[GRASS-SVN] r46528 - grass/branches/releasebranch_6_4/imagery/i.atcorr
Fri Jun 3 02:51:30 EDT 2011
Author: mmetz
Date: 2011-06-02 23:51:30 -0700 (Thu, 02 Jun 2011)
New Revision: 46528
Added:
   grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.cpp
   grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.h
   grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp
   grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.cpp
   grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.h
   grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
   grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
backport i.atcorr
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp	2011-06-03 06:46:11 UTC (rev 46527)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/6s.cpp	2011-06-03 06:51:30 UTC (rev 46528)
@@ -90,10 +90,13 @@
 	c directional reflectances                                             c
 	c**********************************************************************/
+    /* NOTE: wlmoy is not affected by a height and/or vis change */
     float wlmoy;
     if(iwave.iwave != -1) wlmoy = iwave.equivwl();
     else wlmoy = iwave.wl;
+    iwave.wlmoy = wlmoy;
     discom(geom, atms, aero, aerocon, alt, iwave);
     float tamoy, tamoyp, pizmoy, pizmoyp;
     if(aero.iaer != 0) specinterp(wlmoy, tamoy, tamoyp, pizmoy, pizmoyp, aerocon, alt);
@@ -112,9 +115,7 @@
     alt.set_height(height);
     alt.init(atms, aerocon);
-    float wlmoy;
-    if(iwave.iwave != -1) wlmoy = iwave.equivwl();
-    else wlmoy = iwave.wl;
+    float wlmoy = iwave.wlmoy;
@@ -128,9 +129,7 @@
     aerocon.set_visibility(vis, atms);
-    float wlmoy;
@@ -144,9 +143,7 @@
-    float wlmoy;
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.cpp	2011-06-03 06:46:11 UTC (rev 46527)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.cpp	2011-06-03 06:51:30 UTC (rev 46528)
@@ -211,7 +211,7 @@
 	palt = 0;
 	pps = atms.p[0];
 	idatmp = 0;
-	taer55p = 0;
+	original_taer55p = taer55p = 0;
 	puw = 0;
     else if(xpp >= 100)
@@ -219,7 +219,7 @@
 	/* satellite case of equivalent */
 	palt = 1000;
 	pps = 0;
-	taer55p = aerocon.taer55;
+	original_taer55p = taer55p = aerocon.taer55;
 	puw = 0;
 	ftray = 1;
 	idatmp = 4;
@@ -227,9 +227,12 @@
     else
 	/* "real" plane case */
-	cin >> puw;
-	cin >> puo3;
-	cin.ignore(numeric_limits<int>::max(),'\n');	/* ignore comments */
+	cin >> original_puw;
+	cin >> original_puo3;
+	cin.ignore(numeric_limits < int >::max(), '\n');	/* ignore comments */
+	puw = original_puw;
+	puo3 = original_puo3;
 	if ( puw < 0 )
 	    presplane(atms);
@@ -252,7 +255,8 @@
 	palt = plane_sim.zpl[33] - atms.z[0];
 	pps = plane_sim.ppl[33];
-	cin >> taer55p;
+	cin >> original_taer55p;
+	taer55p = original_taer55p;
 	if ((taer55p > 0) || ((aerocon.taer55 - taer55p) < 1e-03))
@@ -274,6 +278,87 @@
+void Altitude::update_hv(AtmosModel & atms, const AerosolConcentration & aerocon)
+    xps = original_xps;
+    xpp = original_xpp;
+    float uwus;
+    float uo3us;
+    if (xps <= 0) {
+	xps = 0;
+	uwus = 1.424f;
+	uo3us = 0.344f;
+    else if (atms.idatm != 8)
+	pressure(atms, atms.uw, atms.uo3);
+    else
+	pressure(atms, uwus, uo3us);
+    if (xpp <= 0) {
+	/* ground measurement option */
+	palt = 0;
+	pps = atms.p[0];
+	idatmp = 0;
+	taer55p = 0;
+	puw = 0;
+    else if (xpp >= 100) {
+	/* satellite case of equivalent */
+	palt = 1000;
+	pps = 0;
+	taer55p = aerocon.taer55;
+	puw = 0;
+	ftray = 1;
+	idatmp = 4;
+    else {
+	/* "real" plane case */
+	if (puw < 0) {
+	    presplane(atms);
+	    idatmp = 2;
+	    if (atms.idatm == 8) {
+		puwus = puw;
+		puo3us = puo3;
+		puw *= atms.uw / uwus;
+		puo3 *= atms.uo3 / uo3us;
+		idatmp = 8;
+	else {
+	    presplane(atms);
+	    idatmp = 8;
+	palt = plane_sim.zpl[33] - atms.z[0];
+	pps = plane_sim.ppl[33];
+	if ((taer55p > 0) || ((aerocon.taer55 - taer55p) < 1e-03)) {
+	    /* a scale heigh of 2km is assumed in case no value is given for taer55p */
+	    taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 2)));
+	else {
+	    /* compute effective scale heigh */
+	    double sham = exp(-palt / 4);
+	    double sha = 1 - (taer55p / aerocon.taer55);
+	    if (sha >= sham)
+		taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / 4)));
+	    else {
+		sha = -palt / log(sha);
+		taer55p = (float)(aerocon.taer55 * (1 - exp(-palt / sha)));
 void Altitude::parse()
     cin >> original_xps;
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.h
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.h	2011-06-03 06:46:11 UTC (rev 46527)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/Altitude.h	2011-06-03 06:51:30 UTC (rev 46528)
@@ -71,6 +71,9 @@
      and used in subsequent calls to init to set xps and xpp */
     float original_xps;
     float original_xpp;
+    float original_taer55p;
+    float original_puw;
+    float original_puo3;
 	void pressure(AtmosModel& atms, float& uw, float& uo3);
@@ -84,8 +87,10 @@
     /* Set the height to be used the next time init is called */
     void set_height(const float height) { original_xps = height; }
-    /* call init when ever xps changes */
+    /* call init only once: init parses input file */
     void init(AtmosModel& atms, const AerosolConcentration &aerocon);
+    /* call update_hv whenever xps changes */
+    void update_hv(AtmosModel& atms, const AerosolConcentration &aerocon);
 	static Altitude Parse();
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html	2011-06-03 06:46:11 UTC (rev 46527)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/description.html	2011-06-03 06:51:30 UTC (rev 46528)
@@ -13,12 +13,11 @@
 performed. The previous settings are restored afterwards.
