[GRASS-SVN] r45580 - grass/trunk/ps/ps.map
Sat Mar 5 17:36:52 EST 2011
Author: martinl
Date: 2011-03-05 14:36:52 -0800 (Sat, 05 Mar 2011)
New Revision: 45580
Added:
   grass/trunk/ps/ps.map/read_key.c
   grass/trunk/ps/ps.map/box.c
   grass/trunk/ps/ps.map/comment.c
   grass/trunk/ps/ps.map/distance.h
   grass/trunk/ps/ps.map/do_geogrid.c
   grass/trunk/ps/ps.map/do_grid.c
   grass/trunk/ps/ps.map/do_header.c
   grass/trunk/ps/ps.map/do_labels.c
   grass/trunk/ps/ps.map/do_plt.c
   grass/trunk/ps/ps.map/do_scalebar.c
   grass/trunk/ps/ps.map/do_vectors.c
   grass/trunk/ps/ps.map/eps.c
   grass/trunk/ps/ps.map/get_scalebar.c
   grass/trunk/ps/ps.map/getgrid.c
   grass/trunk/ps/ps.map/local_proto.h
   grass/trunk/ps/ps.map/main.c
   grass/trunk/ps/ps.map/map_info.c
   grass/trunk/ps/ps.map/map_setup.c
   grass/trunk/ps/ps.map/outl_io.c
   grass/trunk/ps/ps.map/ps_clrtbl.c
   grass/trunk/ps/ps.map/ps_colors.c
   grass/trunk/ps/ps.map/ps_fclrtbl.c
   grass/trunk/ps/ps.map/ps_map.c
   grass/trunk/ps/ps.map/ps_outline.c
   grass/trunk/ps/ps.map/ps_raster.c
   grass/trunk/ps/ps.map/ps_vareas.c
   grass/trunk/ps/ps.map/ps_vlegend.c
   grass/trunk/ps/ps.map/ps_vlines.c
   grass/trunk/ps/ps.map/ps_vpoints.c
   grass/trunk/ps/ps.map/r_border.c
   grass/trunk/ps/ps.map/r_cell.c
   grass/trunk/ps/ps.map/r_colortable.c
   grass/trunk/ps/ps.map/r_group.c
   grass/trunk/ps/ps.map/r_header.c
   grass/trunk/ps/ps.map/r_info.c
   grass/trunk/ps/ps.map/r_paper.c
   grass/trunk/ps/ps.map/r_plt.c
   grass/trunk/ps/ps.map/r_rgb.c
   grass/trunk/ps/ps.map/r_text.c
   grass/trunk/ps/ps.map/r_vareas.c
   grass/trunk/ps/ps.map/r_vlegend.c
   grass/trunk/ps/ps.map/r_vlines.c
   grass/trunk/ps/ps.map/r_vpoints.c
   grass/trunk/ps/ps.map/r_wind.c
   grass/trunk/ps/ps.map/scale.c
   grass/trunk/ps/ps.map/symbol.c
ps.map: -b doesn't require 'output' to be defined
	update options structure
	various minor changes (messages)
Modified: grass/trunk/ps/ps.map/box.c
--- grass/trunk/ps/ps.map/box.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/box.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -3,12 +3,12 @@
  ** Author: Paul W. Carlson     March 1992
-#include "ps_info.h"
 #include "local_proto.h"
 int box_path(double t, double b, double l, double r)
-    fprintf(PS.fp, "%.1f %.1f %.1f %.1f B ", l, b, r, t);
+    if (PS.fp)
+	fprintf(PS.fp, "%.1f %.1f %.1f %.1f B ", l, b, r, t);
     return 0;
@@ -16,8 +16,9 @@
 int box_clip(double t, double b, double l, double r)
     box_path(t, b, l, r);
-    fprintf(PS.fp, "clip newpath\n");
+    if (PS.fp)
+	fprintf(PS.fp, "clip newpath\n");
     return 0;
Modified: grass/trunk/ps/ps.map/comment.c
--- grass/trunk/ps/ps.map/comment.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/comment.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -8,7 +8,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "comment.h"
 #define KEY(x) (strcmp(key,x)==0)
Property changes on: grass/trunk/ps/ps.map/distance.h
___________________________________________________________________
Added: svn:mime-type
   + text/x-chdr
Modified: grass/trunk/ps/ps.map/do_geogrid.c
--- grass/trunk/ps/ps.map/do_geogrid.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_geogrid.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -11,7 +11,6 @@
 #include <grass/glocale.h>
 #include <grass/gprojects.h>
 #define LEFT 0
Modified: grass/trunk/ps/ps.map/do_grid.c
--- grass/trunk/ps/ps.map/do_grid.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_grid.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,7 @@
 #include <string.h>
 #include <math.h>
 #define LEFT 0
Modified: grass/trunk/ps/ps.map/do_header.c
--- grass/trunk/ps/ps.map/do_header.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_header.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -7,7 +7,7 @@
 #include <string.h>
 #include <grass/raster.h>
 #include "header.h"
 static double x, y, dy, fontsize;
Modified: grass/trunk/ps/ps.map/do_labels.c
--- grass/trunk/ps/ps.map/do_labels.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_labels.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -12,7 +12,6 @@
 #include "clr.h"
 #include "labels.h"
Modified: grass/trunk/ps/ps.map/do_plt.c
--- grass/trunk/ps/ps.map/do_plt.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_plt.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -8,7 +8,6 @@
 #include <grass/symbol.h>
 #include "clr.h"
 int do_plt(int after_masking)
Modified: grass/trunk/ps/ps.map/do_scalebar.c
--- grass/trunk/ps/ps.map/do_scalebar.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_scalebar.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -4,8 +4,6 @@
 #include <string.h>
 #include <math.h>
-#include "decorate.h"
 #include "distance.h"
Modified: grass/trunk/ps/ps.map/do_vectors.c
--- grass/trunk/ps/ps.map/do_vectors.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/do_vectors.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -13,7 +13,6 @@
