcpAdd', icons["gcpAdd"],
-                                      self.parent.AddGCP),
-                                     ('gcpDelete', icons["gcpDelete"],
-                                      self.parent.DeleteGCP),
-                                     ('gcpClear', icons["gcpClear"],
-                                      self.parent.ClearGCP),
-                                     (None, ),
-                                     ('rms', icons["gcpRms"],
-                                      self.parent.OnRMS),
-                                     ('georect', icons["georectify"],
-                                      self.parent.OnGeorect))
-class GCPDisplayToolbar(AbstractToolbar):
-    """!GCP Display toolbar
-        """!GCP Display toolbar constructor
-        # add tool to toggle active map window
-        self.togglemapid = wx.NewId()
-        self.togglemap = wx.Choice(parent = self, id = self.togglemapid,
-						    choices = [_('source'), _('target')],
-						    style = wx.CB_READONLY)
-        self.InsertControl(10, self.togglemap)
-        self.SetToolShortHelp(self.togglemapid, '%s %s %s' % (_('Set map canvas for '),
-                                                              Icons['displayWindow']["zoomBack"].GetLabel(),
-                                                              _(' / Zoom to map')))
-        self.Realize()
-        self.action = { 'id' : self.gcpset }
-        self.defaultAction = { 'id' : self.gcpset,
-        self.OnTool(None)
-        return self._getToolbarData((("displaymap", icons["display"],
-                                     ("rendermap", icons["render"],
-                                     ("erase", icons["erase"],
-                                     (None, ),
-                                     ("gcpset", Icons["georectify"]["gcpSet"],
-                                      self.parent.OnPointer),
-                                     ("pan", icons["pan"],
-                                      self.parent.OnPan),
-                                     ("zoomin", icons["zoomIn"],
-                                      self.parent.OnZoomIn),
-                                     ("zoomout", icons["zoomOut"],
-                                      self.parent.OnZoomOut),
-                                     ("zoommenu", icons["zoomMenu"],
-                                      self.parent.OnZoomMenuGCP),
-                                     (None, ),
-                                     ("zoomback", icons["zoomBack"],
-                                     ("zoomtomap", icons["zoomExtent"],
-                                     (None, ),
-                                     ('settings', Icons["georectify"]["settings"],
-                                      self.parent.OnSettings),
-                                     ('help', Icons["misc"]["help"],
-                                      self.parent.OnHelp),
-                                     (None, ),
-                                     ('quit', Icons["georectify"]["quit"],
-                                      self.parent.OnQuit))
-class VDigitToolbar(AbstractToolbar):
-    """!Toolbar for digitization
-    def __init__(self, parent, mapcontent, layerTree = None, log = None):
-        self.mapcontent    = mapcontent # Map class instance
-        self.layerTree     = layerTree  # reference to layer tree associated to map display
-        self.log           = log        # log area
-        self.digit         = None
-        # currently selected map layer for editing (reference to MapLayer instance)
-        self.mapLayer = None
-        # list of vector layers from Layer Manager (only in the current mapset)
-        self.layers   = []
-        self.comboid    = None
-        # only one dialog can be open
-        self.settingsDialog   = None
-        # create toolbars (two rows optionally)
-        # default action (digitize new point, line, etc.)
-        self.action = { 'desc' : 'addLine',
-                        'type' : 'point',
-                        'id'   : self.addPoint }
-        # list of available vector maps
-        self.UpdateListOfLayers(updateTool = True)
-        # realize toolbar
-        self.Realize()
-        self.combo.Hide()
-        self.combo.Show()
-        # disable undo/redo
-        self.EnableTool(self.undo, False)
-        # toogle to pointer by default
-        self.OnTool(None)
-        self.FixSize(width = 105)
-        """!Toolbar data
-        data = []
-        icons = Icons['vdigit']
-        return self._getToolbarData(((None, ),
-                                     ("addPoint", icons["addPoint"],
-                                      self.OnAddPoint),
-                                     ("addLine", icons["addLine"],
-                                      self.OnAddLine,
-                                      wx.ITEM_CHECK),
-                                     ("addBoundary", icons["addBoundary"],
-                                      self.OnAddBoundary,
-                                      wx.ITEM_CHECK),
-                                     ("addCentroid", icons["addCentroid"],
-                                      self.OnAddCentroid,
-                                      wx.ITEM_CHECK),
-                                     ("addArea", icons["addArea"],
-                                      self.OnAddArea,
-                                      wx.ITEM_CHECK),
-                                     ("moveVertex", icons["moveVertex"],
-                                      self.OnMoveVertex,
-                                      wx.ITEM_CHECK),
-                                     ("addVertex", icons["addVertex"],
-                                      self.OnAddVertex,
-                                      wx.ITEM_CHECK),
-                                     ("removeVertex", icons["removeVertex"],
-                                      self.OnRemoveVertex,
-                                      wx.ITEM_CHECK),
-                                     ("splitLine", icons["splitLine"],
-                                      self.OnSplitLine,
-                                      wx.ITEM_CHECK),
-                                     ("editLine", icons["editLine"],
-                                      self.OnEditLine,
-                                      wx.ITEM_CHECK),
-                                     ("moveLine", icons["moveLine"],
-                                      self.OnMoveLine,
-                                      wx.ITEM_CHECK),
-                                     ("deleteLine", icons["deleteLine"],
-                                      self.OnDeleteLine,
-                                      wx.ITEM_CHECK),
-                                     ("displayCats", icons["displayCats"],
-                                      self.OnDisplayCats,
-                                      wx.ITEM_CHECK),
-                                     ("copyCats", icons["copyCats"],
-                                      self.OnCopyCA,
-                                      wx.ITEM_CHECK),
-                                     ("displayAttr", icons["displayAttr"],
-                                      self.OnDisplayAttr,
-                                      wx.ITEM_CHECK),
-                                     ("additionalTools", icons["additionalTools"],
-                                      self.OnAdditionalToolMenu,
-                                      wx.ITEM_CHECK),
-                                     (None, ),
-                                     ("undo", icons["undo"],
-                                      self.OnUndo),
-                                     ("settings", icons["settings"],
-                                      self.OnSettings),
-                                     ("quit", icons["quit"],
-                                      self.OnExit))
-        """!Tool selected -> disable selected tool in map toolbar"""
-        id = self.parent.toolbars['map'].GetAction(type = 'id')
-        self.parent.toolbars['map'].ToggleTool(id, False)
-        # set cursor
-        cursor = self.parent.cursors["cross"]
-        self.parent.MapWindow.SetCursor(cursor)
-        # pointer
-        self.parent.OnPointer(None)
-        if event:
-            else:
-            event.Skip()
-        # clear tmp canvas
-        if self.action['id'] != id:
-            self.parent.MapWindow.ClearLines(pdc = self.parent.MapWindow.pdcTmp)
-            if self.digit and \
-                    len(self.parent.MapWindow.digit.GetDisplay().GetSelected()) > 0:
-                # cancel action
-                self.parent.MapWindow.OnMiddleDown(None)
-        # set focus
-    def OnAddPoint(self, event):
-        """!Add point to the vector map Laier"""
-        Debug.msg (2, "VDigitToolbar.OnAddPoint()")
-        self.action = { 'desc' : "addLine",
-                        'type' : "point",
-        self.parent.MapWindow.mouse['box'] = 'point'
-    def OnAddLine(self, event):
-        """!Add line to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddLine()")
-                        'type' : "line",
-                        'id'   : self.addLine }
-        self.parent.MapWindow.mouse['box'] = 'line'
-        ### self.parent.MapWindow.polycoords = [] # reset temp line
-    def OnAddBoundary(self, event):
-        """!Add boundary to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
-        if self.action['desc'] != 'addLine' or \
-                self.action['type'] != 'boundary':
-            self.parent.MapWindow.polycoords = [] # reset temp line
-                        'type' : "boundary",
-                        'id'   : self.addBoundary }
-    def OnAddCentroid(self, event):
-        """!Add centroid to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
-                        'type' : "centroid",
-                        'id'   : self.addCentroid }
-    def OnAddArea(self, event):
-        """!Add area to the vector map layer"""
-                        'type' : "area",
-                        'id'   : self.addArea }
-    def OnExit (self, event=None):
-        """!Quit digitization tool"""
-        # stop editing of the currently selected map layer
-        if self.mapLayer:
-            self.StopEditing()
-        # close dialogs if still open
-        if self.settingsDialog:
-            self.settingsDialog.OnCancel(None)
-        # set default mouse settings
-        self.parent.MapWindow.mouse['use'] = "pointer"
-        self.parent.MapWindow.mouse['box'] = "point"
-        # disable the toolbar
-        self.parent.RemoveToolbar("vdigit")
-    def OnMoveVertex(self, event):
-        """!Move line vertex"""
-        Debug.msg(2, "Digittoolbar.OnMoveVertex():")
-        self.action = { 'desc' : "moveVertex",
-                        'id'   : self.moveVertex }
-    def OnAddVertex(self, event):
-        """!Add line vertex"""
-        Debug.msg(2, "Digittoolbar.OnAddVertex():")
-        self.action = { 'desc' : "addVertex",
-                        'id'   : self.addVertex }
-    def OnRemoveVertex(self, event):
-        """!Remove line vertex"""
-        Debug.msg(2, "Digittoolbar.OnRemoveVertex():")
-        self.action = { 'desc' : "removeVertex",
-                        'id'   : self.removeVertex }
-    def OnSplitLine(self, event):
-        """!Split line"""
-        Debug.msg(2, "Digittoolbar.OnSplitLine():")
-        self.action = { 'desc' : "splitLine",
-                        'id'   : self.splitLine }
-    def OnEditLine(self, event):
-        """!Edit line"""
-        Debug.msg(2, "Digittoolbar.OnEditLine():")
-        self.action = { 'desc' : "editLine",
-                        'id'   : self.editLine }
-    def OnMoveLine(self, event):
-        """!Move line"""
-        Debug.msg(2, "Digittoolbar.OnMoveLine():")
-        self.action = { 'desc' : "moveLine",
-                        'id'   : self.moveLine }
-        self.parent.MapWindow.mouse['box'] = 'box'
-    def OnDeleteLine(self, event):
-        """!Delete line"""
-        Debug.msg(2, "Digittoolbar.OnDeleteLine():")
-        self.action = { 'desc' : "deleteLine",
-                        'id'   : self.deleteLine }
-    def OnDisplayCats(self, event):
-        """!Display/update categories"""
-        Debug.msg(2, "Digittoolbar.OnDisplayCats():")
-        self.action = { 'desc' : "displayCats",
-                        'id'   : self.displayCats }
-    def OnDisplayAttr(self, event):
-        """!Display/update attributes"""
-        Debug.msg(2, "Digittoolbar.OnDisplayAttr():")
-        self.action = { 'desc' : "displayAttrs",
-                        'id'   : self.displayAttr }
-    def OnCopyCA(self, event):
-        """!Copy categories/attributes menu"""
-        point = wx.GetMousePosition()
-        toolMenu = wx.Menu()
-        # Add items to the menu
-        cats = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                           text = _('Copy categories'),
-                           kind = wx.ITEM_CHECK)
-        toolMenu.AppendItem(cats)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyCats, cats)
-        if self.action['desc'] == "copyCats":
-            cats.Check(True)
-        attrb = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                            text = _('Duplicate attributes'),
-        toolMenu.AppendItem(attrb)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopyAttrb, attrb)
-        if self.action['desc'] == "copyAttrs":
-            attrb.Check(True)
-        # Popup the menu.  If an item is selected then its handler
-        # will be called before PopupMenu returns.