 <p>
-Because using a continuous <b>elevation</b> or <b>visibility</b>
+Because using a <b>elevation</b> and/or <b>visibility</b>
 raster map makes execution time much longer, it is advised to use
-categorized raster maps instead, in conjuction with flag <b>-o</b>.
-This flag tells <em>i.atcorr</em> to try and speedup
-calculations. However, this option under certain conditions can make
-execution time longer.
+the optimization flag <b>-o</b>.
+This flag tells <em>i.atcorr</em> to try and speedup calculations.
+However, this option will increase memory requirements.
 <p>
 If flag <b>-r</b> is used, the input raster data are treated as
@@ -626,11 +625,8 @@
 <div class="code"><pre>
-# using an integer DEM greatly accelerates the i.atcorr computations
-r.mapcalc "elev_int = round(elevation)"
 # find mean elevation (target above sea level, used as initialization value in control file)
-r.univar elev_int
+r.univar elevation
 </pre></div>
 Create a control file 'icnd.txt' for channel 4 (NIR), based on metadata. For the overpass time,
@@ -653,21 +649,21 @@
 Finally, run the atmospheric correction (-r for reflectance input map; -a for date &gt;July 2000;
 -o to use cache acceleration):
-i.atcorr -r -a -o lsat7_2002_40_rad ialt=elev_int icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr
+i.atcorr -r -a -o lsat7_2002_40_rad ialt=elevation icnd=icnd_lsat4.txt oimg=lsat7_2002_40_atcorr
 </pre></div>
 Note that the altitude value from 'icnd_lsat4.txt' file is read at the beginning
 to compute the initial transform. It is necessary to give a value which could
-the the mean value of the elevation model. For the atmospheric correction then
+be the mean value of the elevation model. For the atmospheric correction then
 the raster elevation values are used from the map.
 <p>
 Note that the process is computationally intensive.<br>
 Note also, that <em>i.atcorr</em> reports solar elevation angle above horizon rather than solar zenith angle.
 <h2><font color="red">REMAINING DOCUMENTATION ISSUES</font></h2>
-1. It should be explained under what circumstances the use of categorized maps
-in conjuction with flag <em>-o</em> can slow down the calculations instead of
-speeding them up.
+1. The influence and importance of the visibility value or map should be
+explained, also how to obtain an estimate for either visibility or aerosol
+optical depth at 550nm.
 <h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp	2011-06-03 06:46:11 UTC (rev 46527)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/main.cpp	2011-06-03 06:51:30 UTC (rev 46528)
@@ -29,7 +29,9 @@
 * Addition of IRS-1C LISS, Feb 2009: Markus Neteler
-TODO: use dynamic allocation for TiCache
+* input elevation/visibility map: efficient cache with dynamic memory
+* allocation: Markus Metz, Apr 2011
 #include <cstdlib>
@@ -42,14 +44,25 @@
 #include "Transform.h"
 #include "6s.h"
+#include "rbtree.h"
+/* TICache: create 1 meter bins for altitude in km */
+/* 10m bins are also ok */
+/* BIN_ALT = 1000 / <bin size in meters> */
+#define BIN_ALT 1000.
+/* TICache: create 1 km bins for visibility */
+#define BIN_VIS 1.
+/* uncomment to disable cache usage */
+/* #define _NO_OPTIMIZE_ */
 /* Input options and flags */
 struct Options
     /* options */
     struct Option *iimg;    /* input satellite image */
     struct Option *iscl;    /* input data is scaled to this range */
-    struct Option *ialt;    /* an input elevation map in km used to increase */
+    struct Option *ialt;    /* an input elevation map in meters used to increase */
                             /* atmospheric correction accuracy, including this */
                             /* will make computations take much, much longer */
     struct Option *ivis;    /* an input visibility map in km (same purpose and effect as ialt) */
@@ -71,19 +84,22 @@
     int max;
+struct RBitem
+    int alt;		/* elevation */
+    int vis;		/* visibility */
+    TransformInput ti;	/* transformation parameters */
-int hit = 0;
-int mis = 0;
 /* function prototypes */
-static void adjust_region (char *, const char *);
-static CELL round_c (FCELL);
-static void write_fp_to_cell (int, FCELL *);
-static void process_raster (int, InputMask, ScaleRange, int, int, int, bool, ScaleRange, bool);
-static void copy_colors (char *, const char *, char *);
-static void define_module (void);
-static struct Options define_options (void);
-static void read_scale (Option *, ScaleRange &);
+static void adjust_region(char *, const char *);
+static CELL round_c(FCELL);
+static void write_fp_to_cell(int, FCELL *);
+static void process_raster(int, InputMask, ScaleRange, int, int, int, bool, ScaleRange);
+static void copy_colors(char *, const char *, char *);
+static void define_module(void);
+static struct Options define_options(void);
+static void read_scale(Option *, ScaleRange &);
@@ -91,7 +107,7 @@
    Atmospheric corrections should be done on the whole
    satelite image, not just portions.