 #include "clr.h"
 #include "vector.h"
 int do_vectors(int after_masking)
Modified: grass/trunk/ps/ps.map/eps.c
--- grass/trunk/ps/ps.map/eps.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/eps.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -1,6 +1,5 @@
 #include <math.h>
 #include <string.h>
 /*  test if file is realy EPS file and find bbox
Modified: grass/trunk/ps/ps.map/get_scalebar.c
--- grass/trunk/ps/ps.map/get_scalebar.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/get_scalebar.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -5,8 +5,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/getgrid.c
--- grass/trunk/ps/ps.map/getgrid.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/getgrid.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -5,7 +5,6 @@
 #include <stdlib.h>
 #include <string.h>
 #define KEY(x) (strcmp(x,key)==0)
Modified: grass/trunk/ps/ps.map/local_proto.h
--- grass/trunk/ps/ps.map/local_proto.h	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/local_proto.h	2011-03-05 22:36:52 UTC (rev 45580)
@@ -1,5 +1,9 @@
+#include "group.h"
+#include "ps_info.h"
+#include "decorate.h"
 /* box.c */
 int box_path(double, double, double, double);
 int box_clip(double, double, double, double);
@@ -190,10 +194,15 @@
 int read_cell(char *, char *);
 /* read_cfg.c */
-int set_paper(char *pname);
+int set_paper(char *);
 void reset_map_location(void);
 void print_papers(void);
+/* read_key.c */
+void read_from_keyboard(FILE *, struct PS_data *, int, int, int,
+			struct scalebar *, int *, int *,
+			struct PS_group *);
 /* r_border.c */
 int read_border(void);
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/main.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -11,7 +11,7 @@
  *               Markus Neteler <neteler itc.it>
  *               Alessandro Frigeri <afrigeri unipg.it>
  *               Martin Landa <landa.martin gmail.com>
- * PURPOSE:      This is an enhanced PostScript version of the p.map program
+ * PURPOSE:      Hardcopy PostScript map output utility (based on p.map program)
  * COPYRIGHT:    (C) 2003-2008, 2011 by the GRASS Development Team
  *               This program is free software under the GNU General
@@ -37,9 +37,6 @@
 #include "border.h"
 #include "colortable.h"
-#include "group.h"
 struct border brd;
@@ -58,33 +55,14 @@
 struct PS_group grp;
-#define KEY(x) (strcmp(key,x)==0)
 FILE *tracefd;
 FILE *inputfd;
 int do_mapinfo;
 int do_vlegend;
 char *ps_mask_file;
-static char *help[] = {
-    "rast       rastermap             setcolor   val_range(s) color",
-    "vpoints    vector points map     scalebar   [f|s]",
-    "vlines     vector lines map      paper      [a4|a3|us-letter|...]",
-    "vareas     vector areas map      maploc     x y [width height]",
-    "labels     labelfile             text       east north text",
-    "region     regionfile            line       east north east north",
-    "grid       spacing               point      east north",
-    "geogrid    spacing               header",
-    "outline                          mapinfo",
-    "colortable [y|n]                 vlegend",
-    "comments   [unix-file]           psfile     PostScript include file",
-    "read       unix-file             eps        Encapsulated PostScript file",
-    "rectangle  east north east north",
-    "scale      1:#|# inches|# panels|1 inch = # miles",
-    "border     [y|n]",
 int rotate_plot;
 int eps_output;
 int ps_copies = 1;
@@ -92,9 +70,6 @@
 int main(int argc, char *argv[])
     char buf[1024];
-    char name[GNAME_MAX], mapset[GMAPSET_MAX];
-    int i;
-    int iflag;
     int can_reset_scale;
     int copies_set;
     struct Option *input_file;
@@ -127,8 +102,9 @@
     pflag = G_define_flag();
     pflag->key = 'p';
     pflag->description =
-	_("List paper formats ( name width height left right top bottom(margin) )");
+	_("List paper formats (name width height left right top bottom(margin))");
+    pflag->suppress_required = YES;
     eflag = G_define_flag();
     eflag->key = 'e';
     eflag->description =
@@ -138,32 +114,25 @@
     bflag->key = 'b';
     bflag->description =
 	_("Print map-box's position on the page and exit (inches from top-left of paper)");
-    input_file = G_define_option();
-    input_file->key = "input";
-    input_file->type = TYPE_STRING;
-    input_file->description =
-	_("File containing mapping instructions (or use input=- to enter from keyboard)");
-    input_file->gisprompt = "old_file,file,input";
-    input_file->required = NO;
-    output_file = G_define_option();
-    output_file->key = "output";
-    output_file->type = TYPE_STRING;
-    output_file->gisprompt = "new_file,file,output";
-    output_file->description = _("PostScript output file");
-    /*    output_file->required = YES;   Can omit for -p list page size & exit mode */
+    bflag->suppress_required = YES;
+    input_file = G_define_standard_option(G_OPT_F_INPUT);
