[GRASS-SVN] r47173 - in grass/branches/releasebranch_6_4/gui/wxpython: . gui_modules
Mon Jul 18 15:54:42 EDT 2011
Author: martinl
Date: 2011-07-18 12:54:42 -0700 (Mon, 18 Jul 2011)
New Revision: 47173
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
wxGUI: fix and simplify raster/vector querying in 2D
      (merge r47170 & r41171 from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py	2011-07-18 19:54:07 UTC (rev 47172)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_base.py	2011-07-18 19:54:42 UTC (rev 47173)
@@ -6,7 +6,7 @@
 List of classes:
  - VectorDBInfo
-(C) 2007-2010 by the GRASS Development Team
+(C) 2007-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -28,6 +28,9 @@
 def unicodeValue(value):
     """!Encode value"""
+    if type(value) == types.UnicodeType:
+        return value
     enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
     if enc:
         value = unicode(value, enc)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py	2011-07-18 19:54:07 UTC (rev 47172)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py	2011-07-18 19:54:42 UTC (rev 47173)
@@ -29,10 +29,10 @@
 class DisplayAttributesDialog(wx.Dialog):
     def __init__(self, parent, map,
-                 query=None, cats=None, line=None,
-                 style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
-                 pos=wx.DefaultPosition,
-                 action="add"):
+                 query = None, cats = None, line = None,
+                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+                 pos = wx.DefaultPosition,
+                 action = "add"):
         """!Standard dialog used to add/update/display attributes linked
         to the vector map.
@@ -67,39 +67,41 @@
             label = _("Database connection "
                       "is not defined in DB file.")
-            wx.MessageBox(parent=self.parent,
-                          message=_("No attribute table linked to "
+            wx.MessageBox(parent = self.parent,
+                          message = _("No attribute table linked to "
                                     "vector map <%(vector)s> found. %(msg)s"
                                     "\nYou can disable this message from digitization settings. Or "
                                     "you can create and link attribute table to the vector map "
                                     "using Attribute Table Manager.") %
                           {'vector' : self.map, 'msg' : label},
-                          caption=_("Message"), style=wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
+                          caption = _("Message"), style = wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
             self.mapDBInfo = None
-        wx.Dialog.__init__(self, parent=self.parent, id=wx.ID_ANY,
-                           title="", style=style, pos=pos)
+        wx.Dialog.__init__(self, parent = self.parent, id = wx.ID_ANY,
+                           title = "", style = style, pos = pos)
         # dialog body
         mainSizer = wx.BoxSizer(wx.VERTICAL)
         # notebook
-        self.notebook = wx.Notebook(parent=self, id=wx.ID_ANY, style=wx.BK_DEFAULT)
+        self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
-        self.closeDialog = wx.CheckBox(parent=self, id=wx.ID_ANY,
-                                       label=_("Close dialog on submit"))
+        self.closeDialog = wx.CheckBox(parent = self, id = wx.ID_ANY,
+                                       label = _("Close dialog on submit"))
         self.closeDialog.SetValue(True)
+        if self.action == 'display':
+            self.closeDialog.Enable(False)
         # feature id (text/choice for duplicates)
-        self.fidMulti = wx.Choice(parent=self, id=wx.ID_ANY,
-                                  size=(150, -1))
+        self.fidMulti = wx.Choice(parent = self, id = wx.ID_ANY,
+                                  size = (150, -1))
         self.fidMulti.Bind(wx.EVT_CHOICE, self.OnFeature)
-        self.fidText = wx.StaticText(parent=self, id=wx.ID_ANY)
+        self.fidText = wx.StaticText(parent = self, id = wx.ID_ANY)
-        self.noFoundMsg = wx.StaticText(parent=self, id=wx.ID_ANY,
-                                        label=_("No attributes found"))
+        self.noFoundMsg = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                        label = _("No attributes found"))
-        self.UpdateDialog(query=query, cats=cats)
+        self.UpdateDialog(query = query, cats = cats)
         # set title
         if self.action == "update":
@@ -113,7 +115,9 @@
         btnCancel = wx.Button(self, wx.ID_CANCEL)
         btnReset  = wx.Button(self, wx.ID_UNDO, _("&Reload"))
         btnSubmit = wx.Button(self, wx.ID_OK, _("&Submit"))
+            btnSubmit.Enable(False)
         btnSizer = wx.StdDialogButtonSizer()
         btnSizer.AddButton(btnCancel)
         btnSizer.AddButton(btnReset)
@@ -122,25 +126,25 @@
         btnSizer.AddButton(btnSubmit)
         btnSizer.Realize()
-        mainSizer.Add(item=self.noFoundMsg, proportion=0,
-                      flag=wx.EXPAND | wx.ALL, border=5)