-static void adjust_region (char *name, const char *mapset)
+static void adjust_region(char *name, const char *mapset)
     struct Cell_head iimg_head;	/* the input image header file */
@@ -105,7 +121,7 @@
 /* Rounds a floating point cell value */
-static CELL round_c (FCELL x)
+static CELL round_c(FCELL x)
     if (x >= 0.0)
 	return (CELL)(x + .5);
@@ -115,7 +131,7 @@
 /* Converts the buffer to cell and write it to disk */
-static void write_fp_to_cell (int ofd, FCELL* buf)
+static void write_fp_to_cell(int ofd, FCELL* buf)
     CELL* cbuf;
     int col;
@@ -126,138 +142,88 @@
     G_put_raster_row(ofd, cbuf, CELL_TYPE);
-/* See also Cache note below */
-class TICache
+/* compare function for RB tree */
+static int compare_hv(const void *ti_a, const void *ti_b)
-    enum TICacheSize
-        MAX_TIs = 4096 /* this value is a guess, increase it if in general
-                        * more categories are used. TODO: use dynamic allocation
-                        * since 4096 is the limit on 32bit */
-    TransformInput tis[MAX_TIs];
-    float alts[MAX_TIs];
-    int p;
+    struct RBitem *a, *b;
-public:
-    TICache() { p = 0; for(int i = 0; i < MAX_TIs; i++) alts[i] = -1; }
-    int search(float alt) {
-	for(int i = 0; i < MAX_TIs; i++)
-	    if(alt == alts[i])
-		hit++;
-		return i;
-	mis++;
-	return -1;
+    a = (struct RBitem *)ti_a;
+    b = (struct RBitem *)ti_b;
-    TransformInput get(int i) { return tis[i]; }
-    void add(TransformInput ti, float alt) {
-	tis[p] = ti;
-	alts[p] = alt;
-	p++;
-	if(p >= MAX_TIs) p = 0;
+    /* check most common case first
+     * also faster if either an altitude or a visibility map is given,
+     * but not both */
+    if (a->alt == b->alt) {
+	if (a->vis == b->vis)
+	    return 0;
+	if (a->vis > b->vis)
+	    return 1;
+	else if (a->vis < b->vis)
+	    return -1;
+    else if (a->alt > b->alt)
+	return 1;
+    else if (a->alt < b->alt)
+	return -1;
+    /* should not be reached */
+    return 0;
-/* the transform input map, is a array of ticaches.
-   The first key is the visibility which matches to a TICache for the altitudes.
-   This code is horrible, i just spent 20min writing and 5min debugging it. */
+/* Cache for transformation input parameters */
+class TICache
+    struct RB_TREE *RBTree;
+    unsigned int tree_size;
-/* Cache note:
-   The DEM cases are in range 0 < DEM < 8888 for the World in case of using an
-   integer DEM values in meters. So the cache should ideally store 8888 different
-   cases for the World-type conditions if all happen in the same image. */
-class TIMap
-    enum TIMapSize
+  private:
+    struct RBitem set_alt_vis(float alt, float vis)
-	MAX_TICs = 4096  /* this value is a guess. It means that <size> TI's will be
-                          * the max combinations of vis/alt pairs. TODO: use dynamic allocation
+	struct RBitem rbitem;
-    TICache tic[MAX_TICs]; /* array of TICaches */
-    float visi[MAX_TICs];
-    int p;
+	/* although alt and vis are already rounded,
+	 * the + 0.5 is needed for fp representation errors */
+	/* alt has been converted to kilometers */
+	rbitem.alt = (int) (alt * BIN_ALT + 0.5);
+	/* vis should be kilometers */
+	rbitem.vis = (int) (vis + 0.5);
+	return rbitem;
-public:
-    struct Position
+  public:
+      TICache()
-	int i, j;
-	Position() : i(-1), j(-1) {}
-	Position(int x, int y) : i(x), j(y) {}
-	bool valid() { return i != -1 && j != -1; }
-    TIMap() { p = 0; for(int i = 0; i < MAX_TICs; i++) visi[i] = -1; }
-    Position search(float vis, float alt) {
-	for(int i = 0; i < MAX_TICs; i++)
-	    if(vis == visi[i]) {
-		Position pos;
-		pos.i = i;
-		pos.j = tic[i].search(alt);
-		return pos;
-	return Position();
+	RBTree = rbtree_create(compare_hv, sizeof(struct RBitem));
+	tree_size = 0;
+    int search(float alt, float vis, TransformInput *ti)
+	struct RBitem search_ti = set_alt_vis(alt, vis);
+	struct RBitem *found_ti;
-    TransformInput get(Position pos) { return tic[pos.i].get(pos.j); }
+	found_ti = (struct RBitem *)rbtree_find(RBTree, &search_ti);
+	if (found_ti) {
+	    *ti = found_ti->ti;
+	    return 1;
+	else
+	    return 0;
-    void add(TransformInput ti, float vis, float alt) {
-	tic[p].add(ti, alt);
-	visi[p] = vis;
-	p++;
-	if(p >= MAX_TICs) p = 0;
+    void add(TransformInput ti, float alt, float vis)
+	struct RBitem insert_ti = set_alt_vis(alt, vis);
-struct IntPair
-    FCELL x;
-    FCELL y;
-    IntPair(FCELL i, FCELL j) : x(i), y(j) {}
-    bool operator<(const IntPair& b) const
-	    if(x < b.x) return true;
-	    else if(x > b.x) return false;
-	    else if(y < b.y) return true;
-	    return false;
+	/* add safety check here */
+	tree_size++;
+	insert_ti.ti = ti;
-typedef std::map<IntPair, TransformInput> CacheMap;
-const TransformInput& optimize_va (const FCELL& vis, const FCELL& alt)
-    static CacheMap timap;
-    static TransformInput ti;
-    IntPair key(vis, alt);
-    CacheMap::iterator it = timap.find(key);
-    if(it != timap.end()) /* search found key */
-	ti = (*it).second;
+	rbtree_insert(RBTree, &insert_ti);
-    else
-	pre_compute_hv(alt, vis);
-	ti = compute();
-	timap.insert(std::make_pair(key, ti));
-    return ti;
 /* Process the raster and do atmospheric corrections.