+    input_file->label = _("File containing mapping instructions");
+    input_file->description = _("Use '-' to enter instructions from keyboard)");
+    output_file = G_define_standard_option(G_OPT_F_OUTPUT);
+    output_file->description = _("Name for PostScript output file");
     copies = G_define_option();
     copies->key = "copies";
     copies->type = TYPE_INTEGER;
     copies->options = "1-20";
     copies->description = _("Number of copies to print");
     copies->required = NO;
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     /* Print papers */
     if (pflag->answer) {
 	print_papers();
@@ -194,7 +163,6 @@
     m_info.bgcolor = WHITE;
     hdr.color = BLACK;
     cmt.color = BLACK;
-    PS.grid_color = BLACK;
     m_info.font = G_store(def_font);
     vector.font = G_store(def_font);
     hdr.font = G_store(def_font);
@@ -208,7 +176,6 @@
     ct.cols = 1;
     tracefd = NULL;
     inputfd = stdin;
-    iflag = 0;
     labels.count = 0;
     labels.other = NULL;
     can_reset_scale = 1;
@@ -216,62 +183,45 @@
     grp.do_group = 0;
     brd.R = brd.G = brd.B = 0.;
     brd.width = 1.;
-    PS.grey = 0;
-    PS.mask_needed = 0;
-    PS.do_header = 0;
+    G_zero(&PS, sizeof(struct PS_data));
+    PS.grid_color = BLACK;
     PS.min_y = 72.0 * (PS.page_height - PS.top_marg);
     PS.set_y = 100.0 * PS.min_y;
-    PS.startpanel = 0;
-    PS.endpanel = 0;
     PS.cell_fd = -1;
-    PS.do_outline = 0;
-    PS.do_colortable = 0;
     PS.do_border = TRUE;
-    PS.do_scalebar = 0;
-    PS.grid = 0;
-    PS.scaletext[0] = 0;
-    PS.celltitle[0] = 0;
-    PS.commentfile = NULL;
-    PS.num_psfiles = 0;
-    PS.mask_color = 0;
-    /* PS.map_* variables are set to 0 (not defined) and then may be reset by 'maploc'.
-     * When script is read, main() should call reset_map_location() to reset map size to fit to paper */
-    PS.map_width = 0;
-    PS.map_height = 0;
-    PS.map_x_orig = 0;
-    PS.map_y_orig = 0;
-    PS.map_y_loc = 0;
+    /* PS.map_* variables are set to 0 (not defined) and then may be
+     * reset by 'maploc'.  When script is read, main() should call
+     * reset_map_location() to reset map size to fit to paper */
     /* arguments */
     if (input_file->answer && strcmp(input_file->answer, "-")) {
 	if (NULL == freopen(input_file->answer, "r", stdin))
-	    G_fatal_error("%s - %s: %s", G_program_name(),
+	    G_fatal_error(_("Unable to open file '%s': %s"),
 			  input_file->answer, strerror(errno));
     if (copies->answer) {
 	if (sscanf(copies->answer, "%d", &ps_copies) != 1) {
 	    ps_copies = 1;
-	    error(copies->answer, "", "illegal copies request");
+	    error(copies->answer, "", _("illegal copies request"));
 	copies_set = 1;
-    if (output_file->answer) {
-	if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
-			  output_file->answer, strerror(errno));
+    if (!bflag->answer) {
+	if (output_file->answer) {
+	    if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
+		G_fatal_error("Unable to create file '%s': %s",
+			      output_file->answer, strerror(errno));
+	else {
+	    G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"),
+			  output_file->key, output_file->description);
-    else {
-	G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
-		  output_file->key, output_file->description);
-	G_usage();
-	exit(EXIT_FAILURE);
     /* get current mapset */
     PS.cell_mapset = G_mapset();
@@ -279,451 +229,12 @@
     G_get_set_window(&PS.w);
     Rast_set_window(&PS.w);
-    while (1) {
-	char *key;
-	char *data;
-	if (!input(1, buf, help)) {
-	    if (!iflag) {
-		if (G_getl2(buf, 12, inputfd))
-		    G_warning(_("Data exists after final 'end' instruction!"));
-		break;
-	    iflag = 0;
-	    continue;
-	if (!key_data(buf, &key, &data))
-	    continue;
-	if (KEY("read")) {
-	    if (inputfd != stdin)
-		fclose(inputfd);
-	    if (sscanf(data, "%s", name) != 1) {
-		error(key, data, "no file specified");
-		inputfd = stdin;
-	    else if ((inputfd = fopen(name, "r")) == NULL) {
-		error(key, data, "unable to open");
-		inputfd = stdin;
-	    else
-		iflag = 1;
-	    continue;
-	/* Please, remove before GRASS 7 released */
-	if (KEY("verbose")) {
-	    int verbose;
-	    if (sscanf(data, "%d", &verbose) != 1)
-		verbose = G_verbose_std();
-	    G_warning(_("GRASS environment variable GRASS_VERBOSE "
-			"is overwritten by VERBOSE mapping instruction. "
-			"This mapping instruction is superseded and "
-			"will be removed in future versions of GRASS. "
-			"Please use --verbose instead."));
-	    if (!G_set_verbose(verbose))
-		G_warning(_("Cannot set GRASS_VERBOSE variable."));
-	    continue;
-	if (KEY("paper")) {
-	    if (strlen(data) > 0) {
-		set_paper(data);
-	    read_paper();
-	    continue;
-	if (KEY("maploc")) {
-	    int n;
-	    double x, y, w, h;
-	    n = sscanf(data, "%lf %lf %lf %lf", &x, &y, &w, &h);
-	    if (n == 2 || n == 4) {
-		PS.map_x_orig = x;
-		PS.map_y_loc = y;
-		if (n == 4) {
-		    PS.map_width = w;
