[GRASS-SVN] r46774 - grass/trunk/raster/r.colors
Fri Jun 24 09:17:31 EDT 2011
Author: huhabla
Date: 2011-06-24 06:17:31 -0700 (Fri, 24 Jun 2011)
New Revision: 46774
Added:
   grass/trunk/raster/r.colors/edit_colors.c
   grass/trunk/raster/r.colors/r3.colors.html
   grass/trunk/raster/r.colors/raster3d_main.c
   grass/trunk/raster/r.colors/raster_main.c
   grass/trunk/raster/r.colors/test_elev_double_default.ref
   grass/trunk/raster/r.colors/test_volume_double_default.ref
Removed:
   grass/trunk/raster/r.colors/main.c
   grass/trunk/raster/r.colors/Makefile
   grass/trunk/raster/r.colors/local_proto.h
   grass/trunk/raster/r.colors/r.colors.html
   grass/trunk/raster/r.colors/test.r.colors.sh
Do not use hacks while implementing r3.colors!
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile	2011-06-23 22:30:34 UTC (rev 46773)
+++ grass/trunk/raster/r.colors/Makefile	2011-06-24 13:17:31 UTC (rev 46774)
@@ -1,16 +1,19 @@
 MODULE_TOPDIR = ../..
-PGM = r.colors
+LIBES = $(G3DLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(G3DDEP) $(GISDEP) $(RASTERDEP)
-LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB) $(G3DLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP) $(G3DDEP)
+PROGRAMS = r.colors r3.colors
-include $(MODULE_TOPDIR)/include/Make/Module.make
+r_colors_OBJS = raster_main.o edit_colors.o rules.o stats.o
+r3_colors_OBJS = raster3d_main.o edit_colors.o rules.o stats.o
-default: cmd
+include $(MODULE_TOPDIR)/include/Make/Multi.make
+default: multi
 # Insert thumbnail previews
-r.colors.tmp.html: $(HTMLSRC) thumbnails.py
+r.colors.tmp.html: $(BIN)/r.colors$(EXE) thumbnails.py
 	$(call htmldesc,$<,$@)
 	sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
 	mv -f "$@.tmp" "$@"
@@ -25,3 +28,5 @@
 .PHONY: thumbnails
 .INTERMEDIATE: r.colors.tmp.html
Copied: grass/trunk/raster/r.colors/edit_colors.c (from rev 46750, grass/trunk/raster/r.colors/main.c)
--- grass/trunk/raster/r.colors/edit_colors.c	                        (rev 0)
+++ grass/trunk/raster/r.colors/edit_colors.c	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,447 @@
+ * MODULE:       r.colors
+ * AUTHOR(S):    Michael Shapiro - CERL
+ *               David Johnson
+ * PURPOSE:      Allows creation and/or modification of the color table
+ *               for a raster map layer.
+ * COPYRIGHT:    (C) 2006-2008, 2010 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <sys/types.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+#include <grass/G3d.h>
+static char **rules;
+static int nrules;
+static int cmp(const void *aa, const void *bb)
+    char *const *a = (char *const *) aa;
+    char *const *b = (char *const *) bb;
+    return strcmp(*a, *b);
+static void scan_rules(void)
+    char path[GPATH_MAX];
+    sprintf(path, "%s/etc/colors", G_gisbase());
+    rules = G__ls(path, &nrules);
+    rules = G_realloc(rules, (nrules + 3) * sizeof (const char *));
+    rules[nrules++] = G_store("random");
+    rules[nrules++] = G_store("grey.eq");
+    rules[nrules++] = G_store("grey.log");
+    qsort(rules, nrules, sizeof (char *), cmp);
+static char *rules_list(void)
+    char *list = NULL;
+    int size = 0;
+    int len = 0;
+    int i;
+    for (i = 0; i < nrules; i++) {
+        const char *name = rules[i];
+        int n = strlen(name);
+        if (size < len + n + 2) {
+            size = len + n + 200;
+            list = G_realloc(list, size);
+        if (len > 0)
+            list[len++] = ',';
+        memcpy(&list[len], name, n + 1);
+        len += n;
+    return list;
+static char *rules_descriptions(void)
+    struct Key_Value *kv;
+    int result_len = 0;
+    int result_max = 2000;
+    char *result = G_malloc(result_max);
+    int i;
+    sprintf(path, "%s/etc/colors.desc", G_gisbase());
+    kv = G_read_key_value_file(path);
+    if (!kv)
+        return NULL;
+        const char *desc = G_find_key_value(name, kv);
+        int len;
+        if (!desc)
+            desc = "no description";
