[GRASS-SVN] r47258 - grass/branches/develbranch_6/locale/po
Wed Jul 27 07:52:34 EDT 2011
Author: neteler
Date: 2011-07-27 04:52:34 -0700 (Wed, 27 Jul 2011)
New Revision: 47258
   grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
Fred Maranh?\195?\163o: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2011-07-27 11:52:20 UTC (rev 47257)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_pt_br.po	2011-07-27 11:52:34 UTC (rev 47258)
@@ -13,7 +13,7 @@
 "Project-Id-Version: grasswxpy_pt_br\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2011-06-09 20:20+0200\n"
-"PO-Revision-Date: 2011-07-11 19:31-0300\n"
+"PO-Revision-Date: 2011-07-27 00:02-0300\n"
 "Last-Translator: \n"
 "Language-Team: Português do Brasil <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
@@ -1031,19 +1031,19 @@
 #: ../gui/wxpython/scripts/p.cmd.py:53 ../gui/wxpython/scripts/p.rast.py:99
 #: ../gui/wxpython/scripts/p.vect.py:356
 msgid "GRASS_PYCMDFILE - File not found. Run p.mon."
-msgstr ""
+msgstr "GRASS_PYCMDFILE - Arquivo não encontrado. Execute p.mon."
 #: ../gui/wxpython/scripts/vkrige.py:33
 msgid "No GRASS-python library found."
-msgstr ""
+msgstr "Não encontrei biblioteca GRASS-python."
 #: ../gui/wxpython/scripts/vkrige.py:65
 msgid "Input Data"
-msgstr ""
+msgstr "Dados de entrada"
 #: ../gui/wxpython/scripts/vkrige.py:71
 msgid "Point dataset:"
-msgstr ""
+msgstr "Dataset de pontos:"
 #: ../gui/wxpython/scripts/vkrige.py:83
 msgid "Numeric column:"
@@ -1051,7 +1051,7 @@
 #: ../gui/wxpython/scripts/vkrige.py:94
 msgid "Kriging"
-msgstr ""
+msgstr "Krigando"
 #: ../gui/wxpython/scripts/vkrige.py:108
 #: ../gui/wxpython/gui_modules/gmodeler.py:569
@@ -1090,19 +1090,20 @@
 #: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
-msgstr ""
+msgstr "Módulo de Krigagem"
 #: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
-msgstr ""
+msgstr "Pronto."
 #: ../gui/wxpython/scripts/vkrige.py:295
+#, fuzzy
 msgid "Variogram fitting"
-msgstr ""
+msgstr "Ajuste do variograma"
 #: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
-msgstr ""
+msgstr "Plotar/recarregar variograma"
 #: ../gui/wxpython/scripts/vkrige.py:316
 msgid ":"
@@ -1126,7 +1127,7 @@
 #: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
-msgstr ""
+msgstr "Em construção! Funcionalidade não fornecida."
 #: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:814
 msgid "&File"
@@ -1339,9 +1340,8 @@
 msgstr "Crea un mapa vectorial a partir de archivo de puntos ASCII o archivo ASCII vectorial."
 #: ../gui/wxpython/menustrings.py:59
-#, fuzzy
 msgid "ASCII points as a vector lines"
-msgstr "Gera pontos como pontos 3D"
+msgstr "Pontos ASCII como linhas de vetores"
 #: ../gui/wxpython/menustrings.py:60
 msgid "Import ASCII x,y[,z] coordinates as a series of lines."
@@ -1353,9 +1353,8 @@
 msgstr "Importação de vectores do antigo GRASS"
 #: ../gui/wxpython/menustrings.py:62
-#, fuzzy
 msgid "Imports older versions of GRASS vector maps."
-msgstr "Importa mapas vectoriales de versiones anteriores de GRASS."
+msgstr "Importa versões antigas de mapas vetoriais do GRASS."