-		    PS.map_height = h;
-	    else {
-		error(key, data, "illegal maploc request");
-		gobble_input();
-	    continue;
-	if (KEY("copies")) {
-	    int n, copies;
-	    if (copies_set)
-		continue;
-	    n = sscanf(data, "%d", &copies);
-	    if (n != 1 || copies < 1 || copies > 20) {
-		ps_copies = 1;
-		error(key, data, "illegal copies request");
-	    ps_copies = copies;
-	    continue;
-	if (KEY("setcolor")) {
-	    float R, G, B;
-	    int r, g, b;
-	    int color;
-	    int count;
-	    DCELL *val_list;
-	    DCELL dmin, dmax;
-	    char colorbuf[100];
-	    char catsbuf[100];
-	    if (PS.cell_fd < 0) {
-		error(key, data, "no raster map selected yet");
-		continue;
-	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
-		color = get_color_number(colorbuf);
-		if (color < 0) {
-		    error(key, data, "illegal color");
-		    continue;
-		get_color_rgb(color, &R, &G, &B);
-		r = 255.0 * R;
-		g = 255.0 * G;
-		b = 255.0 * B;
-		if (strncmp(catsbuf, "null", 4) == 0) {
-		    Rast_set_null_value_color(r, g, b, &PS.colors);
-		    continue;
-		if (strncmp(catsbuf, "default", 7) == 0) {
-		    Rast_set_default_color(r, g, b, &PS.colors);
-		    continue;
-		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
-		    error(key, data, "illegal value list");
-		    continue;
-		for (i = 0; i < count; i += 2) {
-		    dmin = val_list[i];
-		    dmax = val_list[i + 1];
-		    Rast_add_d_color_rule(&dmin, r, g, b, &dmax, r, g, b,
-					      &PS.colors);
-		G_free(val_list);
-	    continue;
-	if (KEY("colortable")) {
-	       else
-	    PS.do_colortable = yesno(key, data);
-	    if (PS.do_colortable)
-		read_colortable();
-	    continue;
-	if (KEY("border")) {
-	    PS.do_border = yesno(key, data);
-	    if (PS.do_border)
-		read_border();
-	    continue;
-	if (KEY("scalebar")) {
-	    if (G_projection() == PROJECTION_LL) {
-		error(key, data,
-		      "scalebar is not appropriate for this projection");
-		gobble_input();
-	    PS.do_scalebar = 1;
-	    if (sscanf(data, "%s", sb.type) != 1)
-		strcpy(sb.type, "f");	/* default to fancy scalebar */
-	    read_scalebar();
-	    if (sb.length <= 0.) {
-		error(key, data, "Bad scalebar length");
-		gobble_input();
-	    continue;
-	if (KEY("text")) {
-	    double e, n;
-	    char east[50], north[50];
-	    char text[1024];
-	    if (sscanf(data, "%s %s %[^\n]", east, north, text) == 3
-		&& (scan_easting(east, &e) && scan_northing(north, &n)))
-		read_text(east, north, text);
-	    else {
-		gobble_input();
-		error(key, data, "illegal text request");
-	    continue;
-	if (KEY("point")) {
-	    double e, n;
-	    if (sscanf(data, "%s %s", east, north) == 2
-		read_point(e, n);
-	    else {
-		gobble_input();
-		error(key, data, "illegal point request");
-	    continue;
-	if (KEY("eps")) {
-	    double e, n;
-		read_eps(e, n);
-	    else {
-		gobble_input();
-		error(key, data, "illegal eps request");
-	    continue;
-	if (KEY("line")) {
-	    char east1[50], north1[50];
-	    char east2[50], north2[50];
-	    double e1, n1, e2, n2;
-	    if (sscanf(data, "%s %s %s %s", east1, north1, east2, north2) == 4
-		&& (scan_easting(east1, &e1) && scan_easting(east2, &e2)
-		    && scan_northing(north1, &n1) &&
-		    scan_northing(north2, &n2)))
-		read_line(e1, n1, e2, n2);
-	    else {
-		gobble_input();
-		error(key, data, "illegal line request");
-	    continue;
-	if (KEY("rectangle")) {
-		read_rectangle(e1, n1, e2, n2);
-	    else {
-		gobble_input();
-		error(key, data, "illegal rectangle request");
-	    continue;
-	if (KEY("comments")) {
-	    switch (sscanf(data, "%s %s", name, mapset)) {
-	    case 1:
-		read_comment(name);
-		break;
-	    case 2:
-		error(key, data, "illegal comments request");
-		break;
-	    default:
-		read_comment("");
-		break;
-	    continue;
-	if (KEY("scale")) {
-	    if (!can_reset_scale)
-		continue;
-	    if (check_scale(data))
-		strcpy(PS.scaletext, data);
-	    else {
-		error(key, data, "illegal scale request");
-	    continue;
-	if (KEY("labels")) {
-	    if (scan_gis("paint/labels", "label", key, data, name, mapset, 1))
-		read_labels(name, mapset);
-	    continue;
-	if (KEY("header")) {
-	    read_header();
-	    PS.do_header = 1;
-	    continue;
-	if (KEY("mapinfo")) {
-	    read_info();
-	    do_mapinfo = 1;
-	    continue;
-	if (KEY("vlegend")) {
-	    read_vlegend();
-	    do_vlegend = 1;
-	    continue;
-	if (KEY("outline")) {
-		gobble_input();
-	    else
-		read_outline();
-	    continue;
-	if (KEY("cell") || KEY("rast") || KEY("raster")) {
-	    if (scan_gis("cell", "raster", key, data, name, mapset, 0))
-		read_cell(name, mapset);
-	    continue;
-	if (KEY("greyrast") || KEY("grayrast")) {
-	    PS.grey = 1;
-	    continue;
-	if (KEY("group")) {
-	    G_strip(data);
-	    if (I_find_group(data)) {
-		grp.group_name = G_store(data);
-		grp.do_group = 1;
-		read_group();
-	    else
-		error(key, data, "group not found");
-	    continue;
-	if (KEY("rgb")) {
