[GRASS-SVN] r46806 - grass/trunk/raster3d
Mon Jun 27 16:16:55 EDT 2011
Author: neteler
Date: 2011-06-27 13:16:55 -0700 (Mon, 27 Jun 2011)
New Revision: 46806
   grass/trunk/raster3d/raster3dintro.html
typos; html
Modified: grass/trunk/raster3d/raster3dintro.html
--- grass/trunk/raster3d/raster3dintro.html	2011-06-27 19:46:18 UTC (rev 46805)
+++ grass/trunk/raster3d/raster3dintro.html	2011-06-27 20:16:55 UTC (rev 46806)
@@ -14,11 +14,12 @@
 <h2>3D Raster data (voxel) in GRASS GIS</h2>
 GRASS GIS raster3d maps use the same coordinate system as
-2d raster maps (row count from north to south) with an additional z dimension (depth)
-coutning from bottom to top. The upper left corner (NW) is the origin of the volume.
+2D raster maps (row count from north to south) with an additional z dimension (depth)
+counting from bottom to top. The upper left corner (NW) is the origin of the volume.
 Volumes are stored using a tile cache based approach. This allows abritrary read
 and write operations in the created volume. The size of the tiles can be specified at import time
-with r3.in.ascii or the data can be retiles using r3.retile after import or creation.
+with <a href="r3.in.ascii.html">r3.in.ascii</a> or the data can be retiled using
+<a href="r3.retile.html">r3.retile</a> after import or creation.
 <center>