 #: ../gui/wxpython/menustrings.py:63
 #, fuzzy
@@ -1363,23 +1362,20 @@
 #: ../gui/wxpython/menustrings.py:64
-#, fuzzy
 msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Importa todas as versões antigas de mapas vetoriais do GRASS no mapset atual para o formato atual."
 #: ../gui/wxpython/menustrings.py:65
-#, fuzzy
 msgid "DXF import"
 msgstr "Importação de DXF"
 #: ../gui/wxpython/menustrings.py:66
-#, fuzzy
 msgid "Converts files in DXF format to GRASS vector map format."
-msgstr "Convierte archivos en formato DXF a formato de mapa vectorial de GRASS."
+msgstr "Converte arquivos em formato DXF para o formato de mapa vetorial do GRASS."
 #: ../gui/wxpython/menustrings.py:67
 msgid "WFS"
-msgstr " coordinates as a series of lines"
+msgstr "WFS"
 #: ../gui/wxpython/menustrings.py:68
 #, fuzzy
@@ -1944,7 +1940,7 @@
 #: ../gui/wxpython/menustrings.py:191
 msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-msgstr ""
+msgstr "Um utilitário simples para converter medidas de distância e \"bearing\" para coordenadas e vice-versa."
 #: ../gui/wxpython/menustrings.py:193
 #, fuzzy
@@ -1968,7 +1964,7 @@
 #: ../gui/wxpython/menustrings.py:197
 msgid "Launches script file."
-msgstr ""
+msgstr "Lança arquivo de script."
 #: ../gui/wxpython/menustrings.py:198
 #, fuzzy
@@ -1977,7 +1973,7 @@
 #: ../gui/wxpython/menustrings.py:199
 msgid "Quit wxGUI session"
-msgstr ""
+msgstr "Sai de sessão wxGUI"
 #: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:831
 #, fuzzy
@@ -2081,10 +2077,9 @@
 #: ../gui/wxpython/menustrings.py:222
 msgid "Changes the default GRASS graphical user interface (GUI) setting."
-msgstr ""
+msgstr "Muda a configuração padrão de interface gráfica (GUI)."
 #: ../gui/wxpython/menustrings.py:223
-#, fuzzy
 msgid "Version"
 msgstr "Versão"
@@ -2124,7 +2119,7 @@
 #: ../gui/wxpython/menustrings.py:231
 msgid "Interactively reset the location's projection settings."
-msgstr ""
+msgstr "Zera interativamente as configurações de projeção da locação."
 #: ../gui/wxpython/menustrings.py:232
 #, fuzzy
@@ -2137,12 +2132,13 @@
 msgstr "Convierte coordenadas de una proyección a otra (interfaz cs2cs)."
 #: ../gui/wxpython/menustrings.py:234
+#, fuzzy
 msgid "Install extension from add-ons"
-msgstr ""
+msgstr "Instala extensão a partir de add-ons"
 #: ../gui/wxpython/menustrings.py:235
 msgid "Install new extension from GRASS AddOns SVN repository."
-msgstr ""
+msgstr "Instala nova extensão a partir do repositório SVN de AddOns do GRASS."
 #: ../gui/wxpython/menustrings.py:236
 #, fuzzy
@@ -2151,7 +2147,7 @@
 #: ../gui/wxpython/menustrings.py:237
 msgid "Tool to maintain GRASS extensions in local GRASS installation."
-msgstr ""
+msgstr "Ferramenta para manter extensões do GRASS em instalações locais do GRASS."
 #: ../gui/wxpython/menustrings.py:238 ../gui/wxpython/menustrings.py:832
 #, fuzzy
@@ -2180,7 +2176,7 @@
 #: ../gui/wxpython/menustrings.py:243
 msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr ""
+msgstr "Ferramenta interativa para desenhar e gravar feições vetoriais em um monitor gráfico usando um dispositivo de ponteiro (mouse) e gravar em um mapa raster."
 #: ../gui/wxpython/menustrings.py:244
 #, fuzzy
@@ -2209,7 +2205,7 @@
 #: ../gui/wxpython/menustrings.py:249
 msgid "Manages NULL-values of given raster map."
