[GRASS-SVN] r47211 - in grass/branches/releasebranch_6_4: gui/wxpython/gui_modules lib/python
Thu Jul 21 14:53:22 EDT 2011
Author: martinl
Date: 2011-07-21 11:53:22 -0700 (Thu, 21 Jul 2011)
New Revision: 47211
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
   grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
   grass/branches/releasebranch_6_4/lib/python/task.py
wxGUI/modeler: start model with data item
	       (merge r47210 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py	2011-07-21 18:43:43 UTC (rev 47210)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py	2011-07-21 18:53:22 UTC (rev 47211)
@@ -48,13 +48,21 @@
 from preferences import globalSettings as UserSettings
 class ElementDialog(wx.Dialog):
-    """!General dialog to choose given element (location, mapset, vector map, etc.)"""
     def __init__(self, parent, title, label, id = wx.ID_ANY,
-                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+                 etype = False, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
                  **kwargs):
+        """!General dialog to choose given element (location, mapset, vector map, etc.)
+        @param parent window
+        @param title window title
+        @param label element label
+        @param etype show also ElementSelect
         wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
+        self.etype = etype
+        self.label = label
         self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
         self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
@@ -62,17 +70,26 @@
         self.btnOK.SetDefault()
         self.btnOK.Enable(False)
-        self.label = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
-                                   label = label)
+        if self.etype:
+            self.typeSelect = gselect.ElementSelect(parent = self.panel,
+                                                    size = globalvar.DIALOG_GSELECT_SIZE)
+            self.typeSelect.Bind(wx.EVT_CHOICE, self.OnType)
         self.element = None # must be defined
-        self.__Layout()
+        self.__layout()
     def PostInit(self):
         self.element.SetFocus()
         self.element.Bind(wx.EVT_TEXT, self.OnElement)
+    def OnType(self, event):
+        """!Select element type"""
+        if not self.etype:
+            return
+        evalue = self.typeSelect.GetValue(event.GetString())
+        self.element.SetType(evalue)
     def OnElement(self, event):
         """!Name for vector map layer given"""
         if len(event.GetString()) > 0:
@@ -80,14 +97,23 @@
         else:
-    def __Layout(self):
+    def __layout(self):
         """!Do layout"""
         self.sizer = wx.BoxSizer(wx.VERTICAL)
         self.dataSizer = wx.BoxSizer(wx.VERTICAL)
-        self.dataSizer.Add(self.label, proportion=0,
-                           flag=wx.ALL, border=1)
+        if self.etype:
+            self.dataSizer.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+                                                    label = _("Type of element:")),
+                               proportion=0, flag=wx.ALL, border=1)
+            self.dataSizer.Add(item = self.typeSelect,
+                                                label = self.label),
         # buttons
         btnSizer = wx.StdDialogButtonSizer()
         btnSizer.AddButton(self.btnCancel)
@@ -104,6 +130,10 @@
         """!Return (mapName, overwrite)"""
         return self.element.GetValue()
+    def GetType(self):
+        """!Get element type"""
+        return self.element.tcp.GetType()
 class LocationDialog(ElementDialog):
     """!Dialog used to select location"""
     def __init__(self, parent, title = _("Select GRASS location and mapset"), id =  wx.ID_ANY):
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py	2011-07-21 18:43:43 UTC (rev 47210)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gmodeler.py	2011-07-21 18:53:22 UTC (rev 47211)
@@ -32,7 +32,7 @@
  - ModelConditionDialog
  - WritePythonFile
-(C) 2010 by the GRASS Development Team
+(C) 2010-2011 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -134,7 +134,14 @@
             return len(self.GetItems(objType = ModelAction))
         return len(self.GetItems())
+    def GetNextId(self):
+        """!Get next id (data ignored)"""
+        currId = self.items[-1].GetId()
+        if currId > 0:
+            return currId + 1
+        return 1
     def GetProperties(self):