-        mainSizer.Add(item=self.notebook, proportion=1,
+        mainSizer.Add(item = self.noFoundMsg, proportion = 0,
+                      flag = wx.EXPAND | wx.ALL, border = 5)
+        mainSizer.Add(item = self.notebook, proportion = 1,
         fidSizer = wx.BoxSizer(wx.HORIZONTAL)
-        fidSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY,
-                                        label=_("Feature id:")),
-                     proportion=0, border=5,
-                     flag=wx.ALIGN_CENTER_VERTICAL)
-        fidSizer.Add(item=self.fidMulti, proportion=0,
-        fidSizer.Add(item=self.fidText, proportion=0,
-        mainSizer.Add(item=fidSizer, proportion=0,
-                      flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
-        mainSizer.Add(item=self.closeDialog, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT,
-                      border=5)
-        mainSizer.Add(item=btnSizer, proportion=0,
-                      flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
+        fidSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY,
+                                        label = _("Feature id:")),
+                     proportion = 0, border = 5,
+                     flag = wx.ALIGN_CENTER_VERTICAL)
+        fidSizer.Add(item = self.fidMulti, proportion = 0,
+        fidSizer.Add(item = self.fidText, proportion = 0,
+        mainSizer.Add(item = fidSizer, proportion = 0,
+                      flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
+        mainSizer.Add(item = self.closeDialog, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT,
+                      border = 5)
+        mainSizer.Add(item = btnSizer, proportion = 0,
+                      flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
         # bindigs
         btnReset.Bind(wx.EVT_BUTTON, self.OnReset)
@@ -160,7 +164,7 @@
         if self.notebook.GetPageCount() == 0:
             Debug.msg(2, "DisplayAttributesDialog(): Nothing found!")
             ### self.mapDBInfo = None
     def __SelectAttributes(self, layer):
         """!Select attributes"""
         pass
@@ -169,7 +173,15 @@
         """!Update SQL statement"""
         pass
-    def GetSQLString(self, updateValues=False):
+    def IsFound(self):
+        """!Check for status
+        @return True on attributes found
+        @return False attributes not found
+        return bool(self.notebook.GetPageCount())
+    def GetSQLString(self, updateValues = False):
         """!Create SQL statement string based on self.sqlStatement
         If updateValues is True, update dataFrame according to values
@@ -267,7 +279,8 @@
         """!Cancel button pressed
         self.parent.parent.dialogs['attributes'] = None
-        if self.parent.digit:
+        if hasattr(self, "digit"):
             self.parent.digit.GetDisplay().SetSelected([])
             self.parent.UpdateMap(render = False)
         else:
@@ -277,8 +290,8 @@
     def OnSubmit(self, event):
         """!Submit records"""
-        for sql in self.GetSQLString(updateValues=True):
-            enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+        for sql in self.GetSQLString(updateValues = True):
+            enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
             if not enc and 'GRASS_DB_ENCODING' in os.environ:
                 enc = os.environ['GRASS_DB_ENCODING']
             if enc:
@@ -293,7 +306,7 @@
     def OnFeature(self, event):
         self.fid = int(event.GetString())
-        self.UpdateDialog(cats=self.cats, fid=self.fid)
+        self.UpdateDialog(cats = self.cats, fid = self.fid)
     def GetCats(self):
         """!Get id of selected vector object or 'None' if nothing selected
@@ -309,11 +322,28 @@
         """!Get selected feature id"""
         return self.fid
-    def UpdateDialog(self, map=None, query=None, cats=None, fid=-1):
+    def UpdateDialog(self, map = None, query = None, cats = None, fid = -1,
+                     action = None):
         """!Update dialog
-        Return True if updated otherwise False
+        @param map name of vector map
+        @param query
+        @param cats
+        @param fid feature id
+        @param action add, update, display or None
+        @return True if updated
+        @return False
+        if action:
+            self.action = action
+            if action == 'display':
+                enabled = False
+            else:
+                enabled = True
+            self.closeDialog.Enable(enabled)
+            self.FindWindowById(wx.ID_OK).Enable(enabled)
         if map:
             self.map = map
             # get layer/table/column information
@@ -321,11 +351,11 @@
         if not self.mapDBInfo:
             return False
         self.mapDBInfo.Reset()
         layers = self.mapDBInfo.layers.keys() # get available layers
         # id of selected line
         if query: # select by position
             data = self.mapDBInfo.SelectByPoint(query[0],
@@ -348,7 +378,7 @@
                     idx += 1
         else:
             self.cats = cats
         if fid > 0:
             self.fid = fid
