[GRASS-SVN] r47137 - grass-addons/grass7/gui/wxpython/wx.stream/gui_modules
Sat Jul 16 09:20:45 EDT 2011
Author: madi
Date: 2011-07-16 06:20:45 -0700 (Sat, 16 Jul 2011)
New Revision: 47137
   grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
   grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
Binding functions and handler added - working copy
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py	2011-07-16 09:28:18 UTC (rev 47136)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream.py	2011-07-16 13:20:45 UTC (rev 47137)
@@ -75,7 +75,7 @@
         self.parent = parent
-        wx.Frame.__init__(self, parent = parent, id = id, title = title, name = "RStream", size = (700, 900), **kwargs)
+        wx.Frame.__init__(self, parent = parent, id = id, title = title, name = "RStream", size = (600, 900), **kwargs)
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
         # create the AuiNotebook instance
Modified: grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py
--- grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2011-07-16 09:28:18 UTC (rev 47136)
+++ grass-addons/grass7/gui/wxpython/wx.stream/gui_modules/rstream_panelOne.py	2011-07-16 13:20:45 UTC (rev 47137)
@@ -21,6 +21,8 @@
 import wx
 import gselect
 # First panel # Network extraction
 class TabPanelOne(wx.Panel):
@@ -48,13 +50,13 @@
         text1 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Elevation map (required)")
         select.Add(item = text1, flag = wx.LEFT, pos = (1,0), span = wx.DefaultSpan, border = 0)
-        # Add the box for choosing the map
+        # Add the box for choosing the map
         select1 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
                                type = 'rast', multiple = False)
         select.Add(item = select1, pos = (2,0), span = wx.DefaultSpan)
         # binder
-        select1.Bind(wx.EVT_TEXT, self.OnSelect)
+        select1.Bind(wx.EVT_TEXT, self.OnSelectElev)
@@ -64,89 +66,121 @@
         # Flow accum can be either existent or to be calculated
-        # Check box
+        # RadioButton
         hbox1 = wx.BoxSizer(wx.HORIZONTAL)
-        cb1 = wx.CheckBox(parent = self.panel, label = 'Create by MFD algorithm')
-        hbox1.Add(item = cb1, flag = wx.LEFT, border = 0)
-        cb2 = wx.CheckBox(parent = self.panel, label = 'Create by SFD algorithm')
-        hbox1.Add(item = cb2, flag = wx.LEFT, border = 0)
-        cb3 = wx.CheckBox(parent = self.panel, label = 'Custom (select existing map)')
-        hbox1.Add(item = cb3, flag = wx.LEFT, border = 0)
+        cb1 = wx.RadioButton(parent = self.panel, id = wx.ID_ANY, label = "Custom (select existing map)")
+        hbox1.Add(item = cb1, flag = wx.LEFT)
+        cb2 = wx.RadioButton(parent = self.panel, id = wx.ID_ANY, label = "Create by MFD algorithm")
+        hbox1.Add(item = cb2, flag = wx.LEFT)
+        cb3 = wx.RadioButton(parent = self.panel, id = wx.ID_ANY, label = "Create by SFD algorithm")
+        hbox1.Add(item = cb3, flag = wx.LEFT)
         select.Add(item = hbox1, pos = (4,0))
-        # Check box binder
-        # Box to insert name of new acc map (to be created)
-        txtOne = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
-        select.Add(item = txtOne, flag = wx.LEFT | wx.EXPAND , pos = (5,0), span = wx.DefaultSpan)
+        # Box to insert name of acc map
+        global select2, textOne, textTwo
         select2 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
-                               type = 'rast', multiple = False)
-        select.Add(item = select2, pos = (6,0), span = wx.DefaultSpan)
+                               type = 'rast', multiple = False) # select existing map
