[GRASS-SVN] r47161 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Mon Jul 18 13:19:57 EDT 2011
Author: martinl
Date: 2011-07-18 10:19:56 -0700 (Mon, 18 Jul 2011)
New Revision: 47161
grass/trunk/scripts/g.extension/g.extension.py
g.extension: call tempdir() after parser()
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-07-18 16:45:45 UTC (rev 47160)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-07-18 17:19:56 UTC (rev 47161)
@@ -96,12 +96,11 @@
# temp dir
remove_tmpdir = True
-tmpdir = grass.tempdir()
def check():
for prog in ('svn', 'make', 'install', 'gcc'):
if not grass.find_program(prog, ['--help']):
- grass.fatal(_("%s required. Please install '%s' first.") % (prog, prog))
+ grass.fatal(_("'%s' required. Please install '%s' first.") % (prog, prog))
def expand_module_class_name(c):
name = { 'd' : 'display',
@@ -283,7 +282,6 @@
return ret
def cleanup():
- global tmpdir, remove_tmpdir
if remove_tmpdir:
grass.try_rmdir(tmpdir)
else:
@@ -309,7 +307,7 @@
grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % options['extension'])
- global tmpdir
os.chdir(tmpdir)
if grass.verbosity() == 0:
outdev = open(os.devnull, 'w')
@@ -465,5 +463,7 @@
if __name__ == "__main__":
options, flags = grass.parser()
+ global tmpdir
+ tmpdir = grass.tempdir()
atexit.register(cleanup)
sys.exit(main())
