[GRASS-SVN] r46808 - grass-addons/grass7/raster/r.modis/libmodis
Mon Jun 27 16:41:11 EDT 2011
Author: neteler
Date: 2011-06-27 13:41:11 -0700 (Mon, 27 Jun 2011)
New Revision: 46808
   grass-addons/grass7/raster/r.modis/libmodis/modis.py
some English fixes
Modified: grass-addons/grass7/raster/r.modis/libmodis/modis.py
--- grass-addons/grass7/raster/r.modis/libmodis/modis.py	2011-06-27 20:33:09 UTC (rev 46807)
+++ grass-addons/grass7/raster/r.modis/libmodis/modis.py	2011-06-27 20:41:11 UTC (rev 46808)
@@ -8,11 +8,11 @@
-#  Modis class is licensed under the terms of GNU GPL 2
+#  This MODIS Python class is licensed under the terms of GNU GPL 2.
 #  This program is free software; you can redistribute it and/or
 #  modify it under the terms of the GNU General Public License as
 #  published by the Free Software Foundation; either version 2 of
-#  the License,or (at your option) any later version.
+#  the License, or (at your option) any later version.
 #  This program is distributed in the hope that it will be useful,
 #  but WITHOUT ANY WARRANTY; without even implied warranty of
 #  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
@@ -24,14 +24,14 @@
 #  0.4.0 Fix a lot of bugs, add convertModis class to convert hdf to other
 #        format and projection system (To release)
-#  0.3.0 Fix the choosing of days, change name modisClass to downModis
+#  0.3.0 Fixed the choosing of days, change name modisClass to downModis
 #        and add parseModis (2011-05-24)
 #  0.2.1 Little change in the logging option (2011-01-21)
-#  0.2.0 Add logging and change something in debug methods (2010-12-01)
+#  0.2.0 Added logging and change something in debug methods (2010-12-01)
 #  0.1.3 Correct a little problem with "Connection timed out"
-#  0.1.2 Add two debug methods (2010-13-08)
-#  0.1.1 Add moveFile method (2010-07-02)
-#  0.1.0 First Version of Modis Class (2010-06-19)
+#  0.1.2 Added two debug methods (2010-13-08)
+#  0.1.1 Added moveFile method (2010-07-02)
+#  0.1.0 First Version of MODIS Python Class (2010-06-19)
@@ -51,7 +51,7 @@
 import ftplib
 class downModis:
-  """A class to download modis data from nasa ftp repository"""
+  """A class to download MODIS data from NASA FTP repository"""
   def __init__(self,
                 password,
                 destinationFolder,
@@ -66,20 +66,20 @@
                 debug = False
     """Initialization function :
-        password = is your password, usually your email
-        destinationFolder = where your file are storage
-        user = is your username, by default anonymous
-        url = the url where download data
-        path = the directory where the data that you want download are
-               storaged in the ftp server
-        tiles = a list of tiles that you want downloads, None == all tiles
-        today = the day to start download, to pass a date different to
-                today use this format year-month-day
+        password = is your password, usually your email address
+        destinationFolder = where the files will be stored
+        user = your username, by default anonymous
+        url = the url where to download the MODIS data
+        path = the directory where the data that you want to download are
+               stored on the ftp server
+        tiles = a list of tiles that you want to download, None == all tiles
+        today = the day to start downloading; in order to pass a date different from
+                today use the format YYYY-MM-DD
         delta = timelag i.e. the number of days starting from today
-                (backward)
+                (backwards
-        Create ftp istance, connect user to ftp server and go to the
-        directory where data are storage
+        Creates a ftp instance, connects user to ftp server and goes into the
+        directory where the MODIS data are stored
     # url modis
@@ -99,7 +99,7 @@
     if os.access(destinationFolder,os.W_OK):
       self.writeFilePath = destinationFolder
     else:
-      raise IOError("Folder to write downloaded files doesn't exist or is not" \
+      raise IOError("Folder to store downloaded files does not exist or is not" \
     + "writeable")
     # return the name of product
     if len(self.path.split('/')) == 2:
@@ -129,7 +129,7 @@
     format=LOGGING_FORMAT)
   def connectFTP(self):
-    """ Set connection to ftp server, move to path where data are storaged
+    """ Set connection to ftp server, move to path where data are stored
     and create a list of directory for all days"""
     try:
       # connect to ftp server
@@ -191,7 +191,7 @@
       self.enday = self.str2date(self.enday)
   def getListDays(self):
-      """ Return a list of all days selected """
+      """ Return a list of all selected days """
       self.getToday()
       today_s = self.today.strftime("%Y.%m.%d")
@@ -223,8 +223,8 @@
       return days
   def getFilesList(self):
-    """ Create a list of files to download, is possible choose if download
-    also jpeg files or only hdf"""
+    """ Create a list of files to download, it is possible choose to download
+    also the jpeg files or only the hdf files"""
     def cicle_file(jpeg=False,tile=True):
       finalList = []
       for i in self.listfiles:
@@ -400,7 +400,7 @@
 class parseModis:
   """Class to parse MODIS xml files, it also can create the parameter
-    configuration file for resample MRT software
+    configuration file for resampling with the MRT software
   def __init__(self, filename):
@@ -660,14 +660,14 @@
     if projtype in proj_list:
       conFile.write("OUTPUT_PROJECTION_TYPE = %s\n" % projtype)
     else:
-      raise IOError('The projection type %s is not supportet.\n' \
+      raise IOError('The projection type %s is not supported.\n' \
                    'The projections supported are %s' % (projtype,proj_list))
     conFile.write("OUTPUT_PROJECTION_PARAMETERS = %s\n" % projpar)
     # if datum is in datum_list set the parameter otherwise return an error
     if datum in datum_list:
       conFile.write("DATUM = %s\n" % datum)
     else:
-      raise IOError('The datum %s is not supportet.\n' \
+      raise IOError('The datum %s is not supported.\n' \
                    'The datum supported are %s' % (datum,datum_list))
     # if utm is not None write the UTM_ZONE parameter in the file
     if utm:
@@ -679,7 +679,7 @@
     return filename
 class convertModis:
-  """A class to convert modis data from hdf to tif using resample (mrt tools)
+  """A class to convert modis data from hdf to tif using resample (from MRT tools)
   def __init__(self, hdfname, confile, mrtpath):
@@ -725,7 +725,7 @@
         return os.path.join(self.mrtpath,'resample.exe')
   def run(self):
-    """Exect the process"""
+    """Exec the process"""
     import subprocess
     execut = self.executable()
     if not os.path.exists(execut):
@@ -733,7 +733,7 @@
                     + 'software') % execut
     else:
       subprocess.call([execut,'-p',self.conf])
-    return "The hdf file %s it is converted" % self.name
+    return "The hdf file %s was converted" % self.name
 #class createMosaic:
   #def __init__(self