-        self.parent.MapWindow.PopupMenu(toolMenu)
-        toolMenu.Destroy()
-        if self.action['desc'] == "addPoint":
-            self.ToggleTool(self.copyCats, False)
-    def OnCopyCats(self, event):
-        """!Copy categories"""
-        if self.action['desc'] == 'copyCats': # select previous action
-            self.ToggleTool(self.addPoint, True)
-            self.OnAddPoint(event)
-            return
-        Debug.msg(2, "Digittoolbar.OnCopyCats():")
-        self.action = { 'desc' : "copyCats",
-                        'id'   : self.copyCats }
-    def OnCopyAttrb(self, event):
-        if self.action['desc'] == 'copyAttrs': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnCopyAttrb():")
-        self.action = { 'desc' : "copyAttrs",
-    def OnUndo(self, event):
-        """!Undo previous changes"""
-        self.digit.Undo()
-        event.Skip()
-    def EnableUndo(self, enable=True):
-        """!Enable 'Undo' in toolbar
-        @param enable False for disable
-        if enable:
-            if self.GetToolEnabled(self.undo) is False:
-                self.EnableTool(self.undo, True)
-        else:
-            if self.GetToolEnabled(self.undo) is True:
-    def OnSettings(self, event):
-        """!Show settings dialog"""
-        if self.digit is None:
-            try:
-                self.digit = self.parent.MapWindow.digit = VDigit(mapwindow = self.parent.MapWindow)
-            except SystemExit:
-                self.digit = self.parent.MapWindow.digit = None
-        if not self.settingsDialog:
-            self.settingsDialog = VDigitSettingsDialog(parent = self.parent, title = _("Digitization settings"),
-                                                       style = wx.DEFAULT_DIALOG_STYLE)
-            self.settingsDialog.Show()
-    def OnAdditionalToolMenu(self, event):
-        """!Menu for additional tools"""
-        copy = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                           text = _('Copy features from (background) vector map'),
-        toolMenu.AppendItem(copy)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnCopy, copy)
-        if self.action['desc'] == "copyLine":
-            copy.Check(True)
-        flip = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                           text = _('Flip selected lines/boundaries'),
-        toolMenu.AppendItem(flip)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnFlip, flip)
-        if self.action['desc'] == "flipLine":
-            flip.Check(True)
-        merge = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                            text = _('Merge selected lines/boundaries'),
-        toolMenu.AppendItem(merge)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnMerge, merge)
-        if self.action['desc'] == "mergeLine":
-            merge.Check(True)
-        breakL = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                             text = _('Break selected lines/boundaries at intersection'),
-        toolMenu.AppendItem(breakL)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnBreak, breakL)
-        if self.action['desc'] == "breakLine":
-            breakL.Check(True)
-        snap = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                           text = _('Snap selected lines/boundaries (only to nodes)'),
-        toolMenu.AppendItem(snap)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnSnap, snap)
-        if self.action['desc'] == "snapLine":
-            snap.Check(True)
-        connect = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                              text = _('Connect selected lines/boundaries'),
-        toolMenu.AppendItem(connect)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnConnect, connect)
-        if self.action['desc'] == "connectLine":
-            connect.Check(True)
-        query = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                            text = _('Query features'),
-        toolMenu.AppendItem(query)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnQuery, query)
-        if self.action['desc'] == "queryLine":
-            query.Check(True)
-        zbulk = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                            text = _('Z bulk-labeling of 3D lines'),
-        toolMenu.AppendItem(zbulk)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnZBulk, zbulk)
-        if self.action['desc'] == "zbulkLine":
-            zbulk.Check(True)
-        typeconv = wx.MenuItem(parentMenu = toolMenu, id = wx.ID_ANY,
-                               text = _('Feature type conversion'),
-        toolMenu.AppendItem(typeconv)
-        self.parent.MapWindow.Bind(wx.EVT_MENU, self.OnTypeConversion, typeconv)
-        if self.action['desc'] == "typeConv":
-            typeconv.Check(True)
-        if self.action['desc'] == 'addPoint':
-            self.ToggleTool(self.additionalTools, False)
-    def OnCopy(self, event):
-        """!Copy selected features from (background) vector map"""
-        if self.action['desc'] == 'copyLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnCopy():")
-        self.action = { 'desc' : "copyLine",
-                        'id'   : self.additionalTools }
-    def OnFlip(self, event):
-        """!Flip selected lines/boundaries"""
-        if self.action['desc'] == 'flipLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnFlip():")
-        self.action = { 'desc' : "flipLine",
-    def OnMerge(self, event):
-        """!Merge selected lines/boundaries"""
-        if self.action['desc'] == 'mergeLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnMerge():")
-        self.action = { 'desc' : "mergeLine",
-    def OnBreak(self, event):
-        """!Break selected lines/boundaries"""
-        if self.action['desc'] == 'breakLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnBreak():")
-        self.action = { 'desc' : "breakLine",
-    def OnSnap(self, event):
-        """!Snap selected features"""
-        if self.action['desc'] == 'snapLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnSnap():")
-        self.action = { 'desc' : "snapLine",
-    def OnConnect(self, event):
-        """!Connect selected lines/boundaries"""
-        if self.action['desc'] == 'connectLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnConnect():")
-        self.action = { 'desc' : "connectLine",
-    def OnQuery(self, event):
-        """!Query selected lines/boundaries"""
-        if self.action['desc'] == 'queryLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnQuery(): %s" % \
-                      UserSettings.Get(group = 'vdigit', key = 'query', subkey = 'selection'))
-        self.action = { 'desc' : "queryLine",
-    def OnZBulk(self, event):
-        """!Z bulk-labeling selected lines/boundaries"""
-        if not self.digit.IsVector3D():
-            gcmd.GError(parent = self.parent,
-                        message = _("Vector map is not 3D. Operation canceled."))
-            return
-        if self.action['desc'] == 'zbulkLine': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnZBulk():")
-        self.action = { 'desc' : "zbulkLine",
-    def OnTypeConversion(self, event):
-        """!Feature type conversion
-        Supported conversions:
-         - point <-> centroid
-         - line <-> boundary
-        if self.action['desc'] == 'typeConv': # select previous action
-            return
-        Debug.msg(2, "Digittoolbar.OnTypeConversion():")
-        self.action = { 'desc' : "typeConv",
-    def OnSelectMap (self, event):
-        """!Select vector map layer for editing
-        If there is a vector map layer already edited, this action is
-        firstly terminated. The map layer is closed. After this the
-        selected map layer activated for editing.
-        if event.GetSelection() == 0: # create new vector map layer
-            if self.mapLayer:
-                openVectorMap = self.mapLayer.GetName(fullyQualified = False)['name']
-            else:
-                openVectorMap = None
-            mapName = gdialogs.CreateNewVector(self.parent,
-                                               exceptMap = openVectorMap, log = self.log,
-                                               cmd = (('v.edit',
-                                                       { 'tool' : 'create' },
-                                                       'map')),
-                                               disableAdd = True)[0]
-            if mapName:
-                # add layer to map layer tree
-                if self.layerTree:
-                    self.layerTree.AddLayer(ltype = 'vector',
-                                            lname = mapName,
-                                            lchecked = True,
-                                            lopacity = 1.0,
-                                            lcmd = ['d.vect', 'map=%s' % mapName])
-                    vectLayers = self.UpdateListOfLayers(updateTool = True)
-                    selection = vectLayers.index(mapName)
-                else:
-                    pass # TODO (no Layer Manager)
-            else:
-                self.combo.SetValue(_('Select vector map'))
-                return
-        else:
-            selection = event.GetSelection() - 1 # first option is 'New vector map'
-        # skip currently selected map
-        if self.layers[selection] == self.mapLayer:
-            return False
-        if self.mapLayer:
-            # deactive map layer for editing
-        # select the given map layer for editing
-        self.StartEditing(self.layers[selection])
-        event.Skip()
-        return True
-    def StartEditing (self, mapLayer):
-        """!Start editing selected vector map layer.
-        @param mapLayer MapLayer to be edited
-        # deactive layer
-        self.mapcontent.ChangeLayerActive(mapLayer, False)
-        # clean map canvas
-        self.parent.MapWindow.EraseMap()
-        # unset background map if needed
-        if mapLayer:
-            if UserSettings.Get(group = 'vdigit', key = 'bgmap',
-                                subkey = 'value', internal = True) == mapLayer.GetName():
-                UserSettings.Set(group = 'vdigit', key = 'bgmap',
-                                 subkey = 'value', value = '', internal = True)
-            self.parent.statusbar.SetStatusText(_("Please wait, "
-                                                  "opening vector map <%s> for editing...") % mapLayer.GetName(),
-                                                0)
-        self.parent.MapWindow.pdcVector = wx.PseudoDC()
-        self.mapLayer = mapLayer
-        # open vector map
-        if self.digit.OpenMap(mapLayer.GetName()) is None:
-            return False
-        # update toolbar
-        self.combo.SetValue(mapLayer.GetName())
-        self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
-        lmgr = self.parent.GetLayerManager()
-        if lmgr:
-            lmgr.toolbars['tools'].Enable('vdigit', enable = False)
-        Debug.msg (4, "VDigitToolbar.StartEditing(): layer=%s" % mapLayer.GetName())
-        # change cursor
-        if self.parent.MapWindow.mouse['use'] == 'pointer':
-            self.parent.MapWindow.SetCursor(self.parent.cursors["cross"])
-        if not self.parent.MapWindow.resize:
-            self.parent.MapWindow.UpdateMap(render = True)
-        opacity = mapLayer.GetOpacity(float = True)
-        if opacity < 1.0:
-            alpha = int(opacity * 255)
-            self.digit.UpdateSettings(alpha)
-        return True
-    def StopEditing(self):
-        """!Stop editing of selected vector map layer.
