[GRASS-SVN] r46778 - in grass/trunk: include lib/ogsf visualization/nviz2/cmd
Sat Jun 25 17:32:43 EDT 2011
Author: martinl
Date: 2011-06-25 14:32:43 -0700 (Sat, 25 Jun 2011)
New Revision: 46778
   grass/trunk/include/gstypes.h
   grass/trunk/include/nviz.h
   grass/trunk/include/ogsf_proto.h
   grass/trunk/lib/ogsf/GP2.c
   grass/trunk/lib/ogsf/Gp3.c
   grass/trunk/lib/ogsf/gp.c
   grass/trunk/lib/ogsf/gpd.c
   grass/trunk/visualization/nviz2/cmd/Makefile
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/local_proto.h
   grass/trunk/visualization/nviz2/cmd/main.c
   grass/trunk/visualization/nviz2/cmd/vector.c
wxNviz: ogsflib - initial support for thematic mapping (points-color)
	nviz_cmd - add parameters for thematic mapping (points)
Modified: grass/trunk/include/gstypes.h
--- grass/trunk/include/gstypes.h	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/include/gstypes.h	2011-06-25 21:32:43 UTC (rev 46778)
@@ -1,8 +1,18 @@
-/*  gstypes.h
-   Bill Brown, USACERL
-   January 1993
+  \file include/gstypes.c
+  \brief OGSF header file (structures)
+  This program is free software under the GNU General
+  Public License (>=v2). Read the file COPYING that
+  comes with GRASS for details.
+  \author Original author Bill Brown, USACERL (January 1993)
+  \author Thematic mapping enabled by Martin Landa <landa.martin gmail.com) (06/2011)
+  (C) 2011 by the GRASS Development Team
 #ifndef _GSTYPES_H
 #define _GSTYPES_H
@@ -78,6 +88,10 @@
 #define OGSF_LINE  2
 #define OGSF_POLYGON 3
+#define RED_MASK 0x000000FF
+#define GRN_MASK 0x0000FF00
+#define BLU_MASK 0x00FF0000
 typedef float Point4[4];
 typedef float Point3[3];
 typedef float Point2[2];
@@ -166,17 +180,30 @@
 /* Struct for vector feature displaying attributes */
 typedef struct g_vect_style
-    int color; 		/* Line color */
-    int symbol;		/* Point symbol/line type */
-    float size;		/* Symbol size. Unset for lines. */
-    int width;		/* Line width. Also used for lines forming symbols i.e. X */
+    int color; 		 /* Line color */
+    int symbol;		 /* Point symbol/line type */
+    float size;		 /* Symbol size. Unset for lines. */
+    int width;		 /* Line width. Also used for lines forming symbols i.e. X */
     /*TODO:fill;	 Area fill pattern */
     /*TODO:falpha;	 Area fill transparency */
     /*TODO:lalpha;	 Line/boundary/point transparency */
     /*TODO:struct *orientation;  Symbol orientation */
-    struct g_vect_style *next; /* Point to next gvstyle struct if single point has multiple styles. In such case feature with next style should be shifted.  */
+    struct g_vect_style *next; /* Point to next gvstyle struct if single point has multiple styles.
+				  In such case feature with next style should be shifted. */
 } gvstyle;
+/* Struct for vector map (thematic mapping) */
+typedef struct g_vect_style_thematic
+    int layer;
+    char *color_column;
+    char *symbol_column;
+    char *size_column;
+    char *width_column;
+} gvstyle_thematic;
 /* Line instance */
 typedef struct g_line
@@ -193,7 +220,7 @@
     struct g_line *next;
 } geoline;
-/* Vector line layer */
+/* Vector map (lines) */
     int gvect_id;
@@ -211,8 +238,8 @@
     void *clientdata;
     int thematic_layer;		/* Layer number to use for thematic mapping. <0 == no thematic mapping;
-				    0 == thematic mapping is unset but initialized;
-				    >0 use specified layer */
+				   0 == thematic mapping is unset but initialized;
+				   >0 use specified layer */
     gvstyle *style;	/* Vector default look&feel */
     gvstyle *hstyle;	/* IMHO highlight should be per layer basis. */
 } geovect;
@@ -225,12 +252,12 @@
     struct line_cats *cats;	/* Store information about all layers/cats for thematic display */
     gvstyle *style;
-    signed char highlighted; /* >0 Feature is highlighted */
+    signed char highlighted;    /* >0 Feature is highlighted */
     struct g_point *next;
 } geopoint;
-/* Point layer */
+/* Vector map (points) */
 typedef struct g_site
     int gsite_id;
@@ -247,9 +274,9 @@
     struct g_site *next;
     void *clientdata;
-    int thematic_layer; /* Layer number to use for thematic mapping. */
-    gvstyle *style; 	/* Vector default look&feel */
-    gvstyle *hstyle;	/* IMHO highlight should be per layer basis. */
+    gvstyle_thematic *tstyle;  /* thematic mapping */
+    gvstyle *style; 	       /* points default look&feel */
+    gvstyle *hstyle;	       /* IMHO highlight should be per layer basis */
 } geosite;
 typedef struct
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/include/nviz.h	2011-06-25 21:32:43 UTC (rev 46778)
@@ -59,10 +59,6 @@
 #define DEFAULT_SURF_COLOR 0x33BBFF
-#define RED_MASK 0x000000FF
-#define GRN_MASK 0x0000FF00
-#define BLU_MASK 0x00FF0000
 #define FORMAT_PPM 1
 #define FORMAT_TIF 2
Modified: grass/trunk/include/ogsf_proto.h
--- grass/trunk/include/ogsf_proto.h	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/include/ogsf_proto.h	2011-06-25 21:32:43 UTC (rev 46778)
@@ -33,7 +33,7 @@
 /*========================== Function Prototypes ===========================*/
-/* From GK2.c */
+/* GK2.c */
 int GK_set_interpmode(int);
 void GK_set_tension(float);
 void GK_showtension_start(void);
@@ -53,7 +53,7 @@
 void GK_show_vol(int);
 void GK_show_list(int);
-/* From GP2.c */
+/* GP2.c */
 int GP_site_exists(int);
 int GP_new_site(void);
