[GRASS-SVN] r47106 - grass/trunk/visualization/nviz2/cmd
Thu Jul 14 03:45:20 EDT 2011
Author: annakrat
Date: 2011-07-14 00:45:20 -0700 (Thu, 14 Jul 2011)
New Revision: 47106
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/main.c
   grass/trunk/visualization/nviz2/cmd/volume.c
nviz_cmd: volume slices implemented
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2011-07-14 06:17:07 UTC (rev 47105)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2011-07-14 07:45:20 UTC (rev 47106)
@@ -627,7 +627,7 @@
     params->isosurf_transp_map->multiple = YES;
     params->isosurf_transp_map->required = NO;
     params->isosurf_transp_map->description =
-	_("Name of 3D raster map(s) for transparency");
+	_("Name of 3D raster map(s) for isosurface transparency");
     params->isosurf_transp_map->guisection = _("Volumes");
     params->isosurf_transp_map->key = "isosurf_transparency_map";
@@ -659,6 +659,40 @@
     params->isosurf_shine_const->guisection = _("Volumes");
     params->isosurf_shine_const->options = "0-255";
+    /* slices */
+    /* slice axis */
+    params->slice = G_define_option();
+    params->slice->key = "slice";
+    params->slice->key_desc = "volume:axis";
+    params->slice->type = TYPE_STRING;
+    params->slice->required = NO;
+    params->slice->multiple = YES;
+    params->slice->description = _("Volume slice parallel to given axis (x, y, z)");
+    params->slice->guisection = _("Volumes");
+    /* slice position */
+    params->slice_pos = G_define_option();
+    params->slice_pos->key = "slice_position";
+    params->slice_pos->key_desc = "x1,x2,y1,y2,z1,z2";
+    params->slice_pos->type = TYPE_DOUBLE;
+    params->slice_pos->required = NO;
+    params->slice_pos->multiple = YES;
+    params->slice_pos->description = _("Volume slice position");
+    params->slice_pos->guisection = _("Volumes");
+    params->slice_pos->answer = "0,1,0,1,0,1";
+    /* slice transparency */
+    params->slice_transp = G_define_option();
+    params->slice_transp->key = "slice_transparency";
+    params->slice_transp->key_desc = "value";
+    params->slice_transp->type = TYPE_INTEGER;
+    params->slice_transp->required = NO;
+    params->slice_transp->multiple = YES;
+    params->slice_transp->description = _("Volume slice transparency");
+    params->slice_transp->guisection = _("Volumes");
+    params->slice_transp->answer = "0";
+    params->slice_transp->options = "0-255";
     return;
@@ -852,7 +886,7 @@
     int nvpoints;
-    int nvolumes, nisosurf;
+    int nvolumes, nisosurf, nslices;
     /* topography */
     nelev_map = opt_get_num_answers(params->elev_map);
@@ -1009,8 +1043,9 @@
     nvolumes = opt_get_num_answers(params->volume);
     nisosurf = opt_get_num_answers(params->isosurf_level);
+    nslices = opt_get_num_answers(params->slice);
-    /* transparency */
+    /* isosurface transparency */
     nmaps = opt_get_num_answers(params->isosurf_transp_map);
     nconsts = opt_get_num_answers(params->isosurf_transp_const);
@@ -1019,15 +1054,27 @@
 		      params->isosurf_level->key, nisosurf, params->isosurf_transp_map->key, nmaps,
 		      params->isosurf_transp_const->key, nconsts);
-    /* shininess */
+    /* isosurface shininess */
     nmaps = opt_get_num_answers(params->isosurf_shine_map);
     nconsts = opt_get_num_answers(params->isosurf_shine_const);
     if ((nmaps + nconsts > 0) && (nisosurf != nmaps + nconsts))
-    G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"),
-		    params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
-		    params->isosurf_shine_const->key, nconsts);
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d, <%s> %d"),
+			params->isosurf_level->key, nisosurf, params->isosurf_shine_map->key, nmaps,
+			params->isosurf_shine_const->key, nconsts);
+    nconsts = opt_get_num_answers(params->slice_transp);
+    if (nslices != nconsts)
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
+			params->slice->key, nslices, params->slice_transp->key, nconsts);
+    ncoords = opt_get_num_answers(params->slice_pos);
+    if (ncoords != 6 * nslices)
+	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d x 6)"),
+			  params->slice->key, nslices, params->slice_pos->key, ncoords/6);
