[GRASS-SVN] r47193 - grass/branches/develbranch_6/lib/python
Thu Jul 21 05:41:48 EDT 2011
Author: neteler
Date: 2011-07-21 02:41:48 -0700 (Thu, 21 Jul 2011)
New Revision: 47193
   grass/branches/develbranch_6/lib/python/pythonlib.dox
backport doxygen improvements (maybe solving doxygen namespace collision with vector lib)
Modified: grass/branches/develbranch_6/lib/python/pythonlib.dox
--- grass/branches/develbranch_6/lib/python/pythonlib.dox	2011-07-21 09:41:33 UTC (rev 47192)
+++ grass/branches/develbranch_6/lib/python/pythonlib.dox	2011-07-21 09:41:48 UTC (rev 47193)
@@ -88,42 +88,42 @@
 <b>GRASS-oriented interface to subprocess module</b>
- - exec_command()
+ - python::core::exec_command()
- - feed_command()
+ - python::core::feed_command()
- - make_command()
+ - python::core::make_command()
- - parse_command()
+ - python::core::parse_command()
- - pipe_command()
+ - python::core::pipe_command()
- - read_command()
+ - python::core::read_command()
- - run_command()
+ - python::core::run_command()
- - start_command()
+ - python::core::start_command()
- - write_command()
+ - python::core::write_command()
 <b>Interface to g.message</b>
 These all run g.message, differing only in which flag (if any) is
 used. fatal() is error(), but also calls sys.exit(1).
- - debug()
+ - python::core::debug()
- - error()
+ - python::core::error()
- - fatal()
+ - python::core::fatal()
- - info()
+ - python::core::info()
- - message()
+ - python::core::message()
- - verbose()
+ - python::core::verbose()
- - warning()
+ - python::core::warning()
 <b>Interface to g.parser</b>
@@ -135,47 +135,47 @@
 	    main()
 \endcode
- - parser()
+ - python::core::parser()
 <b>Interface to g.tempfile</b>
 Returns the name of a temporary file, created with g.tempfile.
- - tempfile()
+ - python::core::tempfile()
 <b>Key-value parsers</b>
- - parse_key_val()
+ - python::core::parse_key_val()
 <b>Interface to g.gisenv</b>
- - gisenv()
+ - python::core::gisenv()
 <b>Interface to g.region</b>
- - del_temp_region()
+ - python::core::del_temp_region()
- - region()
+ - python::core::region()
- - use_temp_region()
+ - python::core::use_temp_region()
 <b>Interface to g.findfile</b>
- - find_file()
+ - python::core::find_file()
 <b>Interface to g.list</b>
- - list_grouped()
+ - python::core::list_grouped()
- - list_pairs()
+ - python::core::list_pairs()
- - list_strings()
+ - python::core::list_strings()
- - mlist_grouped()
+ - python::core::mlist_grouped()
 <b>Interface to g.mapsets</b>
- - mapsets()
+ - python::core::mapsets()
 <b>Interface to g.version</b>
@@ -183,13 +183,13 @@
 <b>Color parsing</b>
- - parse_color()
+ - python::core::parse_color()
 <b>Check GRASS environment variables</b>
- - overwrite()
+ - python::core::overwrite()
- - verbosity()
+ - python::core::verbosity()
 <b>Create new GRASS location</b>
@@ -197,15 +197,15 @@
 <b>Various utilities, not specific to GRASS</b>
- - basename()
+ - python::core::basename()
- - find_program()
+ - python::core::find_program()
- - try_remove()
+ - python::core::try_remove()
- - try_rmdir()
+ - python::core::try_rmdir()
- - float_or_dms()
+ - python::core::float_or_dms()
 \section pythonDb Database
@@ -215,11 +215,11 @@
 from grass.script import db as grass
 \endcode
- - db_connection()
+ - python::db::db_connection()
- - db_describe()
+ - python::db::db_describe()
- - db_select()
+ - python::db::db_select()
 \section pythonRaster Raster
@@ -229,11 +229,11 @@
 from grass.script import raster as grass
 \endcode
- - raster_history()
+ - python::raster::raster_history()
- - raster_info()
+ - python::raster::raster_info()
- - mapcalc()
+ - python::raster::mapcalc()
 \section pythonVector Vector
@@ -243,17 +243,17 @@
 from grass.script import vector as grass
 \endcode
- - vector_columns()
+ - python::vector::vector_columns()
- - vector_db()
+ - python::vector::vector_db()
- - vector_db_select()
+ - python::vector::vector_db_select()
- - vector_history()
+ - python::vector::vector_history()
- - vector_info_topo()
+ - python::vector::vector_info_topo()
- - vector_layer_db()
+ - python::vector::vector_layer_db()
 \section pythonSetup Setup