+        desc = _(desc);
+        len = strlen(name) + strlen(desc) + 2;
+        if (result_len + len >= result_max) {
+            result_max = result_len + len + 1000;
+            result = G_realloc(result, result_max);
+        sprintf(result + result_len, "%s;%s;", name, desc);
+        result_len += len;
+    G_free_key_value(kv);
+    return result;
+static void list_rules(void)
+    int i;
+        printf("%s\n", rules[i]);
+static int find_rule(const char *name)
+    int i;
+        if (strcmp(name, rules[i]) == 0)
+            return 1;
+    return 0;
+int edit_colors(int argc, char **argv, int type, const char *maptype, const char* Maptype)
+    int overwrite;
+    int is_from_stdin;
+    int remove;
+    int have_colors;
+    struct Colors colors, colors_tmp;
+    struct Cell_stats statf;
+    int have_stats = 0;
+    struct FPRange range;
+    DCELL min, max;
+    const char *name = NULL, *mapset = NULL;
+    const char *style = NULL, *cmap = NULL, *cmapset = NULL;
+    const char *rules = NULL;
+    int fp;
+    struct GModule *module;
+    struct {
+        struct Flag *r, *w, *l, *g, *a, *n, *e; /* Flag e is not available in r3.colors*/
+    } flag;
+    struct {
+        struct Option *map, *colr, *rast, *volume, *rules;
+    } opt;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("raster"));
+    G_add_keyword(_("color table"));
+    if (type == RASTER3D_TYPE) {
+        module->description =
+            _("Creates/modifies the color table associated with a raster3d map.");
+    } else {
+            _("Creates/modifies the color table associated with a raster map.");
+        opt.map = G_define_standard_option(G_OPT_R3_MAP);
+    } else {
+        opt.map = G_define_standard_option(G_OPT_R_MAP);
+    scan_rules();
+    opt.colr = G_define_option();
+    opt.colr->key = "color";
+    opt.colr->key_desc = "style";
+    opt.colr->type = TYPE_STRING;
+    opt.colr->required = NO;
+    opt.colr->options = rules_list();
+    opt.colr->description = _("Type of color table");
+    opt.colr->descriptions = rules_descriptions();
+    opt.colr->guisection = _("Define");
+    opt.rast = G_define_standard_option(G_OPT_R_INPUT);
+    opt.rast->key = "raster";
+    opt.rast->required = NO;
+    opt.rast->description =
+        _("Raster map from which to copy color table");
+    opt.rast->guisection = _("Define");
+    opt.volume = G_define_standard_option(G_OPT_R3_INPUT);
+    opt.volume->key = "volume";
+    opt.volume->required = NO;
+    opt.volume->description =
+        _("Raster3d map from which to copy color table");
+    opt.volume->guisection = _("Define");
+    opt.rules = G_define_standard_option(G_OPT_F_INPUT);
+    opt.rules->key = "rules";
+    opt.rules->required = NO;
+    opt.rules->label = _("Path to rules file");
+    opt.rules->description = _("\"-\" to read rules from stdin");
+    opt.rules->guisection = _("Define");
+    flag.r = G_define_flag();
+    flag.r->key = 'r';
+    flag.r->description = _("Remove existing color table");
+    flag.r->guisection = _("Remove");
+    flag.w = G_define_flag();
+    flag.w->key = 'w';
+    flag.w->description =
+        _("Only write new color table if one doesn't already exist");
+    flag.l = G_define_flag();
+    flag.l->key = 'l';
+    flag.l->description = _("List available rules then exit");
+    flag.l->suppress_required = YES;
+    flag.l->guisection = _("Print");
+    flag.n = G_define_flag();
+    flag.n->key = 'n';
+    flag.n->description = _("Invert colors");
+    flag.n->guisection = _("Define");
+    flag.g = G_define_flag();
+    flag.g->key = 'g';
+    flag.g->description = _("Logarithmic scaling");
+    flag.g->guisection = _("Define");
+    flag.a = G_define_flag();
+    flag.a->key = 'a';
+    flag.a->description = _("Logarithmic-absolute scaling");
+    flag.a->guisection = _("Define");
+    /* The histogram equalization is currently only available for
+     *  raster map. Therefor no flag is defined for r3.colors.
