[GRASS-SVN] r47194 - grass/trunk/gui/wxpython/gui_modules
Thu Jul 21 05:56:23 EDT 2011
Author: annakrat
Date: 2011-07-21 02:56:22 -0700 (Thu, 21 Jul 2011)
New Revision: 47194
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
wxNviz: display overlays - d.legend
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -484,14 +484,16 @@
             overlay = self.parent.Map.AddOverlay(id=self.ovlId, type=self.name,
                                                  command=self.cmd,
                                                  l_active=False, l_render=False, l_hidden=True)
-            self.parent.MapWindow.overlays[self.ovlId] = {}
-            self.parent.MapWindow.overlays[self.ovlId] = { 'layer' : overlay,
-                                                           'params' : None,
-                                                           'propwin' : None,
-                                                           'cmd' : self.cmd,
-                                                           'coords': (10, 10),
-                                                           'pdcType': 'image' }
+            prop = { 'layer' : overlay,
+                     'params' : None,
+                     'propwin' : None,
+                     'cmd' : self.cmd,
+                     'coords': (10, 10),
+                     'pdcType': 'image' }
+            self.parent.MapWindow2D.overlays[self.ovlId] = prop
+            if self.parent.MapWindow3D:
+                self.parent.MapWindow3D.overlays[self.ovlId] = prop
         else:
             if self.parent.MapWindow.overlays[self.ovlId]['propwin'] == None:
                 return
@@ -528,6 +530,9 @@
         self.parent.Map.GetOverlay(self.ovlId).SetActive(self.chkbox.IsChecked())
         # update map
+        if self.parent.MapWindow.parent.toolbars['nviz']:
+            self.parent.MapWindow.UpdateOverlays()
         self.parent.MapWindow.UpdateMap()
         # close dialog
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -385,6 +385,8 @@
                                              Map = self.Map, tree = self.tree, lmgr = self._layerManager)
             self.MapWindow = self.MapWindow3D
             self.MapWindow.SetCursor(self.cursors["default"])
+            self.MapWindow3D.overlays = self.MapWindow2D.overlays
+            self.MapWindow3D.UpdateOverlays()
                 # add Nviz notebookpage
             self._layerManager.AddNviz()
@@ -394,6 +396,7 @@
             self.MapWindow3D.UpdateView(None)
         else:
             for page in ('view', 'light', 'fringe', 'constant', 'cplane'):
@@ -1686,6 +1689,14 @@
         AddText.SetBitmap(icons["addText"].GetBitmap(self.iconsize))
         decmenu.AppendItem(AddText)
         self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
+        # temporary
+        if self.toolbars['nviz']:
+            AddText.Enable(False)
+            AddScale.Enable(False)
+            AddArrow = wx.MenuItem(decmenu, wx.ID_ANY, _("Add north arrow"))
+            AddArrow.SetBitmap(icons["addBarscale"].GetBitmap(self.iconsize))
+            decmenu.AppendItem(AddArrow)
+            self.Bind(wx.EVT_MENU, self.OnAddArrow, AddArrow)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
@@ -1797,7 +1808,15 @@
             self.MapWindow.UpdateMap(render = False, renderVector = False)
         self.MapWindow.mouse['use'] = 'pointer'
+    def OnAddArrow(self, event):
+        """!Handler for north arrow menu selection.
+            Opens Appearance page of nviz notebook.