-        @return True on success
-        @return False on failure
-        self.combo.SetValue (_('Select vector map'))
-        # save changes
-        if self.mapLayer:
-            Debug.msg (4, "VDigitToolbar.StopEditing(): layer=%s" % self.mapLayer.GetName())
-            if UserSettings.Get(group = 'vdigit', key = 'saveOnExit', subkey = 'enabled') is False:
-                if self.digit.GetUndoLevel() > -1:
-                    dlg = wx.MessageDialog(parent = self.parent,
-                                           message = _("Do you want to save changes "
-                                                     "in vector map <%s>?") % self.mapLayer.GetName(),
-                                           caption = _("Save changes?"),
-                                           style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
-                    if dlg.ShowModal() == wx.ID_NO:
-                        # revert changes
-                        self.digit.Undo(0)
-                    dlg.Destroy()
-                                                  "closing and rebuilding topology of "
-                                                  "vector map <%s>...") % self.mapLayer.GetName(),
-                                                0)
-            if lmgr:
-                lmgr.toolbars['tools'].Enable('vdigit', enable = True)
-                lmgr.notebook.SetSelectionByName('output')
-            self.digit.CloseMap()
-            if lmgr:
-                lmgr.GetLogWindow().GetProgressBar().SetValue(0)
-                lmgr.GetLogWindow().WriteCmdLog(_("Editing of vector map <%s> successfully finished") % \
-                                                    self.mapLayer.GetName())
-            # re-active layer
-            item = self.parent.tree.FindItemByData('maplayer', self.mapLayer)
-            if item and self.parent.tree.IsItemChecked(item):
-                self.mapcontent.ChangeLayerActive(self.mapLayer, True)
-        # change cursor
-        self.parent.MapWindow.SetCursor(self.parent.cursors["default"])
-        self.parent.MapWindow.pdcVector = None
-        # close dialogs
-        for dialog in ('attributes', 'category'):
-            if self.parent.dialogs[dialog]:
-                self.parent.dialogs[dialog].Close()
-                self.parent.dialogs[dialog] = None
-        del self.digit
-        del self.parent.MapWindow.digit
-        self.parent.MapWindow.redrawAll = True
-        return True
-    def UpdateListOfLayers (self, updateTool = False):
-        Update list of available vector map layers.
-        This list consists only editable layers (in the current mapset)
-        Optionally also update toolbar
-        Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
-                   updateTool)
-        layerNameSelected = None
-         # name of currently selected layer
-        if self.mapLayer:
-            layerNameSelected = self.mapLayer.GetName()
-        # select vector map layer in the current mapset
-        layerNameList = []
-        self.layers = self.mapcontent.GetListOfLayers(l_type = "vector",
-                                                      l_mapset = grass.gisenv()['MAPSET'])
-        for layer in self.layers:
-            if not layer.name in layerNameList: # do not duplicate layer
-                layerNameList.append (layer.GetName())
-        if updateTool: # update toolbar
-            if not self.mapLayer:
-                value = _('Select vector map')
-            else:
-                value = layerNameSelected
-            if not self.comboid:
-                self.combo = wx.ComboBox(self, id = wx.ID_ANY, value = value,
-                                         choices = [_('New vector map'), ] + layerNameList, size = (115, -1),
-                self.comboid = self.InsertControl(0, self.combo)
-                self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectMap, self.comboid)
-            else:
-                self.combo.SetItems([_('New vector map'), ] + layerNameList)
-            self.Realize()
-        return layerNameList
-    def GetLayer(self):
-        """!Get selected layer for editing -- MapLayer instance"""
-        return self.mapLayer
-class ProfileToolbar(AbstractToolbar):
-    """!Toolbar for profiling raster map
-        self.Realize()
-        icons = Icons['profile']
-        return self._getToolbarData((('addraster', Icons['layerManager']["addRast"],
-                                      self.parent.OnSelectRaster),
-                                     ('transect', icons["transect"],
-                                      self.parent.OnDrawTransect),
-                                     (None, ),
-                                     ('draw', icons["draw"],
-                                      self.parent.OnCreateProfile),
-                                     ('erase', Icons['displayWindow']["erase"],
-                                     ('drag', Icons['displayWindow']['pan'],
-                                      self.parent.OnDrag),
-                                     ('zoom', Icons['displayWindow']['zoomIn'],
-                                      self.parent.OnZoom),
-                                     ('unzoom', Icons['displayWindow']['zoomBack'],
-                                      self.parent.OnRedraw),
-                                     (None, ),
-                                     ('datasave', icons["save"],
-                                      self.parent.SaveProfileToFile),
-                                     ('image', Icons['displayWindow']["saveFile"],
-                                     ('print', Icons['displayWindow']["print"],
-                                     (None, ),
-                                     ('settings', icons["options"],
-                                      self.parent.ProfileOptionsMenu),
-                                     ('quit', icons["quit"],
-                                      self.parent.OnQuit),
-class NvizToolbar(AbstractToolbar):
-    """!Nviz toolbar
-        self.lmgr = parent.GetLayerManager()
-        self.Realize()
-        icons = Icons['nviz']
-        return self._getToolbarData((("view", icons["view"],
-                                      self.OnShowPage),
-                                     (None, ),
-                                     ("surface", icons["surface"],
-                                      self.OnShowPage),
-                                     ("vector", icons["vector"],
-                                      self.OnShowPage),
-                                     ("volume", icons["volume"],
-                                      self.OnShowPage),
-                                     (None, ),
-                                     ("light", icons["light"],
-                                      self.OnShowPage),
-                                     ("fringe", icons["fringe"],
-                                      self.OnShowPage),
-                                     (None, ),
-                                      self.OnSettings),
-                                     ("help", Icons['misc']["help"],
-                                      self.OnHelp),
-                                     (None, ),
-                                      self.OnExit))
-    def OnShowPage(self, event):
-        """!Go to the selected page"""
-        if not self.lmgr or not hasattr(self.lmgr, "nviz"):
-            event.Skip()
-            return
-        self.lmgr.notebook.SetSelectionByName('nviz')
-        eId = event.GetId()
-        if eId == self.view:
-            self.lmgr.nviz.SetPage('view')
-        elif eId == self.surface:
-            self.lmgr.nviz.SetPage('surface')
-        elif eId == self.vector:
-            self.lmgr.nviz.SetPage('vector')
-        elif eId == self.volume:
-            self.lmgr.nviz.SetPage('volume')
-        elif eId == self.light:
-            self.lmgr.nviz.SetPage('light')
-        elif eId == self.fringe:
-            self.lmgr.nviz.SetPage('fringe')
-        self.lmgr.Raise()
-    def OnHelp(self, event):
-        """!Show 3D view mode help"""
-        if not self.lmgr:
-            gcmd.RunCommand('g.manual',
-                            entry = 'wxGUI.Nviz')
-        else:
-            log = self.lmgr.GetLogWindow()
-            log.RunCmd(['g.manual',
-                        'entry=wxGUI.Nviz'])
-        """!Show nviz notebook page"""
-            self.settingsDialog = NvizPreferencesDialog(parent = self.parent)
-    def OnExit (self, event = None):
-        """!Quit nviz tool (swith to 2D mode)"""
-        # return to map layer page (gets rid of ugly exit bug)
-        self.lmgr.notebook.SetSelectionByName('layers')
-        self.parent.RemoveToolbar("nviz")
-class ModelToolbar(AbstractToolbar):
-    """!Graphical modeler toolbar (see gmodeler.py)
-        self.Realize()
-        icons = Icons['modeler']
-        return self._getToolbarData((('new', icons['new'],
-                                      self.parent.OnModelNew),
-                                     ('open', icons['open'],
-                                      self.parent.OnModelOpen),
-                                     ('save', icons['save'],
-                                      self.parent.OnModelSave),
-                                     ('image', icons['toImage'],
-                                      self.parent.OnExportImage),
-                                     ('python', icons['toPython'],
-                                      self.parent.OnExportPython),
-                                     (None, ),
-                                     ('action', icons['actionAdd'],
-                                      self.parent.OnAddAction),
-                                     ('data', icons['dataAdd'],
-                                      self.parent.OnAddData),
-                                     ('relation', icons['relation'],
-                                      self.parent.OnDefineRelation),
-                                     (None, ),
-                                     ('redraw', icons['redraw'],
-                                      self.parent.OnCanvasRefresh),
-                                     ('validate', icons['validate'],
-                                      self.parent.OnValidateModel),
-                                     ('run', icons['run'],
-                                      self.parent.OnRunModel),
-                                     (None, ),
-                                     ("variables", icons['variables'],
-                                      self.parent.OnVariables),
-                                     ("settings", icons['settings'],
-                                      self.parent.OnPreferences),
-                                     ("help", Icons['misc']['help'],
-                                     (None, ),
-                                     ('quit', icons['quit'],
-                                      self.parent.OnCloseWindow))
-class HistogramToolbar(AbstractToolbar):
-    """!Histogram toolbar (see histogram.py)
-        self.Realize()
-        return self._getToolbarData((('histogram', icons["histogram"],
-                                      self.parent.OnOptions),
-                                     ('rendermao', icons["display"],
-                                     ('erase', icons["erase"],
-                                     ('font', Icons['misc']["font"],
-                                      self.parent.SetHistFont),
-                                     (None, ),
-                                     ('save', icons["saveFile"],
-                                     ('hprint', icons["print"],
-                                     (None, ),
-                                     ('quit', Icons['misc']["quit"],
-class LMWorkspaceToolbar(AbstractToolbar):
-    """!Layer Manager `workspace` toolbar
-        self.Realize()
-        """!Toolbar data
-        icons = Icons['layerManager']
-        return self._getToolbarData((('newdisplay', icons["newdisplay"],
-                                      self.parent.OnNewDisplay),
-                                      ('newdisplay', icons["newdisplay"],
-                                      self.parent.OnNewDisplay1),
-                                     (None, ),
-                                     ('workspaceNew', icons["workspaceNew"],
-                                      self.parent.OnWorkspaceNew),