+        select.Add(item = select2, pos = (5,0), span = wx.DefaultSpan)
+        textOne = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT) # MFD
+        select.Add(item = textOne, flag = wx.LEFT | wx.EXPAND , pos = (6,0), span = wx.DefaultSpan)
+        textTwo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT) # SFD
+        select.Add(item = textTwo, flag = wx.LEFT | wx.EXPAND , pos = (7,0), span = wx.DefaultSpan)
-        # binder
-        select2.Bind(wx.EVT_TEXT, self.OnSelect)
+        # linking buttons and text
+        self.texts = {"Custom (select existing map)" : select2,
+                      "Create by MFD algorithm" : textOne,
+                      "Create by SFD algorithm" : textTwo}
+        self.selectedText = select2 # default is select existing map
+        # Disable
+        textOne.Enable(False)
+        textTwo.Enable(False)
+        # RadioButton binders
+        cb1.Bind(wx.EVT_RADIOBUTTON, self.OnSelectExistAcc)
+        cb2.Bind(wx.EVT_RADIOBUTTON, self.OnSelectMFDAcc)
+        cb3.Bind(wx.EVT_RADIOBUTTON, self.OnSelectSFDAcc)
+        #textOne.Bind(wx.EVT_TEXT, self.OnSelectMFDAcc)
+        #textTwo.Bind(wx.EVT_TEXT, self.OnSelectSFDAcc)
+        #select2.Bind(wx.EVT_TEXT, self.OnSelectExistAcc)
         # Ask user for Mask
         text3 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Mask (optional)")
-        select.Add(item = text3, flag = wx.LEFT, pos = (7,0), span = wx.DefaultSpan)
+        select.Add(item = text3, flag = wx.LEFT, pos = (8,0), span = wx.DefaultSpan)
         select3 = gselect.Select(parent = self.panel, id = wx.ID_ANY, size = (250, -1),
-        select.Add(item = select3, pos = (8,0), span = wx.DefaultSpan)
+        select.Add(item = select3, pos = (9,0), span = wx.DefaultSpan)
         # binder
-        select3.Bind(wx.EVT_TEXT, self.OnSelect)
+        select3.Bind(wx.EVT_TEXT, self.OnSelectMask)
         # Ask user for threshold
         text4 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "INPUT : Threshold (required)")
-        select.Add(item = text4, flag = wx.LEFT, pos = (9,0), span = wx.DefaultSpan)
+        select.Add(item = text4, flag = wx.LEFT, pos = (10,0), span = wx.DefaultSpan)
         # Box to insert threshold
         txtTwo = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
-        select.Add(item = txtTwo, flag = wx.LEFT, pos = (10,0), span = wx.DefaultSpan)
+        select.Add(item = txtTwo, flag = wx.LEFT, pos = (11,0), span = wx.DefaultSpan)
+        # binder
+        txtTwo.Bind(wx.EVT_TEXT, self.OnSelecTh)
         #---------Output maps---------
         # Flow direction map
         text5 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Flow direction map (required)")
-        select.Add(item = text5, flag = wx.LEFT | wx.EXPAND, pos = (11,0), span = wx.DefaultSpan)
+        select.Add(item = text5, flag = wx.LEFT | wx.EXPAND, pos = (12,0), span = wx.DefaultSpan)
         # Box to insert name of new flow dir map (to be created)
         txtThr = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
-        select.Add(item = txtThr, flag = wx.LEFT | wx.EXPAND , pos = (12,0), span = wx.DefaultSpan)
+        select.Add(item = txtThr, flag = wx.LEFT | wx.EXPAND , pos = (13,0), span = wx.DefaultSpan)
+        # binder
+        txtThr.Bind(wx.EVT_TEXT, self.OnSelecFd)
         # Streams map
         text6 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Streams (required)")
-        select.Add(item = text6, flag = wx.LEFT | wx.EXPAND, pos = (13,0), span = wx.DefaultSpan)
+        select.Add(item = text6, flag = wx.LEFT | wx.EXPAND, pos = (14,0), span = wx.DefaultSpan)
         # Box to insert name of new streams map (to be created)