+    if (type == RASTER_TYPE) {
+        flag.e = G_define_flag();
+        flag.e->key = 'e';
+        flag.e->description = _("Histogram equalization");
+        flag.e->guisection = _("Define");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    if (flag.l->answer) {
+        list_rules();
+        return EXIT_SUCCESS;
+    overwrite = !flag.w->answer;
+    remove = flag.r->answer;
+    name = opt.map->answer;
+    style = opt.colr->answer;
+    rules = opt.rules->answer;
+    if (!name)
+        G_fatal_error(_("No %s map specified"), maptype);
+    if (opt.rast->answer && opt.volume->answer)
+        G_fatal_error(_("\raster\" and \"volume\" options are mutually exclusive"));
+    if (opt.rast->answer)
+        cmap = opt.rast->answer;
+    if (opt.volume->answer)
+        cmap = opt.volume->answer;
+    if (!cmap && !style && !rules && !remove)
+        G_fatal_error(_("One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
+    if (!!style + !!cmap + !!rules > 1)
+        G_fatal_error(_("\"color\", \"rules\", and \"raster\" options are mutually exclusive"));
+    if (flag.g->answer && flag.a->answer)
+        G_fatal_error(_("-g and -a flags are mutually exclusive"));
+    is_from_stdin = rules && strcmp(rules, "-") == 0;
+    if (is_from_stdin)
+        rules = NULL;
+    /* Switch between raster and volume */
+        mapset = G_find_grid3(name, "");
+    } else {
+        mapset = G_find_raster2(name, "");
+    if (mapset == NULL)
+        G_fatal_error(_("%s map <%s> not found"), Maptype, name);
+    int stat = -1;
+    if (remove) {
+            stat = G3d_removeColor(name);
+        } else {
+            stat = Rast_remove_colors(name, mapset);
+        if (stat < 0)
+            G_fatal_error(_("Unable to remove color table of %s map <%s>"), maptype, name);
+        if (stat == 0)
+            G_warning(_("Color table of %s map <%s> not found"), maptype, name);
+    G_suppress_warnings(1);
+        have_colors = G3d_readColors(name, mapset, &colors);
+    } else {
+        have_colors = Rast_read_colors(name, mapset, &colors);
+      if (have_colors >= 0)
+      Rast_free_colors(&colors);
+    if (have_colors > 0 && !overwrite) {
+        G_warning(_("Color table exists. Exiting."));
+    G_suppress_warnings(0);
+        fp = 1; /* g3d maps are always floating point */
+        G3d_readRange(name, mapset, &range);
+    } else {
+        fp = Rast_map_is_fp(name, mapset);
+        Rast_read_fp_range(name, mapset, &range);
+    Rast_get_fp_range_min_max(&range, &min, &max);
+    if (is_from_stdin) {
+        if (!read_color_rules(stdin, &colors, min, max, fp))
+    } else if (style) {
+         * here the predefined color-table color-styles are created by GRASS library calls.
