[GRASS-SVN] r47116 - in grass-addons/grass7/raster/r.modis: libmodis r.modis.import
Thu Jul 14 13:16:37 EDT 2011
Author: lucadelu
Date: 2011-07-14 10:16:37 -0700 (Thu, 14 Jul 2011)
New Revision: 47116
   grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
add support for more projection system
Modified: grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
--- grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py	2011-07-14 14:37:52 UTC (rev 47115)
+++ grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py	2011-07-14 17:16:37 UTC (rev 47116)
@@ -38,8 +38,7 @@
     for i in listproj:
         ilist = i.split(':')
         proj[ilist[0].strip()] = ilist[1].strip()
-    towgs = parse_command('g.proj',flags='d')
-    proj['towgs84']=towgs['towgs84']
+    proj.update(parse_command('g.proj',flags='j'))
     return proj
 class product:
@@ -92,23 +91,65 @@
 class projection:
     """Definition of projection for converting from sinusoidal projection to
     another one. Not all projection systems are supported"""
-    def __init__(self,value):
-        self.proj = value
+    def __init__(self):
+        self.proj = get_proj()
+        self.val = self.proj['proj']
+        self.dat = self.proj['datum']
         self.projections = {'ll':'GEO', 'lcc':'LAMBERT CONFORMAL CONIC',
              'merc':'MERCATOR', 'polar':'POLAR STEREOGRAPHIC', 'utm':'UTM',
              'tmerc':'TRANSVERSE MERCATOR'}
-    def returned(self):
-        return self.projections[self.proj]
-class datum:
-    """Definition of datum for converting from sinusoidal projection. Not all
-    datums are supported"""
-        self.datum = value
         self.datumlist = {'none':'NONE', 'nad27':'NAD27', 'nad83':'NAD83',
         'wgs66':'WGS66', 'wgs72':'WGS72', 'wgs84':'WGS84'}
     def returned(self):
-        return self.datumlist[self.datum]
+        """Return the projection in the MRT style"""
+        return self.projections[self.val]
+    def _par(self,key):
+        """Function use in return_params"""
+        if self.proj[key]:
+            SMinor = self.proj[key]
+        else:
+            SMinor = 0.0
+    def return_params(self):
+        """ Return the 13 paramaters for parameter file """
+        if self.val == 'll' or self.val == 'utm':
+            return '( 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )'
+        elif self.val == 'lcc':
+            SMajor = self._par('+a')
+            SMinor = self._par('+b')
+            STDPR1 = self._par('+lat_1')
+            STDPR2 = self._par('+lat_2')
+            CentMer = self._par('+lon_0')
+            CentLat = self._par('+lat_0')
+            FE = self._par('+x_0')
+            FN = self._par('+y_0')
+            st = '( %i %i %d %d %d %d %d %d 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )' % (
+            SMajor, SMinor, STDPR1, STDPR2, CentMer, CentLat, FE, FN )
+            return st
+        elif self.val == 'merc' or self.val == 'polar' or self.val == 'tmerc':
+            if self.val == 'tmerc':
+                Factor = self._par('+k_0')
+            else:
+                Factor = 0.0
+            TrueScale = self._par('+lat_ts')
+            st = '( %i %i %d 0.0 %d %d %d %d 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )' % (
+            SMajor, SMinor, Factor, CentMer, TrueScale, FE, FN )
+            return st
+        else:
+            grass.fatal(_('Projection not supported, please contact the' \
+                          'GRASS-dev mailing list'))
+    def datum(self):
+        """Return the datum in the MRT style"""
+        return self.datumlist[self.dat]
+    def utmzone(self):
+        """Return the utm zone number"""
+        return self.proj['zone']
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html	2011-07-14 14:37:52 UTC (rev 47115)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.html	2011-07-14 17:16:37 UTC (rev 47116)
@@ -13,23 +13,32 @@
 <b>Warning</b>:
 <ul>