-                                     ('workspaceOpen', icons["workspaceOpen"],
-                                      self.parent.OnWorkspaceOpen),
-                                     ('workspaceSave', icons["workspaceSave"],
-                                      self.parent.OnWorkspaceSave),
-class LMDataToolbar(AbstractToolbar):
-    """!Layer Manager `data` toolbar
-        self.Realize()
-        """!Toolbar data
-        return self._getToolbarData((('addMulti', icons["addMulti"],
-                                      self.parent.OnAddMaps),
-                                     ('addrast', icons["addRast"],
-                                      self.parent.OnAddRaster),
-                                     ('rastmisc', icons["rastMisc"],
-                                      self.parent.OnAddRasterMisc),
-                                     ('addvect', icons["addVect"],
-                                      self.parent.OnAddVector),
-                                     ('vectmisc', icons["vectMisc"],
-                                      self.parent.OnAddVectorMisc),
-                                     ('addgrp',  icons["addGroup"],
-                                      self.parent.OnAddGroup),
-                                     ('addovl',  icons["addOverlay"],
-                                      self.parent.OnAddOverlay),
-                                     ('delcmd',  icons["delCmd"],
-                                      self.parent.OnDeleteLayer),
-                                     (None, ),
-                                     ('importMap', icons["import"],
-                                      self.parent.OnImportMenu),
-                                     (None, ),
-                                     ('vdigit', icons["vdigit"],
-                                      self.parent.OnVDigit),
-                                     ('attribute', icons["attrTable"],
-                                      self.parent.OnShowAttributeTable),
-class LMToolsToolbar(AbstractToolbar):
-    """!Layer Manager `tools` toolbar
-        self.Realize()
-        """!Toolbar data
-        return self._getToolbarData((('mapCalc', icons["mapcalc"],
-                                      self.parent.OnMapCalculator),
-                                     ('georect', Icons["georectify"]["georectify"],
-                                      self.parent.OnGCPManager),
-                                     ('modeler', icons["modeler"],
-                                      self.parent.OnGModeler),
-                                     ('mapOutput', icons['mapOutput'],
-                                      self.parent.OnPsMap)
-class LMMiscToolbar(AbstractToolbar):
-    """!Layer Manager `misc` toolbar
-        self.Realize()
-        """!Toolbar data
-        return self._getToolbarData((('settings', icons["settings"],
-class PsMapToolbar(AbstractToolbar):
-        """!Toolbar Hardcopy Map Output Utility (psmap.py)
-        @param parent parent window
-        self.Realize()
-        self.OnTool(None)
-        from psmap import haveImage
-        if not haveImage:
-            self.EnableTool(self.preview, False)
-        """!Toolbar data
-        icons = Icons['psMap']
-        return self._getToolbarData((('loadFile', icons['scriptLoad'],
-                                      self.parent.OnLoadFile),
-                                     ('instructionFile', icons['scriptSave'],
-                                      self.parent.OnInstructionFile),
-                                     (None, ),
-                                     ('pagesetup', icons['pageSetup'],
-                                      self.parent.OnPageSetup),
-                                     (None, ),
-                                     ("pointer", Icons["displayWindow"]["pointer"],
-                                      self.parent.OnPointer, wx.ITEM_CHECK),
-                                     ('pan', Icons["displayWindow"]['pan'],
-                                      self.parent.OnPan, wx.ITEM_CHECK),
-                                     ("zoomin", Icons["displayWindow"]["zoomIn"],
-                                      self.parent.OnZoomIn, wx.ITEM_CHECK),
-                                     ("zoomout", Icons["displayWindow"]["zoomOut"],
-                                      self.parent.OnZoomOut, wx.ITEM_CHECK),
-                                     ('zoomAll', icons['fullExtent'],
-                                      self.parent.OnZoomAll),
-                                     (None, ),
-                                     ('addMap', icons['addMap'],
-                                      self.parent.OnAddMap, wx.ITEM_CHECK),
-                                     ('addRaster', icons['addRast'],
-                                     ('addVector', icons['addVect'],
-                                      self.parent.OnAddVect),
-                                     ("dec", Icons["displayWindow"]["overlay"],
-                                     ("delete", icons["deleteObj"],
-                                      self.parent.OnDelete),
-                                     (None, ),
-                                     ("preview", icons["preview"],
-                                      self.parent.OnPreview),
-                                     ('generatePS', icons['psExport'],
-                                      self.parent.OnPSFile),
-                                     ('generatePDF', icons['pdfExport'],
-                                      self.parent.OnPDFFile),
-                                     (None, ),
Deleted: grass-addons/grass7/gui/wxpython/wx.wms/wxgui.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wxgui.py	2011-07-12 18:50:35 UTC (rev 47099)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wxgui.py	2011-07-12 18:54:28 UTC (rev 47100)
@@ -1,1675 +0,0 @@
- at package wxgui.py
- at brief Main Python app for GRASS wxPython GUI. Main menu, layer management
-toolbar, notebook control for display management and access to
-command console.
-Classes:
- - GMFrame
- - GMApp
-(C) 2006-2011 by the GRASS Development Team
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Michael Barton (Arizona State University)
- at author Jachym Cepicky (Mendel University of Agriculture)
- at author Vaclav Petras <wenzeslaus gmail.com> (menu customization)
-import sys
-import os
-import time
-import string
-import getopt
-import platform
-import signal
-import tempfile
-### XML
-try:
-    import xml.etree.ElementTree as etree
-except ImportError:
-    import elementtree.ElementTree as etree # Python <= 2.4
-### i18N
-import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
-from gui_modules import globalvar
-import wx
-import wx.aui
-import wx.combo
-import wx.html
-import wx.stc
-try:
-    import wx.lib.agw.customtreectrl as CT
-    import wx.lib.agw.flatnotebook   as FN
-    import wx.lib.customtreectrl as CT
-    import wx.lib.flatnotebook   as FN
-try:
-    import wx.lib.agw.advancedsplash as SC
-    SC = None
-sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
-from gui_modules import utils
-from gui_modules import preferences
-from gui_modules import layertree
-from gui_modules import mapdisp
-from gui_modules import menudata
-from gui_modules import menuform
-from gui_modules import histogram
-from gui_modules import profile
-from gui_modules import mcalc_builder as mapcalculator
-from gui_modules import gcmd
-from gui_modules import dbm
-from gui_modules import workspace
-from gui_modules import goutput
-from gui_modules import gdialogs
-from gui_modules import colorrules
-from gui_modules import ogc_services
-from gui_modules import prompt
-from gui_modules import gmodeler
-from gui_modules import vclean
-from gui_modules import nviz_tools
-from gui_modules.wmsmenu import DisplayWMSMenu #sudeep
-from gui_modules.debug    import Debug
-from gui_modules.ghelp    import MenuTreeWindow, AboutWindow, InstallExtensionWindow
-from gui_modules.toolbars import LMWorkspaceToolbar, LMDataToolbar, LMToolsToolbar, LMMiscToolbar
-from gui_modules.gpyshell import PyShellWindow
-from icons.icon           import Icons
-UserSettings = preferences.globalSettings
-class GMFrame(wx.Frame):
-    """!Layer Manager frame with notebook widget for controlling GRASS
-    GIS. Includes command console page for typing GRASS (and other)
-    commands, tree widget page for managing map layers.
-    def __init__(self, parent, id = wx.ID_ANY, title = _("GRASS GIS Layer Manager"),
-                 workspace = None,
-                 size = globalvar.GM_WINDOW_SIZE, style = wx.DEFAULT_FRAME_STYLE, **kwargs):
-        self.baseTitle = title
-        self.iconsize  = (16, 16)
-        wx.Frame.__init__(self, parent = parent, id = id, size = size,
-                          style = style, **kwargs)
-        self.SetTitle(self.baseTitle)
-        self.SetName("LayerManager")
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
-        self._auimgr = wx.aui.AuiManager(self)
-        # initialize variables
-        self.disp_idx      = 0            # index value for map displays and layer trees
-        self.curr_page     = None         # currently selected page for layer tree notebook
-        self.curr_pagenum  = None         # currently selected page number for layer tree notebook
-        self.workspaceFile = workspace    # workspace file
-        self.workspaceChanged = False     # track changes in workspace
-        self.georectifying = None         # reference to GCP class or None
-        self.gcpmanagement = None         # reference to GCP class or None
-        self.existNviz = False
-        # list of open dialogs
-        self.dialogs        = dict()
-        self.dialogs['preferences'] = None
-        self.dialogs['atm'] = list()
-        # creating widgets
-        self._createMenuBar()
-        self.statusbar = self.CreateStatusBar(number = 1)
-        self.notebook  = self._createNoteBook()
-        self.toolbars  = { 'workspace' : LMWorkspaceToolbar(parent = self),
-                           'data'      : LMDataToolbar(parent = self),
-                           'tools'     : LMToolsToolbar(parent = self),
-                           'misc'      : LMMiscToolbar(parent = self) }
-        self._toolbarsData = { 'workspace' : ("toolbarWorkspace",     # name
-                                              _("Workspace Toolbar"), # caption
-                                              1),                     # row
-                               'data'      : ("toolbarData",
-                                              _("Data Toolbar"),
-                                              1),
-                               'misc'      : ("toolbarMisc",
-                                              _("Misc Toolbar"),
-                                              2),
-                               'tools'     : ("toolbarTools",
-                                              _("Tools Toolbar"),
-                                              2),
-        if sys.platform == 'win32':
-            self._toolbarsList = ('workspace', 'data',
-                                  'tools', 'misc')
-        else:
-            self._toolbarsList = ('data', 'workspace',
-                                  'misc', 'tools')
-        for toolbar in self._toolbarsList:
-            name, caption, row = self._toolbarsData[toolbar]
-            self._auimgr.AddPane(self.toolbars[toolbar],
-                                 wx.aui.AuiPaneInfo().
-                                 Name(name).Caption(caption).
-                                 ToolbarPane().Top().Row(row).
-                                 LeftDockable(False).RightDockable(False).
-                                 BottomDockable(False).TopDockable(True).
-                                 CloseButton(False).Layer(2).
-                                 BestSize((self.toolbars[toolbar].GetBestSize())))
-        # bindings
-        self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
-        self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
-        # minimal frame size
-        self.SetMinSize((500, 400))
-        # AUI stuff
-        self._auimgr.AddPane(self.notebook, wx.aui.AuiPaneInfo().
-                             Left().CentrePane().BestSize((-1,-1)).Dockable(False).
-                             CloseButton(False).DestroyOnClose(True).Row(1).Layer(0))
-        self._auimgr.Update()
-        wx.CallAfter(self.notebook.SetSelectionByName, 'layers')
-        # use default window layout ?