+        if (strcmp(style, "random") == 0) {
+            if (fp)
+                G_fatal_error(_("Color table 'random' is not supported for floating point %s map"), maptype);
+            Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
+        } else if (strcmp(style, "grey.eq") == 0) {
+            if (fp)
+                G_fatal_error(_("Color table 'grey.eq' is not supported for floating point %s map"), maptype);
+            if (!have_stats)
+                have_stats = get_stats(name, mapset, &statf);
+            Rast_make_histogram_eq_colors(&colors, &statf);
+        } else if (strcmp(style, "grey.log") == 0) {
+            if (fp)
+                G_fatal_error(_("Color table 'grey.log' is not supported for floating point %s map"), maptype);
+            if (!have_stats)
+            Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
+                                           (CELL) max);
+        } else if (find_rule(style))
+            Rast_make_fp_colors(&colors, style, min, max);
+        else
+            G_fatal_error(_("Unknown color request '%s'"), style);
+    } else if (rules) {
+        if (!Rast_load_fp_colors(&colors, rules, min, max)) {
+            /* for backwards compatibility try as std name; remove for GRASS 7 */
+            /* don't bother with native dirsep as not needed for backwards compatibility */
+            sprintf(path, "%s/etc/colors/%s", G_gisbase(), rules);
+            if (!Rast_load_fp_colors(&colors, path, min, max))
+                G_fatal_error(_("Unable to load rules file <%s>"), rules);
+    } else {
+        /* use color from another map (cmap) */
+        if (opt.rast->answer) {
+            cmapset = G_find_raster2(cmap, "");
+            if (cmapset == NULL)
+                G_fatal_error(_("Raster map <%s> not found"), cmap);
+            if (Rast_read_colors(cmap, cmapset, &colors) < 0)
+                G_fatal_error(_("Unable to read color table for raster map <%s>"), cmap);
+        } else {
+            cmapset = G_find_grid3(cmap, "");
+                G_fatal_error(_("Raster3d map <%s> not found"), cmap);
+            if (G3d_readColors(cmap, cmapset, &colors) < 0)
+                G_fatal_error(_("Unable to read color table for raster3d map <%s>"), cmap);
+    if (fp)
+        Rast_mark_colors_as_fp(&colors);
+    if (flag.n->answer)
+        Rast_invert_colors(&colors);
+    /* This is not avilable for raster3d maps yet */
+        if (flag.e->answer) {
+            if (fp) {
+                struct FP_stats fpstats;
+                get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
+                Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
+            } else {
+                if (!have_stats)
+                Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
+            colors = colors_tmp;
+    if (flag.g->answer) {
+        Rast_log_colors(&colors_tmp, &colors, 100);
+    if (flag.a->answer) {
+        Rast_abs_log_colors(&colors_tmp, &colors, 100);
+    if (fp)
+        G3d_writeColors(name, mapset, &colors);
+    } else {
+        Rast_write_colors(name, mapset, &colors);
+    G_message(_("Color table for %s map <%s> set to '%s'"), maptype, name,
+              is_from_stdin ? "rules" : style ? style : rules ? rules :
+              cmap);
+    exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.colors/local_proto.h
--- grass/trunk/raster/r.colors/local_proto.h	2011-06-23 22:30:34 UTC (rev 46773)
+++ grass/trunk/raster/r.colors/local_proto.h	2011-06-24 13:17:31 UTC (rev 46774)
@@ -21,15 +21,19 @@
 #define __LOCAL_PROTO_H__
 #include <grass/gis.h>
+#include <grass/raster.h>
+#define RASTER_TYPE   1
+#define RASTER3D_TYPE 2
 /* stats.c */
 int get_stats(const char *, const char *, struct Cell_stats *);
 void get_fp_stats(const char *name, const char *mapset,
 		  struct FP_stats *statf,
 		  DCELL min, DCELL max, int geometric, int geom_abs);
-/* main.c */
-int main(int, char *[]);
+/* edit_colors.c */
+int edit_colors(int, char **, int, const char *, const char*);
 /* rules.c */
 int read_color_rules(FILE *, struct Colors *, DCELL, DCELL, int);
Deleted: grass/trunk/raster/r.colors/main.c
--- grass/trunk/raster/r.colors/main.c	2011-06-23 22:30:34 UTC (rev 46773)
+++ grass/trunk/raster/r.colors/main.c	2011-06-24 13:17:31 UTC (rev 46774)
@@ -1,462 +0,0 @@
- * MODULE:       r.colors
- * AUTHOR(S):    Michael Shapiro - CERL
- *               David Johnson
- * PURPOSE:      Allows creation and/or modification of the color table
- *               for a raster map layer.
- * COPYRIGHT:    (C) 2006-2008, 2010 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *               License (>=v2). Read the file COPYING that comes with GRASS
- *               for details.