         """!Get model properties"""
         return self.properties
@@ -196,12 +203,18 @@
     def GetData(self):
         """!Get list of data items"""
         result = list()
+        dataItems = self.GetItems(objType = ModelData)
         for action in self.GetItems(objType = ModelAction):
             for rel in action.GetRelations():
                 dataItem = rel.GetData()
                 if dataItem not in result:
                     result.append(dataItem)
+                dataItems.remove(dataItem)
+        # standalone data
+        if dataItems:
+            result += dataItems
         return result
     def FindData(self, value, prompt):
@@ -356,7 +369,7 @@
         """!Add item to the list"""
         iId = newItem.GetId()
-        i   = 0
+        i  = 0
         for item in self.items:
             if item.GetId() > iId:
                 self.items.insert(i, newItem)
@@ -1179,7 +1192,7 @@
             return
         action = ModelAction(self.model, cmd = cmd, x = width/2, y = height/2,
-                             id = self.model.GetNumItems() + 1)
+                             id = self.model.GetNextId())
         overwrite = self.model.GetProperties().get('overwrite', None)
         if overwrite is not None:
             action.GetTask().set_flag('overwrite', overwrite)
@@ -1207,20 +1220,27 @@
     def OnAddData(self, event):
         """!Add data item to model
-        @todo
         # add action to canvas
         width, height = self.canvas.GetSize()
         data = ModelData(self, x = width/2, y = height/2)
         self.canvas.diagram.AddShape(data)
         data.Show(True)
+        self.ModelChanged()
         self._addEvent(data)
-        # self.model.AddData(data)
+        self.model.AddItem(data)
         self.canvas.Refresh()
+        # show data properties dialog
+        dlg = ModelDataDialog(parent = self, shape = data)
+        data.SetPropDialog(dlg)
+        dlg.CentreOnParent()
+        dlg.Show()
     def OnHelp(self, event):
         """!Display manual page"""
         grass.run_command('g.manual',
@@ -1242,22 +1262,22 @@
     def GetOptData(self, dcmd, layer, params, propwin):
         """!Process action data"""
         if params: # add data items
-            for p in params['params']:
-                if p.get('prompt', '') in ('raster', 'vector', 'raster3d'):
-                    try:
-                        name, mapset = p.get('value', '').split('@', 1)
-                    except (ValueError, IndexError):
-                        continue
+            # for p in params['params']:
+            #     if p.get('prompt', '') in ('raster', 'vector', 'raster3d'):
+            #         try:
+            #             name, mapset = p.get('value', '').split('@', 1)
+            #         except (ValueError, IndexError):
+            #             continue
-                    if mapset != grass.gisenv()['MAPSET']:
-                        continue
+            #         if mapset != grass.gisenv()['MAPSET']:
+            #             continue
-                    # don't use fully qualified names
-                    p['value'] = p.get('value', '').split('@')[0]
-                    for idx in range(1, len(dcmd)):
-                        if p.get('name', '') in dcmd[idx]:
-                            dcmd[idx] = p.get('name', '') + '=' + p.get('value', '')
-                            break
+            #         # don't use fully qualified names
+            #         p['value'] = p.get('value', '').split('@')[0]
+            #         for idx in range(1, len(dcmd)):
+            #             if p.get('name', '') in dcmd[idx]:
+            #                 dcmd[idx] = p.get('name', '') + '=' + p.get('value', '')
+            #                 break
             x = [width/2 + 200, width/2 - 200]
@@ -1740,7 +1760,8 @@
     def GetLog(self, string = True):
         """!Get logging info"""
-        cmd = self.task.getCmd(ignoreErrors = True)
+        cmd = self.task.getCmd(ignoreErrors = True, ignoreRequired = True)
         # substitute variables
         variables = self.parent.GetVariables()
         fparams = self.parent.GetVariables(params = True)
@@ -1910,7 +1931,7 @@
         if name:
             return '/'.join(name) + '=' + self.value + ' (' + self.prompt + ')'
         else:
-            return _('unknown')
+            return self.value + ' (' + self.prompt + ')'
     def GetName(self):
