[GRASS-SVN] r46526 - grass/trunk/vector/v.in.lidar
Fri Jun 3 02:33:01 EDT 2011
Author: mmetz
Date: 2011-06-02 23:33:01 -0700 (Thu, 02 Jun 2011)
New Revision: 46526
   grass/trunk/vector/v.in.lidar/v.in.lidar.html
update manual
Modified: grass/trunk/vector/v.in.lidar/v.in.lidar.html
--- grass/trunk/vector/v.in.lidar/v.in.lidar.html	2011-06-03 06:29:27 UTC (rev 46525)
+++ grass/trunk/vector/v.in.lidar/v.in.lidar.html	2011-06-03 06:33:01 UTC (rev 46526)
@@ -2,12 +2,15 @@
 <em>v.in.lidar</em> converts LiDAR point clouds in LAS format to a GRASS
 vector, using the <a href="http://www.liblas.org">libLAS</a> library.
-The typical file extensions for the LAS format are .las and .laz (compressed).
 The created vector is true 3D with x, y, z coordinates.
+<p>
+The typical file extensions for the LAS format are .las and .laz (compressed).
+The compressed LAS format can be imported only if libLAS has been compiled
+with laszip support. It is also recommended to compile libLAS with GDAL,
+needed to text for matching projections.
 <P>
 For larger datasets, it is recommended to not build topology (-b flag).
 Also, creating a table with attributes can take some time for larger datasets.
-<P>
 <P>
 The optional <b>spatial</b> parameter defines spatial query extents.