+        self._layerManager.nviz.SetPage('decoration')
     def GetOptData(self, dcmd, type, params, propwin):
         """!Callback method for decoration overlay command generated by
         dialog created in menuform.py
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -86,7 +86,7 @@
                         'vlines' : False,
                         'vpoints' : False }
         self.mouse = {
-            'use': 'default'
+            'use': 'pointer'
         self.cursors = {
             'default' : wx.StockCursor(wx.CURSOR_ARROW),
@@ -100,6 +100,12 @@
         self.cplanes = list()
         # list of query points
         self.qpoints = list()
+        # overlays
+        self.overlays = {}
+        self.imagedict = {}
+        self.shapes = []
+        self.dragShape = None
+        self.dragImage = None
         # use display region instead of computational
@@ -171,7 +177,23 @@
             cplane['on'] = False
             self.cplanes.append(cplane)
+    def GetOverlay(self):
+        """!Converts rendered overlay files to wx.Image
+        Updates self.imagedict
+        @return list of images
+        imgs = []
+        for overlay in self.Map.GetListOfLayers(l_type = "overlay", l_active = True):
+            if os.path.isfile(overlay.mapfile) and os.path.getsize(overlay.mapfile):
+                img = wx.Image(overlay.mapfile, wx.BITMAP_TYPE_ANY)
+                self.imagedict[img] = { 'id' : overlay.id,
+                                        'layer' : overlay }
+                imgs.append(img)
+        return imgs
     def OnClose(self, event):
         # cleanup when window actually closes (on quit) and not just is hidden
         self.Reset()
@@ -196,6 +218,7 @@
         dc = wx.PaintDC(self)
         self.DoPaint()
+        self.DrawShapes(dc)
     def DoPaint(self):
         self.SetCurrent()
@@ -233,7 +256,24 @@
             self.init = True
         self.UpdateMap()
+    def UpdateOverlays(self):
+        if self.img is None:
+            self.Map.ChangeMapSize(self.GetClientSize())
+            self.Map.RenderOverlays(force = True)
+        else:
+            self.Map.RenderOverlays(force = False)
+        self.shapes = []
+        for img in self.GetOverlay():
+            # draw any active and defined overlays
+            if self.imagedict[img]['layer'].IsActive():
+                id = self.imagedict[img]['id']
+                coords = self.overlays[id]['coords']
+                bitmap = wx.BitmapFromImage(img)
+                self.shapes.append(DragShape(bitmap, id))
+                self.shapes[-1].pos = coords[:2]
+        self.Refresh(False)
     def OnMouseAction(self, event):
         """!Handle mouse events"""
         # zoom with mouse wheel
@@ -251,6 +291,10 @@
         # dragging
         elif event.Dragging():
             self.OnDragging(event)
+        # double click
+        elif event.ButtonDClick():
+            self.OnDClick(event)
         event.Skip()
@@ -297,7 +341,7 @@
                 self.iview['focus'][coord] = focus[i]
             toggle = self.lmgr.nviz.FindWindowByName('here')
             toggle.SetValue(False)
-            self.mouse['use'] = 'default'
+            self.mouse['use'] = 'pointer'
             self.SetCursor(self.cursors['default'])
         if self.mouse['use'] == "cplane":
@@ -321,7 +365,15 @@
                 self.decoration['arrow']['show'] = True
                 self.decoration['arrow']['position']['x'] = pos[0]
                 self.decoration['arrow']['position']['y'] = size[1] - pos[1]
-                self.DoPaint()
+        if self.mouse['use'] == 'pointer':
+            shape = self.FindShape(event.GetPosition())
+            if shape:
+                self.dragShape = shape
+                self.dragStartPos = event.GetPosition()
+                self.deleteOld = True
         event.Skip()
     def OnDragging(self, event):
@@ -333,6 +385,44 @@
             if x is not None:
                 self.cplanes[idx]['position']['x'] = x
                 self.cplanes[idx]['position']['y'] = y
+            if not self.dragShape:
+                event.Skip()
+                return
+            if self.dragShape and not self.dragImage:
+            # only start the drag after having moved a couple pixels
+                tolerance = 2
+                pt = event.GetPosition()
+                dx = abs(pt.x - self.dragStartPos.x)
+                dy = abs(pt.y - self.dragStartPos.y)
+                if dx <= tolerance and dy <= tolerance:
+                    return
+                elif self.deleteOld:
+                    # refresh the area of the window where the shape was so it
+                    # will get erased.
+                    # need to be redrawn now ?