-  <li>Currently it's tested and It work correctly only with Lat/Long</li>
-  <li>Currently the mosaic flag it is not working</li>
+  <li>Currently it's tested only with Lat/Long, but also the follow projection systems are supported:  Lambert Conformal Conic, Mercator, Polar Stereographic, Transverse Mercator, Universal Transverse Mercator</li>
 </ul>
 <h2>EXAMPLES</h2>
-Import file with the default subset without QA layer
+Import a single file with the default subset without QA layer
 <div class="code"><pre>
+    r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt
+</pre></div>
+Import a single file with your own subset of layers
+<div class="code"><pre>
+    r.modis.import dsn=/path/to/file mrtpath=/path/to/mrt spectral="( 1 0 1 0)"
+</pre></div>
+Import more files with the default subset without QA layer
     r.modis.import filename=/path/to/listfile mrtpath=/path/to/mrt
 </pre></div>
-Import file with the default subset with QA layer
+Import more files like a daily mosais with the default subset with QA layer
-    r.modis.import -q filename=/path/to/listfile mrtpath=/path/to/mrt
+    r.modis.import -qm filename=/path/to/listfile mrtpath=/path/to/mrt
 </pre></div>
-Import file with the your own subset
+Import more files with your own subset of layers
     r.modis.import filename=/path/to/listfile mrtpath=/path/to/mrt spectral="( 1 )"
 </pre></div>
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2011-07-14 14:37:52 UTC (rev 47115)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2011-07-14 17:16:37 UTC (rev 47116)
@@ -90,7 +90,7 @@
 sys.path.append(libmodis)
 # try to import pymodis (modis) and some class for r.modis.download
 try:
-    from rmodislib import resampling, product, get_proj, projection, datum
+    from rmodislib import resampling, product, get_proj, projection
     from modis  import parseModis, convertModis, createMosaic
 except ImportError:
     pass
@@ -145,14 +145,11 @@
     # create parseModis class and the parameter file
     pm = parseModis(hdf)
     # return projection and datum
-    inproj = get_proj()
-    proj = projection(inproj['proj']).returned()
-    if proj != 'GEO':
-        grass.fatal(_('Projection different to Lat/Long is not working yet. Sorry'))
-        return 0
-    dat = datum(inproj['datum']).returned()
+    projObj = projection()
+    proj = projObj.returned()
+    dat = projObj.datum()
     if proj == 'UTM':
-        zone = prod['zone']
+        zone = projObj.utmzone()
     else:
         zone = None
     cod = os.path.split(hdf)[1].split('.')[0]
@@ -163,8 +160,8 @@
         spectr = spectral(opts, cod,q)
     # resampling
     resampl = resampling(opts['resampl']).returned()
-    # projpar TO DO
-    projpar = '( 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 )'
+    # projpar
+    projpar = projObj.return_params()
     return pm.confResample(spectr, None, None, dat, resampl, proj, zone, projpar)
 def import_tif(hdf,basedir,rem,target=False):
@@ -173,16 +170,24 @@
     prefix = os.path.split(hdf)[1].rstrip('.hdf')
     # list of tif files
     tifiles = glob.glob1(basedir, prefix + "*.tif")
+    # check if is in latlong location to set flag l
+    if projection().val == 'll':
+        f = "l"
+    else:
+        f = None
     # for each file import it
     for t in tifiles:
         basename = os.path.splitext(t)[0]
         name = os.path.join(basedir,t)
-        grass.run_command('r.in.gdal', input = name,
-        output = basename, flags = "l", overwrite = True, quiet = True)
-        if rem:
-            os.remove(name)
-        if target:
-             shutil.move(name,target)
+        try:
+            grass.run_command('r.in.gdal', input = name,
+            output = basename, flags = f, overwrite = True, quiet = True)
+            if rem:
+                os.remove(name)
+            if target:
+                shutil.move(name,target)
+        except:
+            grass.fatal(_('Error during import'))
     return 0
 def single(options,remove,qa):