 int GP_num_sites(void);
@@ -63,6 +63,7 @@
 int GP_get_sitename(int, char **);
 int GP_get_style(int, int *, int *, float *, int *);
 int GP_set_style(int, int, int, float, int);
+int GP_set_style_thematic(int, int, const char *, const char *, const char *, const char *);
 int GP_attmode_color(int, const char *);
 int GP_attmode_none(int);
 int GP_set_zmode(int, int);
@@ -77,7 +78,7 @@
 int GP_Set_ClientData(int, void *);
 void *GP_Get_ClientData(int);
-/* From GS2.c */
+/* GS2.c */
 void void_func(void);
 void GS_libinit(void);
 int GS_get_longdim(float *);
@@ -202,13 +203,13 @@
 void GS_getlight_color(int, float *, float *, float *);
 void GS_getlight_ambient(int, float *, float *, float *);
-/* From GSX.c */
+/* GSX.c */
 int GS_check_cancel(void);
 void GS_set_cancel(int);
 void GS_set_cxl_func(void (*)(void));
 void GS_set_swap_func(void (*)(void));
-/* From GS_util.c */
+/* GS_util.c */
 double GS_geodistance(double *, double *, const char *);
 float GS_distance(float *, float *);
 float GS_P2distance(float *, float *);
@@ -226,7 +227,7 @@
 void GS_v3mag(float *, float *);
 int GS_coordpair_repeats(float *, float *, int);
-/* From GV2.c */
+/* GV2.c */
 int GV_vect_exists(int);
 int GV_new_vector(void);
 int GV_num_vects(void);
@@ -248,7 +249,7 @@
 int GV_Set_ClientData(int, void *);
 void *GV_Get_ClientData(int);
-/* From GVL2.c */
+/* GVL2.c */
 void GVL_libinit(void);
 int GVL_get_region(float *, float *, float *, float *, float *, float *);
 void *GVL_get_window();
@@ -304,11 +305,12 @@
 int GVL_slice_set_pos(int, int, float, float, float, float, float, float,
 		      int);
-/* From Gp3.c */
+/* Gp3.c */
 int Gp_set_color(const char *, geopoint *);
 geopoint *Gp_load_sites(const char *, int *, int *);
+int Gp_load_sites_thematic(geosite *);
-/* From Gs3.c */
+/* Gs3.c */
 double Gs_distance(double *, double *);
 int Gs_loadmap_as_float(struct Cell_head *, const char *, float *,
 			struct BM *, int *);
@@ -330,11 +332,11 @@
 		   geosurf *);
 int Gs_update_attrange(geosurf *, int);
-/* From Gv3.c */
+/* Gv3.c */
 geoline *Gv_load_vect(const char *, int *);
 void sub_Vectmem(int);
-/* From gk.c */
+/* gk.c */
 Keylist *gk_copy_key(Keylist *);
 unsigned long gk_get_mask_sofar(float, Keylist *);
 int gk_viable_keys_for_mask(unsigned long, Keylist *, Keylist **);
@@ -352,7 +354,7 @@
 void correct_twist(Keylist *);
 int gk_draw_path(Viewnode *, int, Keylist *);
-/* From gp.c */
+/* gp.c */
 geosite *gp_get_site(int);
 geosite *gp_get_prev_site(int);
 int gp_num_sites(void);
@@ -367,13 +369,13 @@
 void gp_free_sitemem(geosite *);
 void gp_set_drapesurfs(geosite *, int *, int);
-/* From gpd.c */
+/* gpd.c */
 int gs_point_in_region(geosurf *, float *, float *);
 void gpd_obj(geosurf *, gvstyle *, Point3);
 int gpd_2dsite(geosite *, geosurf *, int);
 int gpd_3dsite(geosite *, float, float, int);
-/* From gs.c */
+/* gs.c */
 void gs_err(const char *);
 void gs_init(void);
 geosurf *gs_get_surf(int);
@@ -420,7 +422,7 @@
 int gs_point_is_masked(geosurf *, float *);
 int gs_distance_onsurf(geosurf *, float *, float *, float *, int);
-/* From gs_bm.c */
+/* gs_bm.c */
 struct BM *gsbm_make_mask(typbuff *, float, int, int);
 void gsbm_zero_mask(struct BM *);
 int gsbm_or_masks(struct BM *, struct BM *);
@@ -430,12 +432,12 @@
 int gs_update_curmask(geosurf *);
 void print_bm(struct BM *);
-/* From gs_norms.c */
+/* gs_norms.c */
 void init_vars(geosurf *);
 int gs_calc_normals(geosurf *);
 int calc_norm(geosurf *, int, int, unsigned int);
-/* From gs_query.c */
+/* gs_query.c */
 int gs_los_intersect1(int, float (*)[3], float *);
 int gs_los_intersect(int, float **, float *);
 int RayCvxPolyhedronInt(Point3, Point3, double, Point4 *, int, double *,
@@ -443,7 +445,7 @@
 void gs_get_databounds_planes(Point4 *);
 int gs_setlos_enterdata(Point3 *);
-/* From gsd_cplane.c */
+/* gsd_cplane.c */
 void gsd_def_cplane(int, float *, float *);
 void gsd_update_cplanes(void);
 void gsd_cplane_on(int);
@@ -456,7 +458,7 @@
 void gsd_draw_cplane_fence(geosurf *, geosurf *, int);
 void gsd_draw_cplane(int);
-/* From gsd_fonts.c */
+/* gsd_fonts.c */
 GLuint gsd_set_font(const char *);
 int gsd_get_txtwidth(const char *, int);
 int gsd_get_txtheight(int size);
@@ -464,22 +466,22 @@
 int get_txtdescender(void);
 int get_txtxoffset(void);
-/* From gsd_img_ppm.c */
+/* gsd_img_ppm.c */
 int GS_write_ppm(const char *);
 int gsd_init_mpeg(const char *);
 int gsd_write_mpegframe(void);
 int gsd_close_mpeg(void);
-/* From gsd_img_tif.c */
+/* gsd_img_tif.c */
 int GS_write_tif(const char *);
-/* From gsd_label.c */
+/* gsd_label.c */
 void gs_put_label(const char *, GLuint, int, unsigned long, int *);
 void gsd_remove_curr(void);
 void gsd_remove_all(void);
 void gsd_call_label(void);
-/* From gsd_objs.c */
+/* gsd_objs.c */
 void gsd_box(float *, int, float *);
 void gsd_plus(float *, int, float);
 void gsd_line_onsurf(geosurf *, float *, float *);
@@ -502,7 +504,7 @@
 void primitive_cone(unsigned long);
 void primitive_cylinder(unsigned long, int);
-/* From gsd_prim.c */
+/* gsd_prim.c */
 void gsd_flush(void);
 void gsd_colormode(int);
 void show_colormode(void);
@@ -561,7 +563,7 @@
 void gsd_getwindow(int *, int *, double *, double *);
 int gsd_writeView(unsigned char **, unsigned int, unsigned int);
-/* From gsd_surf.c */
+/* gsd_surf.c */
 int gsd_surf(geosurf *);