+                    self.dragShape.shown = False
+                    self.RefreshRect(self.dragShape.GetRect(), False)
+                    self.Update()
+                    self.deleteOld = False
+                    return
+                else:
+                    if self.dragShape.text:
+                        self.dragImage = wx.DragString(self.dragShape.text,
+                                                      wx.StockCursor(wx.CURSOR_HAND))
+                    else:
+                        self.dragImage = wx.DragImage(self.dragShape.bmp,
+                    hotspot = self.dragStartPos - self.dragShape.pos
+                    self.dragImage.BeginDrag(hotspot, self)
+                    self.dragImage.Move(pt)
+                    self.dragImage.Show()
+            elif self.dragShape and self.dragImage:
+            # now move it and show it again if needed
+                self.dragImage.Move(event.GetPosition())
         event.Skip()
@@ -369,15 +459,40 @@
             idx = self._display.GetCPlaneCurrent()
             self.lmgr.nviz.UpdateCPlanePage(idx)
             self.lmgr.nviz.FindWindowByName('cplaneHere').SetValue(False)
         elif self.mouse["use"] == 'arrow':
             self.lmgr.nviz.FindWindowByName('placeArrow').SetValue(False)
+        elif self.mouse['use'] == 'pointer':
+            if not self.dragImage or not self.dragShape:
+                return
+            # Hide the image, end dragging, and nuke out the drag image.
+            self.dragImage.Hide()
+            self.dragImage.EndDrag()
+            # reposition and draw the shape
+            self.dragShape.pos = (
+                self.dragShape.pos[0] + event.GetPosition()[0] - self.dragStartPos[0],
+                self.dragShape.pos[1] + event.GetPosition()[1] - self.dragStartPos[1]
+            self.overlays[self.dragShape.id]['coords'] = tuple(self.dragShape.GetRect())
+            self.dragShape.shown = True
+            self.RefreshRect(self.dragShape.GetRect())
         event.Skip()
+    def OnDClick(self, event):
+        if shape.id == 1:
+                self.parent.OnAddLegend(None)
     def OnQuerySurface(self, event):
         """!Query surface on given position"""
         size = self.GetClientSizeTuple()
@@ -506,7 +621,18 @@
         self._display.EraseMap()
         self.SwapBuffers()
+    def DrawShapes(self, dc):
+        for shape in self.shapes:
+            if shape.shown:
+                shape.Draw(dc)
+    def FindShape(self, pt):
+            if shape.HitTest(pt):
+                return shape
+        return None
     def IsLoaded(self, item):
         """!Check if layer (item) is already loaded
@@ -1753,3 +1879,32 @@
         self.lmgr.nviz.OnResetView(None)
+class DragShape:
+    """!Class for drawing overlays (based on wxpython demo)"""
+    def __init__(self, bmp, id):
+        self.bmp = bmp
+        self.id = id
+        self.pos = (0,0)
+        self.shown = True
+        self.text = None
+    def HitTest(self, pt):
+        rect = self.GetRect()
+        return rect.InsideXY(pt.x, pt.y)
+    def GetRect(self):
+        return wx.Rect(self.pos[0], self.pos[1],
+                      self.bmp.GetWidth(), self.bmp.GetHeight())
+    def Draw(self, dc, op = wx.COPY):
+        if self.bmp.Ok():
+            memDC = wx.MemoryDC()
+            memDC.SelectObject(self.bmp)
+            dc.Blit(self.pos[0], self.pos[1],
+                    self.bmp.GetWidth(), self.bmp.GetHeight(),
+                    memDC, 0, 0, op, True)
+            return True
+        else:
+            return False
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -4323,6 +4323,7 @@
         win = self.FindWindowById(self.page[name]['notebook'])
         try:
             win.Expand(win.GetFoldPanel(self.page[name]['id']))
+            self.UpdateScrolling((win.GetFoldPanel(self.page[name]['id']).GetGrandParent(),))
         except AttributeError:
             win.SetSelection(self.page[name]['id'])
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -1322,6 +1322,12 @@
         """!Reverse list of layers"""
         return self.layers.reverse()
+    def RenderOverlays(self, force):
+        """!Render overlays only (for nviz)"""
+        for layer in self.overlays:
+            if force or layer.force_render:
+                layer.Render()
 if __name__ == "__main__":
     """!Test of Display class.
     Usage: display=Render()
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-07-21 09:41:48 UTC (rev 47193)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-07-21 09:56:22 UTC (rev 47194)
@@ -340,14 +340,12 @@
     def Enable2D(self, enabled):
         """!Enable/Disable 2D display mode specific tools"""
-        for tool in (self.pointer,
-                     self.pan,
+        for tool in (self.pan,
                      self.zoomin,
                      self.zoomout,
                      self.zoomback,
                      self.zoommenu,
                      self.analyze,
-                     self.dec,
                      self.printmap):
             self.EnableTool(tool, enabled)