-        if UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'enabled'):
-            dim = UserSettings.Get(group = 'general', key = 'defWindowPos', subkey = 'dim')
-            try:
-               x, y = map(int, dim.split(',')[0:2])
-               w, h = map(int, dim.split(',')[2:4])
-               self.SetPosition((x, y))
-               self.SetSize((w, h))
-            except:
-                pass
-        else:
-            self.Centre()
-        self.Layout()
-        self.Show()
-        # load workspace file if requested
-        if self.workspaceFile:
-            # load given workspace file
-            if self.LoadWorkspaceFile(self.workspaceFile):
-                self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.workspaceFile))
-            else:
-                self.workspaceFile = None
-        else:
-            # start default initial display
-            self.NewDisplay(show = False)
-        # show map display widnow
-        # -> OnSize() -> UpdateMap()
-        if self.curr_page and not self.curr_page.maptree.mapdisplay.IsShown():
-            self.curr_page.maptree.mapdisplay.Show()
-        # redirect stderr to log area
-        self.goutput.Redirect()
-        # fix goutput's pane size
-        self.goutput.SetSashPosition(int(self.GetSize()[1] * .45))
-        # start with layer manager on top
-        if self.curr_page:
-            self.curr_page.maptree.mapdisplay.Raise()
-        wx.CallAfter(self.Raise)
-    def _createMenuBar(self):
-        """!Creates menu bar"""
-        self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
-        self.SetMenuBar(self.menubar)
-        self.menucmd = self.menubar.GetCmd()
-    def _setCopyingOfSelectedText(self):
-        copy = UserSettings.Get(group = 'manager', key = 'copySelectedTextToClipboard', subkey = 'enabled')
-        self.goutput.SetCopyingOfSelectedText(copy)
-    def _createNoteBook(self):
-        """!Creates notebook widgets"""
-        self.notebook = menuform.GNotebook(parent = self, style = globalvar.FNPageDStyle)
-        # create displays notebook widget and add it to main notebook page
-        cbStyle = globalvar.FNPageStyle
-        if globalvar.hasAgw:
-            self.gm_cb = FN.FlatNotebook(self, id = wx.ID_ANY, agwStyle = cbStyle)
-        else:
-            self.gm_cb = FN.FlatNotebook(self, id = wx.ID_ANY, style = cbStyle)
-        self.gm_cb.SetTabAreaColour(globalvar.FNPageColor)
-        self.notebook.AddPage(page = self.gm_cb, text = _("Map layers"), name = 'layers')
-        # create 'command output' text area
-        self.goutput = goutput.GMConsole(self)
-        self.notebook.AddPage(page = self.goutput, text = _("Command console"), name = 'output')
-        self._setCopyingOfSelectedText()
-        # create 'search module' notebook page
-        if not UserSettings.Get(group = 'manager', key = 'hideTabs', subkey = 'search'):
-            self.search = MenuTreeWindow(parent = self)
-            self.notebook.AddPage(page = self.search, text = _("Search module"), name = 'search')
-        else:
-            self.search = None
-        # create 'python shell' notebook page
-        if not UserSettings.Get(group = 'manager', key = 'hideTabs', subkey = 'pyshell'):
-            self.pyshell = PyShellWindow(parent = self)
-            self.notebook.AddPage(page = self.pyshell, text = _("Python shell"), name = 'pyshell')
-        else:
-            self.pyshell = None
-        # bindings
-        self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED,    self.OnCBPageChanged)
-        self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
-        self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING,    self.OnCBPageClosed)
-        return self.notebook
-    def AddNviz(self):
-        """!Add nviz notebook page"""
-        Debug.msg(5, "GMFrame.AddNviz(): begin")
-        self.nviz = nviz_tools.NvizToolWindow(parent = self,
-                                              display = self.curr_page.maptree.GetMapDisplay())
-        idx = self.notebook.GetPageIndexByName('layers')
-        self.notebook.InsertPage(indx = idx + 1, page = self.nviz, text = _("3D view"), name = 'nviz')
-        self.notebook.SetSelectionByName('nviz')
-        self.existNviz = True
-        Debug.msg(5, "GMFrame.AddNviz(): end")
-    def RemoveNviz(self):
-        """!Remove nviz notebook page"""
-        # print self.notebook.GetPage(1)
-        self.notebook.RemovePage(self.notebook.GetPageIndexByName('nviz'))
-        del self.nviz
-        self.notebook.SetSelectionByName('layers')
-    def WorkspaceChanged(self):
-        """!Update window title"""
-        if not self.workspaceChanged:
-            self.workspaceChanged = True
-            self.SetTitle(self.baseTitle + " - " +  os.path.basename(self.workspaceFile) + '*')
-    def OnSettingsChanged(self, event):
-        """!Here can be functions which have to be called after EVT_SETTINGS_CHANGED.
-        Now only set copying of selected text to clipboard (in goutput).
-        ### self._createMenuBar() # bug when menu is re-created on the fly
-    def OnGCPManager(self, event):
-        """!Launch georectifier module
-        from gui_modules import gcpmanager
-        gcpmanager.GCPWizard(self)
-    def OnGModeler(self, event):
-        """!Launch Graphical Modeler"""
-        win = gmodeler.ModelFrame(parent = self)
-        win.CentreOnScreen()
-        win.Show()
-    def OnPsMap(self, event):
-        """!Launch Hardcopy Map Output Utility
-        try:
-            from gui_modules import psmap
-        except:
-                        message = _("Hardcopy Map Output Utility is not available. You can install it by %s") % \
-                            'g.extension -s svnurl=https://svn.osgeo.org/grass/grass-addons extension=wx.psmap')
-            return
-        win = psmap.PsMapFrame(parent = self)
-        win.Show()
-    def OnDone(self, returncode):
-        """Command execution finised"""
-        if hasattr(self, "model"):
-            self.model.DeleteIntermediateData(log = self.goutput)
-            del self.model
-        self.SetStatusText('')
-    def OnRunModel(self, event):
-        """!Run model"""
-        filename = ''
-        dlg = wx.FileDialog(parent = self, message=_("Choose model to run"),
-                            defaultDir = os.getcwd(),
-                            wildcard=_("GRASS Model File (*.gxm)|*.gxm"))
-        if dlg.ShowModal() == wx.ID_OK:
-            filename = dlg.GetPath()
-        if not filename:
-            return
-        self.model = gmodeler.Model()
-        self.model.LoadModel(filename)
-        self.SetStatusText(_('Validating model...'), 0)
-        result =  self.model.Validate()
-        if result:
-            dlg = wx.MessageDialog(parent = self,
-                                   message = _('Model is not valid. Do you want to '
-                                               'run the model anyway?\n\n%s') % '\n'.join(errList),
-                                   caption=_("Run model?"),
-                                   style = wx.YES_NO | wx.NO_DEFAULT |
-                                   wx.ICON_QUESTION | wx.CENTRE)
-            ret = dlg.ShowModal()
-            if ret != wx.ID_YES:
-                return
-        self.SetStatusText(_('Running model...'), 0)
-        self.model.Run(log = self.goutput,
-                       onDone = self.OnDone)
-    def OnMapsets(self, event):
-        """!Launch mapset access dialog
-        dlg = preferences.MapsetAccess(parent = self, id = wx.ID_ANY)
-        dlg.CenterOnScreen()
-            ms = dlg.GetMapsets()
-            gcmd.RunCommand('g.mapsets',
-                            parent = self,
-                            mapset = '%s' % ','.join(ms))
-    def OnCBPageChanged(self, event):
-        """!Page in notebook (display) changed"""
-        old_pgnum = event.GetOldSelection()
-        new_pgnum = event.GetSelection()
-        self.curr_page   = self.gm_cb.GetCurrentPage()
-        self.curr_pagenum = self.gm_cb.GetSelection()
-        try:
-            self.curr_page.maptree.mapdisplay.SetFocus()
-        except:
-            pass
-        event.Skip()
-    def OnPageChanged(self, event):
-        """!Page in notebook changed"""
-        page = event.GetSelection()
-        if page == self.notebook.GetPageIndexByName('output'):
-            # remove '(...)'
-            self.notebook.SetPageText(page, _("Command console"))
-            wx.CallAfter(self.goutput.cmd_prompt.SetFocus)
-        self.SetStatusText('', 0)
-        event.Skip()
-    def OnCBPageClosed(self, event):
-        """!Page of notebook closed
-        Also close associated map display
-        if UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
-            maptree = self.curr_page.maptree
-                message = _("Do you want to save changes in the workspace?")
-            else:
-                message = _("Do you want to store current settings "
-                            "to workspace file?")
-            # ask user to save current settings
-            if maptree.GetCount() > 0:
-                dlg = wx.MessageDialog(self,
-                                       message = message,
-                                       caption = _("Close Map Display %d") % (self.curr_pagenum + 1),
-                                       wx.CANCEL | wx.ICON_QUESTION | wx.CENTRE)
-                if ret == wx.ID_YES:
-                    if not self.workspaceFile:
-                        self.OnWorkspaceSaveAs()
-                    else:
-                        self.SaveToWorkspaceFile(self.workspaceFile)
-                elif ret == wx.ID_CANCEL:
-                    event.Veto()
-                    dlg.Destroy()
-                    return
-                dlg.Destroy()
-        self.gm_cb.GetPage(event.GetSelection()).maptree.Map.Clean()
-        self.gm_cb.GetPage(event.GetSelection()).maptree.Close(True)
-        event.Skip()
-    def GetLayerTree(self):
-        """!Get current layer tree"""
-        return self.curr_page.maptree
-    def GetLogWindow(self):
-        """!Get widget for command output"""
-        return self.goutput
-    def GetMenuCmd(self, event):
-        """!Get GRASS command from menu item
-        Return command as a list"""
-        layer = None
-        if event:
-            cmd = self.menucmd[event.GetId()]
-        try:
-            cmdlist = cmd.split(' ')
-        except: # already list?
-            cmdlist = cmd
-        # check list of dummy commands for GUI modules that do not have GRASS
-        # bin modules or scripts.
-        if cmd in ['vcolors', 'r.mapcalc', 'r3.mapcalc']:
-            return cmdlist
-        try:
-            layer = self.curr_page.maptree.layer_selected
-            name = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].name
-            type = self.curr_page.maptree.GetPyData(layer)[0]['type']
-        except:
-            layer = None
-        if layer and len(cmdlist) == 1: # only if no paramaters given
-            if (type == 'raster' and cmdlist[0][0] == 'r' and cmdlist[0][1] != '3') or \
-                    (type == 'vector' and cmdlist[0][0] == 'v'):
-                input = menuform.GUI().GetCommandInputMapParamKey(cmdlist[0])
-                if input:
-                    cmdlist.append("%s=%s" % (input, name))
-        return cmdlist
-    def RunMenuCmd(self, event = None, cmd = []):
-        """!Run command selected from menu"""
-        if event:
-            cmd = self.GetMenuCmd(event)
-        self.goutput.RunCmd(cmd, switchPage = False)
-    def OnMenuCmd(self, event = None, cmd = []):
-        """!Parse command selected from menu"""
-        if event:
-        menuform.GUI(parent = self).ParseCommand(cmd)
-    def OnVDigit(self, event):
-        """!Start vector digitizer
-        if not self.curr_page:
-            self.MsgNoLayerSelected()
-            return
-        tree = self.GetLayerTree()
-        layer = tree.layer_selected
-        # no map layer selected
-        if not layer:
-            return
-        # available only for vector map layers
-        try:
-            mapLayer = tree.GetPyData(layer)[0]['maplayer']
-        except:
-            mapLayer = None
-        if not mapLayer or mapLayer.GetType() != 'vector':
-            gcmd.GMessage(parent = self,
-                          message = _("Selected map layer is not vector."))