 int gsd_surf_map(geosurf *);
 int gsd_surf_const(geosurf *, float);
@@ -574,7 +576,7 @@
 int gsd_wall(float *, float *, float *);
 int gsd_norm_arrows(geosurf *);
-/* From gsd_views.c */
+/* gsd_views.c */
 int gsd_get_los(float (*)[3], short, short);
 void gsd_set_view(geoview *, geodisplay *);
 void gsd_check_focus(geoview *);
@@ -587,7 +589,7 @@
 void gsd_surf2real(geosurf *, Point3);
 void gsd_real2surf(geosurf *, Point3);
-/* From gsd_wire.c */
+/* gsd_wire.c */
 int gsd_wire_surf(geosurf *);
 int gsd_wire_surf_map(geosurf *);
 int gsd_coarse_surf_map(geosurf *);
@@ -595,14 +597,14 @@
 int gsd_wire_surf_func(geosurf *, int (*)());
 int gsd_wire_arrows(geosurf *);
-/* From gsdiff.c */
+/* gsdiff.c */
 void gsdiff_set_SDscale(float);
 float gsdiff_get_SDscale(void);
 void gsdiff_set_SDref(geosurf *);
 geosurf *gsdiff_get_SDref(void);
 float gsdiff_do_SD(float, int);
-/* From gsdrape.c */
+/* gsdrape.c */
 int gsdrape_set_surface(geosurf *);
 int seg_intersect_vregion(geosurf *, float *, float *);
 Point3 *gsdrape_get_segments(geosurf *, float *, float *, int *);
@@ -622,7 +624,7 @@
 int P3toPlane(Point3, Point3, Point3, float *);
 int V3Cross(Point3, Point3, Point3);
-/* From gsds.c */
+/* gsds.c */
 int gsds_findh(const char *, IFLAG *, IFLAG *, int);
 int gsds_newh(const char *);
 typbuff *gsds_get_typbuff(int, IFLAG);
@@ -635,10 +637,10 @@
 int gsds_set_changed(int, IFLAG);
 int gsds_get_type(int);
-/* From gsget.c */
+/* gsget.c */
 int get_mapatt(typbuff *, int, float *);
-/* From gv.c */
+/* gv.c */
 geovect *gv_get_vect(int);
 geovect *gv_get_prev_vect(int);
 int gv_num_vects(void);
@@ -652,18 +654,18 @@
 void gv_free_vectmem(geovect *);
 void gv_set_drapesurfs(geovect *, int *, int);
-/* From gv_quick.c */
+/* gv_quick.c */
 float gv_line_length(geoline *);
 int gln_num_points(geoline *);
 int gv_num_points(geovect *);
 int gv_decimate_lines(geovect *);
-/* From gvd.c */
+/* gvd.c */
 int gs_clip_segment(geosurf *, float *, float *, float *);
 int gvd_vect(geovect *, geosurf *, int);
 void gvd_draw_lineonsurf(geosurf *, float *, float *, int);
-/* From gvl.c */
+/* gvl.c */
 geovol *gvl_get_vol(int);
 geovol *gvl_get_prev_vol(int);
 int gvl_getall_vols(geovol **);
@@ -696,14 +698,14 @@
 geovol_slice *gvl_slice_get_slice(int, int);
 int gvl_slice_freemem(geovol_slice *);
-/* From trans.c */
+/* trans.c */
 void P_scale(float, float, float);
 void P_transform(int, float (*)[4], float (*)[4]);
 int P_pushmatrix(void);
 int P_popmatrix(void);
 void P_rot(float, char);
-/* From gvl_file.c */
+/* gvl_file.c */
 geovol_file *gvl_file_get_volfile(int);
 char *gvl_file_get_name(int);
 int gvl_file_get_file_type(geovol_file *);
@@ -718,19 +720,19 @@
 int gvl_file_set_slices_param(geovol_file *, int, int);
 void gvl_file_get_min_max(geovol_file *, double *, double *);
-/* From Gvl3.c */
+/* Gvl3.c */
 int Gvl_load_colors_data(void **, const char *);
 int Gvl_unload_colors_data(void *);
 int Gvl_get_color_for_value(void *, float *);
-/* From gvl_calc.c */
+/* gvl_calc.c */
 int gvl_isosurf_calc(geovol *);
 int gvl_slices_calc(geovol *);
 void gvl_write_char(int, unsigned char **, unsigned char);
 unsigned char gvl_read_char(int, const unsigned char *);
 void gvl_align_data(int, unsigned char *);
-/* From gvld.c */
+/* gvld.c */
 int gvld_vol(geovol *);
 int gvld_wire_vol(geovol *);
 int gvld_isosurf(geovol *);
Modified: grass/trunk/lib/ogsf/GP2.c
--- grass/trunk/lib/ogsf/GP2.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/lib/ogsf/GP2.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -3,15 +3,11 @@
    \brief OGSF library - loading and manipulating point sets (higher level functions)
-   GRASS OpenGL gsurf OGSF Library
+   (C) 1999-2008, 2011 by the GRASS Development Team
-   (C) 1999-2008 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2). Read the file COPYING that comes with GRASS for details.
-   This program is free software under the
-   GNU General Public License (>=v2).
-   Read the file COPYING that comes with GRASS
-   for details.
    \author Bill Brown USACERL (January 1994)
    \author Doxygenized by Martin landa <landa.martin gmail.com> (May 2008)
@@ -42,7 +38,7 @@
     G_debug(4, "GP_site_exists(%d)", id);
     if (NULL == gp_get_site(id)) {
-	return (0);
+	return 0;
     for (i = 0; i < Next_site && !found; i++) {
@@ -53,7 +49,7 @@
     G_debug(3, "GP_site_exists(): found=%d", found);
-    return (found);
+    return found;
@@ -74,10 +70,10 @@
 	G_debug(3, "GP_new_site() id=%d", np->gsite_id);
-	return (np->gsite_id);
+	return np->gsite_id;
-    return (-1);
+    return -1;
@@ -87,7 +83,7 @@
-    return (gp_num_sites());
+    return gp_num_sites();
@@ -109,17 +105,17 @@
     if (Next_site) {
 	ret = (int *)G_malloc(Next_site * sizeof(int));	/* G_fatal_error */
 	if (!ret) {
-	    return (NULL);
+	    return NULL;
 	for (i = 0; i < Next_site; i++) {
 	    ret[i] = Site_ID[i];
-	return (ret);
+	return ret;
-    return (NULL);
+    return NULL;
@@ -150,21 +146,20 @@
 	if (found) {
 	    --Next_site;
-	    return (1);
+	    return 1;
-    return (-1);
+    return -1;
    \brief Load point set from file
-   Check to see if handle already loaded, if so - free before loading new
-   for now, always load to memory
+   Check to see if handle already loaded, if so - free before loading
+   new for now, always load to memory.