-	    G_strip(data);
-	    grp.do_group = 1;
-	    read_rgb(key, data);
-	    continue;
-	if (KEY("vpoints")) {
-	    if (scan_gis("vector", "vector", key, data, name, mapset, 1))
-		read_vpoints(name, mapset);
-	    continue;
-	if (KEY("vlines")) {
-		read_vlines(name, mapset);
-	    continue;
-	if (KEY("vareas")) {
-		read_vareas(name, mapset);
-	    continue;
-	if (KEY("window") || KEY("region")) {
-	    if (scan_gis("windows", "region definition", key, data, name,
-			 mapset, 1))
-		read_wind(name, mapset);
-	    continue;
-	if (KEY("grid")) {
-	    PS.grid = -1;
-	    PS.grid_numbers = 0;
-	    sscanf(data, "%d", &PS.grid);
-	    if (PS.grid < 0) {
-		PS.grid = 0;
-		error(key, data, "illegal grid spacing");
-		gobble_input();
-	    else
-		getgrid();
-	    continue;
-	if (KEY("geogrid")) {
-	    if (G_projection() == PROJECTION_XY) {
-		error(key, data,
-		      "geogrid is not available for this projection");
-		gobble_input();
-	    /*          if (G_projection() == PROJECTION_LL)
-	       G_message(_("geogrid referenced to [???] ellipsoid"));  */
-	    PS.geogrid = -1.;
-	    PS.geogrid_numbers = 0;
-	    sscanf(data, "%d %s", &PS.geogrid, PS.geogridunit);
-	    if (PS.geogrid < 0) {
-		PS.geogrid = 0;
-		error(key, data, "illegal geo-grid spacing");
-		gobble_input();
-	    else
-		getgeogrid();
-	    continue;
-	if (KEY("psfile")) {
-	    if (PS.num_psfiles >= MAX_PSFILES)
-		continue;
-	    G_strip(data);
-	    PS.psfiles[PS.num_psfiles] = G_store(data);
-	    PS.num_psfiles++;
-	    continue;
-	if (KEY("maskcolor")) {
-	    int ret, r, g, b;
-	    ret = G_str_to_color(data, &r, &g, &b);
-	    if (ret == 1) {
-		PS.mask_r = r / 255.0;
-		PS.mask_g = g / 255.0;
-		PS.mask_b = b / 255.0;
-		PS.mask_color = 1;
-		continue;
-	    else if (ret == 2) {	/* none */
-		continue;
-	    else {
-		error(key, data, "illegal color request");
-	if (*key)
-	    error(key, "", "illegal request");
+    read_from_keyboard(inputfd, &PS, copies_set, ps_copies, can_reset_scale,
+		       &sb, &do_mapinfo, &do_vlegend, &grp);
     /* reset map location base on 'paper' on 'location' */
     reset_map_location();
     if (bflag->answer) {
 	map_setup();
 	fprintf(stdout, "bbox=%.3f,%.3f,%.3f,%.3f\n", PS.map_left / 72.0,
@@ -738,8 +249,8 @@
     ps_mask_file = G_tempfile();
     ps_map();
-    G_message(_("PostScript file [%s] successfully written."),
-	      output_file->answer);
+    G_done_msg(_("PostScript file '%s' successfully written."),
+	       output_file->answer);
     /* cleanup the tempfiles */
     unlink(ps_mask_file);
Modified: grass/trunk/ps/ps.map/map_info.c
--- grass/trunk/ps/ps.map/map_info.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/map_info.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -3,7 +3,6 @@
  ** Author: Paul W. Carlson     April 1992
 #include "map_info.h"
Modified: grass/trunk/ps/ps.map/map_setup.c
--- grass/trunk/ps/ps.map/map_setup.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/map_setup.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -5,8 +5,6 @@
 #include <grass/gis.h>
-#include "group.h"
@@ -85,7 +83,7 @@
 		PS.map_pix_wide);
-    G_message(_("Scale set to %s."), PS.scaletext);
+    G_message(_("Scale set to %s"), PS.scaletext);
     /* compute map edges */
     PS.map_left = 72.0 * PS.map_x_orig;
@@ -106,8 +104,9 @@
     /* save original graphics state */
-    fprintf(PS.fp, "gsave ");
+    if (PS.fp)
+	fprintf(PS.fp, "gsave ");
     /* compute conversion factor from meters to PostScript window coordinates */
        G_begin_distance_calculations();
Modified: grass/trunk/ps/ps.map/outl_io.c
--- grass/trunk/ps/ps.map/outl_io.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/outl_io.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -2,7 +2,6 @@
 static int blank_line();
Modified: grass/trunk/ps/ps.map/ps_clrtbl.c
--- grass/trunk/ps/ps.map/ps_clrtbl.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_clrtbl.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -5,7 +5,6 @@
Modified: grass/trunk/ps/ps.map/ps_colors.c
--- grass/trunk/ps/ps.map/ps_colors.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_colors.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -5,7 +5,6 @@
 #include <stdio.h>
 #include <string.h>
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -7,7 +7,6 @@
Modified: grass/trunk/ps/ps.map/ps_map.c
--- grass/trunk/ps/ps.map/ps_map.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_map.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -7,9 +7,7 @@
 #include <stdio.h>
 #include <unistd.h>
 #include "vector.h"
-#include "group.h"
 #include "border.h"
Modified: grass/trunk/ps/ps.map/ps_outline.c
--- grass/trunk/ps/ps.map/ps_outline.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_outline.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -9,7 +9,6 @@
 static int k, col, row, top, bottom;
Modified: grass/trunk/ps/ps.map/ps_raster.c