         elif len(self.cats.keys()) > 0:
@@ -374,21 +404,21 @@
         # reset notebook
         self.notebook.DeleteAllPages()
         for layer in layers: # for each layer
             if not query: # select by layer/cat
                 if self.fid > 0 and layer in self.cats[self.fid]:
                     for cat in self.cats[self.fid][layer]:
                         nselected = self.mapDBInfo.SelectFromTable(layer,
-        where="%s=%d" % \
+        where = "%s=%d" % \
        (self.mapDBInfo.layers[layer]['key'],
        cat))
                 else:
                     nselected = 0
             # if nselected <= 0 and self.action != "add":
             #    continue # nothing selected ...
             if self.action == "add":
                 if nselected <= 0:
                     if layer in self.cats[self.fid]:
@@ -415,17 +445,17 @@
                         break
                 # use scrolled panel instead (and fix initial max height of the window to 480px)
-                panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
-                                               size=(-1, 150))
-                panel.SetupScrolling(scroll_x=False)
+                panel = scrolled.ScrolledPanel(parent = self.notebook, id = wx.ID_ANY,
+                                               size = (-1, 150))
+                panel.SetupScrolling(scroll_x = False)
-                self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
+                self.notebook.AddPage(page = panel, text = " %s %d / %s %d" % (_("Layer"), layer,
        _("Category"), cat))
                 # notebook body
                 border = wx.BoxSizer(wx.VERTICAL)
-                flexSizer = wx.FlexGridSizer (cols=4, hgap=3, vgap=3)
+                flexSizer = wx.FlexGridSizer (cols = 4, hgap = 3, vgap = 3)
                 flexSizer.AddGrowableCol(3)
                 # columns (sorted by index)
                 names = [''] * len(columns.keys())
@@ -445,34 +475,35 @@
                             value = columns[name]['values'][idx]
                     else:
                         value = ''
-                    colName = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                            label=name)
-                    colType = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                            label="[" + vtype.lower() + "]")
-                    delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
-                    colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value)
+                    colName = wx.StaticText(parent = panel, id = wx.ID_ANY,
+                                            label = name)
+                    colType = wx.StaticText(parent = panel, id = wx.ID_ANY,
+                                            label = "[" + vtype.lower() + "]")
+                    delimiter = wx.StaticText(parent = panel, id = wx.ID_ANY, label = ":")
+                    colValue = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = value)
                     colValue.SetName(name)
                     self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
+                        colValue.SetWindowStyle(wx.TE_READONLY)
-                    flexSizer.Add(colName, proportion=0,
-                                  flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
-                    flexSizer.Add(colType, proportion=0,
-                    flexSizer.Add(delimiter, proportion=0,
-                    flexSizer.Add(colValue, proportion=1,
-                                  flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+                    flexSizer.Add(colName, proportion = 0,
+                                  flag = wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+                    flexSizer.Add(colType, proportion = 0,
+                    flexSizer.Add(delimiter, proportion = 0,
+                    flexSizer.Add(colValue, proportion = 1,
+                                  flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
                     # add widget reference to self.columns
                     columns[name]['ids'].append(colValue.GetId()) # name, type, values, id
                 # for each attribute (including category) END
-                border.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+                border.Add(item = flexSizer, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 5)
                 panel.SetSizer(border)
             # for each category END
         # for each layer END
             self.noFoundMsg.Show(True)
         else:
@@ -497,8 +528,8 @@
                 break
 class ModifyTableRecord(wx.Dialog):
-    def __init__(self, parent, id, title, data, keyEditable=(-1, True),
-                style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+    def __init__(self, parent, id, title, data, keyEditable = (-1, True),
+                style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
         """!Dialog for inserting/updating table record
         Notes:
@@ -507,25 +538,25 @@
         is editable(True) or not.