-   \todo load file handle & ready for reading instead of using
-   memory
+   \todo load file handle & ready for reading instead of using memory
    \param id point set id
    \param filename point set filename
@@ -176,10 +171,10 @@
     geosite *gp;
-    G_debug(3, "GP_load_site(%d, %s)", id, filename);
+    G_debug(3, "GP_load_site(id=%d, name=%s)", id, filename);
     if (NULL == (gp = gp_get_site(id))) {
-	return (-1);
+	return -1;
     if (gp->points) {
@@ -189,12 +184,12 @@
     gp->filename = G_store(filename);
     gp->points = Gp_load_sites(filename, &(gp->n_sites), &(gp->has_z));
     if (gp->points) {
-	return (1);
+	return 1;
-    return (-1);
+    return -1;
@@ -215,12 +210,12 @@
     G_debug(4, "GP_get_sitename(%d)", id);
-	return (-1);
+	return -1;
     *filename = G_store(gp->filename);
-    return (1);
+    return 1;
@@ -237,7 +232,7 @@
     G_debug(4, "GP_get_style(%d)", id);
-	return (-1);
+	return -1;
     *color = gp->style->color;
@@ -245,7 +240,7 @@
     *symbol = gp->style->symbol;
     *size = gp->style->size;
-    return (1);
+    return 1;
@@ -257,17 +252,18 @@
    \param size icon size
    \param symbol icon symbol
+   \return 1 on success
    \return -1 on error (point set not found)
 int GP_set_style(int id, int color, int width, float size, int symbol)
     geosite *gp;
-    G_debug(4, "GP_set_style(%d, %d, %d, %f, %d)", id, color, width, size,
+    G_debug(4, "GP_set_style(id=%d, color=%d, width=%d, size=%f, symbol=%d)", id, color, width, size,
 	    symbol);
-	return (-1);
+	return -1;
     gp->style->color = color;
@@ -275,10 +271,50 @@
     gp->style->size = size;
     gp->style->width = width;
-    return (1);
+    return 1;
+   \brief Set point set style for thematic mapping
+   Updates also style for each geopoint.
+   \param id point set id
+   \param layer layer number for thematic mapping
+   \param color icon color
+   \param width icon line width
+   \param size icon size
+   \param symbol icon symbol
+   \return -1 on error (point set not found)
+int GP_set_style_thematic(int id, int layer, const char* color, const char* width, const char* size, const char* symbol)
+    geosite *gp;
+    G_debug(4, "GP_set_style_thematic(id=%d, layer=%d, color=%s, width=%s, size=%s, symbol=%s)", id, layer,
+	    color, width, size, symbol);
+    if (NULL == (gp = gp_get_site(id))) {
+	return -1;
+    if(!gp->tstyle)
+	gp->tstyle = (gvstyle_thematic *)G_malloc(sizeof(gvstyle_thematic));
+    gp->tstyle->layer = layer;
+    gp->tstyle->color_column = G_store(color);
+    gp->tstyle->symbol_column = G_store(symbol);
+    gp->tstyle->size_column = G_store(size);
+    gp->tstyle->width_column = G_store(width);
+    Gp_load_sites_thematic(gp);
+    return 1;
    \brief Set z-mode
    \param id poin set id
@@ -296,20 +332,20 @@
     G_debug(3, "GP_set_zmode(%d,%d)", id, use_z);
-	return (-1);
+	return -1;
     if (use_z) {
 	if (gp->has_z) {
 	    gp->use_z = 1;
-	    return (1);
+	    return 1;
-	return (0);
+	return 0;
     gp->use_z = 0;
-    return (1);
+    return 1;
@@ -329,11 +365,11 @@
     G_debug(4, "GP_get_zmode(%d)", id);
-	return (-1);
+	return -1;
     *use_z = gp->use_z;
-    return (1);
+    return 1;
@@ -407,10 +443,10 @@
     if (gp && GS_surf_exists(hs)) {
 	gp->drape_surf_id[gp->n_surfs] = hs;
 	gp->n_surfs += 1;
-	return (1);
+	return 1;
-    return (-1);
+    return -1;
@@ -430,7 +466,7 @@
     G_debug(3, "GP_unselect_surf(%d,%d)", hp, hs);
     if (!GP_surf_is_selected(hp, hs)) {
-	return (1);
+	return 1;
     gp = gp_get_site(hp);
@@ -443,12 +479,12 @@
 		gp->n_surfs -= 1;
-		return (1);
+		return 1;
-    return (-1);
+    return -1;
@@ -472,12 +508,12 @@
     if (gp) {
 	for (i = 0; i < gp->n_surfs; i++) {
 	    if (hs == gp->drape_surf_id[i]) {
-		return (1);
+		return 1;
-    return (0);
+    return 0;
@@ -547,10 +583,10 @@
     if (gp) {
 	gp->clientdata = clientd;
-	return (1);
+	return 1;
-    return (-1);
+    return -1;
@@ -570,5 +606,5 @@
 	return (gp->clientdata);
-    return (NULL);
+    return NULL;
Modified: grass/trunk/lib/ogsf/Gp3.c
--- grass/trunk/lib/ogsf/Gp3.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/lib/ogsf/Gp3.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -19,9 +19,10 @@
 #include <stdlib.h>
 #include <grass/gis.h>
+#include <grass/colors.h>
 #include <grass/raster.h>
-#include <grass/site.h>
 #include <grass/vector.h>
+#include <grass/dbmi.h>
 #include <grass/glocale.h>
 #include <grass/gstypes.h>
@@ -30,14 +31,14 @@
    The other alternative may be to load to a tmp file.
-   \param grassname vector point map
-   \param nsites
-   \param has_z 2D or 3D points?
+   \param name name of vector map to be loaded
+   \param[out] nsites number of loaded points
+   \param[out] has_z 2D or 3D points data loaded?