-#include <stdlib.h>
-#include <string.h>
-#include <sys/types.h>
-#include <grass/gis.h>
-#include <grass/raster.h>
-#include <grass/glocale.h>
-#include "local_proto.h"
-#include <grass/G3d.h>
-static char **rules;
-static int nrules;
-static int cmp(const void *aa, const void *bb)
-    char *const *a = (char *const *)aa;
-    char *const *b = (char *const *)bb;
-    return strcmp(*a, *b);
-static void scan_rules(void)
-    char path[GPATH_MAX];
-    sprintf(path, "%s/etc/colors", G_gisbase());
-    rules = G__ls(path, &nrules);
-    rules = G_realloc(rules, (nrules + 3) * sizeof(const char *));
-    rules[nrules++] = G_store("random");
-    rules[nrules++] = G_store("grey.eq");
-    rules[nrules++] = G_store("grey.log");
-    qsort(rules, nrules, sizeof(char *), cmp);
-static char *rules_list(void)
-    char *list = NULL;
-    int size = 0;
-    int len = 0;
-    int i;
-    for (i = 0; i < nrules; i++) {
-	const char *name = rules[i];
-	int n = strlen(name);
-	if (size < len + n + 2) {
-	    size = len + n + 200;
-	    list = G_realloc(list, size);
-	if (len > 0)
-	    list[len++] = ',';
-	memcpy(&list[len], name, n + 1);
-	len += n;
-    return list;
-static char *rules_descriptions(void)
-    struct Key_Value *kv;
-    int result_len = 0;
-    int result_max = 2000;
-    char *result = G_malloc(result_max);
-    int i;
-    sprintf(path, "%s/etc/colors.desc", G_gisbase());
-    kv = G_read_key_value_file(path);
-    if (!kv)
-	return NULL;
-	const char *desc = G_find_key_value(name, kv);
-	int len;
-	if (!desc)
-	    desc = "no description";
-	desc = _(desc);
-	len = strlen(name) + strlen(desc) + 2;
-	if (result_len + len >= result_max) {
-	    result_max = result_len + len + 1000;
-	    result = G_realloc(result, result_max);
-	sprintf(result + result_len, "%s;%s;", name, desc);
-	result_len += len;
-    G_free_key_value(kv);
-    return result;
-static void list_rules(void)
-    int i;
-	printf("%s\n", rules[i]);
-static int find_rule(const char *name)
-    int i;
-	if (strcmp(name, rules[i]) == 0)
-	    return 1;
-    return 0;
-int main(int argc, char **argv)
-    int overwrite;
-    int is_from_stdin;
-    int remove;
-    int have_colors;
-    struct Colors colors, colors_tmp;
-    struct Cell_stats statf;
-    int have_stats = 0;
-    struct FPRange range;
-    DCELL min, max;
-    const char *name = NULL, *mapset = NULL;
-    const char *style = NULL, *cmap = NULL, *cmapset = NULL;
-    const char *rules = NULL;
-    int fp;
-    struct GModule *module;
-    struct
-	struct Flag *r, *w, *l, *g, *a,*n;
-#ifndef USE_RASTER3D
-    struct Flag *e;
-#endif
-    } flag;
-    struct
-	struct Option *map, *colr, *rast, *volume, *rules;
-    } opt;
-#ifdef USE_RASTER3D
-    const char *maptype = "raster3d";
-    const char *Maptype = "Raster3d";
-#else
-    const char *maptype = "raster";
-    const char *Maptype = "Raster";
-#endif
-    G_gisinit(argv[0]);
-    module = G_define_module();
-    G_add_keyword(_("raster3d"));
-    G_add_keyword(_("raster"));
-    G_add_keyword(_("color table"));
-    module->description =
-	_("Creates/modifies the color table associated with a raster3d map.");
-#else
-	_("Creates/modifies the color table associated with a raster map.");
-#endif
-    opt.map = G_define_standard_option(G_OPT_R3_MAP);
-#else
-    opt.map = G_define_standard_option(G_OPT_R_MAP);
-#endif
-    scan_rules();
-    opt.colr = G_define_option();
-    opt.colr->key = "color";
-    opt.colr->key_desc = "style";
-    opt.colr->type = TYPE_STRING;
-    opt.colr->required = NO;
-    opt.colr->options = rules_list();
-    opt.colr->description = _("Type of color table");
-    opt.colr->descriptions = rules_descriptions();
-    opt.colr->guisection = _("Define");
-    opt.rast = G_define_standard_option(G_OPT_R_INPUT);
-    opt.rast->key = "raster";
-    opt.rast->required = NO;
-    opt.rast->description =
-	_("Raster map from which to copy color table");
-    opt.rast->guisection = _("Define");