         """!Get list of names"""
@@ -1924,12 +1945,22 @@
         """!Get prompt"""
         return self.prompt
+    def SetPrompt(self, prompt):
+        """!Set prompt
+        @param prompt
+        self.prompt = prompt
     def GetValue(self):
         """!Get value"""
         return self.value
     def SetValue(self, value):
-        """!Set value"""
+        """!Set value
+        @param value
         self.value = value
         self._setText()
         for direction in ('from', 'to'):
@@ -2022,19 +2053,11 @@
                  style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
         self.parent = parent
         self.shape = shape
-        prompt = shape.GetPrompt()
-        if prompt == 'raster':
-            label = _('Name of raster map:')
-        elif prompt == 'vector':
-            label = _('Name of vector map:')
-        else:
-            label = _('Name of element:')
-        ElementDialog.__init__(self, parent, title, label = label)
-        self.element = gselect.Select(parent = self.panel, id = wx.ID_ANY,
-                                      size = globalvar.DIALOG_GSELECT_SIZE,
+        label, etype = self._getLabel()
+        ElementDialog.__init__(self, parent, title, label = label, etype = etype)
+        self.element = gselect.Select(parent = self.panel,
                                       type = prompt)
         self.element.SetValue(shape.GetValue())
@@ -2049,6 +2072,19 @@
         self._layout()
         self.SetMinSize(self.GetSize())
+    def _getLabel(self):
+        etype = False
+        prompt = self.shape.GetPrompt()
+        if prompt == 'raster':
+            label = _('Name of raster map:')
+        elif prompt == 'vector':
+            label = _('Name of vector map:')
+        else:
+            etype = True
+            label = _('Name of element:')
+        return label, etype
     def _layout(self):
         """!Do layout"""
         self.dataSizer.Add(self.element, proportion=0,
@@ -2060,6 +2096,13 @@
     def OnOK(self, event):
         """!Ok pressed"""
         self.shape.SetValue(self.GetElement())
+        if self.etype:
+            elem = self.GetType()
+            if elem == 'rast':
+                self.shape.SetPrompt('raster')
+            elif elem == 'vect':
         self.parent.canvas.Refresh()
         self.parent.SetStatusText('', 0)
         self.OnCancel(event)
@@ -4004,6 +4047,7 @@
     def Populate(self, data):
         """!Populate the list"""
         self.itemDataMap = dict()
         if self.shape:
             if isinstance(self.shape, ModelCondition):
                 if self.GetName() == 'ElseBlockList':
@@ -4018,6 +4062,9 @@
         if len(self.columns) == 3: # ItemCheckList
             checked = list()
         for action in data:
+            if isinstance(action, ModelData):
+                continue
                 self.itemDataMap[i] = [str(action.GetId()),
                                        action.GetName(),
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2011-07-21 18:43:43 UTC (rev 47210)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py	2011-07-21 18:53:22 UTC (rev 47211)
@@ -19,7 +19,8 @@
  - FormatSelect
  - GdalSelect
  - ProjSelect
+ - ElementSelect
 (C) 2007-2011 by the GRASS Development Team This program is free
 software under the GNU General Public License (>=v2). Read the file
@@ -42,6 +43,7 @@
 sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
 import grass.script as grass
+from   grass.script import task as gtask
 import gcmd
 import utils
@@ -98,6 +100,16 @@
         """!Load elements"""
         self.tcp.GetElementList()
+    def SetType(self, etype, multiple = False, mapsets = None,
+                updateOnPopup = True, onPopup = None):
+        """!Param set element type for widget
+        @param etype element type, see gselect.ElementSelect
+        self.tcp.SetData(type = etype, mapsets = mapsets,
+                         multiple = multiple,
+                         updateOnPopup = updateOnPopup, onPopup = onPopup)
 class VectorSelect(Select):
     def __init__(self, parent, ftype, **kwargs):
         """!Custom to create a ComboBox with a tree control to display and
@@ -511,7 +523,12 @@
             self.updateOnPopup = kargs['updateOnPopup']
         if 'onPopup' in kargs:
             self.onPopup = kargs['onPopup']
+        return self.type
 class VectorDBInfo:
     """!Class providing information about attribute tables
