[GRASS-SVN] r47295 - grass-addons/grass7/gui/wxpython/wx.wms
Thu Jul 28 08:33:34 EDT 2011
Author: sudeepsingh
Date: 2011-07-28 05:33:34 -0700 (Thu, 28 Jul 2011)
New Revision: 47295
   grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
   grass-addons/grass7/gui/wxpython/wx.wms/bgenerateDOM.py
error checking in updating server info data added
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
--- grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-07-28 12:22:53 UTC (rev 47294)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-07-28 12:33:34 UTC (rev 47295)
@@ -1,35 +1,50 @@
 from BeautifulSoup import BeautifulSoup, Tag, BeautifulStoneSoup
 def addServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue):
+    elements = soup.findAll(id = snamevalue)
+    if(len(elements)!=0):
+        return False
+    else:
+        server = Tag(soup, "server")
+        serverinfo.insert(0,server)
+        #Creating server info tags
+        servername = Tag(soup, "servername")
+        serverurl = Tag(soup, "serverurl")
+        username = Tag(soup, "username")
+        password = Tag(soup, "password")
+        #Inserting server info fields
+        server.insert(0, servername)
+        server.insert(1, serverurl)
+        server.insert(2, username)
+        server.insert(3, password)
-    server = Tag(soup, "server")
-    serverinfo.insert(0,server)
+        #Adding attribute to server tag
+        server['id'] = snamevalue
-    #Creating server info tags
-    servername = Tag(soup, "servername")
-    serverurl = Tag(soup, "serverurl")
-    username = Tag(soup, "username")
-    password = Tag(soup, "password")
-    #Inserting server info fields
-    server.insert(0, servername)
-    server.insert(1, serverurl)
-    server.insert(2, username)
-    server.insert(3, password)
+        #Adding text values to the server info fields
+        servername.insert(0,snamevalue)
+        serverurl.insert(0, urlvalue)
+        username.insert(0, unamevalue)
+        password.insert(0, passwordvalue)
+        return True
-    #Adding attribute to server tag
-    server['id'] = snamevalue
-    #Adding text values to the server info fields
-    servername.insert(0,snamevalue)
-    serverurl.insert(0, urlvalue)
-    username.insert(0, unamevalue)
-    password.insert(0, passwordvalue)
-def removerServerInfo(soup, serverID):
+def removeServerInfo(soup, serverID):
     elements = soup.findAll(id = serverID)
-    for element in elements:
-        element.extract()
+    if(len(elements)==0):
+        return False
+    else:
+        for element in elements:
+            element.extract()
+        return True
\ No newline at end of file
+def updateServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue):
+    if(removeServerInfo(soup, snamevalue)):
+        print "1"
+        if(addServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue)):
+            return True
+        else:
+            return False
+    else:
+        return False
Modified: grass-addons/grass7/gui/wxpython/wx.wms/bgenerateDOM.py
--- grass-addons/grass7/gui/wxpython/wx.wms/bgenerateDOM.py	2011-07-28 12:22:53 UTC (rev 47294)
+++ grass-addons/grass7/gui/wxpython/wx.wms/bgenerateDOM.py	2011-07-28 12:33:34 UTC (rev 47295)
@@ -1,5 +1,5 @@
 from BeautifulSoup import BeautifulSoup, Tag, NavigableString, BeautifulStoneSoup
-from ServerInfoAPIs import addServerInfo, removerServerInfo
+from ServerInfoAPIs import addServerInfo, removeServerInfo, updateServerInfo
 try:
     f = open('out.xml','r+')
@@ -10,14 +10,20 @@
 except:
     f = open('out.xml','w')
     serverinfolist = []
+    soup = BeautifulSoup()
 if(len(serverinfolist) == 0):
         serverinfo = Tag(soup, "serverinfo")
         soup.insert(0, serverinfo)
-addServerInfo(soup, soup.serverinfo, 'a1', 'b1', 'c1', 'd1')
-addServerInfo(soup, soup.serverinfo, 'a2', 'b2', 'c2', 'd2')
-removerServerInfo(soup, "a2")
+print addServerInfo(soup, soup.serverinfo, 'a1', 'b1', 'c1', 'd1')
+print addServerInfo(soup, soup.serverinfo, 'a2', 'b2', 'c2', 'd2')
+print updateServerInfo(soup, soup.serverinfo, 'a1', 'b112', 'c112', 'd112')
+print removeServerInfo(soup, "a2")
 xml = soup.prettify()
 f.write(xml)
 f.close()
