[GRASS-SVN] r47251 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jul 26 15:37:29 EDT 2011
Author: martinl
Date: 2011-07-26 12:37:29 -0700 (Tue, 26 Jul 2011)
New Revision: 47251
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/goutput.py
grass/trunk/gui/wxpython/gui_modules/layertree.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/utils.py
wxGUI: attempt to fix #1409
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2011-07-26 17:52:23 UTC (rev 47250)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2011-07-26 19:37:29 UTC (rev 47251)
@@ -620,9 +620,6 @@
else:
GError(parent = parent,
message = stderr)
- if ret != 0:
- return None
Debug.msg(3, "gcmd.RunCommand(): print read error")
if not read:
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-07-26 17:52:23 UTC (rev 47250)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py 2011-07-26 19:37:29 UTC (rev 47251)
@@ -471,7 +471,8 @@
# send GRASS command without arguments to GUI command interface
# except display commands (they are handled differently)
if self.parent.GetName() == "LayerManager" and \
- command[0][0:2] == "d.":
+ command[0][0:2] == "d." and \
+ (len(command) > 1 and 'help' not in ' '.join(command[1:])):
# display GRASS commands
try:
layertype = {'d.rast' : 'raster',
@@ -508,7 +509,7 @@
self.parent.curr_page.maptree.AddLayer(ltype = layertype,
lname = lname,
lcmd = command)
else:
# other GRASS commands (r|v|g|...)
# switch to 'Command output' if required
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-07-26 17:52:23 UTC (rev 47250)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py 2011-07-26 19:37:29 UTC (rev 47251)
@@ -845,7 +845,7 @@
render = False
name = None
if ctrl:
ctrlId = ctrl.GetId()
else:
@@ -1401,7 +1401,7 @@
if not lname:
dcmd = self.GetPyData(item)[0]['cmd']
lname, found = utils.GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
- fullyQualified = True)
+ fullyQualified = True)
if not found:
return None
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2011-07-26 17:52:23 UTC (rev 47250)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2011-07-26 19:37:29 UTC (rev 47251)
@@ -150,15 +150,14 @@
else:
ret, msg = gcmd.RunCommand(self.cmd[0],
getErrorMsg = True,
- # quiet = True,
- verbose = True,
+ quiet = True,
**self.cmd[1])
if ret != 0:
- raise gcmd.GException(value = _("%s failed") % self.cmd[0])
+ raise gcmd.GException(value = _("'%s' failed. Details: %s") % (self.cmd[0], msg))
except gcmd.GException, e:
- # sys.stderr.write(e.value)
+ print >> sys.stderr, e.value
# clean up after problems
for f in [self.mapfile, self.maskfile]:
if not f:
Modified: grass/trunk/gui/wxpython/gui_modules/utils.py
--- grass/trunk/gui/wxpython/gui_modules/utils.py 2011-07-26 17:52:23 UTC (rev 47250)
+++ grass/trunk/gui/wxpython/gui_modules/utils.py 2011-07-26 19:37:29 UTC (rev 47251)
@@ -24,6 +24,7 @@
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
from grass.script import core as grass
+from grass.script import task as gtask
import gcmd
from debug import Debug
@@ -75,6 +76,9 @@
layerType = None):
"""!Get map name from GRASS command
+ Parameter dcmd can be modified when first parameter is not
+ defined.
@param dcmd GRASS command (given as list)
@param fullyQualified change map name to be fully qualified
@param param params directory
@@ -116,7 +120,9 @@
if len(params) < 1:
if len(dcmd) > 1 and '=' not in dcmd[1]:
- params.append((1, None, dcmd[1]))
+ task = gtask.parse_interface(dcmd[0])
+ p = task.get_options()['params'][0].get('name', '')
+ params.append((1, p, dcmd[1]))
else:
return mapname, False
