[GRASS-SVN] r46630 - grass/branches/releasebranch_6_4/db/base
Thu Jun 9 03:50:39 EDT 2011
Author: neteler
Date: 2011-06-09 00:50:39 -0700 (Thu, 09 Jun 2011)
New Revision: 46630
   grass/branches/releasebranch_6_4/db/base/execute.c
GUI sections (backport from 6.5)
Modified: grass/branches/releasebranch_6_4/db/base/execute.c
--- grass/branches/releasebranch_6_4/db/base/execute.c	2011-06-09 05:30:21 UTC (rev 46629)
+++ grass/branches/releasebranch_6_4/db/base/execute.c	2011-06-09 07:50:39 UTC (rev 46630)
@@ -3,9 +3,9 @@
  * MODULE:       db.execute
  * AUTHOR(S):    Radim Blazek <radim.blazek gmail.com> (original contributor)
- *               Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>, Hamish Bowman <hamish_nospam yahoo.com>, Markus Neteler <neteler itc.it>, Stephan Holl
+ *               Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>, Hamish Bowman <hamish_b yahoo.com>, Markus Neteler <neteler itc.it>, Stephan Holl
  * PURPOSE:      process one non-select sql statement
- * COPYRIGHT:    (C) 2002-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2006, 2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -111,13 +111,16 @@
     input = G_define_standard_option(G_OPT_F_INPUT);
     input->required = NO;
     input->description = _("Name of file containing SQL statements");
+    input->guisection = _("Query");
     driver = G_define_standard_option(G_OPT_DRIVER);
     driver->options = db_list_drivers();
+    driver->guisection = _("Connection");
     if ((drv = db_get_default_driver_name()))
 	driver->answer = (char *) drv;
     database = G_define_standard_option(G_OPT_DATABASE);
+    database->guisection = _("Connection");
     if ((db = db_get_default_database_name()))
 	database->answer = (char *) db;
