[GRASS-SVN] r47131 - in grass/trunk: general/g.setproj raster/r.proj raster/r.sunmask
Fri Jul 15 12:43:21 EDT 2011
Author: neteler
Date: 2011-07-15 09:43:21 -0700 (Fri, 15 Jul 2011)
New Revision: 47131
   grass/trunk/general/g.setproj/g.setproj.html
   grass/trunk/general/g.setproj/main.c
   grass/trunk/raster/r.proj/bordwalk.c
   grass/trunk/raster/r.proj/main.c
   grass/trunk/raster/r.proj/r.proj.html
   grass/trunk/raster/r.sunmask/g_solposition.c
updated Morten's address upon request
Modified: grass/trunk/general/g.setproj/g.setproj.html
--- grass/trunk/general/g.setproj/g.setproj.html	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/general/g.setproj/g.setproj.html	2011-07-15 16:43:21 UTC (rev 47131)
@@ -84,7 +84,7 @@
 Irina Kosinovsky,
 U.S. Army Construction Engineering
 Research Laboratory<BR>
-Morten Hulden, morten at tor.ngb.se - rewrote module and added 121 projections <BR>
+Morten Hulden, morten at untamo.net - rewrote module and added 121 projections <BR>
 Andreas Lange, andreas.lange at rhein-main.de - added prelimnary map datum support
 <p>
Modified: grass/trunk/general/g.setproj/main.c
--- grass/trunk/general/g.setproj/main.c	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/general/g.setproj/main.c	2011-07-15 16:43:21 UTC (rev 47131)
@@ -3,7 +3,7 @@
  * MODULE:       g.setproj
  * AUTHOR(S):    M. L. Holko - Soil Conservation Service, USDA
- *               Morten Hulden - morten at ngb.se
+ *               Morten Hulden - morten at untamo.net
  *               Andreas Lange - andreas.lange at rhein-main.de
  * PURPOSE:      Provides a means of creating a new projection information
  *               file (productivity tool).
@@ -29,7 +29,7 @@
  *                    proj=projection of the output project info file
  *   1.2 Changed by Morten Hulden 10/10/99 to add support for more projections
- *                  morten at ngb.se
+ *                  morten at untamo.net
  *   1.3 Changed by Andreas Lange 07/25/00 to add datum support
  *                  Andreas.Lange at Rhein-Main.de
Modified: grass/trunk/raster/r.proj/bordwalk.c
--- grass/trunk/raster/r.proj/bordwalk.c	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/raster/r.proj/bordwalk.c	2011-07-15 16:43:21 UTC (rev 47131)
@@ -1,6 +1,6 @@
  * Function added to r.proj
- * GNU GPL by Morten Hulden <morten at ngb.se>, August 2000
+ * GNU GPL by Morten Hulden <morten at untamo.net>, August 2000
  * bordwalk.c - projects the border cell centers of a map or region
  * to check whether they are inside the borders of another map/region
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/raster/r.proj/main.c	2011-07-15 16:43:21 UTC (rev 47131)
@@ -24,7 +24,7 @@
 *               for details.
 * Changes
-*		 Morten Hulden <morten at ngb.se>, Aug 2000:
+*		 Morten Hulden <morten at untamo.net>, Aug 2000:
 *		 - aborts if input map is outside current location.
 *		 - can handle projections (conic, azimuthal etc) where
 *		 part of the map may fall into areas where south is
Modified: grass/trunk/raster/r.proj/r.proj.html
--- grass/trunk/raster/r.proj/r.proj.html	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/raster/r.proj/r.proj.html	2011-07-15 16:43:21 UTC (rev 47131)
@@ -318,7 +318,7 @@
 Martin Schroeder, University of Heidelberg, Germany<br>
 Man page text from S.J.D. Cox, AGCRC, CSIRO Exploration &amp; Mining, Nedlands, WA<br>
-Updated by <a href="mailto:morten at ngb.se">Morten Hulden</a><br>
+Updated by <a href="mailto:morten at untamo.net">Morten Hulden</a><br>
 Datum tranformation support and cleanup by Paul Kelly
 <p>
Modified: grass/trunk/raster/r.sunmask/g_solposition.c
--- grass/trunk/raster/r.sunmask/g_solposition.c	2011-07-15 15:49:25 UTC (rev 47130)
+++ grass/trunk/raster/r.sunmask/g_solposition.c	2011-07-15 16:43:21 UTC (rev 47131)
@@ -3,7 +3,7 @@
  * given position, date and time
  * Written by Markus Neteler <neteler at geog.uni-hannover.de>
- * with kind help from Morten Hulden
+ * with kind help from Morten Hulden <morten untamo.net>
  * using solpos.c with permission from