-msgstr ""
+msgstr "Gerencia valores NULOS de um dado mapa raster."
 #: ../gui/wxpython/menustrings.py:250
 #, fuzzy
@@ -2333,7 +2329,7 @@
 #: ../gui/wxpython/menustrings.py:274
 msgid "Set color rules based on stddev from a map's mean value."
-msgstr ""
+msgstr "configura regras de cores baseado em stddev de um valor médio de mapa."
 #: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:549
 #, fuzzy
@@ -2597,7 +2593,7 @@
 #: ../gui/wxpython/menustrings.py:326
 msgid "Slope and aspect"
-msgstr ""
+msgstr "Declividade e aspecto"
 #: ../gui/wxpython/menustrings.py:327
 #, fuzzy
@@ -2646,11 +2642,11 @@
 #: ../gui/wxpython/menustrings.py:336
 msgid "Horizon angle"
-msgstr ""
+msgstr "Ângulo do horizonte"
 #: ../gui/wxpython/menustrings.py:337
 msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
+msgstr "Cálculo do ângulo do horizonte de um modelo de elevação digital."
 #: ../gui/wxpython/menustrings.py:338
 #, fuzzy
@@ -2817,8 +2813,9 @@
 msgstr "Pontos de controlo sobre o terreno (GCP)"
 #: ../gui/wxpython/menustrings.py:371
+#, fuzzy
 msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr ""
+msgstr "Programa de cálculo numérico para fluxo de groundwater confinado e não-confinado, transiente em duas dimensões."
 #: ../gui/wxpython/menustrings.py:372
 #, fuzzy
@@ -2832,7 +2829,7 @@
 #: ../gui/wxpython/menustrings.py:374
 msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-msgstr ""
+msgstr "Ferramenta interativa para ajustar o framework de sampling e análise que irá ser usado pelos outros programas r.le."
 #: ../gui/wxpython/menustrings.py:375
 #, fuzzy
@@ -3245,7 +3242,7 @@
 #: ../gui/wxpython/menustrings.py:459
 msgid "IDW from raster points (alternate method for sparse points)"
-msgstr ""
+msgstr "IDW para pontos raster (método alternativo para pontos esparsos)"
 #: ../gui/wxpython/menustrings.py:460
 #, fuzzy
@@ -3284,11 +3281,11 @@
 #: ../gui/wxpython/menustrings.py:467
 msgid "Ordinary or block kriging"
-msgstr ""
+msgstr "Crigagem ordinária ou de bloco"
 #: ../gui/wxpython/menustrings.py:468
 msgid "Performs ordinary or block kriging."
-msgstr ""
+msgstr "Realiza crigagem ordinária ou de bloco."
 #: ../gui/wxpython/menustrings.py:469
 #, fuzzy
@@ -3337,11 +3334,11 @@
 #: ../gui/wxpython/menustrings.py:478
 msgid "Quantiles for large data sets"
-msgstr ""
+msgstr "Quantiles para grandes conjuntos de dados"
 #: ../gui/wxpython/menustrings.py:479
 msgid "Compute quantiles using two passes."
-msgstr ""
+msgstr "Calcula quantiles usando duas passagens"
 #: ../gui/wxpython/menustrings.py:480
 #, fuzzy
@@ -3492,7 +3489,7 @@
 #: ../gui/wxpython/menustrings.py:509
 msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
-msgstr ""
+msgstr "Edita um mapa vetorial, permite adição, remoção e modificação de feições vetoriais selecionadas."
 #: ../gui/wxpython/menustrings.py:510
 #, fuzzy
@@ -3526,7 +3523,7 @@
 #: ../gui/wxpython/menustrings.py:516
 msgid "Smooth or simplify"
-msgstr ""
+msgstr "Suaviza ou simplifica"
 #: ../gui/wxpython/menustrings.py:517
 #, fuzzy
@@ -3570,7 +3567,7 @@
 #: ../gui/wxpython/menustrings.py:525
 msgid "Split lines to shorter segments."
