[GRASS-SVN] r47158 - grass/branches/releasebranch_6_4/locale/po
Mon Jul 18 08:38:14 EDT 2011
Author: aghisla
Date: 2011-07-18 05:38:14 -0700 (Mon, 18 Jul 2011)
New Revision: 47158
   grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po
Small cleanup of obsolete messages with msgattrib --no-obsoletes.
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po	2011-07-18 12:22:20 UTC (rev 47157)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_it.po	2011-07-18 12:38:14 UTC (rev 47158)
@@ -13,7 +13,7 @@
 "Project-Id-Version: grasslibs_it\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-06-09 20:10+0200\n"
-"PO-Revision-Date: 2011-07-18 13:57+0100\n"
+"PO-Revision-Date: 2011-07-18 14:34+0100\n"
 "Last-Translator: Anne Ghisla <a.ghisla at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
 "Language: it\n"
@@ -111,8 +111,11 @@
 #: ../lib/symbol/read.c:259
 #, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr "Nome del simbolo errato:  '%s' (dovrebbe essere: gruppo/nome o gruppo/nome at mapset)"
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+"Nome del simbolo errato:  '%s' (dovrebbe essere: gruppo/nome o gruppo/"
+"nome at mapset)"
 #: ../lib/symbol/read.c:283
 #, c-format
@@ -223,7 +226,8 @@
 #: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
 #, c-format
 msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
+msgstr ""
+"Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
 #: ../lib/proj/convert.c:110
 msgid "Unable parse GRASS PROJ_INFO file"
@@ -235,17 +239,24 @@
 #: ../lib/proj/convert.c:127
 #, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr "OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di errore OGR era %d)"
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr ""
+"OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di "
+"errore OGR era %d)"
 #: ../lib/proj/convert.c:133
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr "OGR non sa ottenere la stringa di parametri in stile WKT (il codice di errore OGR era %d)"
+msgstr ""
+"OGR non sa ottenere la stringa di parametri in stile WKT (il codice di "
 #: ../lib/proj/convert.c:390
 msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr "Nome della proiezione mancante! Probabilmente i parametri di proiezione sono errati."
+msgstr ""
+"Nome della proiezione mancante! Probabilmente i parametri di proiezione sono "
+"errati."
 #: ../lib/proj/convert.c:426
 #, c-format
@@ -254,13 +265,21 @@
 #: ../lib/proj/convert.c:442
 #, c-format
-msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
-msgstr "Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro è stato trovato. Dovresto controllare all'interno di questo."
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
+msgstr ""
+"Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro "
+"è stato trovato. Dovresto controllare all'interno di questo."
 #: ../lib/proj/convert.c:446
 #, c-format
-msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
-msgstr "Numero di trasformazione %d non valido; il range valido è da 1 a %d. I parametri di trasformazione del datum non vengono specificati."
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
+msgstr ""
+"Numero di trasformazione %d non valido; il range valido è da 1 a %d. I "
+"parametri di trasformazione del datum non vengono specificati."
 #: ../lib/gis/sample.c:71
 msgid "Unknown interpolation type"
@@ -374,8 +393,12 @@
 msgstr "Non riesco a scrivere le regole quant per la mappa %s"
 #: ../lib/gis/set_window.c:76
-msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
-msgstr "G_set_window(): la proiezione/zona differisce da quella del raster attualmente aperto"
+msgid ""
+"G_set_window(): projection/zone differs from that of currently open raster "
+"maps"
+msgstr ""
+"G_set_window(): la proiezione/zona differisce da quella del raster "
+"attualmente aperto"
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -470,12 +493,17 @@
 #: ../lib/gis/view.c:546
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " La finestra salvata in \"%s\" è completamente al di fuori della finestra GRASS attualmente in uso."
+msgstr ""
+" La finestra salvata in \"%s\" è completamente al di fuori della finestra "
+"GRASS attualmente in uso."