--- grass/trunk/ps/ps.map/ps_raster.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_raster.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -14,8 +14,6 @@
-#include "group.h"
 static FILE *ps_mask_fp;
Modified: grass/trunk/ps/ps.map/ps_vareas.c
--- grass/trunk/ps/ps.map/ps_vareas.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_vareas.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -12,7 +12,6 @@
 #include <grass/dbmi.h>
 #include "vector.h"
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/ps_vlegend.c
--- grass/trunk/ps/ps.map/ps_vlegend.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_vlegend.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include "vector.h"
 int PS_vlegend(void)
Modified: grass/trunk/ps/ps.map/ps_vlines.c
--- grass/trunk/ps/ps.map/ps_vlines.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_vlines.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -12,7 +12,6 @@
 #include <grass/vector.h>
 #include "clr.h"
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/ps_vpoints.c
--- grass/trunk/ps/ps.map/ps_vpoints.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/ps_vpoints.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -12,7 +12,6 @@
 #include "clr.h"
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_border.c
--- grass/trunk/ps/ps.map/r_border.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_border.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -13,7 +13,6 @@
 #include <grass/colors.h>
 #include "border.h"
Modified: grass/trunk/ps/ps.map/r_cell.c
--- grass/trunk/ps/ps.map/r_cell.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_cell.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include <string.h>
 int read_cell(char *name, char *mapset)
Modified: grass/trunk/ps/ps.map/r_colortable.c
--- grass/trunk/ps/ps.map/r_colortable.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_colortable.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -9,7 +9,6 @@
 #include "clr.h"
Modified: grass/trunk/ps/ps.map/r_group.c
--- grass/trunk/ps/ps.map/r_group.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_group.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -7,8 +7,6 @@
-#include "group.h"
 int read_group(void)
Modified: grass/trunk/ps/ps.map/r_header.c
--- grass/trunk/ps/ps.map/r_header.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_header.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "header.h"
Modified: grass/trunk/ps/ps.map/r_info.c
--- grass/trunk/ps/ps.map/r_info.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_info.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/r_paper.c
--- grass/trunk/ps/ps.map/r_paper.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_paper.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include <stdlib.h>
 #include <string.h>
Modified: grass/trunk/ps/ps.map/r_plt.c
--- grass/trunk/ps/ps.map/r_plt.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_plt.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -1,7 +1,6 @@
 #include <string.h>
 #define KEY(x)(strcmp(key,x)==0)
Modified: grass/trunk/ps/ps.map/r_rgb.c
--- grass/trunk/ps/ps.map/r_rgb.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_rgb.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,8 +6,6 @@
 #include <string.h>
-#include "group.h"
 int read_rgb(char *key, char *data)
Modified: grass/trunk/ps/ps.map/r_text.c
--- grass/trunk/ps/ps.map/r_text.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_text.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -10,7 +10,6 @@
 #include "clr.h"
 #include "labels.h"
 #define EQ(x,y) (strcmp(x,y)==0)
Modified: grass/trunk/ps/ps.map/r_vareas.c
--- grass/trunk/ps/ps.map/r_vareas.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_vareas.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -14,7 +14,6 @@
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_vlegend.c
--- grass/trunk/ps/ps.map/r_vlegend.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_vlegend.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include <stdlib.h>
 #include <string.h>
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_vlines.c
--- grass/trunk/ps/ps.map/r_vlines.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_vlines.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -12,7 +12,6 @@
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_vpoints.c
--- grass/trunk/ps/ps.map/r_vpoints.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_vpoints.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -15,7 +15,6 @@
 #include "vector.h"
Modified: grass/trunk/ps/ps.map/r_wind.c
--- grass/trunk/ps/ps.map/r_wind.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/r_wind.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -3,7 +3,6 @@
 #include <string.h>
Added: grass/trunk/ps/ps.map/read_key.c
--- grass/trunk/ps/ps.map/read_key.c	                        (rev 0)
+++ grass/trunk/ps/ps.map/read_key.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -0,0 +1,464 @@