         txtFou = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
-        select.Add(item = txtFou, flag = wx.LEFT | wx.EXPAND , pos = (14,0), span = wx.DefaultSpan)
+        select.Add(item = txtFou, flag = wx.LEFT | wx.EXPAND , pos = (15,0), span = wx.DefaultSpan)
+        # binder
+        txtFou.Bind(wx.EVT_TEXT, self.OnSelecStr)
         # Network map
         text7 = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = "OUTPUT : Network (required)")
-        select.Add(item = text7, flag = wx.LEFT | wx.EXPAND, pos = (15,0), span = wx.DefaultSpan)
+        select.Add(item = text7, flag = wx.LEFT | wx.EXPAND, pos = (16,0), span = wx.DefaultSpan)
         txtFiv = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, style = wx.TE_LEFT)
-        select.Add(item = txtFiv, flag = wx.LEFT | wx.EXPAND , pos = (16,0), span = wx.DefaultSpan)
+        select.Add(item = txtFiv, flag = wx.LEFT | wx.EXPAND , pos = (17,0), span = wx.DefaultSpan)
+        # binder
+        txtFiv.Bind(wx.EVT_TEXT, self.OnSelecNet)
@@ -166,20 +200,87 @@
         self.SetSizer(sizer)
-    def OnSelect(self, event):
-        """!Gets raster map or function selection and send it to
-        insertion method
+    #-------------input maps-------------
+    def OnSelectElev(self, event):
+        """!Gets elevation map and assign it to var
-        item = event.GetString()
-        self._addSomething(item)
-        import pdb; pdb.set_trace()
+        r_elev = event.GetString()
+        #import pdb; pdb.set_trace()
-    def _addSomething(self, what):
-        """!builds the list of variables
+    def OnSelectMFDAcc(self, event):
+        """!Gets new flow accum map and assign it to var
-        pass
+        if self.selectedText:
+            self.selectedText.Enable(False)
+        radioSelected = event.GetEventObject()
+        r_new_acc = textOne.GetString[radioSelected.GetLabel()] #FIXME event
+        r_new_acc.Enable(True)
+        self.SelectedText = r_new_acc
+        #r_new_acc = event.GetString()
+        # r.watershed elevation = r_elev accumulation = r_new_acc -a (MFD)
+    def OnSelectSFDAcc(self, event):
+        r_new_acc = textTwo.GetString[radioSelected.GetLabel()] #FIXME
+        # r.watershed elevation = r_elev accumulation = r_new_acc -a (SFD, flag = -s)
+    def OnSelectExistAcc(self, event):
+        """!Gets existing flow acc map and assign it to var
+        r_ex_acc = select2.GetString[radioSelected.GetLabel()] #FIXME
+        r_ex_acc.Enable(True)
+        self.SelectedText = r_ex_acc
+        #r_ex_acc = event.GetString()
+    def OnSelectMask(self, event):
+        """!Gets mask map and assign it to var
+        r_mask = event.GetString()
+    def OnSelecTh(self, event):
+        """!Gets threshold and assign it to var
+        thre = event.GetString()
+    #-------------output maps-------------
+    def OnSelecFd(self, event):
+        """!Gets flow direction map and assign it to var
+        r_drain = event.GetString()
+    def OnSelecStr(self, event):
+        """!Gets stream map and assign it to var
+        r_stre = event.GetString()
+    def OnSelecNet(self, event):
+        """!Gets network map and assign it to var
+        v_net = event.GetString()
+    #-------------Buttons-------------
     def buttonData(self):
         return (("Update Preview", self.OnPreview),
                 ("Run Analysis", self.OnRun))
@@ -196,9 +297,15 @@
         self.Bind(wx.EVT_BUTTON, handler, button)
         return button
+    #-------------Preview funct-------------
     def OnPreview(self, event):
         pass
+    #-------------Get the network extraction-------------
     def OnRun(self, event):
         pass