 #: ../lib/gis/view.c:550
 #, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr " Solo  %d%% della finestra salvata in \"%s\" si sovrappone con la finestra GRASS in uso"
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+" Solo  %d%% della finestra salvata in \"%s\" si sovrappone con la finestra "
+"GRASS in uso"
 #: ../lib/gis/get_projname.c:31
 #, c-format
@@ -566,7 +594,9 @@
 #: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
 #, c-format
 msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr "Risolto leggero errore di arrotondamento del dato in input del confine nord (%g>%g)"
+msgstr ""
+"Risolto leggero errore di arrotondamento del dato in input del confine nord "
+"(%g>%g)"
 #: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
 msgid "Illegal latitude for North"
@@ -575,7 +605,9 @@
 #: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
 #, c-format
 msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr "Risolto leggero errore di arrotondamento del dato in input del confine sud (%g>%g)"
+msgstr ""
+"Risolto leggero errore di arrotondamento del dato in input del confine sud "
+"(%g>%g)"
 #: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
 msgid "Illegal latitude for South"
@@ -584,12 +616,16 @@
 #: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
 #, c-format
 msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr "Risolto leggero errore di arrotondamento del dato in input del confine ovest (%g>%g)"
+msgstr ""
+"Risolto leggero errore di arrotondamento del dato in input del confine ovest "
+"(%g>%g)"
 #: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
 #, c-format
 msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr "Risolto leggero errore di arrotondamento del dato in input del confine est (%g>%g)"
+msgstr ""
+"Risolto leggero errore di arrotondamento del dato in input del confine est "
+"(%g>%g)"
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
 msgid "North must be north of South"
@@ -732,8 +768,12 @@
 msgstr "Numero layer"
 #: ../lib/gis/parser.c:596
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-msgstr "Un singolo vettoriale può essere connessa a database multiple. Questo numero determina quale tabella viene usata."
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use."
+msgstr ""
+"Un singolo vettoriale può essere connessa a database multiple. Questo numero "
+"determina quale tabella viene usata."
 #: ../lib/gis/parser.c:605
 msgid "Category value"
@@ -790,11 +830,15 @@
 #: ../lib/gis/parser.c:925
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --verbose."
+msgstr ""
+"Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta "
+"automatica: --verbose."
 #: ../lib/gis/parser.c:939
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --quiet."
+msgstr ""
+"automatica: --quiet."
 #: ../lib/gis/parser.c:969
 #, c-format
@@ -1088,7 +1132,8 @@
 #: ../lib/gis/timestamp.c:282
 #, c-format
 msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
+msgstr ""
+"Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
 #: ../lib/gis/timestamp.c:291
 #, c-format
@@ -1098,7 +1143,8 @@
 #: ../lib/gis/timestamp.c:313
 #, c-format
 msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
+msgstr ""
+"Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
 #: ../lib/gis/timestamp.c:322
 #, c-format
@@ -1112,7 +1158,8 @@
 #: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr " Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
+msgstr ""
+" Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
 #: ../lib/gis/get_row.c:324
 #, c-format
@@ -1473,7 +1520,8 @@
 #: ../lib/gis/reclass.c:148
 #, c-format
 msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr "Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
+msgstr ""
+"Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
 #: ../lib/gis/reclass.c:238
 msgid "Illegal reclass request"
@@ -1584,8 +1632,12 @@
 #: ../lib/gis/distance.c:160
 #, c-format
-msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr "G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgid ""
+"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
+"%f)(%f,%f)"
+msgstr ""
+"G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,%f) S="
+"(%f,%f)(%f,%f)"
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
 #, fuzzy
@@ -1624,8 +1676,12 @@
 #: ../lib/gis/opencell.c:188
 #, c-format
-msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
-msgstr "impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@%s> che non esiste"
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
+msgstr ""
+"impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@"
+"%s> che non esiste"
 #: ../lib/gis/opencell.c:212
 #, c-format
@@ -1634,8 +1690,12 @@
 #: ../lib/gis/opencell.c:219
 #, c-format
-msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
-msgstr "Raster <%s@%s> ha una proiezione differente rispetto alla regione attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
+msgid ""
+"Raster map <%s@%s> is in different projection than current region. Found "
+"raster map <%s@%s>, should be <%s>."