-            return
-        if mapLayer.GetMapset() != grass.gisenv()['MAPSET']:
-                          message = _("Editing is allowed only for vector maps from the "
-                                      "current mapset."))
-            return
-        if not tree.GetPyData(layer)[0]:
-            return
-        dcmd = tree.GetPyData(layer)[0]['cmd']
-        if not dcmd:
-            return
-        tree.OnStartEditing(None)
-    def OnRunScript(self, event):
-        """!Run script"""
-        # open dialog and choose script file
-        dlg = wx.FileDialog(parent = self, message = _("Choose script file to run"),
-                            wildcard = _("Python script (*.py)|*.py|Bash script (*.sh)|*.sh"))
-        filename = None
-        if not filename:
-            return False
-        if not os.path.exists(filename):
-            gcmd.GError(parent = self,
-                        message = _("Script file '%s' doesn't exist. "
-                                    "Operation cancelled.") % filename)
-            return
-        self.goutput.WriteCmdLog(_("Launching script '%s'...") % filename)
-        self.goutput.RunCmd([filename], switchPage = True)
-    def OnChangeLocation(self, event):
-        """Change current location"""
-        dlg = gdialogs.LocationDialog(parent = self)
-            location, mapset = dlg.GetValues()
-            if location and mapset:
-                ret = gcmd.RunCommand("g.gisenv",
-                                      set = "LOCATION_NAME=%s" % location)
-                ret += gcmd.RunCommand("g.gisenv",
-                                       set = "MAPSET=%s" % mapset)
-                if ret > 0:
-                    wx.MessageBox(parent = self,
-                                  message = _("Unable to switch to location <%(loc)s> mapset <%(mapset)s>.") % \
-                                      { 'loc' : location, 'mapset' : mapset },
-                                  caption = _("Error"), style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
-                else:
-                    # close workspace
-                    self.OnWorkspaceClose()
-                    self.OnWorkspaceNew()
-                                  message = _("Current location is <%(loc)s>.\n"
-                                              "Current mapset is <%(mapset)s>.") % \
-                                  caption = _("Info"), style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-    def OnChangeMapset(self, event):
-        """Change current mapset"""
-        dlg = gdialogs.MapsetDialog(parent = self)
-            mapset = dlg.GetMapset()
-            if mapset:
-                if gcmd.RunCommand("g.gisenv",
-                                   set = "MAPSET=%s" % mapset) != 0:
-                                  message = _("Unable to switch to mapset <%s>.") % mapset,
-                else:
-                                  message = _("Current mapset is <%s>.") % mapset,
-    def OnNewVector(self, event):
-        """!Create new vector map layer"""
-        name, add = gdialogs.CreateNewVector(self, log = self.goutput,
-                                             cmd = (('v.edit',
-                                                     'map')))
-        if name and add:
-            self.curr_page.maptree.AddLayer(ltype = 'vector',
-                                            lname = name,
-                                            lchecked = True,
-                                            lopacity = 1.0,
-                                            lcmd = ['d.vect', 'map=%s' % name])
-    def OnAboutGRASS(self, event):
-        """!Display 'About GRASS' dialog"""
-        win = AboutWindow(self)
-        win.Show(True)
-    def _popupMenu(self, data):
-        """!Create popup menu
-        menu = wx.Menu()
-        for key, handler in data:
-            if key is None:
-                menu.AppendSeparator()
-                continue
-            item = wx.MenuItem(menu, wx.ID_ANY, Icons['layerManager'][key].GetLabel())
-            item.SetBitmap(Icons['layerManager'][key].GetBitmap(self.iconsize))
-            menu.AppendItem(item)
-            self.Bind(wx.EVT_MENU, handler, item)
-        # create menu
-        self.PopupMenu(menu)
-        menu.Destroy()
-    def OnImportMenu(self, event):
-        """!Import maps menu (import, link)
-        self._popupMenu((('rastImport',    self.OnImportGdalLayers),
-                         ('rastLink',      self.OnLinkGdalLayers),
-                         (None, None),
-                         ('vectImport',    self.OnImportOgrLayers),
-                         ('vectLink',      self.OnLinkOgrLayers)))
-    def OnWorkspaceNew(self, event = None):
-        """!Create new workspace file
-        Erase current workspace settings first
-        Debug.msg(4, "GMFrame.OnWorkspaceNew():")
-        # start new map display if no display is available
-            self.NewDisplay()
-        if self.workspaceFile and self.workspaceChanged:
-            self.OnWorkspaceSave()
-        elif self.workspaceFile is None and maptree.GetCount() > 0:
-             dlg = wx.MessageDialog(self, message = _("Current workspace is not empty. "
-                                                    "Do you want to store current settings "
-                                                    "to workspace file?"),
-                                    caption = _("Create new workspace?"),
-                                    style = wx.YES_NO | wx.YES_DEFAULT | \
-                                        wx.CANCEL | wx.ICON_QUESTION)
-                 dlg.Destroy()
-                 return
-             dlg.Destroy()
-        # delete all items
-        maptree.DeleteAllItems()
-        # add new root element
-        maptree.root = maptree.AddRoot("Map Layers")
-        self.curr_page.maptree.SetPyData(maptree.root, (None,None))
-        # no workspace file loaded
-    def OnWorkspaceOpen(self, event = None):
-        """!Open file with workspace definition"""
-        dlg = wx.FileDialog(parent = self, message = _("Choose workspace file"),
-                            defaultDir = os.getcwd(), wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"))
-        filename = ''
-        if filename == '':
-            return
-        Debug.msg(4, "GMFrame.OnWorkspaceOpen(): filename=%s" % filename)
-        # delete current layer tree content
-        self.LoadWorkspaceFile(filename)
-        self.workspaceFile = filename
-    def LoadWorkspaceFile(self, filename):
-        """!Load layer tree definition stored in GRASS Workspace XML file (gxw)
-        @todo Validate against DTD
-        @return False on error
-        # dtd
-        dtdFilename = os.path.join(globalvar.ETCWXDIR, "xml", "grass-gxw.dtd")
-        # parse workspace file
-        try:
-            gxwXml = workspace.ProcessWorkspaceFile(etree.parse(filename))
-        except Exception, e:
-                        message = _("Reading workspace file <%s> failed.\n"
-                                    "Invalid file, unable to parse XML document.") % filename)
-            return
-        busy = wx.BusyInfo(message = _("Please wait, loading workspace..."),
-                           parent = self)
-        wx.Yield()
-        # load layer manager window properties
-        if UserSettings.Get(group = 'workspace', key = 'posManager', subkey = 'enabled') is False:
-            if gxwXml.layerManager['pos']:
-                self.SetPosition(gxwXml.layerManager['pos'])
-            if gxwXml.layerManager['size']:
-                self.SetSize(gxwXml.layerManager['size'])
-        # start map displays first (list of layers can be empty)
-        displayId = 0
-        mapdisplay = list()
-        for display in gxwXml.displays:
-            mapdisp = self.NewDisplay(show = False)
-            mapdisplay.append(mapdisp)
-            maptree = self.gm_cb.GetPage(displayId).maptree
-            # set windows properties
-            mapdisp.SetProperties(render = display['render'],
-                                  mode = display['mode'],
-                                  showCompExtent = display['showCompExtent'],
-                                  constrainRes = display['constrainRes'],
-                                  projection = display['projection']['enabled'])
-            if display['projection']['enabled']:
-                if display['projection']['epsg']:
-                    UserSettings.Set(group = 'display', key = 'projection', subkey = 'epsg',
-                                     value = display['projection']['epsg'])
-                    if display['projection']['proj']:
-                        UserSettings.Set(group = 'display', key = 'projection', subkey = 'proj4',
-                                         value = display['projection']['proj'])
-            # set position and size of map display
-            if UserSettings.Get(group = 'workspace', key = 'posDisplay', subkey = 'enabled') is False:
-                if display['pos']:
-                    mapdisp.SetPosition(display['pos'])
-                if display['size']:
-                    mapdisp.SetSize(display['size'])
-            # set extent if defined
-            if display['extent']:
-                w, s, e, n = display['extent']
-                region = maptree.Map.region = maptree.Map.GetRegion(w = w, s = s, e = e, n = n)
-                mapdisp.GetWindow().ResetZoomHistory()
-                mapdisp.GetWindow().ZoomHistory(region['n'],
-                                                region['s'],
-                                                region['e'],
-                                                region['w'])
-            mapdisp.Show()
-            displayId += 1
-        maptree = None
-        selected = [] # list of selected layers
-        # load list of map layers
-        for layer in gxwXml.layers:
-            display = layer['display']
-            maptree = self.gm_cb.GetPage(display).maptree
-            newItem = maptree.AddLayer(ltype = layer['type'],
-                                       lname = layer['name'],
-                                       lchecked = layer['checked'],
-                                       lopacity = layer['opacity'],
-                                       lcmd = layer['cmd'],
-                                       lgroup = layer['group'],
-                                       lnviz = layer['nviz'],
-                                       lvdigit = layer['vdigit'])
-            if layer.has_key('selected'):
-                if layer['selected']:
-                    selected.append((maptree, newItem))
-                else:
-                    maptree.SelectItem(newItem, select = False)
-        for maptree, layer in selected:
-            if not maptree.IsSelected(layer):
-                maptree.SelectItem(layer, select = True)
-                maptree.layer_selected = layer
-        busy.Destroy()
-        if maptree:
-            # reverse list of map layers
-            maptree.Map.ReverseListOfLayers()
-        for mdisp in mapdisplay:
-            mdisp.MapWindow2D.UpdateMap()
-        return True
-    def OnWorkspaceLoadGrcFile(self, event):
-        """!Load map layers from GRC file (Tcl/Tk GUI) into map layer tree"""
-        dlg = wx.FileDialog(parent = self, message = _("Choose GRC file to load"),
-                            defaultDir = os.getcwd(), wildcard = _("Old GRASS Workspace File (*.grc)|*.grc"))
-        filename = ''
-            return
-        Debug.msg(4, "GMFrame.OnWorkspaceLoadGrcFile(): filename=%s" % filename)
-            self.NewDisplay()
-                           parent = self)
-        wx.Yield()
-        maptree = None
-        for layer in workspace.ProcessGrcFile(filename).read(self):
-            maptree = self.gm_cb.GetPage(layer['display']).maptree
-                                       lgroup = layer['group'])
-            busy.Destroy()
-        if maptree:
-    def OnWorkspaceSaveAs(self, event = None):
-        """!Save workspace definition to selected file"""
-        dlg = wx.FileDialog(parent = self, message = _("Choose file to save current workspace"),
-                            defaultDir = os.getcwd(), wildcard = _("GRASS Workspace File (*.gxw)|*.gxw"), style = wx.FD_SAVE)
-        filename = ''
-            return False
-        # check for extension
-        if filename[-4:] != ".gxw":
-            filename += ".gxw"
-        if os.path.exists(filename):
-            dlg = wx.MessageDialog(self, message = _("Workspace file <%s> already exists. "
-                                                   "Do you want to overwrite this file?") % filename,
-                                   caption = _("Save workspace"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
-            if dlg.ShowModal() != wx.ID_YES:
-                dlg.Destroy()
-                return False
-        Debug.msg(4, "GMFrame.OnWorkspaceSaveAs(): filename=%s" % filename)
-        self.SaveToWorkspaceFile(filename)
-    def OnWorkspaceSave(self, event = None):
-        """!Save file with workspace definition"""
-                                                   "Do you want to overwrite this file?") % \
-                                       self.workspaceFile,
-                dlg.Destroy()
-            else:
-                Debug.msg(4, "GMFrame.OnWorkspaceSave(): filename=%s" % self.workspaceFile)
-        else:
-    def SaveToWorkspaceFile(self, filename):
-        """!Save layer tree layout to workspace file
-        Return True on success, False on error
-        tmpfile = tempfile.TemporaryFile(mode = 'w+b')
-        try:
-            workspace.WriteWorkspaceFile(lmgr = self, file = tmpfile)
-        except StandardError, e:
-                        message = _("Writing current settings to workspace file "
-                                    "failed."))