-   \return pointer to geopoint struct
+   \return pointer to geopoint struct (array)
    \return NULL on failure
-geopoint *Gp_load_sites(const char *grassname, int *nsites, int *has_z)
+geopoint *Gp_load_sites(const char *name, int *nsites, int *has_z)
     struct Map_info map;
     static struct line_pnts *Points = NULL;
@@ -45,52 +46,50 @@
     geopoint *top, *gpt, *prev;
     int np, ltype, eof;
     struct Cell_head wind;
-    RASTER_MAP_TYPE rtype;
     int ndim;
     const char *mapset;
     np = 0;
     eof = 0;
-    *has_z = 0;
-    mapset = G_find_vector2(grassname, "");
+    mapset = G_find_vector2(name, "");
     if (!mapset) {
-	G_warning(_("Vector map <%s> not found"), grassname);
+	G_warning(_("Vector map <%s> not found"), name);
 	return NULL;
-    Vect_set_open_level(2);
-    if (Vect_open_old(&map, grassname, "") == -1) {
+    Vect_set_open_level(1);
+    if (Vect_open_old(&map, name, "") == -1) {
 	G_fatal_error(_("Unable to open vector map <%s>"),
-		      G_fully_qualified_name(grassname, mapset));
+		      G_fully_qualified_name(name, mapset));
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     top = gpt = (geopoint *) G_malloc(sizeof(geopoint));
+    G_zero(gpt, sizeof(geopoint));
     if (!top) {
-	return (NULL);
+	return NULL;
     G_get_set_window(&wind);
     /* get ndim */
+    *has_z = 0;
     ndim = 2;
     if (Vect_is_3d(&map)) {
+	*has_z = 1;
 	ndim = 3;
-    /* set rtype */
-    rtype = CELL_TYPE;
     while (eof == 0) {
 	ltype = Vect_read_next_line(&map, Points, Cats);
 	switch (ltype) {
 	case -1:
 		G_warning(_("Unable to read vector map <%s>"),
 		return (NULL);
 	case -2:		/* EOF */
@@ -105,13 +104,11 @@
 	    gpt->p3[Y] = Points->y[0];
 	    if (ndim > 2) {
-		*has_z = 1;
 		gpt->dims = 3;
 		gpt->p3[Z] = Points->z[0];
 	    else {
 		gpt->dims = 2;
-		*has_z = 0;
 	    /* Store category info for thematic display */
@@ -120,18 +117,16 @@
 	    else {
-		gpt->cats = NULL;
 		Vect_reset_cats(Cats);
-	    gpt->highlighted = 0;
-	    G_debug(3, "loading vector point %d %f %f -- %d",
+	    G_debug(5, "loading vector point %d x=%f y=%f ncats=%d",
 		    np, Points->x[0], Points->y[0], Cats->n_cats);
 	    gpt->next = (geopoint *) G_malloc(sizeof(geopoint));	/* G_fatal_error */
+	    G_zero(gpt->next, sizeof(geopoint));
 	    if (!gpt->next) {
-		return (NULL);
+		return NULL;
 	    prev = gpt;
@@ -148,15 +143,102 @@
     if (!np) {
 	G_warning(_("No points from vector map <%s> fall within current region"),
 	return (NULL);
     else {
 	G_message(_("Vector map <%s> loaded (%d points)"),
-		  G_fully_qualified_name(grassname, mapset), np);
+		  G_fully_qualified_name(name, mapset), np);
     *nsites = np;
-    return (top);
+    return top;
+  \brief Load styles for geopoints based on thematic mapping
+  \todo Currently only supports color settings
+  \param gp pointer to geosite structure
+  \return number of points defined by thematic mapping
+int Gp_load_sites_thematic(geosite *gp)
+    geopoint *gpt;
+    struct Map_info Map;
+    struct field_info *Fi;
+    int nvals, cat, npts;
+    int red, blu, grn;
+    const char *str;
+    const char *mapset;
+    dbDriver *driver;
+    dbValue value;
+    if(!gp || !gp->tstyle || !gp->filename)
+	return -1;
+    mapset = G_find_vector2(gp->filename, "");
+    if (!mapset) {
+	G_fatal_error(_("Vector map <%s> not found"), gp->filename);
+    if (Vect_open_old(&Map, gp->filename, "") == -1) {
+	G_fatal_error(_("Unable to open vector map <%s>"),
+		      G_fully_qualified_name(gp->filename, mapset));
+    Fi = Vect_get_field(&Map, gp->tstyle->layer);
+    if (!Fi)
+	G_fatal_error(_("Database connection not defined for layer %d"),
+		      gp->tstyle->layer);
+    driver = db_start_driver_open_database(Fi->driver, Fi->database);
+    if (!driver)
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Fi->database, Fi->driver);
+    gpt = gp->points;
+    npts = 0;
+    G_message(_("Loading thematic points layer <%s>..."),
+    for(;gpt; gpt = gpt->next) {
+	gpt->style = (gvstyle *) G_malloc(sizeof(gvstyle));
+	G_zero(gpt->style, sizeof(gvstyle));
+	/* use default style */
+	gpt->style->color  = gp->style->color;
+	gpt->style->symbol = gp->style->symbol;
+	gpt->style->size   = gp->style->size;
+	gpt->style->width  = gp->style->width;
+	Vect_cat_get(gpt->cats, gp->tstyle->layer, &cat);
+	if (cat < 0)
+	    continue;
+	/* color */
+	nvals = db_select_value(driver, Fi->table, Fi->key, cat, gp->tstyle->color_column, &value);
+	if (nvals < 1)
+	    continue;
+	str = db_get_value_string(&value);
+	if (G_str_to_color(str, &red, &grn, &blu) != 1) {
+	    G_warning(_("Invalid color definition (%s)"),
+		      str);
+	else {
+	    gpt->style->color = (red & RED_MASK) + ((int)((grn) << 8) & GRN_MASK) +
+		((int)((blu) << 16) & BLU_MASK);
+	npts++;
+    return npts;
Modified: grass/trunk/lib/ogsf/gp.c
--- grass/trunk/lib/ogsf/gp.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/lib/ogsf/gp.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -127,7 +127,8 @@
     if (!np) {
 	return (NULL);
+    G_zero(np, sizeof(geosite));
     lp = gp_get_last_site();
     if (lp) {
 	lp->next = np;
@@ -137,14 +138,14 @@
 	Site_top = np;
 	np->gsite_id = FIRST_SITE_ID;
-    np->next = NULL;
     np->style = (gvstyle *) G_malloc(sizeof(gvstyle));
     if (!np->style)
 	return NULL;
+    G_zero(np->style, sizeof (gvstyle));
     np->hstyle = (gvstyle *) G_malloc(sizeof(gvstyle));
     if (!np->hstyle)
 	return NULL;
+    G_zero(np->hstyle, sizeof (gvstyle));
     return (np);
@@ -188,38 +189,24 @@
 int gp_set_defaults(geosite * gp)
-    int i;
     float dim;
     G_debug(5, "gp_set_defaults");
     if (!gp) {
-	return (-1);
+	return -1;
     GS_get_longdim(&dim);
-    gp->filename = NULL;
-    gp->n_sites = gp->use_z = gp->n_surfs = gp->use_mem = 0;
-    gp->x_trans = gp->y_trans = gp->z_trans = 0.0;
-    gp->points = NULL;
-    gp->has_z = 0;
-    gp->thematic_layer = -1;
     gp->style->color = 0xF0F0F0;
     gp->style->size = dim / 100.;
     gp->style->width = 1;
     gp->style->symbol = ST_X;
-    gp->style->next = NULL;
     gp->hstyle->color = 0xFF0000;
     gp->hstyle->size = dim / 150.;
     gp->hstyle->symbol = ST_X;
-    gp->hstyle->next = NULL;
-    gp->next = NULL;