+msgstr ""
+"Raster <%s@%s> ha una proiezione differente rispetto alla regione "
+"attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
 #: ../lib/gis/opencell.c:226
 #, c-format
@@ -1650,7 +1710,9 @@
 #: ../lib/gis/opencell.c:262
 #, c-format
 msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr "la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il supporto a GDAL"
+msgstr ""
+"la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il "
+"supporto a GDAL"
 #: ../lib/gis/opencell.c:642
 #, c-format
@@ -1672,8 +1734,10 @@
 msgstr "G__open_raster_new(): non sono disponibili file temporanei"
 #: ../lib/gis/opencell.c:736
-msgid "Unable to write embedded null values for raster map open for random access"
-msgstr "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
+msgid ""
+"Unable to write embedded null values for raster map open for random access"
+msgstr ""
+"Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
 #: ../lib/gis/opencell.c:941
 msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
@@ -1710,8 +1774,11 @@
 msgstr "Raster <%s> non è xdr: byte_order: %s"
 #: ../lib/gis/opencell.c:1179
-msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr "G_set_quant_rules() può essere chiamato solo per le mappe raster aperte in lettura"
+msgid ""
+"G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr ""
+"G_set_quant_rules() può essere chiamato solo per le mappe raster aperte in "
+"lettura"
 #: ../lib/gis/mask_info.c:40
 #, c-format
@@ -2076,7 +2143,8 @@
 #: ../lib/gis/get_cellhd.c:105
 #, c-format
 msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr "È una riclassificazione del raster <%s@%s> il cui file header non è valido."
+msgstr ""
+"È una riclassificazione del raster <%s@%s> il cui file header non è valido."
 #: ../lib/gis/get_cellhd.c:109
 #, c-format
@@ -2084,8 +2152,12 @@
 msgstr "Formato non valido."
 #: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
-msgstr "Versione incompatibile della libreria per il modulo. È necessario ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
+"Versione incompatibile della libreria per il modulo. È necessario "
+"ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
 #: ../lib/gis/gisinit.c:63
 #, c-format
@@ -2094,7 +2166,9 @@
 #: ../lib/gis/gisinit.c:110
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "Sistema non inizializzato. Il programmatore si è scordato di usare la funzione G_gisinit()."
+msgstr ""
+"Sistema non inizializzato. Il programmatore si è scordato di usare la "
+"funzione G_gisinit()."
 #: ../lib/gis/history.c:132 ../lib/g3d/g3dhistory.c:42
 #, c-format
@@ -2108,11 +2182,14 @@
 #: ../lib/gis/history.c:263
 msgid "Not enough room in history file to record command line."
-msgstr "Insufficiente spazio nel file della history per salvare la riga di comando."
+msgstr ""
+"Insufficiente spazio nel file della history per salvare la riga di comando."
 #: ../lib/gis/history.c:285
 msgid "Not enough room in history file for command line (truncated)."
-msgstr "Insufficiente spazio nel file della history per salvare la riga di comando (troncato)."
+msgstr ""
+"Insufficiente spazio nel file della history per salvare la riga di comando "
+"(troncato)."
 #: ../lib/driver/main.c:90
 #, c-format
@@ -2131,7 +2208,8 @@
 #: ../lib/driver/parse_ftcap.c:32
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
+msgstr ""
+"%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
 #: ../lib/driver/parse_ftcap.c:38
 #, c-format
@@ -2145,8 +2223,12 @@
 #: ../lib/vector/diglib/plus_node.c:217
 #, c-format
-msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
-msgstr "Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo %d, linea %d"
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
+"Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo "
+"%d, linea %d"
 #: ../lib/vector/diglib/plus.c:288
 msgid "Unable read topology for nodes"
@@ -2231,17 +2313,23 @@
 #: ../lib/vector/diglib/plus_area.c:382
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr "Centroide inesistente %d registrato per l'area (baco nella libreria vettoriale)"
+msgstr ""
+"Centroide inesistente %d registrato per l'area (baco nella libreria "
+"vettoriale)"
 #: ../lib/vector/diglib/plus_area.c:406
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente %d"
+msgstr ""
+"Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente "
+"%d"
 #: ../lib/vector/diglib/plus_area.c:749
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente %d"
+msgstr ""
+"Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente "
+"%d"
 #: ../lib/vector/diglib/file.c:157
 msgid "Writing to file loaded to memory not supported"
@@ -2295,12 +2383,14 @@
 #: ../lib/vector/Vlib/legal_vname.c:48
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
+msgstr ""
+"Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
 #: ../lib/vector/Vlib/legal_vname.c:55
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
+msgstr ""
+"Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
 #: ../lib/vector/Vlib/legal_vname.c:63
 #, c-format
@@ -2309,8 +2399,11 @@
 #: ../lib/vector/Vlib/legal_vname.c:70
 #, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr "Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono essere usate come nome della mappa."