@@ -274,9 +240,9 @@
    oflt: if true use FCELL_TYPE for output
    oscale: output file's range (default is min = 0, max = 255)
-static void process_raster (int ifd, InputMask imask, ScaleRange iscale,
+static void process_raster(int ifd, InputMask imask, ScaleRange iscale,
 			    int ialt_fd, int ivis_fd, int ofd, bool oflt,
-			    ScaleRange oscale, bool optimize)
+			    ScaleRange oscale)
     FCELL* buf;         /* buffer for the input values */
     FCELL* alt = NULL;         /* buffer for the elevation values */
@@ -284,13 +250,21 @@
     FCELL  prev_alt = -1.f;
     FCELL  prev_vis = -1.f;
     int row, col, nrows, ncols;
+    /* switch on optimization automatically if elevation and/or visibility map is given */
+    bool optimize = (ialt_fd >= 0 || ivis_fd >= 0);
+#ifdef _NO_OPTIMIZE_
+    optimize = false;
+#endif
     /* do initial computation with global elevation and visibility values */
     TransformInput ti;
     ti = compute();
-    TICache ticache;    /* use this to increase computation speed when an elevation map with categories are given */
+    /* use a cache to increase computation speed when an elevation map
+     * and/or a visibility map is given */
+    TICache ticache;
     /* allocate memory for buffers */
     buf = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
     if(ialt_fd >= 0) alt = (FCELL*)G_allocate_raster_buf(FCELL_TYPE);
@@ -323,22 +297,47 @@
         /* loop over all the values in the row */
 	for(col = 0; col < ncols; col++)
-	    if(vis && G_is_f_null_value(&vis[col]) ||
-	       alt && G_is_f_null_value(&alt[col]) ||
+	    if ((vis && G_is_f_null_value(&vis[col])) ||
+	       (alt && G_is_f_null_value(&alt[col])) ||
 	              G_is_f_null_value(&buf[col]))
 	        G_set_f_null_value(&buf[col], 1);
 	        continue;
-	    if (ialt_fd >= 0)
-		alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
+	    if (ialt_fd >= 0) {
+		if (alt[col] < 0)
+		    alt[col] = 0; /* on or below sea level, all the same for 6S */
+		else
+		    alt[col] /= 1000.0f;	/* converting to km from input which should be in meter */
+		/* round to nearest altitude bin */
+		/* rounding result: watch out for fp representation error */
+		alt[col] = ((int) (alt[col] * BIN_ALT + 0.5)) / BIN_ALT;
+	    if (ivis_fd >= 0) {
+		if (vis[col] < 0)
+		    vis[col] = 0; /* negative visibility is invalid, print a WARNING ? */
+		/* round to nearest visibility bin */
+		vis[col] = ((int) (vis[col] + 0.5));
             /* check if both maps are active and if whether any value has changed */
             if((ialt_fd >= 0) && (ivis_fd >= 0) && ((prev_vis != vis[col]) || (prev_alt != alt[col])))
                	prev_alt = alt[col]; /* update new values */
                	prev_vis = vis[col];
- 		if(optimize) ti = optimize_va(vis[col], alt[col]); /* try to optimize? */
+		if (optimize) {
+		    int in_cache = ticache.search(alt[col], vis[col], &ti);
+		    if (!in_cache) {
+			pre_compute_hv(alt[col], vis[col]);	/* re-compute transformation inputs */
+			ti = compute();	/* ... */
+			ticache.add(ti, alt[col], vis[col]);
 		else { /* no optimizations */
 		    ti = compute();
@@ -350,18 +349,16 @@
                     prev_vis = vis[col];        /* keep track of previous visibility */
-                    if(optimize)
-                        int p = ticache.search(vis[col]);
-                        if(p >= 0) ti = ticache.get(p);
-                        else
-                            pre_compute_v(vis[col]);    /* re-compute transformation inputs */
-                            ti = compute();             /* ... */
+		    if (optimize) {
+			int in_cache = ticache.search(0, vis[col], &ti);
-                            ticache.add(ti, vis[col]);
+			if (!in_cache) {
+			    pre_compute_v(vis[col]);	/* re-compute transformation inputs */
+			    ticache.add(ti, 0, vis[col]);
                     else
@@ -373,18 +370,16 @@
                     prev_alt = alt[col];        /* keep track of previous altitude */
-                    if(optimize)
-                        int p = ticache.search(alt[col]);
-                        else
-                            pre_compute_h(alt[col]);    /* re-compute transformation inputs */
+		    if (optimize) {
+			int in_cache = ticache.search(alt[col], 0, &ti);
-                            ticache.add(ti, alt[col]);
+			if (!in_cache) {
+			    pre_compute_h(alt[col]);	/* re-compute transformation inputs */
+			    ticache.add(ti, alt[col], 0);
                     else
@@ -400,7 +395,7 @@
             buf[col] = buf[col] * ((float)oscale.max - (float)oscale.min) + oscale.min;
             if(~oflt && (buf[col] > (float)oscale.max))
-		G_warning (_("The output data will overflow. Reflectance > 100%%"));
+		G_warning(_("The output data will overflow. Reflectance > 100%%"));
         /* write output */
@@ -418,7 +413,7 @@