-    for (i = 0; i < MAX_SURFS; i++) {
-	gp->drape_surf_id[i] = 0;
-    return (1);
+    return 1;
@@ -262,7 +249,7 @@
-   \brief Free geosite struct
+   \brief Free allocated geosite struct
    \param fp pointer to geosite struct
@@ -274,7 +261,7 @@
     geosite *gp;
     int found = 0;
-    G_debug(5, "gp_free_site");
+    G_debug(5, "gp_free_site(id=%d)", fp->gsite_id);
     if (Site_top) {
 	if (fp == Site_top) {
@@ -321,34 +308,38 @@
 void gp_free_sitemem(geosite * fp)
     geopoint *gpt, *tmp;
-    gvstyle *gvs, *tmpstyle;
     G_free((void *)fp->filename);
     fp->filename = NULL;
-    if (fp->style)
+    if (fp->style) {
 	G_free(fp->style);
-    if (fp->hstyle)
+    if (fp->hstyle) {
 	G_free(fp->hstyle);
     if (fp->points) {
 	for (gpt = fp->points; gpt;) {
 	    G_free(gpt->cats);
-	    if (fp->thematic_layer > -1) {	/* Style also exists for features */
-		for (gvs = fp->style; gvs;) {
-		    tmpstyle = gvs;
-		    gvs = gvs->next;
-		    G_free(tmpstyle);
+	    if(gpt->style) {
+		G_free(gpt->style);
 	    tmp = gpt;
 	    gpt = gpt->next;
 	    G_free(tmp);
 	fp->n_sites = 0;
 	fp->points = NULL;
+    if(fp->tstyle) {
+	G_free(fp->tstyle->color_column);
+	G_free(fp->tstyle->symbol_column);
+	G_free(fp->tstyle->size_column);
+	G_free(fp->tstyle->width_column);
     return;
Modified: grass/trunk/lib/ogsf/gpd.c
--- grass/trunk/lib/ogsf/gpd.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/lib/ogsf/gpd.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -1,21 +1,17 @@
-   \file gpd.c
+  \file lib/ogsf/gpd.c
+  \brief OGSF library - loading and manipulating point sets (lower level)
-   \brief OGSF library - loading and manipulating point sets
+  \author Bill Brown USACERL, GMSL/University of Illinois (December 1993)
+  \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
-   for details.
-   \author Bill Brown USACERL, GMSL/University of Illinois (December 1993)
-   \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
 #include <stdlib.h>
 #include <math.h>
@@ -29,17 +25,17 @@
 #define v_border 50
-   \brief Check if point is in region
-   Check for cancel every CHK_FREQ points
-   \param gs surface (geosurf)
-   \param pt point (array(X,Y,Z))
-   \param region region settings (array (top,bottom,left,right))
-   \return 0 point outside of region
-   \return 1 point inside region
+  \brief Check if point is in region
+  Check for cancel every CHK_FREQ points
+  \param gs surface (geosurf)
+  \param pt point (array(X,Y,Z))
+  \param region region settings (array (top,bottom,left,right))
+  \return 0 point outside of region
+  \return 1 point inside region
 int gs_point_in_region(geosurf * gs, float *pt, float *region)
     float top, bottom, left, right;
@@ -62,15 +58,15 @@
-   \brief Draw point representing object
-   Do normal transforms before calling
-   Note gs: NULL if 3d obj or const elev surface
-   \param style object displaying style (highlighted or not)
-   \param pt 3d point (Point3)
+  \brief Draw point representing object
+  Do normal transforms before calling
+  Note gs: NULL if 3d obj or const elev surface
+  \param style object displaying style (highlighted or not)
+  \param pt 3d point (Point3)
 void gpd_obj(geosurf * gs, gvstyle * style, Point3 pt)
@@ -200,23 +196,23 @@
-   \brief ADD
-   Need to think about translations - If user translates surface,
-   sites should automatically go with it, but translating sites should
-   translate it relative to surface on which it's displayed
-   Handling mask checking here
-   \todo prevent scaling by 0
-   \param gp site (geosite)
-   \param do_fast (unused)
-   \return 0
-   \return 1
+  \brief Draw 2D point set
+  Need to think about translations - If user translates surface,
+  sites should automatically go with it, but translating sites should
+  translate it relative to surface on which it's displayed
+  Handling mask checking here
+  \todo prevent scaling by 0
+  \param gp site (geosite)
+  \param do_fast (unused)
+  \return 0 on failure
 int gpd_2dsite(geosite * gp, geosurf * gs, int do_fast)
     float site[3], konst;
@@ -227,9 +223,8 @@
     GLint viewport[4];
     GLint window[4];
     if (GS_check_cancel()) {
-	return (0);
+	return 0;
     if (gs) {
@@ -263,7 +258,7 @@
 		    gsd_linewidth(1);
 		    gsd_popmatrix();
-		    return (0);
+		    return 0;
@@ -279,54 +274,54 @@
 		    /* returns 0 if outside or masked */
 		    site[Z] += gp->z_trans;
-		    if (gsd_checkpoint
-			(site, window, viewport, modelMatrix, projMatrix))
+		    if (gsd_checkpoint(site, window,
+				       viewport, modelMatrix, projMatrix))
 			continue;
 		    else {
 			if (gpt->highlighted > 0)
 			    gpd_obj(gs, gp->hstyle, site);
-			else if (gp->thematic_layer > 0)
+			else if (gp->tstyle)
 			    gpd_obj(gs, gpt->style, site);
-		    else
+			else
 			    gpd_obj(gs, gp->style, site);
 	    else if (src == CONST_ATT) {
 		if (gs_point_in_region(gs, site, NULL)) {
 			continue;
 		    else {
-		    else
+			else
 	gsd_linewidth(1);
 	gsd_popmatrix();
-    return (1);
+    return 1;
-   \brief ADD
-   \param xo,yo
-   \return 0
-   \return 1
+  \brief Draw 3D point set
+  \param xo,yo
+  \return 0 on success
+  \return 1 on failure
 int gpd_3dsite(geosite * gp, float xo, float yo, int do_fast)
     float site[3], tz;
@@ -377,15 +372,15 @@
 		gpd_obj(NULL, gp->hstyle, site);
 		gpd_obj(NULL, gpt->style, site);
 	    else
 		gpd_obj(NULL, gp->style, site);
     gsd_linewidth(1);
     gsd_popmatrix();
-    return (1);
+    return 1;
Modified: grass/trunk/visualization/nviz2/cmd/Makefile
--- grass/trunk/visualization/nviz2/cmd/Makefile	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/visualization/nviz2/cmd/Makefile	2011-06-25 21:32:43 UTC (rev 46778)
@@ -15,7 +15,8 @@
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(INC) \
 	$(TIFFINCPATH) $(DSPINC) \
-	$(VECT_CFLAGS) $(OPENGLINC)
+	$(VECT_CFLAGS) $(OPENGLINC) \
+	$(VECT_CFLAGS)
 ifeq ($(OPENGL_X11),1)
 EXTRA_CFLAGS += $(XCFLAGS)
@@ -23,8 +24,8 @@
 EXTRA_LDFLAGS = $(OGL_LIBS)
-LIBES = $(GISLIB) $(OGSFLIB) $(NVIZLIB) $(G3DLIB)
-DEPENDENCIES = $(GISDEP) $(NVIZDEP)
+LIBES = $(GISLIB) $(OGSFLIB) $(NVIZLIB) $(G3DLIB) $(VECTORLIB) $(DBMILIB)
+DEPENDENCIES = $(GISDEP) $(NVIZDEP) $(VECTORDEP) $(DBMIDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -3,7 +3,7 @@
