[GRASS-SVN] r47109 - in grass/branches/develbranch_6: gui/wxpython/xml locale/po
Thu Jul 14 04:16:37 EDT 2011
Author: neteler
Date: 2011-07-14 01:16:37 -0700 (Thu, 14 Jul 2011)
New Revision: 47109
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
   grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
   grass/branches/develbranch_6/locale/po/grasswxpy_de.po
   grass/branches/develbranch_6/locale/po/grasswxpy_el.po
   grass/branches/develbranch_6/locale/po/grasswxpy_es.po
   grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
   grass/branches/develbranch_6/locale/po/grasswxpy_id.po
   grass/branches/develbranch_6/locale/po/grasswxpy_it.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
   grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
   grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
   grass/branches/develbranch_6/locale/po/grasswxpy_th.po
   grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
   grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
   grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
typo fixed
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2011-07-14 08:16:37 UTC (rev 47109)
@@ -2011,7 +2011,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Color rules</label>
-	      <help>Interacrive management of vector color tables.</help>
+	      <help>Interactive management of vector color tables.</help>
 	      <handler>RulesCmd</handler>
 	      <keywords>vector,color table</keywords>
 	      <command>v.colors</command>
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_cs.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_cs.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_cs.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3610,7 +3610,7 @@
 "sloupce."
 #: ../gui/wxpython/menustrings.py:550
-msgid "Interacrive management of vector color tables."
+msgid "Interactive management of vector color tables."
 msgstr "Interaktivní správa vektorové tabulky barev"
 #: ../gui/wxpython/menustrings.py:551
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_de.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_de.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3646,7 +3646,7 @@
 "numerischen Spalte der Attributtabelle."
 msgstr "Interaktives Verwalten der Vektorfarbtabelle"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_el.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_el.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_el.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3360,7 +3360,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_es.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_es.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_es.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3241,7 +3241,7 @@
 msgstr "Establece las reglas de color para los objetos espaciales de un vectorial utilizando una columna de atributos numéricos."
 msgstr "Gestión interactiva de tablas de color vectoriales."
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_fr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_fr.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_fr.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3466,7 +3466,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_id.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_id.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_id.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3772,7 +3772,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_it.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_it.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_it.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3509,7 +3509,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ja.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ja.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ja.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3597,7 +3597,7 @@
 msgstr "数値属性の列を使用して、ベクトルのカラールールを設定"
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ml.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ml.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ml.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3461,7 +3461,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pl.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pl.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3541,7 +3541,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3961,7 +3961,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3672,7 +3672,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_ru.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_ru.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_ru.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3738,7 +3738,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_th.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_th.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_th.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3573,7 +3573,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_tr.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_tr.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_tr.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3668,7 +3668,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_vi.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_vi.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_vi.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3748,7 +3748,7 @@
 "cột thuộc tính kiểu số."
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2011-07-14 08:15:16 UTC (rev 47108)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2011-07-14 08:16:37 UTC (rev 47109)
@@ -3556,7 +3556,7 @@
 #, fuzzy
 msgstr "提供色彩表的栅格图名称"