+#include <string.h>
+#include <grass/colors.h>
+#include <grass/imagery.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+#define KEY(x) (strcmp(key,x)==0)
+static char *help[] = {
+    "rast       rastermap             setcolor   val_range(s) color",
+    "vpoints    vector points map     scalebar   [f|s]",
+    "vlines     vector lines map      paper      [a4|a3|us-letter|...]",
+    "vareas     vector areas map      maploc     x y [width height]",
+    "labels     labelfile             text       east north text",
+    "region     regionfile            line       east north east north",
+    "grid       spacing               point      east north",
+    "geogrid    spacing               header",
+    "outline                          mapinfo",
+    "colortable [y|n]                 vlegend",
+    "comments   [unix-file]           psfile     PostScript include file",
+    "read       unix-file             eps        Encapsulated PostScript file",
+    "rectangle  east north east north",
+    "scale      1:#|# inches|# panels|1 inch = # miles",
+    "border     [y|n]",
+void read_from_keyboard(FILE *inputfd, struct PS_data *PS,
+			int copies_set, int ps_copies, int can_reset_scale,
+			struct scalebar *sb, int *do_mapinfo, int *do_vlegend,
+			struct PS_group *grp)
+    int i;
+    int iflag;
+    char name[GNAME_MAX], mapset[GMAPSET_MAX];
+    char buf[1024];
+    iflag = 0;
+    while (1) {
+	char *key;
+	char *data;
+	if (!input(1, buf, help)) {
+	    if (!iflag) {
+		if (G_getl2(buf, 12, inputfd))
+		    G_warning(_("Data exists after final 'end' instruction!"));
+		break;
+	    iflag = 0;
+	    continue;
+	if (!key_data(buf, &key, &data))
+	    continue;
+	if (KEY("read")) {
+	    if (inputfd != stdin)
+		fclose(inputfd);
+	    if (sscanf(data, "%s", name) != 1) {
+		error(key, data, "no file specified");
+		inputfd = stdin;
+	    else if ((inputfd = fopen(name, "r")) == NULL) {
+		error(key, data, "unable to open");
+		inputfd = stdin;
+	    else
+		iflag = 1;
+	    continue;
+	if (KEY("paper")) {
+	    if (strlen(data) > 0) {
+		set_paper(data);
+	    read_paper();
+	    continue;
+	if (KEY("maploc")) {
+	    int n;
+	    double x, y, w, h;
+	    n = sscanf(data, "%lf %lf %lf %lf", &x, &y, &w, &h);
+	    if (n == 2 || n == 4) {
+		PS->map_x_orig = x;
+		PS->map_y_loc = y;
+		if (n == 4) {
+		    PS->map_width = w;
+		    PS->map_height = h;
+	    else {
+		error(key, data, "illegal maploc request");
+		gobble_input();
+	    continue;
+	if (KEY("copies")) {
+	    int n, copies;
+	    if (copies_set)
+		continue;
+	    n = sscanf(data, "%d", &copies);
+	    if (n != 1 || copies < 1 || copies > 20) {
+		ps_copies = 1;
+		error(key, data, "illegal copies request");
+	    ps_copies = copies;
+	    continue;
+	if (KEY("setcolor")) {
+	    float R, G, B;
+	    int r, g, b;
+	    int color;
+	    int count;
+	    DCELL *val_list;
+	    DCELL dmin, dmax;
+	    char colorbuf[100];
+	    char catsbuf[100];
+	    if (PS->cell_fd < 0) {
+		error(key, data, "no raster map selected yet");
+		continue;
+	    if (sscanf(data, "%s %[^\n]", catsbuf, colorbuf) == 2) {
+		color = get_color_number(colorbuf);
+		if (color < 0) {
+		    error(key, data, "illegal color");
+		    continue;
+		get_color_rgb(color, &R, &G, &B);
+		r = 255.0 * R;
+		g = 255.0 * G;
+		b = 255.0 * B;
+		if (strncmp(catsbuf, "null", 4) == 0) {
+		    Rast_set_null_value_color(r, g, b, &(PS->colors));
+		    continue;
+		if (strncmp(catsbuf, "default", 7) == 0) {
+		    Rast_set_default_color(r, g, b, &(PS->colors));
+		    continue;
+		if ((count = parse_val_list(catsbuf, &val_list)) < 0) {
+		    error(key, data, "illegal value list");
+		    continue;
+		for (i = 0; i < count; i += 2) {
+		    dmin = val_list[i];
+		    dmax = val_list[i + 1];
+		    Rast_add_d_color_rule(&dmin, r, g, b, &dmax, r, g, b,
+					  &(PS->colors));
+		G_free(val_list);
+	    continue;
+	if (KEY("colortable")) {
+	    PS->do_colortable = 0;
+	       else
+	    PS->do_colortable = yesno(key, data);
+	    if (PS->do_colortable)
+		read_colortable();
+	    continue;
+	if (KEY("border")) {
+	    PS->do_border = yesno(key, data);
+	    if (PS->do_border)
+		read_border();
+	    continue;
+	if (KEY("scalebar")) {
+	    if (G_projection() == PROJECTION_LL) {
+		error(key, data,
+		      "scalebar is not appropriate for this projection");
+		gobble_input();
+	    PS->do_scalebar = 1;
+	    if (sscanf(data, "%s", sb->type) != 1)
+		strcpy(sb->type, "f");	/* default to fancy scalebar */
+	    read_scalebar();
+	    if (sb->length <= 0.) {
+		error(key, data, "Bad scalebar length");
+		gobble_input();
+	    continue;
+	if (KEY("text")) {
+	    double e, n;
+	    char east[50], north[50];
+	    char text[1024];
+	    if (sscanf(data, "%s %s %[^\n]", east, north, text) == 3
+		&& (scan_easting(east, &e) && scan_northing(north, &n)))
+		read_text(east, north, text);
+	    else {
+		gobble_input();
+		error(key, data, "illegal text request");