   \brief Parse command
-  (C) 2008, 2010 by the GRASS Development Team
+  (C) 2008, 2010-2011 by the GRASS Development Team
   License (>=v2). Read the file COPYING that comes with GRASS
@@ -368,6 +368,14 @@
     params->vpoints->guisection = _("Vector points");
     params->vpoints->key = "vpoint";
+    params->vpoint_layer = G_define_standard_option(G_OPT_V_FIELD);
+    params->vpoint_layer->multiple = YES;
+    params->vpoint_layer->required = NO;
+    params->vpoint_layer->description = _("Layer number or name for thematic mapping");
+    params->vpoint_layer->guisection = _("Vector points");
+    params->vpoint_layer->key = "vpoint_layer";
+    params->vpoint_layer->answer = "1";
     /* point width */
     params->vpoint_size = G_define_option();
     params->vpoint_size->key = "vpoint_size";
@@ -380,6 +388,13 @@
     params->vpoint_size->options = "1-1000";
     params->vpoint_size->answer = "100";
+    params->vpoint_size_column = G_define_standard_option(G_OPT_DB_COLUMN);
+    params->vpoint_size_column->multiple = YES;
+    params->vpoint_size_column->required = NO;
+    params->vpoint_size_column->label = _("Name of size definition column");
+    params->vpoint_size_column->key = "vpoint_size_column";
+    params->vpoint_size_column->guisection = _("Vector points");
     /* point width */
     params->vpoint_width = G_define_option();
     params->vpoint_width->key = "vpoint_width";
@@ -392,6 +407,13 @@
     params->vpoint_width->options = "1-1000";
     params->vpoint_width->answer = "2";
+    params->vpoint_width_column = G_define_standard_option(G_OPT_DB_COLUMN);
+    params->vpoint_width_column->multiple = YES;
+    params->vpoint_width_column->required = NO;
+    params->vpoint_width_column->label = _("Name of width definition column");
+    params->vpoint_width_column->key = "vpoint_width_column";
+    params->vpoint_width_column->guisection = _("Vector points");
     /* point color */
     params->vpoint_color = G_define_standard_option(G_OPT_C_FG);
     params->vpoint_color->multiple = YES;
@@ -401,6 +423,13 @@
     params->vpoint_color->answer = "blue";
     params->vpoint_color->guisection = _("Vector points");
+    params->vpoint_color_column = G_define_standard_option(G_OPT_DB_COLUMN);
+    params->vpoint_color_column->multiple = YES;
+    params->vpoint_color_column->required = NO;
+    params->vpoint_color_column->label = _("Name of color definition column");
+    params->vpoint_color_column->key = "vpoint_color_column";
+    params->vpoint_color_column->guisection = _("Vector points");
     /* point mode */
     params->vpoint_marker = G_define_option();
     params->vpoint_marker->key = "vpoint_marker";
@@ -414,6 +443,13 @@
     params->vpoint_marker->answer = "sphere";
     params->vpoint_marker->guisection = _("Vector points");
+    params->vpoint_marker_column = G_define_standard_option(G_OPT_DB_COLUMN);
+    params->vpoint_marker_column->multiple = YES;
+    params->vpoint_marker_column->required = NO;
+    params->vpoint_marker_column->label = _("Name of marker definition column");
+    params->vpoint_marker_column->key = "vpoint_marker_column";
+    params->vpoint_marker_column->guisection = _("Vector points");
     /* position */
     params->vpoint_pos = G_define_option();
     params->vpoint_pos->key = "vpoint_position";
@@ -656,8 +692,10 @@
     int nelev_map, nelev_const, nelevs;
     int nmaps, nconsts;
-    int nvects;
+    int nvlines;
+    int nvpoints;
     /* topography */
     nelev_map = opt_get_num_answers(params->elev_map);
     nelev_const = opt_get_num_answers(params->elev_const);
@@ -744,39 +782,46 @@
-     * vector
+     * vector lines
-    nvects = opt_get_num_answers(params->vlines);
+    nvlines = opt_get_num_answers(params->vlines);
     /* width */
     nconsts = opt_get_num_answers(params->vline_width);
-    if (nvects > 0 && nconsts != nvects)
+    if (nvlines > 0 && nconsts != nvlines)
 	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d)"),
-		      params->vlines->key, nvects, params->vline_width->key,
+		      params->vlines->key, nvlines, params->vline_width->key,
 		      nconsts);
     /* color */
     nconsts = opt_get_num_answers(params->vline_color);
 	G_fatal_error(_("Inconsistent number of attributes (<%s> %d: <%s> %d"),
-		      params->vlines->key, nvects, params->vline_color->key,
+		      params->vlines->key, nvlines, params->vline_color->key,
 		      nconsts);
     /* mode */
     nconsts = opt_get_num_answers(params->vline_mode);
-		      params->vlines->key, nvects, params->vline_mode->key,
+		      params->vlines->key, nvlines, params->vline_mode->key,
 		      nconsts);
     /* height */
     nconsts = opt_get_num_answers(params->vline_height);
-		      params->vlines->key, nvects, params->vline_height->key,
+		      params->vlines->key, nvlines, params->vline_height->key,
 		      nconsts);
     return;
+     * vector points
+    nvpoints = opt_get_num_answers(params->vpoints);
+    /* TODO */
 void print_error(int nmaps, int nconsts, int nelevs,
Modified: grass/trunk/visualization/nviz2/cmd/local_proto.h
--- grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/visualization/nviz2/cmd/local_proto.h	2011-06-25 21:32:43 UTC (rev 46778)
@@ -19,6 +19,7 @@
 	*vlines, *vline_width, *vline_color, *vline_mode, *vline_height, *vline_pos,
     /* vector points */
 	*vpoints, *vpoint_size, *vpoint_marker, *vpoint_color, *vpoint_width, *vpoint_pos,
+	*vpoint_layer, *vpoint_size_column, *vpoint_marker_column, *vpoint_color_column, *vpoint_width_column,
     /* volumes */
 	*volume, *volume_mode, *volume_shade, *volume_pos, *volume_res, *isosurf_level,
     /* misc */
@@ -48,6 +49,7 @@
 int load_vpoints(const struct GParams *, nv_data *);
 int vlines_set_attrb(const struct GParams *);
 int vpoints_set_attrb(const struct GParams *);
+int check_thematic(const struct GParams *, int);
 /* volume.c */
 int load_rasters3d(const struct GParams *, nv_data *);
Modified: grass/trunk/visualization/nviz2/cmd/main.c
--- grass/trunk/visualization/nviz2/cmd/main.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/visualization/nviz2/cmd/main.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -7,7 +7,7 @@
  * PURPOSE:      Renders GIS data in 3D space.