-msgstr ""
+msgstr "Divide linhas em segmentos menores."
 #: ../gui/wxpython/menustrings.py:526
 #, fuzzy
@@ -3669,11 +3666,11 @@
 #: ../gui/wxpython/menustrings.py:548
 msgid "Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
+msgstr "Ajusta regras de cores para feições num vetor usando uma coluna de atributos numéricos."
 #: ../gui/wxpython/menustrings.py:550
 msgid "Interactive management of vector color tables."
-msgstr ""
+msgstr "gestão interativa de tabelas de cores de vetores."
 #: ../gui/wxpython/menustrings.py:551
 #, fuzzy
@@ -3827,7 +3824,7 @@
 #: ../gui/wxpython/menustrings.py:581
 msgid "Allocate subnets for nearest centres (direction from centre)."
-msgstr ""
+msgstr "Alocar subredes para centros mais próximos (direção saindo do centro)."
 #: ../gui/wxpython/menustrings.py:582
 #, fuzzy
@@ -3835,8 +3832,9 @@
 msgstr "Dividir rede"
 #: ../gui/wxpython/menustrings.py:583
+#, fuzzy
 msgid "Splits net by cost isolines."
-msgstr ""
+msgstr "Splits net by cost isolines."
 #: ../gui/wxpython/menustrings.py:584
 #, fuzzy
@@ -3855,7 +3853,7 @@
 #: ../gui/wxpython/menustrings.py:587
 msgid "Computes shortest distance via the network between the given sets of features."
-msgstr ""
+msgstr "Calcula menor distância através da rede entre um dado conjunto de feições."
 #: ../gui/wxpython/menustrings.py:588
 #, fuzzy
@@ -3874,7 +3872,7 @@
 #: ../gui/wxpython/menustrings.py:591
 msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
+msgstr "Calcula o menor caminho entre cada par de vértices de uma rede."
 #: ../gui/wxpython/menustrings.py:592
 #, fuzzy
@@ -3888,19 +3886,19 @@
 #: ../gui/wxpython/menustrings.py:594
 msgid "Bridges and articulation points"
-msgstr ""
+msgstr "Pontos de articulação e pontes"
 #: ../gui/wxpython/menustrings.py:595
 msgid "Computes bridges and articulation points in the network."
-msgstr ""
+msgstr "Calcula pontos de articulação e pontes na rede."
 #: ../gui/wxpython/menustrings.py:596
 msgid "Maximum flow"
-msgstr ""
+msgstr "Fluxo máximo"
 #: ../gui/wxpython/menustrings.py:597
 msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
+msgstr "Calcula o fluxo máximo entre dois conjuntos de vértices na rede."
 #: ../gui/wxpython/menustrings.py:598
 #, fuzzy
@@ -3909,7 +3907,7 @@
 #: ../gui/wxpython/menustrings.py:599
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
+msgstr "Calcula conectividade de vértices entre dois conjuntos de vértices na rede."
 #: ../gui/wxpython/menustrings.py:600
 #, fuzzy
@@ -3918,7 +3916,7 @@
 #: ../gui/wxpython/menustrings.py:601
 msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
+msgstr "Calcula componentes fortemente e fracamente conectados na rede."
 #: ../gui/wxpython/menustrings.py:602
 #, fuzzy
@@ -3926,8 +3924,9 @@
 msgstr "Teste de normalidade"
 #: ../gui/wxpython/menustrings.py:603
+#, fuzzy
 msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr ""
+msgstr "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 #: ../gui/wxpython/menustrings.py:604
 #, fuzzy
@@ -3936,15 +3935,15 @@
 #: ../gui/wxpython/menustrings.py:605
 msgid "Create Steiner tree for the network and given terminals"
-msgstr ""
+msgstr "Cria uma árvore de Steiner para a rede e terminais dados"
 #: ../gui/wxpython/menustrings.py:606
 msgid "Minimum spanning tree"
-msgstr ""
+msgstr "Árvore de recobrimento mínima"
 #: ../gui/wxpython/menustrings.py:607
 msgid "Computes minimum spanning tree for the network."