 /* Copy the colors from map named iname to the map named oname */
-static void copy_colors (char *iname, const char *imapset, char *oname)
+static void copy_colors(char *iname, const char *imapset, char *oname)
     struct Colors colors;
@@ -428,7 +423,7 @@
 /* Define our module so that Grass can print it if the user wants to know more. */
     struct GModule *module;
@@ -458,13 +453,13 @@
 /* Define the options and flags */
     struct Options opts;
-    opts.iimg = G_define_standard_option (G_OPT_R_INPUT);
-    opts.iimg->key		= "iimg";
+    opts.iimg = G_define_standard_option(G_OPT_R_INPUT);
+    opts.iimg->key = "iimg";
     opts.iscl = G_define_option();
     opts.iscl->key          = "iscl";
     opts.iscl->type         = TYPE_INTEGER;
@@ -526,13 +521,14 @@
     opts.optimize = G_define_flag();
     opts.optimize->key = 'o';
-    opts.optimize->description = _("Try to increase computation speed when categorized altitude or/and visibility map is used");
+    opts.optimize->description =
+	_("Try to increase computation speed when altitude and/or visibility map is used");
     return opts;
 /* Read the min and max values from the iscl and oscl options */
-void read_scale (Option *scl, ScaleRange &range)
+void read_scale(Option *scl, ScaleRange &range)
     /* set default values */
     range.min = 0;
@@ -545,7 +541,7 @@
         if(range.min==range.max)
-            G_warning (_("Scale range length should be > 0; Using default values: [0,255]"));
+            G_warning(_("Scale range length should be > 0; Using default values: [0,255]"));
             range.min = 0;
             range.max = 255;
@@ -574,6 +570,7 @@
     int ivis_fd = -1;       /* input visibility map's file descriptor */
     const char *iimg_mapset, *ialt_mapset, *iviz_mapset;
     struct History hist;
+    struct Cell_head orig_window;
     /* Define module */
     define_module();
@@ -590,16 +587,17 @@
     if ( (iimg_mapset = G_find_cell2 ( opts.iimg->answer, "") ) == NULL )
 	G_fatal_error ( _("Raster map <%s> not found"), opts.iimg->answer);
     if((iimg_fd = G_open_cell_old(opts.iimg->answer, iimg_mapset)) < 0)
-	G_fatal_error (_("Unable to open raster map <%s>"),
+	G_fatal_error(_("Unable to open raster map <%s>"),
 		       G_fully_qualified_name(opts.iimg->answer, iimg_mapset));
+    G_get_set_window(&orig_window);
     adjust_region(opts.iimg->answer, iimg_mapset);
     if(opts.ialt->answer) {
 	if ( (ialt_mapset = G_find_cell2 ( opts.ialt->answer, "") ) == NULL )
 	    G_fatal_error ( _("Raster map <%s> not found"), opts.ialt->answer);
 	if((ialt_fd = G_open_cell_old(opts.ialt->answer, ialt_mapset)) < 0)
 			   G_fully_qualified_name(opts.ialt->answer, ialt_mapset));
@@ -607,7 +605,7 @@
 	if ( (iviz_mapset = G_find_cell2 ( opts.ivis->answer, "") ) == NULL )
 	    G_fatal_error ( _("Raster map <%s> not found"), opts.ivis->answer);
 	if((ivis_fd = G_open_cell_old(opts.ivis->answer, iviz_mapset)) < 0)
 			   G_fully_qualified_name(opts.ivis->answer, iviz_mapset));
@@ -615,13 +613,13 @@
     if(opts.oflt->answer)
 	if((oimg_fd = G_open_fp_cell_new(opts.oimg->answer)) < 0)
-	    G_fatal_error (_("Unable to create raster map <%s>"),
+	    G_fatal_error(_("Unable to create raster map <%s>"),
 			   opts.oimg->answer);
     else
 	if((oimg_fd = G_open_raster_new(opts.oimg->answer, CELL_TYPE)) < 0)
 			   opts.oimg->answer);
@@ -639,9 +637,14 @@
     if(opts.etmbefore->answer) imask = (InputMask)(imask | ETM_BEFORE);
     if(opts.etmafter->answer) imask = (InputMask)(imask | ETM_AFTER);
+    if (opts.optimize->answer)
+	G_important_message(_("Optimization is switched on automatically, the -o flag has no effect"));
     /* process the input raster and produce our atmospheric corrected output raster. */
+    G_message(_("Atmospheric correction..."));
     process_raster(iimg_fd, imask, iscale, ialt_fd, ivis_fd,
-                   oimg_fd, opts.oflt->answer, oscale, opts.optimize->answer);
+                   oimg_fd, opts.oflt->answer, oscale);
     /* Close the input and output file descriptors */
@@ -658,5 +661,8 @@
        Scaling is ignored and color ranges might not be correct. */
     copy_colors(opts.iimg->answer, iimg_mapset, opts.oimg->answer);
-    exit (EXIT_SUCCESS);
+    G_set_window(&orig_window);
+    G_message(_("Atmospheric correction complete."));
+    exit(EXIT_SUCCESS);
Added: grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.cpp
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.cpp	                        (rev 0)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.cpp	2011-06-03 06:51:30 UTC (rev 46528)
@@ -0,0 +1,552 @@
+ * \file rbtree.c
+ * \brief binary search tree
+ * Generic balanced binary search tree (Red Black Tree) implementation
+ * (C) 2009 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2).  Read the file COPYING that comes with GRASS for details.
