[GRASS-SVN] r46791 - in grass/trunk/gui/wxpython: . xml
Sun Jun 26 12:35:35 EDT 2011
Author: martinl
Date: 2011-06-26 09:35:35 -0700 (Sun, 26 Jun 2011)
New Revision: 46791
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: update for GSoC testing (wx.stream)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2011-06-26 16:29:22 UTC (rev 46790)
+++ grass/trunk/gui/wxpython/wxgui.py	2011-06-26 16:35:35 UTC (rev 46791)
@@ -332,7 +332,23 @@
         win.CentreOnScreen()
         win.Show()
+    def OnRStream(self, event):
+        """!GSoC's r.stream.* interface for testing
+        try:
+            from gui_modules import rstream
+        except:
+            gcmd.GError(parent = self.parent,
+                        message = _("RStream Utility is not available. You can install it by %s") % \
+                            'g.extension -s extension=wx.stream')
+            return
+        win = rstream.RStreamFrame(parent = self)
+        win.CentreOnScreen()
+        win.Show()
     def OnDone(self, returncode):
         """Command execution finised"""
         if hasattr(self, "model"):
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2011-06-26 16:29:22 UTC (rev 46790)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2011-06-26 16:35:35 UTC (rev 46791)
@@ -738,6 +738,18 @@
 	  <command>ps.map</command>
 	</menuitem>
 	<separator />
+	<menu>
+	  <label>GSoC testing</label>
+	  <items>
+	    <menuitem>
+	      <label>RStream</label>
+	      <help>GUI for hydrological modelling (r.stream.*)</help>
+	      <keywords>raster,hydrology</keywords>
+	      <handler>OnRStream</handler>
+	    </menuitem>
+	  </items>
+	</menu>
+	<separator />
 	<menuitem>
 	  <label>Launch script</label>
 	  <help>Launches script file.</help>