         # parent -> VDigitWindow
-        wx.Dialog.__init__(self, parent, id, title, style=style)
+        wx.Dialog.__init__(self, parent, id, title, style = style)
         self.CenterOnParent()
         self.keyId = keyEditable[0]
-        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
-        box = wx.StaticBox(parent=self.panel, id=wx.ID_ANY, label='')
+        box = wx.StaticBox(parent = self.panel, id = wx.ID_ANY, label = '')
-        self.dataPanel = scrolled.ScrolledPanel(parent=self.panel, id=wx.ID_ANY,
-                                            style=wx.TAB_TRAVERSAL)
-        self.dataPanel.SetupScrolling(scroll_x=False)
+        self.dataPanel = scrolled.ScrolledPanel(parent = self.panel, id = wx.ID_ANY,
+                                            style = wx.TAB_TRAVERSAL)
+        self.dataPanel.SetupScrolling(scroll_x = False)
         # buttons
         self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
-        self.btnSubmit = wx.Button(self.panel, wx.ID_OK, _("Submit"))
+        self.btnSubmit = wx.Button(self.panel, wx.ID_OK, _("&Submit"))
         self.btnSubmit.SetDefault()
@@ -545,14 +576,14 @@
                     id += 1
                     continue
                 else:
-                    valueWin = wx.SpinCtrl(parent=self.dataPanel, id=wx.ID_ANY,
-                                           value=value, min=-1e9, max=1e9, size=(250, -1))
+                    valueWin = wx.SpinCtrl(parent = self.dataPanel, id = wx.ID_ANY,
+                                           value = value, min = -1e9, max = 1e9, size = (250, -1))
             else:
-                valueWin = wx.TextCtrl(parent=self.dataPanel, id=wx.ID_ANY,
-                                       value=value, size=(250, -1))
+                valueWin = wx.TextCtrl(parent = self.dataPanel, id = wx.ID_ANY,
+                                       value = value, size = (250, -1))
-            label = wx.StaticText(parent=self.dataPanel, id=wx.ID_ANY,
-                                  label=column + ":")
+            label = wx.StaticText(parent = self.dataPanel, id = wx.ID_ANY,
+                                  label = column + ":")
             self.widgets.append((label.GetId(),
                                  valueWin.GetId()))
@@ -560,38 +591,31 @@
             id += 1
         self.__Layout()
-        # winSize = self.GetSize()
-        # fix height of window frame if needed
-        # if winSize[1] > 480:
-        #    winSize[1] = 480
-        #    self.SetSize(winSize)
-        # self.SetMinSize(winSize)
     def __Layout(self):
         """!Do layout"""
         sizer = wx.BoxSizer(wx.VERTICAL)
         # data area
-        dataSizer = wx.FlexGridSizer (cols=2, hgap=3, vgap=3)
+        dataSizer = wx.FlexGridSizer (cols = 2, hgap = 3, vgap = 3)
         dataSizer.AddGrowableCol(1)
         for labelId, valueId in self.widgets:
             label = self.FindWindowById(labelId)
             value = self.FindWindowById(valueId)
-            dataSizer.Add(label, proportion=0,
-            dataSizer.Add(value, proportion=0,
+            dataSizer.Add(label, proportion = 0,
+            dataSizer.Add(value, proportion = 0,
         self.dataPanel.SetAutoLayout(True)
         self.dataPanel.SetSizer(dataSizer)
         dataSizer.Fit(self.dataPanel)
         if self.usebox:
-            self.boxSizer.Add(item=self.dataPanel, proportion=1,
+            self.boxSizer.Add(item = self.dataPanel, proportion = 1,
         # buttons
@@ -600,15 +624,15 @@
         btnSizer.Realize()
         if not self.usebox:
-            sizer.Add(item=self.dataPanel, proportion=1,
+            sizer.Add(item = self.dataPanel, proportion = 1,
         else:
-            sizer.Add(item=self.boxSizer, proportion=1,
+            sizer.Add(item = self.boxSizer, proportion = 1,
-        sizer.Add(item=btnSizer, proportion=0,
+        sizer.Add(item = btnSizer, proportion = 0,
         framewidth = self.GetSize()[0]