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+"Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono "
+"essere usate come nome della mappa."
 #: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
 #, c-format
@@ -2356,7 +2449,9 @@
 #: ../lib/vector/Vlib/cats.c:407
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr "Impossibile convertire la stringa '%s' della categoria (da '%s') al range della categoria"
+msgstr ""
+"Impossibile convertire la stringa '%s' della categoria (da '%s') al range "
+"della categoria"
 #: ../lib/vector/Vlib/sindex.c:97
 msgid "not implemented"
@@ -2368,8 +2463,12 @@
 msgstr "Impossibile eliminare l'elemento %d dall'indice spaziale"
 #: ../lib/vector/Vlib/sindex.c:127
-msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
-msgstr "Impossibile costruire l'indice spaziale dalla topologia, il vettoriale non è aperto al livello 2 della topologia"
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topo level 2"
+msgstr ""
+"Impossibile costruire l'indice spaziale dalla topologia, il vettoriale non è "
+"aperto al livello 2 della topologia"
 #: ../lib/vector/Vlib/sindex.c:168
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -2459,8 +2558,12 @@
 #: ../lib/vector/Vlib/geos.c:56
 #, c-format
-msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr "Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+"Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo "
+"di features nel vettoriale <%s>: %d)"
 #: ../lib/vector/Vlib/geos.c:61
 msgid "only native format supported"
@@ -2480,7 +2583,9 @@
 #: ../lib/vector/Vlib/geos.c:105
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr "Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con id %d"
+msgstr ""
+"Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con "
+"id %d"
 #: ../lib/vector/Vlib/geos.c:203
 #, c-format
@@ -2629,7 +2734,9 @@
 #: ../lib/vector/Vlib/field.c:98
 msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr "Impossibile aprire il collegamento al database, la mappa non è stata aperta in modalità di SCRITTURA"
+msgstr ""
+"Impossibile aprire il collegamento al database, la mappa non è stata aperta "
+"in modalità di SCRITTURA"
 #: ../lib/vector/Vlib/field.c:104
 msgid "Unable to add database link"
@@ -2673,8 +2780,12 @@
 msgstr "Impossibile aprire il driver OGR DBMI"
 #: ../lib/vector/Vlib/field.c:551
-msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
-msgstr "Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
+msgstr ""
+"Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno "
+"di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
 #: ../lib/vector/Vlib/field.c:606
 #, c-format
@@ -2689,11 +2800,13 @@
 #: ../lib/vector/Vlib/field.c:709
 #, c-format
 msgid "Unable to open vector database definition file '%s'"
-msgstr "Impossibile aprire il file %s delle definizioni del database vettoriale"
+msgstr ""
+"Impossibile aprire il file %s delle definizioni del database vettoriale"
 #: ../lib/vector/Vlib/field.c:804
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
+msgstr ""
+"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
 #: ../lib/vector/Vlib/area.c:53
 msgid "Attempt to read points of nonexistent area"
@@ -2732,8 +2845,12 @@
 #: ../lib/vector/Vlib/read.c:102
 #, c-format
-msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
+msgid ""
+"Vect_read_line(): feature id %d is not reasonable (max features in vector "
+"map <%s>: %d)"
+msgstr ""
+"Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di "
+"features nel vettoriale <%s>: %d)"
 #: ../lib/vector/Vlib/build_nat.c:93
 msgid "Unable to add area (map closed, topo saved)"
@@ -2926,13 +3043,21 @@
 #: ../lib/vector/Vlib/open_nat.c:145
 #, c-format
-msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
-msgstr "Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes in eccesso)"
+msgid ""
+"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
+msgstr ""
+"Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes in "
+"eccesso)"
 #: ../lib/vector/Vlib/open_nat.c:149
 #, c-format
-msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr "Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes mancanti)"
+msgid ""
+"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+"missing)."
+msgstr ""
+"Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes "
+"mancanti)"
 #: ../lib/vector/Vlib/net.c:121
 msgid "Building graph..."