-msgstr ""
+msgstr "Cálcula a árvore de recobrimento mínima para a rede."
 #: ../gui/wxpython/menustrings.py:608
 #, fuzzy
@@ -3953,7 +3952,7 @@
 #: ../gui/wxpython/menustrings.py:609
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
+msgstr "Cria um ciclo conectando vértices dados (Problema do caixeiro-viajante)."
 #: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:611
 #, fuzzy
@@ -4017,7 +4016,7 @@
 #: ../gui/wxpython/menustrings.py:624
 msgid "Produces a convex hull for a given vector map."
-msgstr ""
+msgstr "Produz uma envoltória convexa para um dado mapa vetorial."
 #: ../gui/wxpython/menustrings.py:625
 #, fuzzy
@@ -4180,8 +4179,9 @@
 msgstr "Mostrar dados de atributos"
 #: ../gui/wxpython/menustrings.py:657
+#, fuzzy
 msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
+msgstr "Classifica dados de atributos, e.g. para \"mapping\" temático"
 #: ../gui/wxpython/menustrings.py:658
 #, fuzzy
@@ -4306,12 +4306,13 @@
 msgstr "HIS para RGB"
 #: ../gui/wxpython/menustrings.py:682
+#, fuzzy
 msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr ""
+msgstr "Transforma mapas raster do espaço de cores HIS (Hue-Intensity-Saturation) para o espaço de cores RGB (Red-Green-Blue -- Vermelho-Verde-Azul)."
 #: ../gui/wxpython/menustrings.py:684
 msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr ""
+msgstr "Transforma mapas raster do espaço de cores RGB (Red-Green-Blue -- Vermelho-Verde-Azul) para o espaço de cores HIS (Hue-Intensity-Saturation)."
 #: ../gui/wxpython/menustrings.py:685
 #, fuzzy
@@ -4325,11 +4326,11 @@
 #: ../gui/wxpython/menustrings.py:687
 msgid "Ortho photo rectification (requires Xterm)"
-msgstr ""
+msgstr "Orto foto retificação (requer Xterm)"
 #: ../gui/wxpython/menustrings.py:688
 msgid "Menu driver for the photo imagery programs."
-msgstr ""
+msgstr "Driver de menu para os programas de imageria de fotos."
 #: ../gui/wxpython/menustrings.py:689
 msgid "Brovey sharpening"
@@ -4348,11 +4349,11 @@
 #: ../gui/wxpython/menustrings.py:692
 #, fuzzy
 msgid "Clustering input for unsupervised classification"
-msgstr "Clustering de input para classificação não-supervisada"
+msgstr "Entrada de clustering para classificação não-supervisionada"
 #: ../gui/wxpython/menustrings.py:693
 msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-msgstr ""
+msgstr "Gera assinaturas espectrais para tipos de cobertura de terrenos numa imagem usando um algoritmo de clustering."
 #: ../gui/wxpython/menustrings.py:694
 #, fuzzy
@@ -4361,7 +4362,7 @@
 #: ../gui/wxpython/menustrings.py:695
 msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
+msgstr "Classifica as reflectâncias espectrais de células em dados de imageria."
 #: ../gui/wxpython/menustrings.py:696
 #, fuzzy
@@ -4380,7 +4381,7 @@
 #: ../gui/wxpython/menustrings.py:699
 msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-msgstr ""
+msgstr "Gera assinaturas espectrais para uma imagem ao permitir que o usuário esboce uma região de Interesse."