+ * \author Original author Julienne Walker 2003, 2008
+ *         GRASS implementation Markus Metz, 2009
+/* balanced binary search tree implementation
+ * this one is a Red Black Tree, no parent pointers, no threads
+ * The core code comes from Julienne Walker's tutorials on binary search trees
+ * original license: public domain
+ * http://eternallyconfuzzled.com/tuts/datastructures/jsw_tut_rbtree.aspx
+ * some ideas come from libavl (GPL >= 2)
+ * Red Black Trees are used to maintain a data structure with
+ * search, insertion and deletion in O(log N) time
+#include <cassert>
+#include <cstdlib>
+#include <cstring>
+extern "C"
+#include <grass/gis.h>
+#include <grass/glocale.h>
+/* internal functions */
+struct RB_NODE *rbtree_single(struct RB_NODE *, int);
+struct RB_NODE *rbtree_double(struct RB_NODE *, int);
+void *rbtree_first(struct RB_TRAV *);
+void *rbtree_next(struct RB_TRAV *);
+struct RB_NODE *rbtree_make_node(size_t, void *);
+int is_red(struct RB_NODE *);
+/* create new tree and initialize
+ * returns pointer to new tree, NULL for memory allocation error
+struct RB_TREE *rbtree_create(rb_compare_fn *compare, size_t rb_datasize)
+    struct RB_TREE *tree = (struct RB_TREE *)malloc(sizeof(struct RB_TREE));
+    if (tree == NULL) {
+	G_warning("RB tree: Out of memory!");
+	return NULL;
+    assert(compare);
+    tree->datasize = rb_datasize;
+    tree->rb_compare = compare;
+    tree->count = 0;
+    tree->root = NULL;
+    return tree;
+/* add an item to a tree
+ * non-recursive top-down insertion
+ * the algorithm does not allow duplicates and also does not warn about a duplicate
+ * returns 1 on success, 0 on failure
+int rbtree_insert(struct RB_TREE *tree, void *data)
+    assert(tree && data);
+    if (tree->root == NULL) {
+	/* create a new root node for tree */
+	tree->root = rbtree_make_node(tree->datasize, data);
+	    return 0;
+    else {
+	struct RB_NODE head = { 0 };	/* False tree root */
+	struct RB_NODE *g, *t;	/* Grandparent & parent */
+	struct RB_NODE *p, *q;	/* Iterator & parent */
+	int dir = 0, last = 0;
+	/* Set up helpers */
+	t = &head;
+	g = p = NULL;
+	q = t->link[1] = tree->root;
+	/* Search down the tree */
+	for (;;) {
+	    if (q == NULL) {
+		/* Insert new node at the bottom */
+		p->link[dir] = q = rbtree_make_node(tree->datasize, data);
+		if (q == NULL)
+		    return 0;
+	    else if (is_red(q->link[0]) && is_red(q->link[1])) {
+		/* Color flip */
+		q->red = 1;
+		q->link[0]->red = 0;
+		q->link[1]->red = 0;
+	    /* Fix red violation */
+	    if (is_red(q) && is_red(p)) {
+		int dir2 = t->link[1] == g;
+		if (q == p->link[last])
+		    t->link[dir2] = rbtree_single(g, !last);
+		else
+		    t->link[dir2] = rbtree_double(g, !last);
+	    last = dir;
+	    dir = tree->rb_compare(q->data, data);
+	    /* Stop if found. This check also disallows duplicates in the tree */
+	    if (dir == 0)
+		break;
+	    dir = dir < 0;
+	    /* Move the helpers down */
+	    if (g != NULL)
+		t = g;
+	    g = p, p = q;
+	    q = q->link[dir];
+	/* Update root */
+	tree->root = head.link[1];
+    /* Make root black */
+    tree->root->red = 0;
+    tree->count++;
+    return 1;
+/* remove an item from a tree that matches given data
+ * non-recursive top-down removal
+ * returns 1 on successful removal
+ * returns 0 if data item was not found
+int rbtree_remove(struct RB_TREE *tree, const void *data)
+    struct RB_NODE *q, *p, *g;	/* Helpers */
+    struct RB_NODE *f = NULL;	/* Found item */
+    int dir = 1, removed = 0;
+	return 0;		/* empty tree, nothing to remove */
+    q = &head;
+    g = p = NULL;
+    q->link[1] = tree->root;
+    /* Search and push a red down */
+    while (q->link[dir] != NULL) {
+	int last = dir;
+	/* Update helpers */
+	g = p, p = q;
+	q = q->link[dir];
+	/* Save found node */
+	if (dir == 0)
+	    f = q;
+	dir = dir < 0;
+	/* Push the red node down */
+	if (!is_red(q) && !is_red(q->link[dir])) {
+	    if (is_red(q->link[!dir]))
+		p = p->link[last] = rbtree_single(q, dir);
+	    else if (!is_red(q->link[!dir])) {
+		struct RB_NODE *s = p->link[!last];
+		if (s != NULL) {
+		    if (!is_red(s->link[!last]) && !is_red(s->link[last])) {
+			/* Color flip */
+			p->red = 0;
+			s->red = 1;
+			q->red = 1;
+		    else {
+			int dir2 = g->link[1] == p;
+			if (is_red(s->link[last]))
+			    g->link[dir2] = rbtree_double(p, last);
+			else if (is_red(s->link[!last]))
+			    g->link[dir2] = rbtree_single(p, last);
+			/* Ensure correct coloring */
+			q->red = g->link[dir2]->red = 1;
+			g->link[dir2]->link[0]->red = 0;
+			g->link[dir2]->link[1]->red = 0;
+    /* Replace and remove if found */
+    if (f != NULL) {
+	free(f->data);
+	f->data = q->data;
+	p->link[p->link[1] == q] = q->link[q->link[0] == NULL];
+	free(q);
+	q = NULL;
+	tree->count--;
+	removed = 1;
+    else
+	G_debug(2, "RB tree: data not found in search tree");
+    /* Update root and make it black */
+    if (tree->root != NULL)
+    return removed;
+/* find data item in tree