         self.SetMinSize((framewidth,150))
@@ -621,27 +645,7 @@
         self.Layout()
-#        # set window frame size (min & max)
-#        minFrameHeight = 150
-#        maxFrameHeight = 2 * minFrameHeight
-#        if self.GetSize()[1] > minFrameHeight:
-#            print 'size ='+str(self.GetSize()[1])
-#            print 'if 1'
-#            self.SetMinSize((self.GetSize()[0], minFrameHeight))
-#        else:
-#            print 'else 1'
-#            self.SetMinSize(self.GetSize())
-#        if self.GetSize()[1] > maxFrameHeight:
-#            print 'if 2'
-#            self.SetSize((self.GetSize()[0], maxFrameHeight))
-#        else:
-#            print 'else 2'
-#            self.SetSize(self.panel.GetSize())
-    def GetValues(self, columns=None):
+    def GetValues(self, columns = None):
         """!Return list of values (casted to string).
         If columns is given (list), return only values of given columns.
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2011-07-18 19:54:07 UTC (rev 47172)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp.py	2011-07-18 19:54:42 UTC (rev 47173)
@@ -360,12 +360,10 @@
         # check for GLCanvas and OpenGL
         if not nviz.haveNviz:
             self.toolbars['map'].combo.SetValue (_("2D view"))
-            wx.MessageBox(parent = self,
-                          message = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
-                                      "was not found or loaded properly.\n"
-                                      "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg),
-                          caption = _("Error"),
-                          style = wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            gcmd.GError(parent = self,
+                        message = _("Unable to switch to 3D display mode.\nThe Nviz python extension "
+                                    "was not found or loaded properly.\n"
+                                    "Switching back to 2D display mode.\n\nDetails: %s" % nviz.errorMsg))
             return
         # add Nviz toolbar and disable 2D display mode tools
@@ -602,7 +600,7 @@
                 else: # line, boundary
                     self.MapWindow.mouse['box'] = 'line'
             elif self.toolbars['vdigit'].GetAction() in ['addVertex', 'removeVertex', 'splitLine',
-                                                         'editLine', 'displayCats', 'displayAttrs',
+                                                         'editLine', 'displayCats', 'queryMap',
                                                          'copyCats']:
                 self.MapWindow.mouse['box'] = 'point'
             else: # moveLine, deleteLine
@@ -1216,46 +1214,7 @@
     def GetWindow(self):
         """!Get map window"""
         return self.MapWindow
-    def _OnQuery(self):
-        """!Internal method used by OnQuery*() methods"""
-        if not self.IsStandalone() and  \
-                self.toolbars['map'].GetAction() == 'displayAttrb':
-            # switch to output console to show query results
-            self._layerManager.notebook.SetSelectionByName('output')
-        self.MapWindow.mouse['box'] = "point"
-        self.MapWindow.zoomtype = 0
-        # change the cursor
-        self.MapWindow.SetCursor(self.cursors["cross"])
-    def OnQueryDisplay(self, event):
-        """!Query currrent raster/vector map layers (display mode) -
-        2D view mode
-        if self.toolbars['map'].GetAction() == 'displayAttrb': # select previous action
-            self.toolbars['map'].SelectDefault(event)
-            return
-        self.toolbars['map'].action['desc'] = 'displayAttrb'
-        self.MapWindow.mouse['use'] = "query"
-        self._OnQuery()
-    def OnQueryModify(self, event):
-        """!Query vector map layer (edit mode) - 2D view mode
-        if self.toolbars['map'].GetAction() == 'modifyAttrb': # select previous action
-            return