-    opt.volume = G_define_standard_option(G_OPT_R3_INPUT);
-    opt.volume->key = "volume";
-    opt.volume->required = NO;
-    opt.volume->description =
-	_("Raster3d map from which to copy color table");
-    opt.volume->guisection = _("Define");
-    opt.rules = G_define_standard_option(G_OPT_F_INPUT);
-    opt.rules->key = "rules";
-    opt.rules->required = NO;
-    opt.rules->label = _("Path to rules file");
-    opt.rules->description = _("\"-\" to read rules from stdin");
-    opt.rules->guisection = _("Define");
-    flag.r = G_define_flag();
-    flag.r->key = 'r';
-    flag.r->description = _("Remove existing color table");
-    flag.r->guisection = _("Remove");
-    flag.w = G_define_flag();
-    flag.w->key = 'w';
-    flag.w->description =
-	_("Only write new color table if one doesn't already exist");
-    flag.l = G_define_flag();
-    flag.l->key = 'l';
-    flag.l->description = _("List available rules then exit");
-    flag.l->suppress_required = YES;
-    flag.l->guisection = _("Print");
-    flag.n = G_define_flag();
-    flag.n->key = 'n';
-    flag.n->description = _("Invert colors");
-    flag.n->guisection = _("Define");
-    flag.g = G_define_flag();
-    flag.g->key = 'g';
-    flag.g->description = _("Logarithmic scaling");
-    flag.g->guisection = _("Define");
-    flag.a = G_define_flag();
-    flag.a->key = 'a';
-    flag.a->description = _("Logarithmic-absolute scaling");
-    flag.a->guisection = _("Define");
-    flag.e = G_define_flag();
-    flag.e->key = 'e';
-    flag.e->description = _("Histogram equalization");
-    flag.e->guisection = _("Define");
-#endif
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    if (flag.l->answer) {
-	list_rules();
-	return EXIT_SUCCESS;
-    overwrite = !flag.w->answer;
-    remove = flag.r->answer;
-    name = opt.map->answer;
-    if (!name)
-	G_fatal_error(_("No %s map specified"), maptype);
-    if(opt.rast->answer && opt.volume->answer)
-	G_fatal_error(_("\raster\" and \"volume\" options are mutually exclusive"));
-    style = opt.colr->answer;
-    if(opt.rast->answer)
-        cmap = opt.rast->answer;
-    if(opt.volume->answer)
-        cmap = opt.volume->answer;
-    rules = opt.rules->answer;
-    if (!cmap && !style && !rules && !remove)
-	G_fatal_error(_("One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be specified!"));
-    if (!!style + !!cmap + !!rules > 1)
-	G_fatal_error(_("\"color\", \"rules\", and \"raster\" options are mutually exclusive"));
-    if (flag.g->answer && flag.a->answer)
-	G_fatal_error(_("-g and -a flags are mutually exclusive"));
-    is_from_stdin = rules && strcmp(rules, "-") == 0;
-    if (is_from_stdin)
-	rules = NULL;
-    mapset = G_find_grid3(name, "");
-#else
-    mapset = G_find_raster2(name, "");
-#endif
-    if (mapset == NULL)
-	G_fatal_error(_("%s map <%s> not found"), Maptype, name);
-    if (remove) {
-	int stat = G3d_removeColor(name);
-#else
-	int stat = Rast_remove_colors(name, mapset);
-#endif
-	if (stat < 0)
-	    G_fatal_error(_("Unable to remove color table of %s map <%s>"), maptype, name);
-	if (stat == 0)
-	    G_warning(_("Color table of %s map <%s> not found"), maptype, name);
-    G_suppress_warnings(1);
-    have_colors = G3d_readColors(name, mapset, &colors);
-#else
-    have_colors = Rast_read_colors(name, mapset, &colors);
-#endif
-      if (have_colors >= 0)
-      Rast_free_colors(&colors);
-    if (have_colors > 0 && !overwrite) {
-	G_warning(_("Color table exists. Exiting."));
-    G_suppress_warnings(0);
-    fp = 1; /* g3d maps are always floating point */
-    G3d_readRange(name, mapset, &range);
-#else
-    fp = Rast_map_is_fp(name, mapset);
-    Rast_read_fp_range(name, mapset, &range);
-#endif
-    Rast_get_fp_range_min_max(&range, &min, &max);
-    if (is_from_stdin) {
-	if (!read_color_rules(stdin, &colors, min, max, fp))
-    else if (style) {
-	 * here the predefined color-table color-styles are created by GRASS library calls.