+ * returns pointer to data item if found else NULL
+void *rbtree_find(struct RB_TREE *tree, const void *data)
+    struct RB_NODE *curr_node = tree->root;
+    int cmp;
+    while (curr_node != NULL) {
+	cmp = tree->rb_compare(curr_node->data, data);
+	if (cmp == 0)
+	    return curr_node->data;	/* found */
+	curr_node = curr_node->link[cmp < 0];
+    return NULL;
+/* initialize tree traversal
+ * (re-)sets trav structure
+ * returns 0
+int rbtree_init_trav(struct RB_TRAV *trav, struct RB_TREE *tree)
+    assert(trav && tree);
+    trav->tree = tree;
+    trav->curr_node = tree->root;
+    trav->first = 1;
+    trav->top = 0;
+    return 0;
+/* traverse the tree in ascending order
+ * useful to get all items in the tree non-recursively
+ * struct RB_TRAV *trav needs to be initialized first
+ * returns pointer to data, NULL when finished
+void *rbtree_traverse(struct RB_TRAV *trav)
+    assert(trav);
+    if (trav->curr_node == NULL) {
+	if (trav->first)
+	    G_debug(1, "RB tree: empty tree");
+	else
+	    G_debug(1, "RB tree: finished traversing");
+	return NULL;
+    if (!trav->first)
+	return rbtree_next(trav);
+    else {
+	trav->first = 0;
+	return rbtree_first(trav);
+/* find start point to traverse the tree in ascending order
+ * useful to get a selection of items in the tree
+ * magnitudes faster than traversing the whole tree
+ * may return first item that's smaller or first item that's larger
+void *rbtree_traverse_start(struct RB_TRAV *trav, const void *data)
+    int dir = 0;
+    assert(trav && data);
+	if (trav->first)
+	    G_warning("RB tree: empty tree");
+	else
+	    G_warning("RB tree: finished traversing");
+	return NULL;
+    if (!trav->first)
+    /* else first time, get start node */
+    trav->first = 0;
+    trav->top = 0;
+    while (trav->curr_node != NULL) {
+	dir = trav->tree->rb_compare(trav->curr_node->data, data);
+	/* exact match, great! */
+	if (dir == 0)
+	    return trav->curr_node->data;
+	else {
+	    dir = dir < 0;
+	    /* end of branch, also reached if
+	     * smallest item is larger than search template or
+	     * largest item is smaller than search template */
+	    if (trav->curr_node->link[dir] == NULL)
+	    trav->up[trav->top++] = trav->curr_node;
+	    trav->curr_node = trav->curr_node->link[dir];
+    return NULL;		/* should not happen */
+/* two functions needed to fully traverse the tree: initialize and continue
+ * this one here uses a stack
+ * parent pointers or threads would also be possible
+ * but these would need to be added to RB_NODE
+ * -> more memory needed for standard operations
+/* start traversing the tree
+ * returns pointer to smallest data item
+void *rbtree_first(struct RB_TRAV *trav)
+    /* get smallest item */
+    while (trav->curr_node->link[0] != NULL) {
+	trav->curr_node = trav->curr_node->link[0];
+    return trav->curr_node->data;	/* return smallest item */
+/* continue traversing the tree in ascending order
+ * returns pointer to data item, NULL when finished
+void *rbtree_next(struct RB_TRAV *trav)
+    if (trav->curr_node->link[1] != NULL) {
+	/* something on the right side: larger item */
+	trav->curr_node = trav->curr_node->link[1];
+	/* go down, find smallest item in this branch */
+    else {
+	/* at smallest item in this branch, go back up */
+	struct RB_NODE *last;
+	do {
+	    if (trav->top == 0) {
+		trav->curr_node = NULL;
+		break;
+	    last = trav->curr_node;
+	    trav->curr_node = trav->up[--trav->top];
+	} while (last == trav->curr_node->link[1]);
+    if (trav->curr_node != NULL) {
+    else
+	return NULL;		/* finished traversing */
+/* destroy the tree */
+void rbtree_destroy(struct RB_TREE *tree)
+    struct RB_NODE *it;
+    struct RB_NODE *save = tree->root;
+    Rotate away the left links so that
+    we can treat this like the destruction
+    of a linked list
+    while((it = save) != NULL) {
+	if (it->link[0] == NULL) {
+	    /* No left links, just kill the node and move on */
+	    save = it->link[1];
+	    free(it->data);
+	    it->data = NULL;
+	    free(it);
+	    it = NULL;
+	else {
+	    /* Rotate away the left link and check again */
+	    save = it->link[0];
+	    it->link[0] = save->link[1];
+	    save->link[1] = it;
+    free(tree);
+    tree = NULL;
+/* used for debugging: check for errors in tree structure */
+int rbtree_debug(struct RB_TREE *tree, struct RB_NODE *root)
+    int lh, rh;
+    if (root == NULL)
+	return 1;
+    else {
+	struct RB_NODE *ln = root->link[0];
+	struct RB_NODE *rn = root->link[1];
+	int lcmp = 0, rcmp = 0;
+	/* Consecutive red links */
+	if (is_red(root)) {
+	    if (is_red(ln) || is_red(rn)) {
+		G_warning("Red Black Tree debugging: Red violation");
+		return 0;
+	lh = rbtree_debug(tree, ln);
+	rh = rbtree_debug(tree, rn);
+	if (ln) {
+	    lcmp = tree->rb_compare(ln->data, root->data);
+	if (rn) {
+	    rcmp = tree->rb_compare(rn->data, root->data);
+	/* Invalid binary search tree:
+	 * left node >= parent or right node <= parent */
+	if ((ln != NULL && lcmp > -1)
+	    || (rn != NULL && rcmp < 1)) {
