[GRASS-SVN] r46813 - grass/trunk/visualization/nviz2/cmd
Tue Jun 28 03:04:41 EDT 2011
Author: annakrat
Date: 2011-06-28 00:04:41 -0700 (Tue, 28 Jun 2011)
New Revision: 46813
   grass/trunk/visualization/nviz2/cmd/args.c
   grass/trunk/visualization/nviz2/cmd/surface.c
nviz_cmd: fixed segmentation fault when loading more surfaces
Modified: grass/trunk/visualization/nviz2/cmd/args.c
--- grass/trunk/visualization/nviz2/cmd/args.c	2011-06-27 20:57:48 UTC (rev 46812)
+++ grass/trunk/visualization/nviz2/cmd/args.c	2011-06-28 07:04:41 UTC (rev 46813)
@@ -690,7 +690,7 @@
 void check_parameters(const struct GParams *params)
     int nelev_map, nelev_const, nelevs;
-    int nmaps, nconsts;
+    int nmaps, nconsts, ncoords;
     int nvlines;
@@ -779,6 +779,13 @@
 	    G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
 			  params->elev_map->key, params->elev_const->key,
 			  nelevs, params->wire_color->key, nconsts);
+        /* position */
+        ncoords = opt_get_num_answers(params->surface_pos);
+        if (ncoords > 0 && 3 * nelevs != ncoords)
+            G_fatal_error(_("Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"),
+                              params->elev_map->key, params->elev_const->key, nelevs,
+                              params->surface_pos->key, ncoords);
Modified: grass/trunk/visualization/nviz2/cmd/surface.c
--- grass/trunk/visualization/nviz2/cmd/surface.c	2011-06-27 20:57:48 UTC (rev 46812)
+++ grass/trunk/visualization/nviz2/cmd/surface.c	2011-06-28 07:04:41 UTC (rev 46813)
@@ -74,9 +74,9 @@
 	/* set position */
-	x = atof(params->surface_pos->answers[i]);
-	y = atof(params->surface_pos->answers[i+1]);
-	z = atof(params->surface_pos->answers[i+2]);
+	x = atof(params->surface_pos->answers[i*3+0]);
+	y = atof(params->surface_pos->answers[i*3+1]);
+	z = atof(params->surface_pos->answers[i*3+2]);
 	GS_set_trans(id, x, y, z);
@@ -229,7 +229,7 @@
 	/* style */
-	if (strcmp(params->style->answers[i], "wire") == 0) {
+	if (strcmp(style, "wire") == 0) {
 	    draw_mode |= DM_GRID_WIRE;
 	else {			/* surface */
@@ -237,7 +237,7 @@
 	/* shading */
-	if (strcmp(params->shade->answers[i], "flat") == 0) {
+	if (strcmp(shade, "flat") == 0) {
 	    draw_mode |= DM_FLAT;
 	else {			/* gouraud */