 #: ../gui/wxpython/menustrings.py:700
 #, fuzzy
@@ -4604,7 +4605,7 @@
 #: ../gui/wxpython/menustrings.py:746
 msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
-msgstr ""
+msgstr "Programa de cálculo numérico para fluxo de água subterrânea confinada, transiente, em três dimensões"
 #: ../gui/wxpython/menustrings.py:747
 #, fuzzy
@@ -4733,12 +4734,11 @@
 #: ../gui/wxpython/menustrings.py:772
 msgid "Drops an attribute table."
-msgstr ""
+msgstr "Apaga uma tabela de atributos."
 #: ../gui/wxpython/menustrings.py:773
-#, fuzzy
 msgid "Copy table"
-msgstr "Copiar tabla"
+msgstr "Copiar tabela"
 #: ../gui/wxpython/menustrings.py:774
 #, fuzzy
@@ -4954,11 +4954,11 @@
 #: ../gui/wxpython/menustrings.py:829
 msgid "Quit modeler"
-msgstr ""
+msgstr "Sair do modelador"
 #: ../gui/wxpython/menustrings.py:830
 msgid "Close modeler window"
-msgstr ""
+msgstr "Fechar janela do modelador"
 #: ../gui/wxpython/menustrings.py:833
 #: ../gui/wxpython/gui_modules/gmodeler.py:3003
@@ -4978,7 +4978,7 @@
 #: ../gui/wxpython/menustrings.py:837
 msgid "Add data"
-msgstr ""
+msgstr "Adicionar dados"
 #: ../gui/wxpython/menustrings.py:839
 #, fuzzy
@@ -4992,7 +4992,7 @@
 #: ../gui/wxpython/menustrings.py:842
 msgid "Adds loop (for) to model"
-msgstr ""
+msgstr "Adicionar loop (for) ao modelo"
 #: ../gui/wxpython/menustrings.py:843
 #, fuzzy
@@ -5001,7 +5001,7 @@
 #: ../gui/wxpython/menustrings.py:844
 msgid "Adds condition (if/else) to model"
-msgstr ""
+msgstr "Adiciona condicional (se/então) ao modelo"
 #: ../gui/wxpython/menustrings.py:845
 #, fuzzy
@@ -5010,7 +5010,7 @@
 #: ../gui/wxpython/menustrings.py:846
 msgid "Remove action/data from model"
-msgstr ""
+msgstr "Remove ação/dado do modelo"
 #: ../gui/wxpython/menustrings.py:847
 #: ../gui/wxpython/gui_modules/gmodeler.py:3288
@@ -5020,7 +5020,7 @@
 #: ../gui/wxpython/menustrings.py:848
 msgid "Model properties (name, purpose, etc.)"
-msgstr ""
+msgstr "Propriedades do modelo (nome, objetivo, etc.)"
 #: ../gui/wxpython/menustrings.py:849
 #, fuzzy
@@ -5029,15 +5029,15 @@
 #: ../gui/wxpython/menustrings.py:850
 msgid "Delete intermediate data defined in the model"
-msgstr ""
+msgstr "Apaga dados intermediários definidos no modelo"
 #: ../gui/wxpython/menustrings.py:852
 msgid "Run entire model"
-msgstr ""
+msgstr "Rodar o modelo inteiro"
 #: ../gui/wxpython/menustrings.py:854
 msgid "Validate entire model"
-msgstr ""
+msgstr "Validar o modelo inteiro"
 #: ../gui/wxpython/menustrings.py:856
 #, fuzzy
@@ -5051,7 +5051,7 @@
 #: ../gui/wxpython/menustrings.py:858
 msgid "About Graphical Modeler"
-msgstr ""
+msgstr "Sobre o Modelador Gráfico"
 #: ../gui/wxpython/menustrings.py:859
 #, fuzzy
@@ -5155,7 +5155,7 @@
 #: ../gui/wxpython/gui_modules/colorrules.py:669
 #, python-format
 msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
+msgstr "Valor de regra '%s' inválido. Não posso aplicar tabela de cores."