- * COPYRIGHT:    (C) 2008,2010 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2008, 2010-2011 by the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
@@ -105,7 +105,7 @@
     /* load point vector maps */
     if (params->vpoints->answer) {
 	load_vpoints(params, &data);
-	/* set attributes for 2d lines */
+	/* set attributes for points */
 	vpoints_set_attrb(params);
Modified: grass/trunk/visualization/nviz2/cmd/vector.c
--- grass/trunk/visualization/nviz2/cmd/vector.c	2011-06-25 13:52:47 UTC (rev 46777)
+++ grass/trunk/visualization/nviz2/cmd/vector.c	2011-06-25 21:32:43 UTC (rev 46778)
@@ -3,7 +3,7 @@
   \brief Vector subroutines
@@ -15,6 +15,8 @@
 #include <stdlib.h>
 #include <string.h>
+#include <grass/vector.h>
 #include "local_proto.h"
@@ -136,7 +138,7 @@
-  \brief Set vector points mode
+  \brief Set vector points style
   \param params parameters
@@ -145,19 +147,28 @@
 int vpoints_set_attrb(const struct GParams *params)
-    int i;
+    int i, layer;
     int *site_list, nsites;
     int marker, color, width;
     float size;
-    char *marker_str;
+    char *marker_str, *color_column, *size_column, *width_column, *marker_column;
     site_list = GP_get_site_list(&nsites);
     for (i = 0; i < nsites; i++) {
+	layer = check_thematic(params, FALSE);
 	color = Nviz_color_from_str(params->vpoint_color->answers[i]);
+	color_column = params->vpoint_color_column->answers ?
+	    params->vpoint_color_column->answers[i] : NULL;
 	size = atof(params->vpoint_size->answers[i]);
+	size_column = params->vpoint_size_column->answers ?
+	    params->vpoint_size_column->answers[i] : NULL;
 	width = atoi(params->vpoint_width->answers[i]);
+	width_column = params->vpoint_width_column->answers ?
+	    params->vpoint_width_column->answers[i] : NULL;
 	marker_str = params->vpoint_marker->answers[i];
+	marker_column = params->vpoint_marker_column->answers ?
+	    params->vpoint_marker_column->answers[i] : NULL;
 	if (strcmp(marker_str, "x") == 0)
 	    marker = ST_X;
@@ -179,7 +190,94 @@
 	    G_fatal_error(_("Unknown icon marker"));
 	GP_set_style(site_list[i], color, width, size, marker);
+	if (color_column || width_column || size_column || marker_column) {
+	    GP_set_style_thematic(site_list[i], layer, color_column, width_column,
+				  size_column, marker_column);
     return 1;
+int check_thematic(const struct GParams *params, int vlines)
+    int i, type;
+    struct Option *map, *layer, *color, *size, *width, *marker;
+    dbDriver *driver;
+    dbColumn *column;
+    if (vlines) {
+	map    = params->vlines; /*TODO */
+	layer  = NULL;
+	color  = NULL;
+	size   = NULL;
+	width  = NULL;
+	marker = NULL;
+    else {
+	map    = params->vpoints;
+	layer  = params->vpoint_layer;
+	color  = params->vpoint_color_column;
+	size   = params->vpoint_size_column;
+	width  = params->vpoint_width_column;
+	marker = params->vpoint_marker_column;
+    for (i = 0; map->answers[i]; i++) {
+	if (1 > Vect_open_old(&Map, map->answer, ""))
+	    G_fatal_error(_("Unable to open vector map <%s>"), map->answer);
+	Fi = Vect_get_field2(&Map, layer->answer);
+	if (!Fi)
+	    G_fatal_error(_("Database connection not defined for layer %s"),
+			  layer->answer);
+	if (!driver)
+	if (color->answers && color->answers[i]) {
+	    db_get_column(driver, Fi->table, color->answers[i], &column);
+	    if (!column)
+		G_fatal_error(_("Column <%s> in table <%s> not found"),
+			      color->answers[i], Fi->table);
+	    if (db_column_Ctype(driver, Fi->table, color->answers[i]) != DB_C_TYPE_STRING)
+		G_fatal_error(_("Data type of color column must be character"));
+	if (size->answers && size->answers[i]) {
+	    db_get_column(driver, Fi->table, size->answers[i], &column);
+	    if (!column)
+			      size->answers[i], Fi->table);
+	    type = db_column_Ctype(driver, Fi->table, size->answers[i]);
+	    if (type != DB_C_TYPE_INT && type != DB_C_TYPE_DOUBLE)
+		G_fatal_error(_("Data type of size column must be numeric"));
+	if (width->answers && width->answers[i]) {
+	    db_get_column(driver, Fi->table, width->answers[i], &column);
+	    if (!column)
+			      width->answers[i], Fi->table);
+	    type = db_column_Ctype(driver, Fi->table, width->answers[i]);
+		G_fatal_error(_("Data type of width column must be numeric"));
+	if (marker->answers && marker->answers[i]) {
+	    db_get_column(driver, Fi->table, marker->answers[i], &column);
+	    if (!column)
+			      marker->answers[i], Fi->table);
+	    if (db_column_Ctype(driver, Fi->table, marker->answers[i]) != DB_C_TYPE_STRING)
+		G_fatal_error(_("Data type of marker column must be character"));
+    return Fi->number;