@@ -2968,12 +3093,16 @@
 #: ../lib/vector/Vlib/net.c:254
 #, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net.c:273
 #, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found"
+"(direction of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net.c:322
@@ -2987,7 +3116,9 @@
 #: ../lib/vector/Vlib/net.c:402
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr "Record del database non trovato per il nodo %d (cat = %d) (costo impostato a 0)"
+msgstr ""
+"Record del database non trovato per il nodo %d (cat = %d) (costo impostato a "
+"0)"
 #: ../lib/vector/Vlib/net.c:429
 msgid "Flattening the graph..."
@@ -3054,13 +3185,19 @@
 #: ../lib/vector/Vlib/write.c:219
 #, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
+msgid ""
+"Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr ""
+"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul "
+"livello topologico"
 #: ../lib/vector/Vlib/write.c:225
 #, c-format
-msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
+msgid ""
+"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in "
+"modalità di scrittura"
 #: ../lib/vector/Vlib/write.c:239
 #, c-format
@@ -3069,13 +3206,19 @@
 #: ../lib/vector/Vlib/write.c:265
 #, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
+msgid ""
+"Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr ""
+"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul "
 #: ../lib/vector/Vlib/write.c:271
 #, c-format
-msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
+msgid ""
+"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in "
 #: ../lib/vector/Vlib/write.c:285
 #, c-format
@@ -3093,8 +3236,11 @@
 msgstr ""
 #: ../lib/vector/Vlib/open.c:179
-msgid "Vector map which is not in the current mapset cannot be opened for update"
-msgstr "Il vettoriale che non presente nel mapset in uso non può essere aperta per gli aggiornamenti"
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
+msgstr ""
+"Il vettoriale che non presente nel mapset in uso non può essere aperta per "
+"gli aggiornamenti"
 #: ../lib/vector/Vlib/open.c:199 ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115
 #, c-format
@@ -3104,8 +3250,12 @@
 #: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
 #: ../lib/vector/Vlib/open.c:299
 #, c-format
-msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
-msgstr "Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire la topologia con v.build."
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"by v.build."
+msgstr ""
+"Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire "
+"la topologia con v.build."
 #: ../lib/vector/Vlib/open.c:214
 msgid "Unable to read head file"
@@ -3143,7 +3293,9 @@
 #: ../lib/vector/Vlib/open.c:731
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr "La dimensione del file 'coor' differisce dal valore salvato nel file di topologia"
+msgstr ""
+"La dimensione del file 'coor' differisce dal valore salvato nel file di "
+"topologia"
 #: ../lib/vector/Vlib/open.c:742
 #, c-format
@@ -3171,13 +3323,22 @@
 #: ../lib/vector/Vlib/open_ogr.c:147
 #, c-format
-msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr "Versione %d.%d del formato dell'indice delle features non è supportata da questa release. Ricostruire la topologia o aggiornare GRASS."
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
+msgstr ""
+"Versione %d.%d del formato dell'indice delle features non è supportata da "
+"questa release. Ricostruire la topologia o aggiornare GRASS."
 #: ../lib/vector/Vlib/open_ogr.c:152
 #, c-format
-msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr "Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice delle features del vettore. Si consiglia di ricostruire la topologia o aggiornare GRASS."
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+"Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice "
+"delle features del vettore. Si consiglia di ricostruire la topologia o "
+"aggiornare GRASS."