+	    G_warning("Red Black Tree debugging: Binary tree violation");
+	    return 0;
+	/* Black height mismatch */
+	if (lh != 0 && rh != 0 && lh != rh) {
+	    G_warning("Red Black Tree debugging: Black violation");
+	    return 0;
+	/* Only count black links */
+	if (lh != 0 && rh != 0)
+	    return is_red(root) ? lh : lh + 1;
+	else
+	    return 0;
+ *  internal functions for Red Black Tree maintenance  *
+/* add a new node to the tree */
+struct RB_NODE *rbtree_make_node(size_t datasize, void *data)
+    struct RB_NODE *new_node = (struct RB_NODE *)malloc(sizeof(*new_node));
+    if (new_node == NULL)
+	G_fatal_error("RB Search Tree: Out of memory!");
+    new_node->data = malloc(datasize);
+    if (new_node->data == NULL)
+    memcpy(new_node->data, data, datasize);
+    new_node->red = 1;		/* 1 is red, 0 is black */
+    new_node->link[0] = NULL;
+    new_node->link[1] = NULL;
+    return new_node;
+/* check for red violation */
+int is_red(struct RB_NODE *root)
+    if (root)
+	return root->red == 1;
+    return 0;
+/* single rotation */
+struct RB_NODE *rbtree_single(struct RB_NODE *root, int dir)
+    struct RB_NODE *newroot = root->link[!dir];
+    root->link[!dir] = newroot->link[dir];
+    newroot->link[dir] = root;
+    root->red = 1;
+    newroot->red = 0;
+    return newroot;
+/* double rotation */
+struct RB_NODE *rbtree_double(struct RB_NODE *root, int dir)
+    root->link[!dir] = rbtree_single(root->link[!dir], !dir);
+    return rbtree_single(root, dir);
Added: grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.h
--- grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.h	                        (rev 0)
+++ grass/branches/releasebranch_6_4/imagery/i.atcorr/rbtree.h	2011-06-03 06:51:30 UTC (rev 46528)
@@ -0,0 +1,112 @@
+ *                          USAGE                            *
+ * NOTE: duplicates are not supported
+ * custom compare function
+ * extern int my_compare_fn(const void *, const void *);
+ * int my_compare_fn(const void *a, const void *b) {
+ *   if ((mydatastruct *) a < (mydatastruct *) b)
+ *     return -1;
+ *   else if ((mydatastruct *) a > (mydatastruct *) b)
+ *     return 1;
+ *   else if ((mydatastruct *) a == (mydatastruct *) b)
+ *     return 0;
+ * create and initialize tree:
+ * struct RB_TREE *mytree = rbtree_create(my_compare_fn, item_size);
+ * insert items to tree:
+ * struct mydatastruct data = <some data>;
+ * if (rbtree_insert(mytree, &data) == 0)
+ * 	 G_warning("could not insert data");
+ * find item in tree:
+ * if (rbtree_find(mytree, &data) == 0)
+ * 	 G_message("data not found");
+ * delete item from tree:
+ * if (rbtree_remove(mytree, &data) == 0)
+ * 	  G_warning("could not find data in tree");
+ * traverse tree (get all items in tree in ascending order):
+ * struct RB_TRAV trav;
+ * rbtree_init_trav(&trav, tree);
+ * while ((data = rbtree_traverse(&trav)) != NULL) {
+ *   if (my_compare_fn(data, threshold_data) == 0) break;
+ * 	   <do something with data>;
+ * get a selection of items: all data > data1 and < data2
+ * start in tree where data is last smaller or first larger compared to data1
+ * data = rbtree_traverse_start(&trav, &data1);
+ *	 if (data > data2) break;
+ * destroy tree:
+ * rbtree_destroy(mytree);
+ * debug the whole tree with
+ * rbtree_debug(mytree, mytree->root);
+#include <stddef.h>
+/* maximum RB Tree height */
+#define RBTREE_MAX_HEIGHT 64        /* should be more than enough */
+/* routine to compare data items
+ * return -1 if rb_a < rb_b
+ * return  0 if rb_a == rb_b
+ * return  1 if rb_a > rb_b
+typedef int rb_compare_fn(const void *rb_a, const void *rb_b);
+struct RB_NODE
+    unsigned char red;              /* 0 = black, 1 = red */
+    void *data;                     /* any kind of data */
+    struct RB_NODE *link[2];        /* link to children: link[0] for smaller, link[1] for larger */
+struct RB_TREE
+    struct RB_NODE *root;           /* root node */
+    size_t datasize;                /* item size */
+    size_t count;                   /* number of items in tree. */
+    rb_compare_fn *rb_compare;      /* function to compare data */
+struct RB_TRAV
+    struct RB_TREE *tree;           /* tree being traversed */
+    struct RB_NODE *curr_node;      /* current node */
+    struct RB_NODE *up[RBTREE_MAX_HEIGHT];  /* stack of parent nodes */
+    int top;                        /* index for stack */
+    int first;                      /* little helper flag */
+/* tree functions */
+struct RB_TREE *rbtree_create(rb_compare_fn *, size_t);
+void rbtree_destroy(struct RB_TREE *);
+int rbtree_insert(struct RB_TREE *, void *);
+int rbtree_remove(struct RB_TREE *, const void *);
+void *rbtree_find(struct RB_TREE *, const void *);
+/* tree traversal functions */
+int rbtree_init_trav(struct RB_TRAV *, struct RB_TREE *);
+void* rbtree_traverse(struct RB_TRAV *);
+void *rbtree_traverse_start(struct RB_TRAV *, const void *);
+/* debug tree from given node downwards */
+int rbtree_debug(struct RB_TREE *, struct RB_NODE *);