-	if (strcmp(style, "random") == 0) {
-	    if (fp)
-		G_fatal_error(_("Color table 'random' is not supported for floating point %s map"), maptype);
-	    Rast_make_random_colors(&colors, (CELL) min, (CELL) max);
-	else if (strcmp(style, "grey.eq") == 0) {
-	    if (fp)
-		G_fatal_error(_("Color table 'grey.eq' is not supported for floating point %s map"), maptype);
-	    if (!have_stats)
-		have_stats = get_stats(name, mapset, &statf);
-	    Rast_make_histogram_eq_colors(&colors, &statf);
-	else if (strcmp(style, "grey.log") == 0) {
-	    if (fp)
-		G_fatal_error(_("Color table 'grey.log' is not supported for floating point %s map"), maptype);
-	    if (!have_stats)
-	    Rast_make_histogram_log_colors(&colors, &statf, (CELL) min,
-					(CELL) max);
-	else if (find_rule(style))
-	    Rast_make_fp_colors(&colors, style, min, max);
-	else
-	    G_fatal_error(_("Unknown color request '%s'"), style);
-    else if (rules) {
-	if (!Rast_load_fp_colors(&colors, rules, min, max)) {
-	    /* for backwards compatibility try as std name; remove for GRASS 7 */
-	    /* don't bother with native dirsep as not needed for backwards compatibility */
-	    sprintf(path, "%s/etc/colors/%s", G_gisbase(), rules);
-	    if (!Rast_load_fp_colors(&colors, path, min, max))
-		G_fatal_error(_("Unable to load rules file <%s>"), rules);
-    else {
-	/* use color from another map (cmap) */
-        if(opt.rast->answer) {
-            cmapset = G_find_raster2(cmap, "");
-            if (cmapset == NULL)
-                G_fatal_error(_("Raster map <%s> not found"), cmap);
-            if (Rast_read_colors(cmap, cmapset, &colors) < 0)
-                G_fatal_error(_("Unable to read color table for raster map <%s>"), cmap);
-        } else {
-            cmapset = G_find_grid3(cmap, "");
-                G_fatal_error(_("Raster3d map <%s> not found"), cmap);
-            if (G3d_readColors(cmap, cmapset, &colors) < 0)
-                G_fatal_error(_("Unable to read color table for raster3d map <%s>"), cmap);
-    if (fp)
-	Rast_mark_colors_as_fp(&colors);
-    if (flag.n->answer)
-	Rast_invert_colors(&colors);
-    /* This is not avilable for raster3d maps yet */
-    if (flag.e->answer) {
-	if (fp) {
-	    struct FP_stats fpstats;
-	    get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer, flag.a->answer);
-	    Rast_histogram_eq_fp_colors(&colors_tmp, &colors, &fpstats);
-	else {
-	    if (!have_stats)
-	    Rast_histogram_eq_colors(&colors_tmp, &colors, &statf);
-	colors = colors_tmp;
-#endif
-    if (flag.g->answer) {
-	Rast_log_colors(&colors_tmp, &colors, 100);
-    if (flag.a->answer) {
-	Rast_abs_log_colors(&colors_tmp, &colors, 100);
-    if (fp)
-    G3d_writeColors(name, mapset, &colors);
-#else
-    Rast_write_colors(name, mapset, &colors);
-#endif
-    G_message(_("Color table for %s map <%s> set to '%s'"), maptype, name,
-	      is_from_stdin ? "rules" : style ? style : rules ? rules :
-	      cmap);
-    exit(EXIT_SUCCESS);
Modified: grass/trunk/raster/r.colors/r.colors.html
--- grass/trunk/raster/r.colors/r.colors.html	2011-06-23 22:30:34 UTC (rev 46773)
+++ grass/trunk/raster/r.colors/r.colors.html	2011-06-24 13:17:31 UTC (rev 46774)
@@ -9,6 +9,10 @@
 to copy the color map.
 <p>
+The <b>volume</b> option allows user to specify a volume (3d raster) map
+<i>name</i> from which to copy the color map.
+<p>
 All color tables are stored in $GISBASE/etc/colors/. Further user-defined color tables
 can also be stored in this directory for access from the <em>color</em> parameter.
 <p>
Added: grass/trunk/raster/r.colors/r3.colors.html
--- grass/trunk/raster/r.colors/r3.colors.html	                        (rev 0)
+++ grass/trunk/raster/r.colors/r3.colors.html	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,17 @@
+<h2>DESCRIPTION</h2>
+<i>r3.colors</i> has exactly the same functionality as <i>r.colors</i> but for volume maps.