 #: ../lib/vector/Vlib/level_two.c:234 ../lib/vector/Vlib/level_two.c:259
 #: ../lib/vector/Vlib/level_two.c:283 ../lib/vector/Vlib/level_two.c:302
@@ -3220,7 +3381,8 @@
 #: ../lib/vector/Vlib/cindex.c:511
 #, c-format
 msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr "Impossibile aprire il file di indici di categoria per il vettoriale <%s@%s>"
+msgstr ""
+"Impossibile aprire il file di indici di categoria per il vettoriale <%s@%s>"
 #: ../lib/vector/Vlib/build_ogr.c:272
 #, c-format
@@ -3232,7 +3394,8 @@
 msgstr "Build parziale per OGR non supportato"
 #: ../lib/vector/Vlib/build_ogr.c:342
-msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgid ""
+"Random read is not supported by OGR for this layer, cannot build support"
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:349
@@ -3471,7 +3634,8 @@
 msgstr "Impossibile risolvere il sistema di equazioni lineari"
 #: ../lib/gpde/N_parse_options.c:59
-msgid "The type of solver which should solve the symmetric linear equation system"
+msgid ""
+"The type of solver which should solve the symmetric linear equation system"
 msgstr ""
 #: ../lib/gpde/N_parse_options.c:71
@@ -3480,14 +3644,19 @@
 #: ../lib/gpde/N_parse_options.c:80
 msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr "Numero massimo di iterazioni utilizzato per risolvere il sistema di equazioni lineari"
+msgstr ""
+"Numero massimo di iterazioni utilizzato per risolvere il sistema di "
+"equazioni lineari"
 #: ../lib/gpde/N_parse_options.c:89
-msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgid ""
+"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
 msgstr ""
 #: ../lib/gpde/N_parse_options.c:98
-msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgid ""
+"The relaxation parameter used by the jacobi and sor solver for speedup or "
+"stabilizing"
 msgstr ""
 #: ../lib/gpde/N_parse_options.c:106
@@ -3814,7 +3983,7 @@
 #: ../lib/gpde/N_solvers_krylov.c:200
 #, c-format
 msgid "PCG -- iteration %i error  %g\n"
-msgstr ""
+msgstr "PCG -- iterazione %i errore  %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:365
 #, c-format
@@ -3868,7 +4037,8 @@
 #: ../lib/init/lock.c:60
 #, c-format
 msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr "Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
+msgstr ""
+"Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
 #: ../lib/rst/interp_float/output2d.c:125
 #, c-format
@@ -3876,13 +4046,22 @@
 msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:111
-msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
-msgstr "La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi la regione per includere l'area dove si trovano i punti. Continuando i calcoli..."
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
+"La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi "
+"la regione per includere l'area dove si trovano i punti. Continuando i "
+"calcoli..."
 #: ../lib/rst/interp_float/interp2d.c:212
 #, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
-msgstr "Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
+msgstr ""
+"Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene "
+"alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/input2d.c:47
 #, c-format
@@ -3940,7 +4119,8 @@
 #: ../lib/rst/interp_float/vinput2d.c:328
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
+msgstr ""
+"Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
 #: ../lib/rst/interp_float/vinput2d.c:331
 #, c-format
@@ -3949,7 +4129,9 @@
 #: ../lib/rst/interp_float/vinput2d.c:335
 #, c-format
-msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:340
@@ -3958,13 +4140,22 @@
 #: ../lib/rst/interp_float/vinput2d.c:345
 #, c-format
-msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
-msgstr "Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= %d per connessione continua dei segmenti, npmin > segmax (consultare il manuale)"
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
+"Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= "
+"%d per connessione continua dei segmenti, npmin > segmax (consultare il "
+"manuale)"
 #: ../lib/rst/interp_float/vinput2d.c:351
 #, c-format
-msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
-msgstr "Ci sono meno di %d punti per l'interpolazione. Non è richiesta segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
+"Ci sono meno di %d punti per l'interpolazione. Non è richiesta "
+"segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
 #: ../lib/rst/interp_float/vinput2d.c:355
 #, c-format
@@ -4048,7 +4239,8 @@
 #: ../lib/g3d/g3dopen.c:124
 msgid "G3d_openCellOld: projection does not match window projection"
-msgstr "G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
+msgstr ""
+"G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
 #: ../lib/g3d/g3dopen.c:128
 msgid "G3d_openCellOld: zone does not match window zone"
@@ -4106,8 +4298,12 @@
 #: ../lib/arraystats/class.c:221
 #, c-format
-msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
-msgstr "Ci sono interruzioni di classe fuori dal range min-max. Numero di classi ridotto a %i, ma saranno usate probabiltà per %i classi."
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
+msgstr ""
+"Ci sono interruzioni di classe fuori dal range min-max. Numero di classi "
+"ridotto a %i, ma saranno usate probabiltà per %i classi."