     linked to a vector map"""
@@ -1581,3 +1598,27 @@
         self.SetItems(listMaps)
         self.SetValue('')
+class ElementSelect(wx.Choice):
+    def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_COMBOBOX_SIZE,
+                 **kwargs):
+        """!Widget for selecting GIS element
+        @param parent parent window
+        super(ElementSelect, self).__init__(parent, id, size = size,
+                                            style = wx.CB_READONLY, **kwargs)
+        self.SetName("ElementSelect")
+        task = gtask.parse_interface('g.list')
+        p = task.get_param(value = 'type')
+        self.values = p.get('values', [])
+        self.SetItems(self.values)
+    def GetValue(self, name):
+        """!Translate value
+        @param name element name
+        return name
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2011-07-21 18:43:43 UTC (rev 47210)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/menuform.py	2011-07-21 18:53:22 UTC (rev 47211)
@@ -623,10 +623,10 @@
     def OnApply(self, event):
         """!Apply the command"""
         if self.modeler:
-            cmd = self.createCmd(ignoreErrors = True)
+            cmd = self.createCmd(ignoreErrors = True, ignoreRequired = True)
         else:
             cmd = self.createCmd()
         if cmd is not None and self.get_dcmd is not None:
             # return d.* command to layer tree for rendering
             self.get_dcmd(cmd, self.layer, {"params": self.task.params,
@@ -713,9 +713,10 @@
         if event:
             event.Skip()
-    def createCmd(self, ignoreErrors = False):
+    def createCmd(self, ignoreErrors = False, ignoreRequired = False):
         """!Create command string (python list)"""
-        return self.notebookpanel.createCmd(ignoreErrors = ignoreErrors)
+        return self.notebookpanel.createCmd(ignoreErrors = ignoreErrors,
+                                            ignoreRequired = ignoreRequired)
 class cmdPanel(wx.Panel):
     """!A panel containing a notebook dividing in tabs the different
@@ -1621,15 +1622,16 @@
                                             None,
                                             self.task)
         """!Produce a command line string (list) or feeding into GRASS.
-        If ignoreErrors == True then it will return whatever has been
+        @param ignoreErrors True then it will return whatever has been
         built so far, even though it would not be a correct command
-        for GRASS.
+        for GRASS
         try:
-            cmd = self.task.getCmd(ignoreErrors = ignoreErrors)
+            cmd = self.task.getCmd(ignoreErrors = ignoreErrors,
         except ValueError, err:
             dlg = wx.MessageDialog(parent = self,
                                    message = unicode(err),
@@ -1710,7 +1712,7 @@
         start = time.time()
         dcmd_params = {}
-        if completed ==  None:
+        if completed == None:
             get_dcmd = None
             layer = None
             dcmd_params = None
Modified: grass/branches/releasebranch_6_4/lib/python/task.py
--- grass/branches/releasebranch_6_4/lib/python/task.py	2011-07-21 18:43:43 UTC (rev 47210)
+++ grass/branches/releasebranch_6_4/lib/python/task.py	2011-07-21 18:53:22 UTC (rev 47211)
@@ -191,12 +191,14 @@
         return errorList
-    def getCmd(self, ignoreErrors = False):
+    def getCmd(self, ignoreErrors = False, ignoreRequired = False):
         """!Produce an array of command name and arguments for feeding
         into some execve-like command processor.
         @param ignoreErrors True to return whatever has been built so
         far, even though it would not be a correct command for GRASS
+        @param ignoreRequired True to ignore required flags, otherwise
+        '<required>' is shown
         cmd = [self.name]
@@ -213,7 +215,7 @@
             if p.get('value','') ==  '' and p.get('required', False):
                 if p.get('default', '') !=  '':
                     cmd +=  [ '%s=%s' % (p['name'], p['default']) ]
-                elif ignoreErrors is True and not suppress_required:
+                elif ignoreErrors and not suppress_required and not ignoreRequired:
                     cmd +=  [ '%s=%s' % (p['name'], _('<required>')) ]
             elif p.get('value','') !=  '' and p['value'] !=  p.get('default','') :
                 # Output only values that have been set, and different from defaults