-            return False
-        try:
-            mfile = open(filename, "w")
-            tmpfile.seek(0)
-            for line in tmpfile.readlines():
-                mfile.write(line)
-        except IOError:
-                        message = _("Unable to open file <%s> for writing.") % filename)
-            return False
-        mfile.close()
-        return True
-    def OnWorkspaceClose(self, event = None):
-        """!Close file with workspace definition
-        If workspace has been modified ask user to save the changes.
-        Debug.msg(4, "GMFrame.OnWorkspaceClose(): file=%s" % self.workspaceFile)
-        self.OnDisplayCloseAll()
-        self.disp_idx = 0
-    def OnDisplayClose(self, event = None):
-        """!Close current map display window
-        if self.curr_page and self.curr_page.maptree.mapdisplay:
-            self.curr_page.maptree.mapdisplay.OnCloseWindow(event)
-    def OnDisplayCloseAll(self, event = None):
-        """!Close all open map display windows
-        displays = list()
-        for page in range(0, self.gm_cb.GetPageCount()):
-            displays.append(self.gm_cb.GetPage(page).maptree.mapdisplay)
-        for display in displays:
-            display.OnCloseWindow(event)
-    def RulesCmd(self, event):
-        """!Launches dialog for commands that need rules input and
-        processes rules
-        if cmd[0] == 'r.colors':
-            ctable = colorrules.ColorTable(self, raster = True)
-        else:
-            ctable = colorrules.ColorTable(self, raster = False)
-        ctable.CentreOnScreen()
-        ctable.Show()
-    def OnInstallExtension(self, event):
-        """!Install extension from GRASS Addons SVN repository"""
-        win = InstallExtensionWindow(self, size = (650, 550))
-        win.Show()
-    def OnPreferences(self, event):
-        """!General GUI preferences/settings
-        if not self.dialogs['preferences']:
-            dlg = preferences.PreferencesDialog(parent = self)
-            self.dialogs['preferences'] = dlg
-            self.dialogs['preferences'].CenterOnScreen()
-            dlg.Bind(preferences.EVT_SETTINGS_CHANGED, self.OnSettingsChanged)
-        self.dialogs['preferences'].ShowModal()
-        """!Show help
-        self.goutput.RunCmd(['g.manual','-i'])
-    def DispHistogram(self, event):
-        Init histogram display canvas and tools
-        self.histogram = histogram.HistFrame(self,
-                                             id = wx.ID_ANY, pos = wx.DefaultPosition, size = (400,300),
-                                             style = wx.DEFAULT_FRAME_STYLE)
-        #show new display
-        self.histogram.Show()
-        self.histogram.Refresh()
-        self.histogram.Update()
-    def DispProfile(self, event):
-        Init profile canvas and tools
-        self.profile = profile.ProfileFrame(self,
-        self.profile.Show()
-        self.profile.Refresh()
-        self.profile.Update()
-    def OnMapCalculator(self, event, cmd = ''):
-        """!Init map calculator for interactive creation of mapcalc statements
-        if event:
-            try:
-            except KeyError:
-                cmd = ['r.mapcalc']
-        win = mapcalculator.MapCalcFrame(parent = self,
-                                         cmd = cmd[0])
-        win.Show()
-    def OnVectorCleaning(self, event, cmd = ''):
-        """!Init interactive vector cleaning
-        if event:
-        win = vclean.VectorCleaningFrame(parent = self, cmd = cmd[0])
-        win.Show()
-    def OnImportDxfFile(self, event, cmd = None):
-        """!Convert multiple DXF layers to GRASS vector map layers"""
-        dlg = gdialogs.DxfImportDialog(parent = self)
-        dlg.CentreOnScreen()
-        dlg.Show()
-    def OnImportGdalLayers(self, event, cmd = None):
-        """!Convert multiple GDAL layers to GRASS raster map layers"""
-        dlg = gdialogs.GdalImportDialog(parent = self)
-        dlg.Show()
-    def OnLinkGdalLayers(self, event, cmd = None):
-        """!Link multiple GDAL layers to GRASS raster map layers"""
-        dlg = gdialogs.GdalImportDialog(parent = self, link = True)
-        dlg.Show()
-    def OnImportOgrLayers(self, event, cmd = None):
-        """!Convert multiple OGR layers to GRASS vector map layers"""
-        dlg = gdialogs.GdalImportDialog(parent = self, ogr = True)
-        dlg.Show()
-    def OnLinkOgrLayers(self, event, cmd = None):
-        """!Links multiple OGR layers to GRASS vector map layers"""
-        dlg = gdialogs.GdalImportDialog(parent = self, ogr = True, link = True)
-        dlg.Show()
-    def OnImportWMS(self, event):
-        """!Import data from OGC WMS server"""
-        dlg = ogc_services.WMSDialog(parent = self, service = 'wms')
-        if dlg.ShowModal() == wx.ID_OK: # -> import layers
-            layers = dlg.GetLayers()
-            if len(layers.keys()) > 0:
-                for layer in layers.keys():
-                    cmd = ['r.in.wms',
-                           'mapserver=%s' % dlg.GetSettings()['server'],
-                           'layers=%s' % layer,
-                           'output=%s' % layer,
-                           'format=png',
-                           '--overwrite']
-                    styles = ','.join(layers[layer])
-                    if styles:
-                        cmd.append('styles=%s' % styles)
-                    self.goutput.RunCmd(cmd, switchPage = True)
-                    self.curr_page.maptree.AddLayer(ltype = 'raster',
-                                                    lname = layer,
-                                                    lcmd = ['d.rast', 'map=%s' % layer],
-                                                    multiple = False)
-            else:
-                self.goutput.WriteWarning(_("Nothing to import. No WMS layer selected."))
-        dlg.Destroy()
-    def OnShowAttributeTable(self, event):
-        """!Show attribute table of the given vector map layer
-            return
-        if not layer:
-            return
-        try:
-            maptype = tree.GetPyData(layer)[0]['maplayer'].type
-        except:
-            maptype = None
-        if not maptype or maptype != 'vector':
-            return
-            return
-        if not dcmd:
-            return
-        busy = wx.BusyInfo(message = _("Please wait, loading attribute data..."),
-                           parent = self)
-        wx.Yield()
-        dbmanager = dbm.AttributeManager(parent = self, id = wx.ID_ANY,
-                                         size = wx.Size(500, 300),
-                                         item = layer, log = self.goutput)
-        busy.Destroy()
-        # register ATM dialog
-        self.dialogs['atm'].append(dbmanager)
-        # show ATM window
-        dbmanager.Show()
-    def OnNewDisplay1(self, event = None):
-        """!Create new layer tree and map display instance"""
-        self.NewDisplay1()
-    def NewDisplay1(self, show = True):
-        Debug.msg(1, "GMFrame.NewDisplay(): idx=%d" % self.disp_idx)
-    	DisplayWMSMenu()
-    def OnNewDisplay(self, event = None):
-        self.NewDisplay()
-    def NewDisplay(self, show = True):
-        """!Create new layer tree, which will
-        create an associated map display frame
-        @param show show map display window if True
-        @return reference to mapdisplay intance
-        # make a new page in the bookcontrol for the layer tree (on page 0 of the notebook)
-        self.pg_panel = wx.Panel(self.gm_cb, id = wx.ID_ANY, style = wx.EXPAND)
-        self.gm_cb.AddPage(self.pg_panel, text = "Display "+ str(self.disp_idx + 1), select = True)
-        # create layer tree (tree control for managing GIS layers)  and put on new notebook page
-        self.curr_page.maptree = layertree.LayerTree(self.curr_page, id = wx.ID_ANY, pos = wx.DefaultPosition,
-                                                     size = wx.DefaultSize, style = wx.TR_HAS_BUTTONS |
-                                                     wx.TR_LINES_AT_ROOT| wx.TR_HIDE_ROOT |
-                                                     wx.TR_DEFAULT_STYLE| wx.NO_BORDER | wx.FULL_REPAINT_ON_RESIZE,
-                                                     idx = self.disp_idx, lmgr = self, notebook = self.gm_cb,
-                                                     auimgr = self._auimgr, showMapDisplay = show)
-        # layout for controls
-        cb_boxsizer = wx.BoxSizer(wx.VERTICAL)
-        cb_boxsizer.Add(self.curr_page.maptree, proportion = 1, flag = wx.EXPAND, border = 1)
-        self.curr_page.SetSizer(cb_boxsizer)
-        cb_boxsizer.Fit(self.curr_page.maptree)
-        self.curr_page.Layout()
-        self.curr_page.maptree.Layout()
-            idx = 4 + self.disp_idx * 4
-            try:
-                x, y = map(int, dim.split(',')[idx:idx + 2])
-                w, h = map(int, dim.split(',')[idx + 2:idx + 4])
-                self.curr_page.maptree.mapdisplay.SetPosition((x, y))
-                self.curr_page.maptree.mapdisplay.SetSize((w, h))
-            except:
-                pass
-        self.disp_idx += 1
-        return self.curr_page.maptree.mapdisplay
-    def OnAddMaps(self, event = None):
-        """!Add selected map layers into layer tree"""
-        dialog = gdialogs.AddMapLayersDialog(parent = self, title = _("Add selected map layers into layer tree"))
-        if dialog.ShowModal() == wx.ID_OK:
-                self.NewDisplay()
-                               parent = self)
-            wx.Yield()
-            for layerName in dialog.GetMapLayers():
-                if dialog.GetLayerType() == 'raster':
-                    cmd = ['d.rast', 'map=%s' % layerName]
-                elif dialog.GetLayerType() == 'vector':
-                    cmd = ['d.vect', 'map=%s' % layerName]
-                newItem = maptree.AddLayer(ltype = dialog.GetLayerType(),
-                                           lname = layerName,
-                                           lchecked = False,
-                                           lopacity = 1.0,
-                                           lcmd = cmd,
-                                           lgroup = None)
-            busy.Destroy()
-    def OnAddRaster(self, event):
-        """!Add raster map layer"""
-            self.NewDisplay(show = True)
-        self.curr_page.maptree.AddLayer('raster')
-    def OnAddRaster3D(self, event):
-        """!Add 3D raster map layer"""
-        self.AddRaster3D(event)