+	    continue;
+	if (KEY("point")) {
+	    double e, n;
+	    if (sscanf(data, "%s %s", east, north) == 2
+		read_point(e, n);
+	    else {
+		gobble_input();
+		error(key, data, "illegal point request");
+	    continue;
+	if (KEY("eps")) {
+	    double e, n;
+		read_eps(e, n);
+	    else {
+		gobble_input();
+		error(key, data, "illegal eps request");
+	    continue;
+	if (KEY("line")) {
+	    char east1[50], north1[50];
+	    char east2[50], north2[50];
+	    double e1, n1, e2, n2;
+	    if (sscanf(data, "%s %s %s %s", east1, north1, east2, north2) == 4
+		&& (scan_easting(east1, &e1) && scan_easting(east2, &e2)
+		    && scan_northing(north1, &n1) &&
+		    scan_northing(north2, &n2)))
+		read_line(e1, n1, e2, n2);
+	    else {
+		gobble_input();
+		error(key, data, "illegal line request");
+	    continue;
+	if (KEY("rectangle")) {
+		read_rectangle(e1, n1, e2, n2);
+	    else {
+		gobble_input();
+		error(key, data, "illegal rectangle request");
+	    continue;
+	if (KEY("comments")) {
+	    switch (sscanf(data, "%s %s", name, mapset)) {
+	    case 1:
+		read_comment(name);
+		break;
+	    case 2:
+		error(key, data, "illegal comments request");
+		break;
+	    default:
+		read_comment("");
+		break;
+	    continue;
+	if (KEY("scale")) {
+	    if (!can_reset_scale)
+		continue;
+	    if (check_scale(data))
+		strcpy(PS->scaletext, data);
+	    else {
+		PS->scaletext[0] = 0;
+		error(key, data, "illegal scale request");
+	    continue;
+	if (KEY("labels")) {
+	    if (scan_gis("paint/labels", "label", key, data, name, mapset, 1))
+		read_labels(name, mapset);
+	    continue;
+	if (KEY("header")) {
+	    read_header();
+	    PS->do_header = 1;
+	    continue;
+	if (KEY("mapinfo")) {
+	    read_info();
+	    *do_mapinfo = 1;
+	    continue;
+	if (KEY("vlegend")) {
+	    read_vlegend();
+	    *do_vlegend = 1;
+	    continue;
+	if (KEY("outline")) {
+		gobble_input();
+	    else
+		read_outline();
+	    continue;
+	if (KEY("cell") || KEY("rast") || KEY("raster")) {
+	    if (scan_gis("cell", "raster", key, data, name, mapset, 0))
+		read_cell(name, mapset);
+	    continue;
+	if (KEY("greyrast") || KEY("grayrast")) {
+	    PS->grey = 1;
+	    continue;
+	if (KEY("group")) {
+	    G_strip(data);
+	    if (I_find_group(data)) {
+		grp->group_name = G_store(data);
+		grp->do_group = 1;
+		read_group();
+	    else
+		error(key, data, "group not found");
+	    continue;
+	if (KEY("rgb")) {
+	    G_strip(data);
+	    read_rgb(key, data);
+	    continue;
+	if (KEY("vpoints")) {
+	    if (scan_gis("vector", "vector", key, data, name, mapset, 1))
+		read_vpoints(name, mapset);
+	    continue;
+	if (KEY("vlines")) {
+		read_vlines(name, mapset);
+	    continue;
+	if (KEY("vareas")) {
+		read_vareas(name, mapset);
+	    continue;
+	if (KEY("window") || KEY("region")) {
+	    if (scan_gis("windows", "region definition", key, data, name,
+			 mapset, 1))
+		read_wind(name, mapset);
+	    continue;
+	if (KEY("grid")) {
+	    PS->grid = -1;
+	    PS->grid_numbers = 0;
+	    sscanf(data, "%d", &(PS->grid));
+	    if (PS->grid < 0) {
+		PS->grid = 0;
+		error(key, data, "illegal grid spacing");
+		gobble_input();
+	    else
+		getgrid();
+	    continue;
+	if (KEY("geogrid")) {
+	    if (G_projection() == PROJECTION_XY) {
+		error(key, data,
+		      "geogrid is not available for this projection");
+		gobble_input();
+	    /*          if (G_projection() == PROJECTION_LL)
+	       G_message(_("geogrid referenced to [???] ellipsoid"));  */
+	    PS->geogrid = -1.;
+	    PS->geogrid_numbers = 0;
+	    sscanf(data, "%d %s", &(PS->geogrid), PS->geogridunit);
+	    if (PS->geogrid < 0) {
+		PS->geogrid = 0;
+		error(key, data, "illegal geo-grid spacing");
+		gobble_input();
+	    else
+		getgeogrid();
+	    continue;
+	if (KEY("psfile")) {
+	    if (PS->num_psfiles >= MAX_PSFILES)
+		continue;
+	    G_strip(data);
+	    PS->psfiles[PS->num_psfiles] = G_store(data);
+	    PS->num_psfiles++;
+	    continue;
+	if (KEY("maskcolor")) {
+	    int ret, r, g, b;
+	    ret = G_str_to_color(data, &r, &g, &b);
+	    if (ret == 1) {
+		PS->mask_r = r / 255.0;
+		PS->mask_g = g / 255.0;
+		PS->mask_b = b / 255.0;
+		PS->mask_color = 1;
+		continue;
+	    else if (ret == 2) {	/* none */
+		continue;
+	    else {
+		error(key, data, "illegal color request");
+	if (*key)
+	    error(key, "", "illegal request");
Property changes on: grass/trunk/ps/ps.map/read_key.c
   + text/x-csrc
Added: svn:eol-style
   + native
Modified: grass/trunk/ps/ps.map/scale.c
--- grass/trunk/ps/ps.map/scale.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/scale.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -10,7 +10,6 @@
 #define PWIDTH	(PS.page_width-PS.left_marg-PS.right_marg)
Modified: grass/trunk/ps/ps.map/symbol.c
--- grass/trunk/ps/ps.map/symbol.c	2011-03-05 18:38:16 UTC (rev 45579)
+++ grass/trunk/ps/ps.map/symbol.c	2011-03-05 22:36:52 UTC (rev 45580)
@@ -6,7 +6,6 @@
 #include "clr.h"
 #include "vector.h"