+With the exception that the <b>-e</b> flag, which equalizes the original raster's color table,
+only works for raster maps. Please refer to <a href="r.colors.html">r.colors</a>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.colors.html">r.colors</a>
+</em>
+<h2>AUTHORS</h2>
+Michael Shapiro and David Johnson
+<p>
+<i>Last changed: $Date: 2011-01-03 14:54:24 +0100 (Mo, 03. Jan 2011) $</i>
Added: grass/trunk/raster/r.colors/raster3d_main.c
--- grass/trunk/raster/r.colors/raster3d_main.c	                        (rev 0)
+++ grass/trunk/raster/r.colors/raster3d_main.c	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,26 @@
+ * MODULE:       r3.colors
+ *               David Johnson
+ * COPYRIGHT:    (C) 2006 by the GRASS Development Team
+ *               for details.
+/* This is the main function for r3.colors*/
+int main(int argc, char **argv)
+    return edit_colors(argc, argv, RASTER3D_TYPE, "raster3d", "Raster3d");
\ No newline at end of file
Added: grass/trunk/raster/r.colors/raster_main.c
--- grass/trunk/raster/r.colors/raster_main.c	                        (rev 0)
+++ grass/trunk/raster/r.colors/raster_main.c	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,26 @@
+ *               David Johnson
+ *               for details.
+    return edit_colors(argc, argv, RASTER_TYPE, "raster", "Raster");
Modified: grass/trunk/raster/r.colors/test.r.colors.sh
--- grass/trunk/raster/r.colors/test.r.colors.sh	2011-06-23 22:30:34 UTC (rev 46773)
+++ grass/trunk/raster/r.colors/test.r.colors.sh	2011-06-24 13:17:31 UTC (rev 46774)
@@ -1,5 +1,5 @@
 # This script tests r.colors and r.colors.out as well
-# as r3.colors and r3.colors.out
+# as r3.colors and r3.colors.out which have the same code base
 # Color rules are set with r/r3.colors and exported using r/r3.colors.out
 # We specific a small region in the
@@ -49,6 +49,7 @@
 r.colors -a map=test_elev_double rules=example3 && r.colors.out --o map=test_elev_double rules=test_elev_double_example3_logabs.txt
 r.colors    map=test_elev_double rules=example4 && r.colors.out --o map=test_elev_double rules=test_elev_double_example4.txt
 r.colors -n map=test_elev_double rast=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_example4_inv.txt
 # The volume maps using r3.colors and r3.colors.out
 r3.colors    map=volume_double_null rules=example1 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example1.txt
 r3.colors    map=volume_double_null rules=example2 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example2.txt
@@ -57,4 +58,10 @@
 r3.colors -a map=volume_double_null rules=example3 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example3_logabs.txt
 r3.colors    map=volume_double_null rules=example4 && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4.txt
 r3.colors -n map=volume_double_null volume=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_example4_inv.txt
+# Apply a raster color table to the volume map
 r3.colors    map=volume_double_null raster=test_elev_double   && r3.colors.out --o map=volume_double_null rules=test_volume_double_example5.txt
+# Test the removement the raster3d color table, a default color table will be created
+r3.colors -r map=volume_double_null && r3.colors.out --o map=volume_double_null rules=test_volume_double_default.txt
+# Test the removement the raster color table, a default color table will be created
+r.colors -r map=test_elev_double && r.colors.out --o map=test_elev_double rules=test_elev_double_default.txt
Added: grass/trunk/raster/r.colors/test_elev_double_default.ref
--- grass/trunk/raster/r.colors/test_elev_double_default.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/test_elev_double_default.ref	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,8 @@
+1.5 255:255:0
+3.1 0:255:0
+4.7 0:255:255
+6.3 0:0:255
+7.9 255:0:255
+9.5 255:0:0
+nv 255:255:255
+default 255:255:255
Added: grass/trunk/raster/r.colors/test_volume_double_default.ref
--- grass/trunk/raster/r.colors/test_volume_double_default.ref	                        (rev 0)
+++ grass/trunk/raster/r.colors/test_volume_double_default.ref	2011-06-24 13:17:31 UTC (rev 46774)
@@ -0,0 +1,8 @@
+4 255:255:0
+8 0:255:0
+12 0:255:255
+16 0:0:255
+20 255:0:255
+24 255:0:0
+nv 255:255:255