-    def OnAddRasterMisc(self, event):
-        """!Create misc raster popup-menu"""
-        self._popupMenu((('addRast3d', self.OnAddRaster3D),
-                         (None, None),
-                         ('addRgb',    self.OnAddRasterRGB),
-                         ('addHis',    self.OnAddRasterHIS),
-                         (None, None),
-                         ('addShaded', self.OnAddRasterShaded),
-                         (None, None),
-                         ('addRArrow', self.OnAddRasterArrow),
-                         ('addRNum',   self.OnAddRasterNum)))
-    def OnAddVector(self, event):
-        """!Add vector map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('vector')
-    def OnAddVectorMisc(self, event):
-        """!Create misc vector popup-menu"""
-        self._popupMenu((('addThematic', self.OnAddVectorTheme),
-                         ('addChart',    self.OnAddVectorChart)))
-    def OnAddVectorTheme(self, event):
-        """!Add thematic vector map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('thememap')
-    def OnAddVectorChart(self, event):
-        """!Add chart vector map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('themechart')
-    def OnAddOverlay(self, event):
-        """!Create decoration overlay menu"""
-        self._popupMenu((('addGrid',     self.OnAddGrid),
-                         ('addLabels',   self.OnAddLabels),
-                         ('addGeodesic', self.OnAddGeodesic),
-                         ('addRhumb',    self.OnAddRhumb),
-                         (None, None),
-                         ('addCmd',      self.OnAddCommand)))
-        """!Add 3D raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('3d-raster')
-    def OnAddRasterRGB(self, event):
-        """!Add RGB raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('rgb')
-    def OnAddRasterHIS(self, event):
-        """!Add HIS raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('his')
-    def OnAddRasterShaded(self, event):
-        """!Add shaded relief raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('shaded')
-    def OnAddRasterArrow(self, event):
-        """!Add flow arrows raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('rastarrow')
-    def OnAddRasterNum(self, event):
-        """!Add cell number raster map to the current layer tree"""
-        self.curr_page.maptree.AddLayer('rastnum')
-    def OnAddCommand(self, event):
-        """!Add command line map layer to the current layer tree"""
-        self.curr_page.maptree.AddLayer('command')
-    def OnAddGroup(self, event):
-        """!Add layer group"""
-        self.curr_page.maptree.AddLayer('group')
-    def OnAddGrid(self, event):
-        """!Add grid map layer to the current layer tree"""
-        self.curr_page.maptree.AddLayer('grid')
-    def OnAddGeodesic(self, event):
-        """!Add geodesic line map layer to the current layer tree"""
-        self.curr_page.maptree.AddLayer('geodesic')
-    def OnAddRhumb(self, event):
-        """!Add rhumb map layer to the current layer tree"""
-        self.curr_page.maptree.AddLayer('rhumb')
-    def OnAddLabels(self, event):
-        """!Add vector labels map layer to the current layer tree"""
-        self.curr_page.maptree.AddLayer('labels')
-    def OnDeleteLayer(self, event):
-        """!Remove selected map layer from the current layer Tree
-        if not self.curr_page or not self.curr_page.maptree.layer_selected:
-            return
-        if UserSettings.Get(group = 'manager', key = 'askOnRemoveLayer', subkey = 'enabled'):
-            layerName = ''
-            for item in self.curr_page.maptree.GetSelections():
-                name = str(self.curr_page.maptree.GetItemText(item))
-                idx = name.find('(opacity')
-                if idx > -1:
-                    layerName += '<' + name[:idx].strip(' ') + '>,\n'
-                else:
-                    layerName += '<' + name + '>,\n'
-            layerName = layerName.rstrip(',\n')
-            if len(layerName) > 2: # <>
-                message = _("Do you want to remove map layer(s)\n%s\n"
-                            "from layer tree?") % layerName
-            else:
-                message = _("Do you want to remove selected map layer(s) "
-            dlg = wx.MessageDialog (parent = self, message = message,
-                                    caption = _("Remove map layer"),
-                dlg.Destroy()
-                return
-            dlg.Destroy()
-        for layer in self.curr_page.maptree.GetSelections():
-            if self.curr_page.maptree.GetPyData(layer)[0]['type'] == 'group':
-                self.curr_page.maptree.DeleteChildren(layer)
-            self.curr_page.maptree.Delete(layer)
-    def OnKeyDown(self, event):
-        """!Key pressed"""
-        kc = event.GetKeyCode()
-        if event.ControlDown():
-            if kc == wx.WXK_TAB:
-                # switch layer list / command output
-                if self.notebook.GetSelection() == self.notebook.GetPageIndexByName('layers'):
-                    self.notebook.SetSelectionByName('output')
-                else:
-        try:
-            ckc = chr(kc)
-        except ValueError:
-            event.Skip()
-            return
-        if event.CtrlDown():
-            if kc == 'R':
-                self.OnAddRaster(None)
-            elif kc == 'V':
-                self.OnAddVector(None)
-        event.Skip()
-    def OnCloseWindow(self, event):
-        """!Cleanup when wxGUI is quitted"""
-            self._auimgr.UnInit()
-            self.Destroy()
-            return
-        if self.workspaceChanged and \
-                UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
-            else:
-                                       caption = _("Quit GRASS GUI"),
-                    else:
-                    event.Veto()
-                    dlg.Destroy()
-                    return
-                dlg.Destroy()
-        # don't ask any more...
-        UserSettings.Set(group = 'manager', key = 'askOnQuit', subkey = 'enabled',
-                         value = False)
-        self.gm_cb.DeleteAllPages()
-        self.Destroy()
-    def MsgNoLayerSelected(self):
-        """!Show dialog message 'No layer selected'"""
-                      message = _("No map layer selected. Operation cancelled."),
-                      caption = _("Message"),
-                      style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
-class GMApp(wx.App):
-    def __init__(self, workspace = None):
-        """!Main GUI class.
-        @param workspace path to the workspace file
-        # call parent class initializer
-        wx.App.__init__(self, False)
-        self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
-    def OnInit(self):
-        """!Initialize all available image handlers
-        @return True
-        wx.InitAllImageHandlers()
-        # create splash screen
-        introImagePath = os.path.join(globalvar.ETCIMGDIR, "silesia_splash.png")
-        introImage     = wx.Image(introImagePath, wx.BITMAP_TYPE_PNG)
-        introBmp       = introImage.ConvertToBitmap()
-        if SC:
-            splash = SC.AdvancedSplash(bitmap = introBmp,
-                                       timeout = 2000, parent = None, id = wx.ID_ANY)
-            splash.SetText(_('Starting GRASS GUI...'))
-            splash.SetTextColour(wx.Colour(45, 52, 27))
-            splash.SetTextFont(wx.Font(pointSize = 15, family = wx.DEFAULT, style = wx.NORMAL,
-                                       weight = wx.BOLD))
-            splash.SetTextPosition((150, 430))
-        else:
-            wx.SplashScreen (bitmap = introBmp, splashStyle = wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
-                             milliseconds = 2000, parent = None, id = wx.ID_ANY)
-        wx.Yield()
-        ### TODO: adjust initial window layout if necessary
-        w, h = wx.GetDisplaySize()
-        # only neccessary if one of the windows is falling out of
-        # the current display size
-        # check if settings file exists
-        # if settings file exists, check if we should use the stored settings
-        #     if we should use stored settings, use stored settings
-        #     else use default settings
-        # else if settings file does not exist, use default settings
-        # check if any of the windows is falling out of the current display
-        # if yes, pull it in
-        #   falling out to the right
-        #   x pos = display width - window width
-        #   falling out to the bottom
-        #   y pos = 0
-        # update settings
-        # if settings file exists, update settings but keep settings for
-        # additional map display windows, or update them too
-        # do not erase settings for additional map display windows !
-        # create and show main frame
-        mainframe = GMFrame(parent = None, id = wx.ID_ANY,
-                            workspace = self.workspaceFile)
-        mainframe.Show()
-        self.SetTopWindow(mainframe)
-        return True
-class Usage(Exception):
-    def __init__(self, msg):
-        self.msg = msg
-def printHelp():
-    """!Print program help"""
-    print >> sys.stderr, "Usage:"
-    print >> sys.stderr, " python wxgui.py [options]"
-    print >> sys.stderr, "%sOptions:" % os.linesep
-    print >> sys.stderr, " -w\t--workspace file\tWorkspace file to load"
-    sys.exit(0)
-def process_opt(opts, args):
-    """!Process command-line arguments"""
-    workspaceFile = None
-    for o, a in opts:
-        if o in ("-h", "--help"):
-            printHelp()
-        if o in ("-w", "--workspace"):
-            if a != '':
-                workspaceFile = str(a)
-            else:
-                workspaceFile = args.pop(0)
-    return (workspaceFile,)
-def main(argv = None):
-    # process command-line arguments
-    if argv is None:
-        argv = sys.argv
-    try:
-        try:
-            opts, args = getopt.getopt(argv[1:], "hw:",
-                                       ["help", "workspace"])
-        except getopt.error, msg:
-            raise Usage(msg)
-    except Usage, err:
-        print >> sys.stderr, err.msg
-        print >> sys.stderr, "for help use --help"
-        printHelp()
-    workspaceFile = process_opt(opts, args)[0]
-    # run application
-    app = GMApp(workspaceFile)
-    # suppress wxPython logs
-    q = wx.LogNull()
-    app.MainLoop()
-if __name__ == "__main__":
-    sys.exit(main())
