[GRASS-SVN] r47152 - grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
Mon Jul 18 04:05:37 EDT 2011
Author: martinl
Date: 2011-07-18 01:05:37 -0700 (Mon, 18 Jul 2011)
New Revision: 47152
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
wxGUI: don't crash on v.db.connect
       (merge r47150 from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py	2011-07-18 08:04:27 UTC (rev 47151)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py	2011-07-18 08:05:37 UTC (rev 47152)
@@ -619,10 +619,7 @@
         else:
             GError(parent = parent,
                    message = stderr)
-    if ret != 0:
-        return None
     Debug.msg(3, "gcmd.RunCommand(): print read error")
     if not read:
         if not getErrorMsg:
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2011-07-18 08:04:27 UTC (rev 47151)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2011-07-18 08:05:37 UTC (rev 47152)
@@ -626,16 +626,16 @@
 class LayerSelect(wx.ComboBox):
     """!Creates combo box for selecting data layers defined for vector.
-    The 'layer' terminology is likely to change for GRASS 7
     def __init__(self, parent,
-                 id=wx.ID_ANY, pos=wx.DefaultPosition,
-                 size=globalvar.DIALOG_LAYER_SIZE,
-                 vector=None, choices=[], initial=[], default=None):
+                 id = wx.ID_ANY, pos = wx.DefaultPosition,
+                 size = globalvar.DIALOG_LAYER_SIZE,
+                 vector = None, choices = [], initial = [], default = None):
         super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
                                           choices=choices)
+        self.parent  = parent
         self.initial = initial
         self.SetName("LayerSelect")
@@ -646,25 +646,39 @@
         self.InsertLayers(vector = vector)
     def InsertLayers(self, vector):
-        """!Insert layers for a vector into the layer combobox"""
+        """!Insert layers for a vector into the layer combobox
+        @param vector name of vector map
         if vector:
-            layers = utils.GetVectorNumberOfLayers(self, vector)
+            layers = utils.GetVectorNumberOfLayers(vector)
         else:
             layers = list()
         for layer in self.initial:
             if layer in layers:
                 continue
             layers.append(layer)
         if self.default:
             if len(layers) == 0:
                 layers.insert(0, str(self.default))
             elif self.default not in layers:
                 layers.append(self.default)
         if len(layers) >= 1:
             self.SetItems(layers)
+    def Reset(self):
+        """!Reset value"""
+        items = self.GetItems()
+        if items:
+            if '-1' in items:
+                self.SetStringSelection('-1')
+            else:
+                self.SetSelection(0)
+        else:
+            self.SetValue('')
 class DriverSelect(wx.ComboBox):
     """!Creates combo box for selecting database driver.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2011-07-18 08:04:27 UTC (rev 47151)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2011-07-18 08:05:37 UTC (rev 47152)
@@ -220,6 +220,7 @@
             if name == 'LayerSelect':
                 if map in cparams and not cparams[map]['layers']:
                     win.InsertLayers(vector = map)
+                    win.Reset()
                     cparams[map]['layers'] = win.GetItems()
             elif name == 'TableSelect':
@@ -1149,16 +1150,16 @@
                                     if lyrvalue not in initial:
                                         initial.append(str(lyrvalue))
-                                win = gselect.LayerSelect(parent=which_panel,
-                                                          initial=initial,
-                                                          default=p['default'])
+                                win = gselect.LayerSelect(parent = which_panel,
+                                                          initial = initial,
+                                                          default = p['default'])
                                 p['wxGetValue'] = win.GetStringSelection
                                 win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
                                 win.Bind(wx.EVT_TEXT, self.OnSetValue)
                                 win.SetValue(str(value))    # default or previously set value
                             else:
-                                win = wx.SpinCtrl(parent=which_panel, id=wx.ID_ANY,
-                                                  min=1, max=100, initial=int(p['default']))
+                                win = wx.SpinCtrl(parent = which_panel, id = wx.ID_ANY,
+                                                  min = 1, max = 100, initial = int(p['default']))
                                 win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
                                 win.SetValue(int(value))    # default or previously set value
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py	2011-07-18 08:04:27 UTC (rev 47151)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/utils.py	2011-07-18 08:05:37 UTC (rev 47152)
@@ -272,8 +272,12 @@
     """!Sort list items (not case-sensitive)"""
     list.sort(cmp=lambda x, y: cmp(x.lower(), y.lower()))
-def GetVectorNumberOfLayers(parent, vector):
-    """!Get list of vector layers"""
+def GetVectorNumberOfLayers(vector, parent = None):
+    """!Get list of vector layers
+    @param parent parent window (to show dialog) or None
     layers = []
     if not vector:
         return layers
@@ -283,19 +287,19 @@
         Debug.msg(5, "utils.GetVectorNumberOfLayers(): vector map '%s' not found" % vector)
         return layers
-    ret = gcmd.RunCommand('v.db.connect',
-                          parent = parent,
-                          flags = 'g',
-                          read = True,
-                          map = fullname,
-                          fs = ';')
-    if not ret:
+    ret, out, msg = gcmd.RunCommand('v.db.connect',
+                                    getErrorMsg = True,
+                                    read = True,
+                                    flags = 'g',
+                                    map = fullname,
+                                    fs = ';')
+    if ret != 0:
+        sys.stderr.write(_("Vector map <%s>") % fullname + ": " + msg + "\n")
         return layers
-    else:
-        Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
-    for line in ret.splitlines():
+    Debug.msg(1, "GetVectorNumberOfLayers(): ret %s" % ret)
+    for line in out.splitlines():
         try:
             layer = line.split(';')[0]
             if '/' in layer:
