[GRASS-SVN] r46767 - in sandbox: . martinl
Thu Jun 23 14:48:50 EDT 2011
Author: martinl
Date: 2011-06-23 11:48:50 -0700 (Thu, 23 Jun 2011)
New Revision: 46767
Added:
   sandbox/martinl/
   sandbox/martinl/compile_grass.sh
   sandbox/martinl/get_extensions.py
create `sandbox/martinl`
Added: sandbox/martinl/compile_grass.sh
--- sandbox/martinl/compile_grass.sh	                        (rev 0)
+++ sandbox/martinl/compile_grass.sh	2011-06-23 18:48:50 UTC (rev 46767)
@@ -0,0 +1,28 @@
+#!/bin/sh
+# Compile GRASS 6.4, 6.5 and 7.0 (update source code from SVN repository)
+SRC=$HOME/src
+update() {
+    dir=$1
+    echo "Updating $dir..."
+    cd $SRC/$dir
+    svn up || (svn cleanup && svn up)
+compile() {
+    dir=$1
+    version=$2
+    update $dir
+    echo "Compiling $dir..."
+    make distclean
+    ../configures.sh grass$version
+    make
+compile grass64_release 6
+compile grass6_devel 6
+compile grass_trunk 7
+exit 0
Property changes on: sandbox/martinl/compile_grass.sh
___________________________________________________________________
Added: svn:executable
Added: sandbox/martinl/get_extensions.py
--- sandbox/martinl/get_extensions.py	                        (rev 0)
+++ sandbox/martinl/get_extensions.py	2011-06-23 18:48:50 UTC (rev 46767)
@@ -0,0 +1,21 @@
+#!/usr/bin/python
+import os
+import sys
+gisbase = os.environ['GISBASE'] = "/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu"
+sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "python"))
+import grass.script as grass
+import grass.script.setup as gsetup
+def main():
+    gsetup.init(gisbase)
+    print grass.gisenv()
+    print grass.region()
+    return 0
+if __name__ == "__main__":
+    sys.exit(main())
Property changes on: sandbox/martinl/get_extensions.py
