[GRASS-SVN] r47318 - grass-addons/grass7/gui/wxpython/wx.wms
Sat Jul 30 10:36:34 EDT 2011
Author: sudeepsingh
Date: 2011-07-30 07:36:34 -0700 (Sat, 30 Jul 2011)
New Revision: 47318
Added:
   grass-addons/grass7/gui/wxpython/wx.wms/AddServer.wxg
   grass-addons/grass7/gui/wxpython/wx.wms/WMSMenu.wxg
wxGlade gui files to manage the interfaces
Added: grass-addons/grass7/gui/wxpython/wx.wms/AddServer.wxg
--- grass-addons/grass7/gui/wxpython/wx.wms/AddServer.wxg	                        (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.wms/AddServer.wxg	2011-07-30 14:36:34 UTC (rev 47318)
@@ -0,0 +1,221 @@
+<?xml version="1.0"?>
+<!-- generated by wxGlade 0.6.3 on Sat Jul 30 20:04:23 2011 -->
+<application path="/home/sudeep/gsoc/code/src/playground/addserver.py" name="" class="" option="0" language="python" top_window="frame_2" encoding="UTF-8" use_gettext="0" overwrite="0" use_new_namespace="1" for_version="2.8" is_template="0">
+    <object class="ServerAdd" name="frame_2" base="EditFrame">
+        <style>wxDEFAULT_FRAME_STYLE</style>
+        <title>AddServer</title>
+        <statusbar>1</statusbar>
+        <size>422, 250</size>
+        <object class="wxStatusBar" name="StatusBar" base="EditStatusBar">
+            <fields>
+                <field width="-1">StatusBar</field>
+            </fields>
+        </object>
+        <object class="wxBoxSizer" name="sizer_1" base="EditBoxSizer">
+            <orient>wxVERTICAL</orient>
+            <object class="sizeritem">
+                <flag>wxEXPAND</flag>
+                <border>0</border>
+                <option>0</option>
+                <object class="wxBoxSizer" name="sizer_2" base="EditBoxSizer">
+                    <orient>wxHORIZONTAL</orient>
+                        <object class="wxStaticText" name="Servers" base="EditStaticText">
+                            <attribute>1</attribute>
+                            <label>  Servers</label>
+                            <size>90, 17</size>
+                        </object>
+                    </object>
+                        <object class="wxComboBox" name="ServerList" base="EditComboBox">
+                            <selection>-1</selection>
+                            <choices>
+                            </choices>
+                            <events>
+                                <handler event="EVT_COMBOBOX">OnServerList</handler>
+                            </events>
+                            <size>189, 29</size>
+                        </object>
+                    </object>
+                </object>
+            </object>
+                <object class="wxStaticLine" name="static_line_1" base="EditStaticLine">
+                    <style>wxLI_HORIZONTAL</style>
+                </object>
+            </object>
+                <option>1</option>
+                <object class="wxBoxSizer" name="sizer_3" base="EditBoxSizer">
+                        <object class="wxStaticText" name="ServerName" base="EditStaticText">
+                            <label>  ServerName*</label>
+                            <size>96, 20</size>
+                        </object>
+                    </object>
+                        <object class="wxTextCtrl" name="ServerNameText" base="EditTextCtrl">
+                            <size>189, 25</size>
+                        </object>
+                    </object>
+                </object>
+            </object>
+                <object class="wxBoxSizer" name="sizer_4" base="EditBoxSizer">
+                        <object class="wxStaticText" name="URL" base="EditStaticText">
+                            <label>  URL*</label>
+                            <size>90, 20</size>
+                        </object>
+                    </object>
+                        <object class="wxTextCtrl" name="URLText" base="EditTextCtrl">
+                        </object>
+                    </object>
+                </object>
+            </object>
+                <object class="wxBoxSizer" name="sizer_5" base="EditBoxSizer">
+                        <object class="wxStaticText" name="Username" base="EditStaticText">
+                            <label>  Username*</label>
+                        </object>
+                    </object>
+                        <object class="wxTextCtrl" name="UsernameText" base="EditTextCtrl">
+                        </object>
+                    </object>
+                </object>
+            </object>
+                <object class="wxBoxSizer" name="sizer_6" base="EditBoxSizer">
+                        <object class="wxStaticText" name="Password" base="EditStaticText">
+                            <label>  Password</label>
+                        </object>
+                    </object>
+                        <object class="wxTextCtrl" name="PasswordText" base="EditTextCtrl">
+                            <style>wxTE_PASSWORD</style>
+                        </object>
+                    </object>
+                </object>
+            </object>
+                <object class="wxStaticText" name="PasswordExplain" base="EditStaticText">
+                    <label>  Note: Password will be stored as a plain text</label>
+                    <size>303, 20</size>
+                </object>
+            </object>