-        self.toolbars['map'].action['desc'] = 'modifyAttrb'
-        self.MapWindow.mouse['use'] = "queryVector"
-        self.MapWindow.pen = wx.Pen(colour = 'Red', width = 2, style = wx.SHORT_DASH)
-        self._OnQuery()
     def OnNvizQuerySurface(self, event):
         """!Query current surface in 3D view mode"""
         if self.toolbars['map'].GetAction() == 'nvizQuerySurface':
@@ -1312,9 +1271,10 @@
                 ltype = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
                 dcmd = self.tree.GetPyData(layer)[0]['cmd']
                 name, found = utils.GetLayerNameFromCmd(dcmd)
                 if not found:
                     continue
-                if ltype is 'raster':
+                if ltype == 'raster':
                     rast.append(name)
                 elif ltype in ('rgb', 'his'):
                     for iname in name.split('\n'):
@@ -1394,23 +1354,13 @@
         if not self.tree.layer_selected or \
                 self.tree.GetPyData(self.tree.layer_selected)[0]['type'] != 'vector':
-                          message = _("No vector map selected for querying."),
-                          caption = _("Vector querying"),
-                          style = wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+            gcmd.GMessage(parent = self,
+                          message = _("No vector map selected for querying."))
             return
-        if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
-                grass.gisenv()['MAPSET']:
-                          message = _("Only vector map from the current mapset can be modified."),
-            return
         posWindow = self.ClientToScreen((x + self.MapWindow.dialogOffset,
                                          y + self.MapWindow.dialogOffset))
         qdist = 10.0 * ((self.Map.region['e'] - self.Map.region['w']) /
                         self.Map.width)
@@ -1418,21 +1368,32 @@
         mapName = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].name
+        if self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer'].GetMapset() != \
+                grass.gisenv()['MAPSET']:
+            mode = 'display'
+        else:
+            mode = 'update'
         if self.dialogs['attributes'] is None:
-            self.dialogs['attributes'] = \
-                dbm_dialogs.DisplayAttributesDialog(parent = self.MapWindow,
-                                                    map = mapName,
-                                                    query = ((east, north), qdist),
-                                                    pos = posWindow,
-                                                    action = "update")
+            dlg = dbm_dialogs.DisplayAttributesDialog(parent = self.MapWindow,
+                                                      map = mapName,
+                                                      query = ((east, north), qdist),
+                                                      pos = posWindow,
+                                                      action = mode)
+            self.dialogs['attributes'] = dlg
         else:
             # selection changed?
             if not self.dialogs['attributes'].mapDBInfo or \
                     self.dialogs['attributes'].mapDBInfo.map != mapName:
-                self.dialogs['attributes'].UpdateDialog(map = mapName, query = ((east, north), qdist))
+                self.dialogs['attributes'].UpdateDialog(map = mapName, query = ((east, north), qdist),
+                                                        action = mode)
             else:
-                self.dialogs['attributes'].UpdateDialog(query = ((east, north), qdist))
+                self.dialogs['attributes'].UpdateDialog(query = ((east, north), qdist),
+                                                        action = mode)
+        if not self.dialogs['attributes'].IsFound():
+            self._layerManager.goutput.WriteLog(_('Nothing found.'))
