[GRASS-SVN] r46562 - grass/trunk/vector/v.out.ogr
Sat Jun 4 03:18:33 EDT 2011
Author: mmetz
Date: 2011-06-04 00:18:33 -0700 (Sat, 04 Jun 2011)
New Revision: 46562
   grass/trunk/vector/v.out.ogr/attrb.c
clean up attribute export
Modified: grass/trunk/vector/v.out.ogr/attrb.c
--- grass/trunk/vector/v.out.ogr/attrb.c	2011-06-03 18:29:08 UTC (rev 46561)
+++ grass/trunk/vector/v.out.ogr/attrb.c	2011-06-04 07:18:33 UTC (rev 46562)
@@ -44,12 +44,6 @@
 	    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
 		G_fatal_error(_("Unable to fetch data from table"));
-	    if (!more) {
-		/* start from the beginning in case multiple grass vector features
-		 * share the same category */
-		if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
-		    G_fatal_error(_("Unable to fetch data from table"));
 	    if (!more) {
 		/* G_warning ("No database record for cat = %d", cat); */
@@ -86,7 +80,7 @@
 						      (Column));
 		    G_debug(2, "  column = %s -> fieldnum = %d",
 			    db_get_column_name(Column), ogrfieldnum);
 		    if (ogrfieldnum < 0) {
 			G_debug(4, "Could not get OGR field number for column %s",
 				                         db_get_column_name(Column));