 #: ../lib/ogsf/GVL2.c:248
 #, c-format
@@ -4193,8 +4389,12 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
-msgstr "gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si notifichino gli sviluppatori GRASS"
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
+msgstr ""
+"gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si "
+"notifichino gli sviluppatori GRASS"
 #: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/gsd_img_ppm.c:53
 #: ../lib/ogsf/gsd_img_ppm.c:96 ../lib/ogsf/GK2.c:219
@@ -4220,7 +4420,9 @@
 #: ../lib/ogsf/Gs3.c:647
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr "Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol=%d"
+msgstr ""
+"Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol="
+"%d"
 #: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
 #, c-format
@@ -4331,7 +4533,9 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:306
 msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr "Impossibile ricavare il formato di output dall'estensione del file: si userà MPEG"
+msgstr ""
+"Impossibile ricavare il formato di output dall'estensione del file: si userà "
+"MPEG"
 #: ../lib/ogsf/gsd_img_mpeg.c:310
 msgid "Unable to find suitable output format"
@@ -4357,17 +4561,23 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:25
 #, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o 'NULL'.\n"
+msgstr ""
+"Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o "
+"'NULL'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:33
 #, c-format
 msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr "Nome della tabella della mappa <%s> non valido. Deve iniziare con una lettera.\n"
+msgstr ""
+"Nome della tabella della mappa <%s> non valido. Deve iniziare con una "
+"lettera.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:43
 #, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr "Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è permesso.\n"
+msgstr ""
+"Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è "
+"permesso.\n"
 #: ../lib/db/dbmi_base/login.c:98
 msgid "Login file corrupted"
@@ -4475,8 +4685,13 @@
 msgstr "Errore di memoria nell'allocare il timestamp"
 #: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
-msgstr "Nota per sviluppatori: Per i vettoriali a punti viene usata una sites library modificata. (il modulo va aggiornato alla libreria vettoriale di GRASS6)"
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
+msgstr ""
+"Nota per sviluppatori: Per i vettoriali a punti viene usata una sites "
+"library modificata. (il modulo va aggiornato alla libreria vettoriale di "
+"GRASS6)"
 #: ../lib/sites/sites.c:397
 msgid "Cannot fetch row"
@@ -4569,7 +4784,9 @@
 #: ../lib/gmath/la.c:531
 msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr "La matrice (o sottomatrice) presenta singolarità. La soluzione è indeterminata."
+msgstr ""
+"La matrice (o sottomatrice) presenta singolarità. La soluzione è "
+"indeterminata."
 #: ../lib/gmath/la.c:535
 msgid "Problem in LA routine."
@@ -4577,7 +4794,8 @@
 #: ../lib/gmath/la.c:542
 msgid "Procedure not yet available for selected matrix type"
-msgstr "Procedura non ancora disponibile per la tipologia della matrice selezionata"
+msgstr ""
+"Procedura non ancora disponibile per la tipologia della matrice selezionata"
 #: ../lib/gmath/la.c:576
 msgid "Matrix is not square. Cannot determine inverse"
@@ -4675,17 +4893,21 @@
 #: ../lib/imagery/points.c:124
 #, c-format
 msgid "Unable to open control point file for group [%s in %s]"
-msgstr "Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr ""
+"Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
 #: ../lib/imagery/points.c:132
 #, c-format
 msgid "Bad format in control point file for group [%s in %s]"
-msgstr "Formato non supportato nel file dei punti di controllo per il gruppo [%s in %s]"
+msgstr ""
+"Formato non supportato nel file dei punti di controllo per il gruppo [%s in "
+"%s]"
 #: ../lib/imagery/points.c:159
 #, c-format
 msgid "Unable to create control point file for group [%s in %s]"
-msgstr "Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr ""
+"Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
 #: ../lib/imagery/fopen.c:23
 #, c-format
@@ -4705,17 +4927,20 @@
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+msgstr ""
+"Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+msgstr ""
+"Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
+msgstr ""
+"Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
 #: ../lib/imagery/list_gp.c:34
 #, c-format
@@ -4741,15 +4966,3 @@
 #, c-format
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
 msgstr "subgroup <%s> del gruppo <%s> fa riferimento ai seguenti raster\n"
-#~ msgid "Vector is not 3D"
-#~ msgstr "Il vettore non è 3D"
-#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr "Impossibile trovare la colonna z <%s> (si prega di verificarne il nome con v.info)"
-#~ msgid "Unknown Location"
-#~ msgstr "Posizione sconosciuta"
-#~ msgid "Too many arguments"
-#~ msgstr "troppi argomenti"