+                <object class="wxStaticLine" name="static_line_2" base="EditStaticLine">
+                </object>
+            </object>
+                <object class="wxBoxSizer" name="sizer_7" base="EditBoxSizer">
+                        <object class="wxButton" name="Save" base="EditButton">
+                            <label>Save</label>
+                            <events>
+                                <handler event="EVT_BUTTON">OnSave</handler>
+                            </events>
+                        </object>
+                    </object>
+                        <object class="wxButton" name="Remove" base="EditButton">
+                            <label>Remove</label>
+                            <events>
+                                <handler event="EVT_BUTTON">OnRemove</handler>
+                            </events>
+                        </object>
+                    </object>
+                        <object class="wxButton" name="AddNew" base="EditButton">
+                            <label>AddNew</label>
+                            <events>
+                                <handler event="EVT_BUTTON">OnAddNew</handler>
+                            </events>
+                        </object>
+                    </object>
+                        <border>6</border>
+                        <object class="wxButton" name="Quit" base="EditButton">
+                            <label>Quit</label>
+                            <events>
+                                <handler event="EVT_BUTTON">OnQuit</handler>
+                            </events>
+                        </object>
+                    </object>
+                </object>
+            </object>
+        </object>
+    </object>
+</application>
Added: grass-addons/grass7/gui/wxpython/wx.wms/WMSMenu.wxg
--- grass-addons/grass7/gui/wxpython/wx.wms/WMSMenu.wxg	                        (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.wms/WMSMenu.wxg	2011-07-30 14:36:34 UTC (rev 47318)
@@ -0,0 +1,100 @@
+<!-- generated by wxGlade 0.6.3 on Sat Jul 30 20:02:11 2011 -->
+<application path="/home/sudeep/gsoc/code/src/playground/wmsmenu.py" name="" class="" option="0" language="python" top_window="wms_Frame" encoding="UTF-8" use_gettext="0" overwrite="0" use_new_namespace="1" for_version="2.6" is_template="0">
+    <object class="wmsFrame" name="wms_Frame" base="EditFrame">
+        <title>wmsFrame</title>
+                <flag>wxALL|wxEXPAND|wxALIGN_RIGHT|wxALIGN_BOTTOM|wxALIGN_CENTER_HORIZONTAL|wxALIGN_CENTER_VERTICAL|wxSHAPED</flag>
+                                    <label>URL</label>
+                                </object>
+                            </object>
+                                    <style>wxCB_SIMPLE</style>
+                                    <choices>
+                                    </choices>
+                                    <events>
+                                        <handler event="EVT_TEXT_ENTER">OnServerListEnter</handler>
+                                    </events>
+                                </object>
+                            </object>
+                        </object>
+                    </object>
+                        <object class="wxTreeCtrl" name="LayerTree" base="EditTreeCtrl">
+                            <style>wxTR_HAS_BUTTONS|wxTR_NO_LINES|wxTR_MULTIPLE|wxTR_MULTIPLE|wxTR_DEFAULT_STYLE|wxSUNKEN_BORDER</style>
+                            <events>
+                                <handler event="EVT_TREE_ITEM_ACTIVATED">OnLayerTreeActivated</handler>
+                                <handler event="EVT_TREE_SEL_CHANGED">OnLayerTreeSelChanged</handler>
+                            </events>
+                            <size>400, 250</size>
+                        </object>
+                    </object>
+                        <flag>wxALIGN_CENTER_HORIZONTAL</flag>
+                                <object class="wxButton" name="GetCapabilities" base="EditButton">
+                                    <label>GetCapabilities</label>
+                                    <events>
+                                        <handler event="EVT_BUTTON">OnGetCapabilities</handler>
+                                    </events>
+                                </object>
+                            </object>
+                                <object class="wxButton" name="GetMaps" base="EditButton">
+                                    <label>GetMaps</label>
+                                    <events>
+                                        <handler event="EVT_BUTTON">OnGetMaps</handler>
+                                    </events>
+                                </object>
+                            </object>
+                                <object class="wxButton" name="addServer" base="EditButton">
+                                    <label>AddServer</label>
+                                    <events>
+                                        <handler event="EVT_BUTTON">OnAddServer</handler>
+                                    </events>
+                                </object>
+                            </object>
+                        </object>
+                    </object>
+                </object>
+            </object>
+        </object>
+    </object>
+</application>