 #: ../gui/wxpython/gui_modules/colorrules.py:701
 #, fuzzy
@@ -5182,14 +5182,14 @@
 #: ../gui/wxpython/gui_modules/histogram.py:357
 msgid "Select font for histogram text"
-msgstr ""
+msgstr "Selecionar fonte para o texto do histograma"
 #: ../gui/wxpython/gui_modules/histogram.py:403
 #: ../gui/wxpython/gui_modules/mapdisp.py:1140
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
 #: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
+msgstr "Escolha um nome de arquivo para salvar a imagem (não é necessário adicionar extensão)"
 #: ../gui/wxpython/gui_modules/histogram.py:436
 #: ../gui/wxpython/gui_modules/mapdisp.py:1173
@@ -5230,7 +5230,7 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:130
 msgid "Cl&ear"
-msgstr ""
+msgstr "&Limpar"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:136
 #, fuzzy
@@ -5240,7 +5240,7 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
 #, fuzzy
 msgid "&Load"
-msgstr "Cargar"
+msgstr "Carregar"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:139
 #, fuzzy
@@ -5261,13 +5261,12 @@
 msgstr "Adicionar"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:149
-#, fuzzy
 msgid "subtract"
-msgstr "Superfície"
+msgstr "Subtrair"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:151
 msgid "modulus"
-msgstr ""
+msgstr "módulo"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:153
 #, fuzzy
@@ -5276,11 +5275,11 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:158
 msgid "left shift"
-msgstr ""
+msgstr "shift da esquerda"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:160
 msgid "right shift"
-msgstr ""
+msgstr "shift da direita"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:162
 msgid "right shift (unsigned)"
@@ -5303,15 +5302,15 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:170
 msgid "less than or equal to"
-msgstr ""
+msgstr "menor ou igual a"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:172
 msgid "equal to"
-msgstr ""
+msgstr "igual a"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:174
 msgid "not equal to"
-msgstr ""
+msgstr "diferente"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:177
 #, fuzzy
@@ -5320,31 +5319,31 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:179
 msgid "NOT"
-msgstr ""
+msgstr "NÃO"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:181
 msgid "bitwise AND"
-msgstr ""
+msgstr "E bit-a-bit"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:183
 msgid "bitwise OR"
-msgstr ""
+msgstr "OU bit-a-bit"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:185
 msgid "logical AND"
-msgstr ""
+msgstr "E lógico"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:187
 msgid "logical AND (ignores NULLs)"
-msgstr ""
+msgstr "E lógico (ignora NULOS)"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:189
 msgid "logical OR"
-msgstr ""
+msgstr "OU lógico"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:191
 msgid "logical OR (ignores NULLs)"
-msgstr ""
+msgstr "OU lógico (ignora NULOS)"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:193
 #, fuzzy
@@ -5415,21 +5414,21 @@
 #: ../gui/wxpython/gui_modules/gpyshell.py:36
 #, python-format
 msgid "Welcome to wxGUI Interactive Python Shell %s"
-msgstr ""
+msgstr "Bem vindo ao shell Python Interativo do wxGUI %s"
 #: ../gui/wxpython/gui_modules/gpyshell.py:37
 #, python-format
 msgid "Type %s for more GRASS scripting related information."
-msgstr ""
+msgstr "Digite %s para mais informações relacionadas a scripts GRASS."
 #: ../gui/wxpython/gui_modules/gpyshell.py:38
 #, python-format
 msgid "Type %s to add raster or vector to the layer tree."
-msgstr ""
+msgstr "Digite %s para adicionar vetores ou rasters à árvore de camadas"
 #: ../gui/wxpython/gui_modules/gpyshell.py:47
 msgid "Delete all text from the shell"
-msgstr ""
+msgstr "Apague todo o texto do shell"
 #: ../gui/wxpython/gui_modules/gpyshell.py:97
 #, fuzzy, python-format
@@ -5676,12 +5675,12 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
 #: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
-msgstr ""
+msgstr "fonte"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
-msgstr ""
+msgstr "destino"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1114
 #, fuzzy