         cats = self.dialogs['attributes'].GetCats()
         try:
@@ -1469,11 +1430,8 @@
             self.toolbars['map'].OnTool(event)
             action = self.toolbars['map'].GetAction()
-        point = wx.GetMousePosition()
-        toolsmenu = wx.Menu()
-        # add items to the menu
         if self.toolbars['nviz']:
+            toolsmenu = wx.Menu()
             raster = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
                                  text = _("Query surface (raster map)"),
                                  kind = wx.ITEM_CHECK)
@@ -1488,48 +1446,23 @@
             self.Bind(wx.EVT_MENU, self.OnNvizQueryVector, vector)
             if action == "nvizQueryVector":
                 vector.Check(True)
+            self.PopupMenu(toolsmenu)
+            toolsmenu.Destroy()
         else:
-            display = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
-                                  text = _("Query raster/vector map(s) (display mode)"),
-                                  kind = wx.ITEM_CHECK)
-            toolsmenu.AppendItem(display)
-            self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
-            numLayers = 0
-            if self.tree:
-                for layer in self.tree.GetSelections():
-                    ltype = self.tree.GetPyData(layer)[0]['maplayer'].GetType()
-                    if ltype in ('raster', 'rgb', 'his',
-                                 'vector', 'thememap', 'themechart'):
-                        numLayers += 1
-            if not self.IsStandalone() and numLayers < 1:
-                display.Enable(False)
-            if action == "displayAttrb":
-                display.Check(True)
+            self.toolbars['map'].action['desc'] = 'queryMap'
+            self.MapWindow.mouse['use'] = "query"
-            modify = wx.MenuItem(parentMenu = toolsmenu, id = wx.ID_ANY,
-                                 text = _("Query vector map (edit mode)"),
-            toolsmenu.AppendItem(modify)
-            self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
-            modify.Enable(False)
-            if action == "modifyAttrb":
-                modify.Check(True)
+            if not self.IsStandalone():
+                # switch to output console to show query results
+                self._layerManager.notebook.SetSelectionByName('output')
-            digitToolbar = self.toolbars['vdigit']
-            if self.tree and self.tree.layer_selected:
-                mapLayer = self.tree.GetPyData(self.tree.layer_selected)[0]['maplayer']
-                if mapLayer.GetType() == 'vector' and \
-                        mapLayer.GetMapset() == grass.gisenv()['MAPSET'] and \
-                        (not digitToolbar or (digitToolbar and \
-                             digitToolbar.GetLayer() != mapLayer)):
-                    modify.Enable(True)
-            else:
+            self.MapWindow.mouse['box'] = "point"
+            self.MapWindow.zoomtype = 0
+            # change the cursor
+            self.MapWindow.SetCursor(self.cursors["cross"])
-        self.PopupMenu(toolsmenu)
-        toolsmenu.Destroy()
     def AddTmpVectorMapLayer(self, name, cats, useId = False, addLayer = True):
         """!Add temporal vector map layer to map composition
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-18 19:54:07 UTC (rev 47172)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/mapdisp_window.py	2011-07-18 19:54:42 UTC (rev 47173)
@@ -1191,8 +1191,23 @@
         elif self.mouse["use"] == "query":
             # querying
-            self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
+            layers = self.GetSelectedLayer(multi = True)
+            isRaster = False
+            nVectors = 0
+            for l in layers:
+                if l.GetType() == 'raster':
+                    isRaster = True
+                    break
+                if l.GetType() == 'vector':
+                    nVectors += 1
+            if isRaster or nVectors > 1:
+                self.parent.QueryMap(self.mouse['begin'][0],self.mouse['begin'][1])
+            else:
+                self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
+                # clear temp canvas
+                self.UpdateMap(render = False, renderVector = False)
         elif self.mouse["use"] == "queryVector":
             # editable mode for vector map layers
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2011-07-18 19:54:07 UTC (rev 47172)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxgui.py	2011-07-18 19:54:42 UTC (rev 47173)
@@ -893,7 +893,7 @@
         if os.path.exists(filename):
             dlg = wx.MessageDialog(self, message = _("Workspace file <%s> already exists. "
-                                                   "Do you want to overwrite this file?") % filename,
+                                                     "Do you want to overwrite this file?") % filename,
                                    caption = _("Save workspace"), style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
             if dlg.ShowModal() != wx.ID_YES:
                 dlg.Destroy()