     return;
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-07-14 06:17:07 UTC (rev 47105)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-07-14 07:45:20 UTC (rev 47106)
@@ -23,7 +23,7 @@
     /* volumes */
 	*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
 	*isosurf_color_map, *isosurf_color_const, *isosurf_transp_map, *isosurf_transp_const,
-	*isosurf_shine_map, *isosurf_shine_const,
+	*isosurf_shine_map, *isosurf_shine_const, *slice_pos, *slice, *slice_transp,
     /* misc */
 	*exag, *bgcolor,
     /* cutting planes */
@@ -60,6 +60,7 @@
 /* volume.c */
 int load_rasters3d(const struct GParams *, nv_data *);
 int add_isosurfs(const struct GParams *, nv_data *);
+int add_slices(const struct GParams *, nv_data *);
 void draw_cplane(const struct GParams *, nv_data *);
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c	2011-07-14 06:17:07 UTC (rev 47105)
+++ grass/trunk/visualization/nviz2/cmd/main.c	2011-07-14 07:45:20 UTC (rev 47106)
@@ -33,7 +33,7 @@
     struct GParams *params;
     int i, ret;
-    int red, grn, blu, sx, sy;
+    int red, grn, blu;
     float size;
     double vp_height, z_exag;	/* calculated viewpoint height, z-exag */
     int width, height;		/* output image size */
@@ -120,6 +120,11 @@
 	add_isosurfs(params, &data);
+    /* define slices for displaying volumes */
+    if (params->slice->answer) {
+	add_slices(params, &data);
     /* focus on loaded data */
     Nviz_set_focus_map(MAP_OBJ_UNDEFINED, -1);
Modified: grass/trunk/visualization/nviz2/cmd/volume.c
--- grass/trunk/visualization/nviz2/cmd/volume.c	2011-07-14 06:17:07 UTC (rev 47105)
+++ grass/trunk/visualization/nviz2/cmd/volume.c	2011-07-14 07:45:20 UTC (rev 47106)
@@ -214,3 +214,93 @@
     return 1;
+int add_slices(const struct GParams *params, nv_data *data)
+    int i;
+    int num, nvols, *vol_list, id, nslices, axis;
+    int res, draw_mode;
+    char **tokens;
+    const char* style;
+    vol_list = GVL_get_vol_list(&nvols);
+    for (i = 0; params->slice->answers[i]; i++) {
+	tokens = G_tokenize(params->slice->answers[i], ":");
+	if (G_number_of_tokens(tokens) != 2)
+	    G_fatal_error(_("Error tokenize '%s'"),
+			  params->slice->answers[i]);
+	num = atoi(tokens[0]);
+	if (!strcmp(tokens[1],"x") || !strcmp(tokens[1],"X"))
+	    axis = 0;
+	else if (!strcmp(tokens[1],"y") || !strcmp(tokens[1],"Y"))
+	    axis = 1;
+	else if (!strcmp(tokens[1],"z") || !strcmp(tokens[1],"Z"))
+	    axis = 2;
+	else
+	    G_fatal_error(_("Wrong name for axis: %s"),
+			  tokens[1]);
+	G_free_tokens(tokens);
+	if (num > nvols) {
+	    G_fatal_error(_("Volume set number %d is not available"),
+			  num);
+	id = vol_list[num-1];
+	if (GVL_slice_add(id) < 0) {
+	    G_fatal_error(_("Unable to add slice (volume set %d)"),
+			  id);
+	nslices = GVL_slice_num_slices(id);
+	if (GVL_slice_set_pos(id, nslices-1, atof(params->slice_pos->answers[i*6+0]),
+					     atof(params->slice_pos->answers[i*6+1]),
+					     atof(params->slice_pos->answers[i*6+2]),
+					     atof(params->slice_pos->answers[i*6+3]),
+					     atof(params->slice_pos->answers[i*6+4]),
+					     atof(params->slice_pos->answers[i*6+5]),
+					     axis) < 0)
+	    G_fatal_error(_("Unable to set slice (%d) position of volume %d"),
+			  nslices-1, id);
+	/* set transparency */
+	if (GVL_slice_set_transp(id, nslices-1, atoi(params->slice_transp->answers[i])) < 0)
+	    G_fatal_error(_("Unable to set slice (%d) transparency of volume %d"),
+			  nslices-1, id);
+    /* set draw resolution and shading after slices are added*/
+    for (i = 0; i < nvols; i++) {
+	id = vol_list[i];
+	/* set resolution */
+	if (opt_get_num_answers(params->volume_res) != nvols)
+	    res = atof(params->volume_res->answers[0]);
+	else
+	    res = atof(params->volume_res->answers[i]);
+	GVL_slice_set_drawres(id, res, res, res);
+	/* set shading */
+	if (opt_get_num_answers(params->volume_shade) != nvols)
+	    style = params->volume_shade->answers[0];
+	else
+	    style = params->volume_shade->answers[i];
+	draw_mode = 0;
+	if (strcmp(style, "flat") == 0) {
+	    draw_mode |= DM_FLAT;
+	else {
+	    draw_mode |= DM_GOURAUD;
+	GVL_slice_set_drawmode(id, draw_mode);
+    return 1;
